  • 0
What is best program to fix cues
thcdgaf
Question
What program out there to fix inside of cue file to match the filename of multiple files or batch command just need to fix multiple not one by one thanx in advance
Sent from my LGL34C using Tapatalk
5 answers to this question
I second! I've been learning that I've been doing a lot of these things the hard way. What cue files are you working on? Recently I was doing this same thing manually with 3do .img/.iso & cues and then I found out I didn't even need the cue files. Only if it was a .bin file did I need the .cue with it.
I've found that doing it manually has always been the best option. It IS a lot of work, and very time consuming. When building a PS1 set years ago, this was the only option (Re-Dump sets hadn't come along yet). As TravCar said above, there are some cases that you may not even need the .cue file, but in the case of using .bin/.cue, yes, your .cue file will have to match spot on with the .bin file. I haven't tried the program Giga mentioned above, but it's worth a go if it'll make things move along faster for you. If not, manually editing them all in notepad might be your only other option.
