American Laser Games and RocketLauncher
awaawaawa
Hi,
I configure Daphne Singe and from outside it run correctly.Via .bat file all the game works well.
In Rocket Launcher the games do not start.
What I have to configure??
And onother doubt.
Why in the Hyperspin database there are not all the games?? For example Time Traveller??
Thanks in advance
set your default emulator to PC launcher if you are using bat files.
make sure you add this to your PClauncher.ini
RocketLauncher\Modules\PCLauncher\PCLauncher.ini
You can do the same with WOW Action MAX
[crimepatrol]
Application=J:\Roms\Daphne Singe\crimepatrol.bat
[drugwars]
Application=J:\Roms\Daphne Singe\drugwars.bat
[maddog]
Application=J:\Roms\Daphne Singe\maddog.bat
[maddog2]
Application=J:\Roms\Daphne Singe\maddog2.bat
[hjohnnyrock]
Application=J:\Roms\Daphne Singe\hjohnnyrock.bat
[lbh]
Application=J:\Roms\Daphne Singe\lbh.bat
[spacepirates]
Application=J:\Roms\Daphne Singe\spacepirates.bat
[timegal]
Application=J:\Roms\Daphne Singe\timegal.bat
[hayate]
Application=J:\Roms\Daphne Singe\hayate.bat
[timetrav]
Application=J:\Roms\Daphne Singe\timetrav.bat
the location of your bat files will be different from mine.
the American Laser XML set by manufacture not emulator.
Time Traveler = Atari
Time Gal = Taito
Ninja Hayate =  Taito
you should add those Laser Games to your Daphne wheel,  they will be better placed since they are joystick not gun games.
I'm guessing
Hi,
And onother doubt.
Thanks in advance
Search for the Daphne and Daphne-Singe tutorials here and then read through all the pages of both. That should help you get them set up.
[crimepatrol]
[drugwars]
[maddog]
[maddog2]
[hjohnnyrock]
[lbh]
[spacepirates]
[timegal]
[hayate]
[timetrav]
Time Gal = Taito
Thanks for the answer.
How can I set the PCLauncher as defualt emulator?? When I add an emulator for American Laser Game the only modulo to choice is Daphne SInge.
I did not understand the XML set by manufacture...
Thanks
Thanks
Emulator and Module are two different things. However you don't normally use PCLauncher for Daphne-Singe. It sounds to me like he is doing it an alternate way by launching .bat files to thenm launch the games. So far as I know that isn't the normal way to do it. Normally I believe the bat files are just used to test that your roms/files are working properly outside of RL (like yours are)
Did you already go read and follow the tutorials I told you about? If not then you need to go through those entire tutorials first. They will help you get it set up.
http://www.hyperspin-fe.com/topic/2139-complete-guide-for-american-laser-gameswow-actionmax-in-hypespin-and-RL
http://www.hyperspin-fe.com/topic/2161-complete-guide-for-daphne-in-hyperspin-and-RL/
For the XML he was saying that those three games are run using the Daphne-Singe emulator, but it makes more sense to have them in the normal Daphne Hyperspin wheel & database with the other laserdisc games. Don't worry about that yet. First read the tutorials, get it working right, figure that part out later once you understand it a bit better.
their are multiple way of doing things
The bat files are the "Correct" and only way to launch the Daphne Singe emulator  WITHOUT A FRONT END.
other then a command line with is basically a manual bat file.
a module was created for the daphne singe emulator witch eliminates the bat files,  but the PClauncher method works just as fine with the bat files.
Like I said,  you select the PC launcher as your default emulator
you do not need to set up the Daphne Sing Global emulator,  their is no need to select a module for it.
the rom path is left blank. ( path to your bat files are stored in the PClauncher.ini)
you can use this method that can be set up  by
- edditing your PClauncher.ini
- setting the PClauncher as your default emulator
or
you can read through multiple pages of How to using the Daphne Singe Module.
