demonseed Posted May 28, 2015 Posted May 28, 2015 Hey Ok so I have 1.3 stable and Rocketlauncher. I set up Atari 2600 in Stella and retro arch.. all works well outside of HS. In HS I run a game I get "Can not find hyperlaunch.exe." Now when I check HyperHQ it has execution set to HYPERLAUNCH with rom dir set,. and command says Hyperlaunch.exe "Atari 2600" "ROMNAME" Obviously it is looking for hyperlaunch.exe which was replaced when I updated? what do I do to correct this and what should it be pointed to>? Thanks In advance! Jim
planetoide Posted May 28, 2015 Posted May 28, 2015 Check this: http://www.hyperspin-fe.com/topic/2187-how-to-install-hyperspin/
32assassin Posted May 28, 2015 Posted May 28, 2015 Hyperespin 1.3 Only works with Hyperlaunch. You need to run a transition tool in order to make it compatible with rocketlaunher. (Start at step 3 if you already have Rocketlauncher installed) http://www.rlauncher.com/wiki/index.php?title=Transition_From_HyperLaunch3 you can avoid all this by simply updating Hyperspin to version 1.4 (beta)
Jumpstile Posted May 28, 2015 Posted May 28, 2015 He can't update to 1.4 beta. He's not a platinum member. - J* How to rebuild your MAME ROM set using CLRMAMEPRO - Walkthrough HERE!
demonseed Posted May 28, 2015 Author Posted May 28, 2015 Sorry guys I did do the transition. And I am not a member yet. but will be. I was just waiting to next week (pay day). lLso wanted to confirm that if I go $50 do I still get 25 percent off emumovies? (reason I ask is the link at the 50$ donation says "click here" but it does not work. I looked into the step 3 and I did all that.. All my emulators that I had installed when I did the tranisition work and have the correct link to rocketlauncher. When I add new ones, it is not updating it... do I still do step 3?? or something different?
demonseed Posted May 29, 2015 Author Posted May 29, 2015 **Solved---did below and then had to remove rom folder in HQ and extension!!! thanks so much Hey So I went into the Atari 2600 file in hyperspin (I believe its the ini) and I edited manually as follows. It now tries to run but says it could not find a rom with any extension..? I added my HQ the picture on the right is the latest.. it tries to run.. but still fails. some error about making sure I have proper retroarch modulr. Mayb I should just update to 1.4 [exe info] path=E:\Rocketlauncher\ rompath=E:\Hyperspin\Emulators\Stella\roms\ userompath=true exe=RocketLauncher.exe romextension=.bin parameters="Atari 2600" -f "E:\HyperSpin\HyperSpin.exe" -p "HyperSpin" searchsubfolders= pcgame=false winstate=NORMAL hyperlaunch=false hyperlaunch_per_game_modules=false hyperlaunch_cpwizard_enabled=false
