Creating PC fighting games / systems?
Bonoscot
Guys I'm trying to create a new wheel PC fighting games....I have created the wheel fine , however in emulators I cant select PC launcher (nothing appears at all) and also  in modules , No module appears? I need the module so that I can select edit and set paths to my fighting games  ( like I can do with the pc games,thats fine)
any help be appreciated
Did you add PC launcher in global emulators.. As a virtual emulator . Then you assign the module. If you have PC games setup then you should already have PC launcher
yeah the pc games are fine, launcher is set in there,as is irtual emulator...the games run as they should
When I click on the PC fighting games and select emulator, there is no emulators in the default list at all,its blank.
When I also click on the modules tab,there are no modules at all to select.
I assume I use the same settings as PC games,but I cant select anything under
edit: I went to rocketlauncher/emulator settings/Pcfighting games/emulator and typed in PCLauncher....it now has appeared in emulators tab.....
Its just the module? How do I get a module to appear under PC fighting games now? I need the PCLauncher.ahk I assume? then I can select edit globule module and add my games from list?
As Jeremy said... Go into rocketlauncher /modules folder.. Edit pclauncher.ahk and type in your system name . Then in RLui go to your fighting game system and add PC launcher emulator, then module should show
Btw I recently added this myself :)
Not a bad idea. Don't really like the name "PC" Fighting Games though.
Just Fighting Games or Fighters or Modern Fighters sounds better. Even Steam Fighters sounds better.
There are a lot of good native pc fighting games.... SF V will be a must have in a cabinet!
