AAE and ACTIONMAX.. ESC and NUM LOCK OFF issue
mikeyngo
Hello, I have Hyperspin Project running with my X-arcade tankstick. I'm having issues getting AAE and ACTIONMAX Emulator to ESC. It doesn't. I went into settings and set the ESC to 1 & 2.
Loaded up hyperlaunch works. But cannot exit. Do I need to add something to the AHK? Also with AAE, everytime I manually exit with the keyboard, it turns off my NUM LOCK, freezing my x-arcade. Is there a way I can tell it not to turn off num lock?
THank you
THank you
That numlock crap happens to me too. It sucks
Instagram : baddeolv
Facebook : Brian Addeo
Add this after process, waitclose:
SetNumLockState, Off
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I downloaded the AAE Module and added the SetNumLockState, OFf on AAE.AHK. But it doesn't work. My numlock is still off. Here is my code:
Runwait, %executable% %romName%, %emuPath%, Hide UseErrorLevel
ExitApp
;Required
CloseProcess:
;waitclose:
return
Also, I still cannot exit on both AAE and ACTIONMAX Emulators. My settings.ini is:
Last_System=Atari Lynx
Last_Rom=Batman Returns (USA, Europe)
Exit_Script_Key=~q & ~s
Exit_Emulator_Key=~1 & ~2
Toggle_Cursor_Key=t
MultiGame_Key=NumpadSub
MultiGame_Select_Key=Enter
MultiGame_Exit_Key=Esc
Path_To_Daemontools=
Path_To_CPWizard=
Fade_In_Interrupt_Keys=anykey
Keymapper_Path=
Keymapper_Profiles_Path=D:\Hyperspin\Keymapper Profiles\
Any ideas how I should go about? Thank you all for your help.
If you want on, then simply
....wait for it....
BAM
SetNumLockState, ON
Also you didnt place it where i said. It must be right below process, waitclose, or in your case because you are using your own module, under the runwait line.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Awesome doh. lol. Thanks its exiting with numlock on. Just curious why I cannot EXIT AAE or ACTIONMAX by pressing 1 & 2? Do I need to do something in AHK?
Yes, the module I am using is this one by DJVJ. http://hyperlist.hyperspin-fe.com/index.php?module=browseahk&system=121
Here is the AHK code with the numlock on that DJVJ suggested.
aaeINI := CheckFile(emuPath . "aae.ini")
IniRead, currentFullScreen, %aaeINI%, main, windowed
GUI_ID := FadeInStart()
; Setting Fullscreen setting in ini if it doesn't match what user wants above
If ( Fullscreen != "true" And currentFullScreen = 0 )
IniWrite, 1, %aaeINI%, main, windowed
Else If ( Fullscreen = "true" And currentFullScreen = 1 )
IniWrite, 0, %aaeINI%, main, windowed
7z1 := 7z(romPath, romName, romExtension, 7zExtractDir)
Run, %executable% %romName%, %emuPath%
WinWait, ahk_class AllegroWindow
WinWaitActive, ahk_class AllegroWindow
GUI_ID2 := FadeInExit()
Process, WaitClose, %executable%
7z2 := 7zCleanUp()
GUI_ID4 := FadeOutExit()
WinActivate, Hyperspin
SetNumLockState, ON
ExitApp
CloseProcess:
GUI_ID3 := FadeOutStart()
WinClose, ahk_class AllegroWindow
Return
Any ideas? Any help is appreciated. Thank you
Its the module that I'm using that DJVJ posted up. The only thing I added was the SetNumLockState, On. Both unmodified and modified version doesn't exit at all when 1 & 2 is pressed. Same goes with ACTIONMAX. All the other emulators I worked on worked... I have no clue why...
Try putting something like this inside the CloseProcess label:
Tooltip, Closing
Sleep, 3000
And see if the tooltip shows up when you press those buttons. Or use a message box instead and disable fading so you can see it.
Aren't 1 & 2 the default start buttons in AAE? Did you change them? It might be the case of AAE consuming those key presses and ahk not getting it, personally I wouldn't use such a combo to exit.
Thank you for your reply. You might be right. It the way x-arcade was setup. I'm gonna try to change the button combo to something else, maybe 3 and 4. To see if that works. Thank you
  • 4 months later...
Hello there.
Please help to resolve my problem. I`m using X-arcade dual joystick and when I start (!!!) AAE emulator it switching NumLock off.
If I need to change commands in some files, please note where can I find them. I`m a newcommer and HyperSpin blowing my mind about a week D:
Ups. It was broker ver. of AAE Emulator. Sorry guys.
Now just please tell me where i need to type:
waitclose:
SetNumLockState, On
to turn back NumLock after closing AAE? I do not have any AAE.ahk.
  • 1 year later...
Hey' can u paste ur aae module here? My num lock keeps turning off only in that module. I use hold 1 ans 2 to exit. When I do this right now I see the fade out screen but it freezes there. If I try again and push esc it closes just fine. All my emulators have hold 1 snd 2 to exit. Is there something I can add to the standArd aae module that is out for RocketLauncher
