ninja2bceen Posted December 3, 2015 Posted December 3, 2015 File Name: Hypermint- Ultimate Auditting tool File Submitter: ninja2bceen File Submitted: 03 Dec 2015 File Category: Audit Tools Credits: horsey horsey Many have asked for a copy of this awesome tool. Horsey hasn't updated his thread and you could only get it on a per request basis while he was developing it. If this needs to be taken down so be it but so many have asked for it, I figured I would just post it. you may have to delete the config file in order to set it up on your system for the first time Manager:Main menu management:Manage multiple main menu xmls.Uses new enabled tags for HS 1.4Sort systems and add from a master list.Shows whether have the system xml & genres for a system. Database Management:Imports db's from Hyperspin.Imports favorites from HS.Scans HS & RL Media.Uses new enabled tags for HS 1.4 (same with genres created from here)Basic xml editing in gridview.Update & save favorites from checkboxes in grid. Viewer & Files Pane:Send selected file/s to Rubbish (Trash, Backup)..Hypermint/Rubbish/Hyperspin..Hypermint/Rubbish/Rocketlaunch Convert PDF to imagesConvert Text to PDF Todo:Renaming of filesUnused files cleaner.Media matching for all.Chop pdf booklets (good for snes etc)Add options to load media with image editors etc Multiple System Generation:Add games from any list into the MSG preparation list.Add favorites in one swoop on the current selected list.Scan over all systems for favorites in the current selected main menu and add to prep list.Add an existing HS settings ini for your preferred look of wheelOption to create symbolic links for all media & themes when generated.Option to create genre lists when generated.Option to include a RL games.ini for rom/system map.Option to copy the systems default.zip to the rom if one doesn't exist. (Only symbolic links)Builds a database and you're ready to go. Only thing missing is the Main menu theme for your system.ToDO:Add options to generate MultiSystem from the statistics in RL. Top 100 etc etc. Bezel Edit:Send bezels in by right click images on the viewer, or drag over , set co ordinates.Creates ini. Instruction Cards:Create presets for instruction cards.Right click on any image in viewer to convert & send to correct folder and naming with chosen preset. Image Editing:Bog standard editing. Useful for creating: Fades, BackgroundsRight click images send to this editor. Intro Video Generator:Scan current selected system for videos.Add randomly or by selection.Generate an avisynth script which includes fading, dissolving the same as Emumovies.Option to include the wheel image on the video for each game. (Set pos and resize options)Shows frame size and proper framerate when added or scanned.NOTE TO THE STABLE: Forget to add opacity.Todo: Add video trimming with fades Wheel Generator:Create wheels , Letters,Genres, Special Art for selected system.Can save presets for later use. Search:Built in browser to search for game assets.Drag drop assets into selected game cells to correct folders. RL & HS.Youtube downloader and search:Pick resolution & download to folder (Currently only HS, needs more work) RL Stats:Scan your stats and view them here in a different context.ToDO:implement stat filters & Multi system gensAdd removing of sections from ini. Game Launching (RL only):Right click on main list to launch or launch with RL modes. Pause , fade etc.Game controller button:Opens drop in window and can launch selected game from here or just push random to get another game.ToDo: Turn this random function into full screen application for launching inside HS. http://www.rlauncher.com/forum/showthread.php?1426-Hypermint&highlight=hypermint Click here to download this file Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
spotUP Posted December 3, 2015 Posted December 3, 2015 Nothing happens when i click scan... and the gui looks very beta.. but maybe that's the stage where it's at. If i scan for RL media a big spinner pops up and won't go away.
Metalzoic Posted December 3, 2015 Posted December 3, 2015 I downloaded this a couple weeks ago to play around with and couldn't really find an actual use for it myself, but it looks like it does a lot more than I thought it did though. Still can't see where I would really need it though. Ninja what do you use it for? Do you use it a lot?
ninja2bceen Posted December 3, 2015 Author Posted December 3, 2015 Find missing artwork, videos etc. can modify xml easily, fix bezel inis as a start Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
xzotic Posted December 4, 2015 Posted December 4, 2015 Some sort of video would be great to show how to use this tool. Looks like it could do a lot but I can't get it to work either.
ninja2bceen Posted December 4, 2015 Author Posted December 4, 2015 Look up hyper mint on rocket launcher there are videos there Sent from my iPad using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
iNTiGOD Posted December 4, 2015 Posted December 4, 2015 Nothing happens when i click scan... and the gui looks very beta.. but maybe that's the stage where it's at. If i scan for RL media a big spinner pops up and won't go away. This happened to me also. I put in the correct paths and it never seemed to detect my systems. I opened and closed it several times and cant remember what i click but then bam..... my systems appeared and all the systems came to life. I have only used it to generate text wheels for snes satellaview MAME High Score Tutorial For HyperSpin
ninja2bceen Posted December 4, 2015 Author Posted December 4, 2015 The mm version posted was his latest. I didn't have that same experience though. Click the gear to map hyperspin and rocketlauncher and it should just appear Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
