rodzosa Posted July 10, 2015 Posted July 10, 2015 Good day everyone, I really don't know how to apply HyperSpin Startup Script? I hope you do understand my curiosity. Anyone can help me please? thank you very much in advance...
Metalzoic Posted July 10, 2015 Posted July 10, 2015 My guess is that people put it into HyperHQ so it automatically runs as soon as you launch Hyperspin. Or maybe some people put it directly in their Startup folder to launch with windows.
ghutch92 Posted July 10, 2015 Posted July 10, 2015 From the downloads page. To use it Open HyperHQ, Go to Main Settings -> Startup\Exit -> and set the .exe file as your startup program. How to make it work: Run it once, a new file should appear in the folder it is in. It's name will be the same name as this program and will have the extension "ini" Open the ini file. You should see some of the settings described below. [Required] HyperSpin_Folder_Path REQUIRED! is the path to the folder containing hyperspin.exe (Default is .\ which would be the same folder as the startup script. ..\ means one folder up. ..\..\ would mean two folders up). Absolute paths are still accepted. Primary_Color_RRGGBB is the background color of the menus given in a hex rrggbb format. Examples and a color picker can be found here. Secondary_Color_RRGGBB is the background color of the menus given in a hex rrggbb format. Examples and a color picker can be found here. [Controls] Joysticks_Enabled can be true or false. Set this to true to use a joystick or gamepad with hyperspin. May work for controllers other than the 360 controller. Joystick_Delay is the number of milliseconds to wait before repeating for only the hyperspin startup menus Joystick_Deadzone is a number between 0 and 49 representing the size of the axis deadzone for every axis. 0 is the most sensitive. 49 is the least sensitive. Joysticks_MaxNumberOfJoysticks is a number between 1 and 16 that represents how many joysticks you want to use at the same time (using same control layout) to control hyperspin Joystick_Up, Joystick_Down, Joystick_SkipUp, Joystick_SkipDown, Joystick_SkipUpNumber, Joystick_SkipDownNumber, Joystick_HyperSpin, Joystick_Genre, Joystick_Favorites, Joystick_Start and Joystick_Exit do the same thing as their HyperSpin keyboard counterparts. Joystick_Roulette, Joystick_Volume, Joystick_Volume_Close, Joystick_QuickLaunch and Joystick_QuickLaunch_Close joystick controls for roulette, volume bar and quicklaunch bar. Joystick_Info, Joystick_Info_Close, Joystick_Filters and Joystick_Filters_Close are not yet implemented, need to be able to receive Event Dispatcher info, com xml code are needed to get these controls to work. Joystick control options in the settings are separated by a vertical bar delimiter | . The joystick control options available are as follows for axis: JoyX-, JoyX+, JoyY-, JoyY+, JoyZ-, JoyZ+, JoyR-, JoyR+, JoyU-, JoyU+, JoyV- and JoyV+ for dpad/hat switch: JoyPOVN, JoyPOVE, JoyPOVS and JoyPOVW for buttons: Joy1, Joy2, Joy3, Joy4, Joy5, Joy6, Joy7, Joy8, Joy9, Joy10, Joy11, Joy12, Joy13, Joy14, Joy15, Joy16, Joy17, Joy18, Joy19, Joy20, Joy21, Joy22, Joy23, Joy24, Joy25, Joy26, Joy27, Joy28, Joy29, Joy30, Joy31 and Joy32 [startup] Minimize_Background_Windows_Enabled can be true or false. Set this to true to minimize windows when this script starts. Window_Classes_To_Not_Minimize is a comma delimited list of window classes that will not be minimized. To get the window class you can use this tool AU3 Window Spy.zip. [Exit] Restore_Windows_On_Exit can be true or false, if true it will restore all windows minimized by the script, if false the windows will stay minimized when hyperspin exits [startup] & [Exit] Process_Name_To_Close_1 is the name of the process you wish to close. To add more processes to close, just change the 1 to a 2 for the second process, the 2 to a 3 for a third process, etc. Example: Process_Name_To_Close_1=notepad.exe Process_Name_To_Close_2=hyperlaunch.exe Program_To_Run_Target_1 is a document, URL, executable file (.exe, .com, .bat, etc.), shortcut (.lnk), or system verb to launch. If Target is a local file and no path was specified with it, The script's directory will be searched first. If no matching file is found there, the system will search for and launch the file if it is integrated ("known"), e.g. by being contained in one of the PATH folders. To pass parameters, add them immediately after the program or document name. If a parameter contains spaces, it is safest to enclose it in double quotes (even though it may work without them in some cases). Paths relative to the startup script are allowed.Program_To_Run_Working_Dir_1 is the working directory for the launched item. Do not enclose the name in double quotes even if it contains spaces. If omitted, the script's own working directory will be used. Relative Paths are not allowed. Program_To_Run_MaxMinHide_1 is if omitted, Target will be launched normally. Alternatively, it can contain one or more of these words: Max :launch maximized Min :launch minimized Hide : launch hidden (cannot be used in combination with either of the above) Note: Some applications (e.g. Calc.exe) do not obey the requested startup state and thus Max/Min/Hide will have no effect. To add more programs to open, just change the 1 to a 2 for the second program, the 2 to a 3 for a third program, etc. Example: Program_To_Run_Target_1=C:\Utilities\Xpadder\xpadder.exe "C:\HyperLaunch\Profiles\xpadder\HyperSpin\p1.xpadderprofile" /M Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= Program_To_Run_Target_2=HyperSearch.exe Program_To_Run_Working_Dir_2=C:\HyperSpin\HyperSearch Program_To_Run_MaxMinHide_2= Program_To_Run_Target_3=explorer.exe Program_To_Run_Working_Dir_3= Program_To_Run_MaxMinHide_3= [Roulette]Roulette_Key is the compatible autohotkey key name for the key or two key combo used to trigger the roulette event. Modifier Symbols are accepted. There is already built in support for the roulette function for joysticks. Roulette_Min_MilliSeconds is the minimum amount of milliseconds to spin the HyperSpin menu wheel Roulette_Min_MilliSeconds is the maximum amount of milliseconds to spin the HyperSpin menu wheel [Volume_Menu] Volume_Menu_Key is the compatible autohotkey key name for the key or two key combo used to open/close the volume bar. Modifier Symbols are accepted. There is already built in support for the volume menu for joysticks. Volume_Bar_Offset_From_Bottom is the distance in pixels from the bottom of the screen to the bottom of the volume bar. For reference the windows 7 taskbar is typically 40 pixels. [QuickLaunch] QuickLaunch_Key is the compatible autohotkey key name for the key or two key combo used to open/close the quicklaunch menu. Modifier Symbols are accepted. There is already built in support for the quicklaunch menu for joysticks. QuickLaunch_Enabled can be true or false. Set to false to disable the use of the quicklaunch menu, useful to disable if you don't want to ruin the arcade experience, useful to enable to help troubleshoot and make changes to your setup, amongst other things. QuickLaunch_Left_Offset is the distance in pixels from the left of the screen to the left edge of the logos QuickLaunch_Top_Offset is the distance in pixels from the top of the screen to the top edge of the first selectable logo QuickLaunch_Bottom_Offset is the distance in pixels from the bottom of the screen to the bottom edge of the last selectable logo Item_1_Path is a document file, executable file (.exe, .com, .bat, etc.), or shortcut file (.lnk), to launch. If Target is a local file and no path was specified with it, The script's directory will be searched first. If no matching file is found there, it will not be added to the menu as an option. Paths relative to the startup script are allowed. Item_1_Parameters is the parameters to pass to the application. If a parameter contains spaces, it is safest to enclose it in double quotes (even though it may work without them in some cases). Item_1_LogoPath is a path to an image file to be used as the logo for the application in the quicklaunch menu. If this value does not exist or is empty, this script will attempt to extract and use the application's icon. Item_1_Ignore_Process_Close can be true or false. does not reactivate hyperspin or the quicklaunch menu when the application specified is closed. Useful for for applications that use a launcher. To add more items to the quicklaunch menu, just change the 1 to a 2 for the second item, the 2 to a 3 for a third item, etc. Example: Item_1_Path=C:\HyperSpin\HyperSpin.exe Item_1_Parameters=Item_1_LogoPath=Item_1_Ignore_Process_Close=false Item_2_Path=C:\HyperSpin\HyperHQ.exe Item_2_Parameters=Item_2_LogoPath=Item_2_Ignore_Process_Close=false Item_3_Path=C:\HyperSpin\HyperSync Cloud\HyperSync Cloud.exe Item_3_Parameters=-true Item_3_LogoPath=Item_3_Ignore_Process_Close=false Item_4_Path=C:\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe Item_4_Parameters=Item_4_LogoPath=C:\HyperLaunch\HyperLaunch Icons\hlhqicon256x256.png Item_4_Ignore_Process_Close=false Item_5_Path=C:\HyperSpin\HyperTools\Filter HyperList.exe Item_5_Parameters=Item_5_LogoPath=Item_5_Ignore_Process_Close=false Item_6_Path=C:\HyperSpin\HyperTools\Rename ROMs.exe Item_6_Parameters=Item_6_LogoPath=Item_6_Ignore_Process_Close=false Item_7_Path=C:\HyperSpin\HyperTools\Split HyperList.exe Item_7_Parameters=Item_7_LogoPath=Item_7_Ignore_Process_Close=false Item_8_Path=C:\HyperSpin\HyperTools\Create New HyperList.exe Item_8_Parameters=Item_8_LogoPath=Item_8_Ignore_Process_Close=false Item_9_Path=C:\HyperSpin\HyperTools\Merge HyperLists.exe Item_9_Parameters=Item_9_LogoPath=Item_9_Ignore_Process_Close=false How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
