iclowl Posted May 21, 2015 Posted May 21, 2015 Hello I did a clean install of Hyperspin 1.3.3 and the latest rLauncher is set up using tutorials on Youtube. Everything is working except I am not able to launch a MAME rom from Hyperspin. I am able to load MAME in rLauncher and start roms from there. But if I try to load a game in Hyperspin, I get an error saying No Default_Emulator found in C:\HYPERSPIN\RocketLauncher\Settings\<ROM NAME>\Emulators.ini I guess it has something to do with the syntax for loading the rom? Here is the log output: [code] 21:10:51:371 | RL | INFO | +N/A | Main - RocketLauncher v1.0.0.0 (www.rlauncher.com) 21:10:51:820 | RL | INFO | +452 | Main - System Specs: RocketLauncher Dir: C:\HYPERSPIN\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Professional SKU: Professional Total Memory: 3969.88 MB Free Memory: 2325.47 MB Used Memory: 1644.414 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 2 GPU 1 Name: Intel(R) HD Graphics GPU 1 RAM: 1792.94 MB GPU 1 Driver Version: 10.18.10.3621 Sound 1 Device: Realtek High Definition Audio Sound 1 Status: Enabled Sound 2 Device: Intel(R) Display Audio Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1200 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 21:10:51:820 | RL | INFO | +0 | CheckFile - Checking if C:\HYPERSPIN\RocketLauncher\RocketLauncher.exe exists 21:10:51:826 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1200 21:10:51:826 | RL | INFO | +0 | CheckFile - Checking if C:\HYPERSPIN\RocketLauncher\Plugins\HyperSpin.plugin exists 21:10:51:827 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 21:10:51:827 | RL | INFO | +0 | Main - RocketLauncher received "ssf2" and "MAM" 21:10:51:827 | RL | INFO | +0 | Main - Did not find a "C:\HYPERSPIN\RocketLauncher\Settings\ssf2\Game Options.ini" file, skipping any game-specific options. 21:10:51:828 | RL | WARNING | +0 | RIniReadCheck - Created missing RocketLauncher ini key: "Default_Emulator" in section: "Roms" in "C:\HYPERSPIN\RocketLauncher\Settings\ssf2\Emulators.ini" 21:10:59:360 | RL | ERROR | +7535 | No Default_Emulator found in "C:\HYPERSPIN\RocketLauncher\Settings\ssf2\Emulators.ini" Please set one so RocketLauncher knows what module to use. 21:10:59:360 | RL | INFO | +0 | ExitScript - Started 21:10:59:643 | RL | INFO | +281 | SystemCursor - Restoring mouse cursor 21:10:59:663 | RL | INFO | +16 | ExitScript - Ended [/code] Please help a newbie :-)
gigapig Posted May 21, 2015 Posted May 21, 2015 We had the same problem yesterday. Why RocketLauncher is looking for the emulator "ssf2" is a mystery. Unless you provide detailed info on how you set it all up I think you'll need to start again. Did you set up Mame in RocketlauncherUI? Did you use the transition tool?
iclowl Posted May 21, 2015 Author Posted May 21, 2015 I set up MAME in RocketLauncherUI. Sorry if this is a dumb question but do I need to use the transition tool for a fresh install of HS1.3.3 and rLauncher 1.0 ?
gigapig Posted May 21, 2015 Posted May 21, 2015 Because HyperSpin 1.3 is looking for HyperLaunch then I think you need to use section 3B of the guide. Back up first. http://www.rlauncher.com/wiki/index.php?title=Transition_From_HyperLaunch3 Maybe others have had the same issues? http://www.rlauncher.com/forum/showthread.php?948-RocketLauncher-v1-0-Release!
iclowl Posted May 21, 2015 Author Posted May 21, 2015 I ran the transition tool. Now I am able to launch the rom, it starts to load but then just exits back to the HS MAME menu. Log: http://pastebin.com/ECY87Edv Command line preview in HyperHQ: "C:\HYPERSPIN\RocketLauncher\RocketLauncher.exe" "RomName." "MAME" -f "C:\HYPERSPIN\HyperSpin.exe" -p "HyperSpin"
joepone Posted June 2, 2015 Posted June 2, 2015 Hi Guys....thanks for all of this info on here. I have been running into the same problem. I just stumbled upon Hyperspin/Hyperlaunch recently and installed everything by using some tutorials that I'd found online. Everything seemed to be working and linked correctly, however when I tried launching a game (using MAME) from Hyperspin, nothing at all would happen. I wasn't getting a message or anything. I could scroll through and see the games that I'd loaded but that was it. I saw a post on here last night regarding the transition tool and ignored it because I'd never had Hyperlaunch, I've only had Rocketlauncher. I deleted both softwares from my PC last night before I saw the post anyway. I'm getting ready to do a fresh install right now but just want to see if that might be my issue if I run into it again? Basically, should the transition tool always be used, regardless if you've had Hyperlaunch or not? Thanks in advance for the feedback.
dbdecker Posted June 6, 2015 Posted June 6, 2015 Same issue, guys over at RL suggest all my settings are in fact correct. Also HS is not even opening RL, no logs are created in troubleshooting. ive done 2 clean installs, transitioned HS1.3 only. Hyperspin just wont open a rom. The PATH when in CMD works fine. All I can assume is that the parameters in HS HQ are not being passed correctly: "MAME" -f "C:\HyperSpin\HyperSpin.exe" -p "HyperSpin" com line preview: "C:\RocketLauncher\RocketLauncher.exe" "RomName." "MAME" -f "C:\HyperSpin\HyperSpin.exe" -p "HyperSpin"
dbdecker Posted June 6, 2015 Posted June 6, 2015 Hi Guys....thanks for all of this info on here. I have been running into the same problem. I just stumbled upon Hyperspin/Hyperlaunch recently and installed everything by using some tutorials that I'd found online. Everything seemed to be working and linked correctly, however when I tried launching a game (using MAME) from Hyperspin, nothing at all would happen. I wasn't getting a message or anything. I could scroll through and see the games that I'd loaded but that was it. I saw a post on here last night regarding the transition tool and ignored it because I'd never had Hyperlaunch, I've only had Rocketlauncher. I deleted both softwares from my PC last night before I saw the post anyway. I'm getting ready to do a fresh install right now but just want to see if that might be my issue if I run into it again? Basically, should the transition tool always be used, regardless if you've had Hyperlaunch or not? Thanks in advance for the feedback. Did you have any luck?
baddeolv Posted June 6, 2015 Posted June 6, 2015 Open up, HyperHQ (the green logo) make sure HyperLaunch is ticked under wheel settings Sent from my iPhone using Tapatalk Instagram : baddeolv Facebook : Brian Addeo
dbdecker Posted June 7, 2015 Posted June 7, 2015 rocketlaunch team are saying not to do that http://www.rlauncher.com/wiki/index.php?title=Transition_From_HyperLaunch3
baddeolv Posted June 8, 2015 Posted June 8, 2015 Well that fix worked for me on a few systems instantly. Sent from my iPhone using Tapatalk Instagram : baddeolv Facebook : Brian Addeo
dbdecker Posted June 8, 2015 Posted June 8, 2015 Shame. I can get MAME to run that way, but no other consoles I might need to find a copy of Hyperlaunch and wait out the beta to HS1.4
bleasby Posted June 9, 2015 Posted June 9, 2015 make sure you follow everything that is written here: http://www.rlauncher.com/wiki/index.php?title=HyperSpin you most probably have wrong settings defined on HyperHQ. When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
dbdecker Posted June 9, 2015 Posted June 9, 2015 I've had Rocketlauncher dev tell me that its correct, followed that guide http://www.rlauncher.com/forum/showthread.php?1213-HyperSpin-133-and-RLauncher-1-setup-assistance-request&p=11835#post11835 [exe info] path=C:\RocketLauncher\ rompath= userompath=true exe=RocketLauncher.exe romextension= parameters="MAME" -f "C:\Hyperspin\HyperSpin.exe" -p "HyperSpin" searchsubfolders=false pcgame=false winstate=NORMAL hyperlaunch=false [filters] parents_only=false themes_only=false wheels_only=false [themes] use_parent_vids=true use_parent_themes=false animate_out_default=false reload_backgrounds=false [wheel] alpha=.15 small_alpha=1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=C:\HyperSpin\Media\MAME\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=false remove_info_text=false use_last_game=true last_game=1942w random_game=false start_on_favorites=false [Special Art A] default=false active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [Special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [Special Art C] active=true x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640
demonseed Posted June 13, 2015 Posted June 13, 2015 I am suddenly having issues too.. Games in RL and HS loaded fine before.. now nothing...
dbdecker Posted June 13, 2015 Posted June 13, 2015 I got mine working thanks to bleasby Run HS as administrator
wrufai Posted July 7, 2015 Posted July 7, 2015 I got mine working thanks to bleasby Run HS as administrator So after running HS as an administrator, you were able to select a game? I'm having the same issue with HS 1.4 beta and will try this out when I get home tonight.
