alain401 Posted June 10, 2015 Posted June 10, 2015 Ok heres the problem. Everything i run mame , it doesnt run on my center monitor (main monitor) its opens to the left monitor (right monitor if disconnect) I been pulling my hair trying to figure out how to get mame to open in the middle monitor. Help? Every other program / emulator opens in the middle. Will post pics later
alain401 Posted June 10, 2015 Author Posted June 10, 2015 Yes i have tried running mame in windowed mode then close/exit in the middle monitor
bleasby Posted June 10, 2015 Posted June 10, 2015 mame has a Screen option. I am sure about that. I don't remenber exactly what is it because it has being a while since I messed up with that but you can change that on its config files. Either that or just make your middle monitor your primary screen. When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
alain401 Posted June 10, 2015 Author Posted June 10, 2015 The middle is set as my primary. Yeah i tried messing with the screen option, didnt work
32assassin Posted June 10, 2015 Posted June 10, 2015 MAME and MESS will not display in your primary monitor it will display in monitor #1 by default. go to your MAME emulator folder, look for the ini folder and open the MAME.ini. look for this # OSD PER-WINDOW VIDEO OPTIONS # screen0 auto change the auto to whatever monitor number you need. example if your center monitor is monitor #2 screen0 \\.\DISPLAY2
