Rotgut Posted January 3, 2016 Posted January 3, 2016 I've done searches and can't seem to find a solution to this... does anyone have any advice? Thanks
Rotgut Posted January 3, 2016 Author Posted January 3, 2016 Just to be clear, when I select a game in the -- let's say Game Boy Advance wheel -- the rom loads perfectly, however audio from the HS game wheel continues to play. Also happens with other systems such as TurboGrafx-X 16 and Genesis. I don't get it. Yes, I am using RocketLauncher for these. Anyone?
Rotgut Posted January 4, 2016 Author Posted January 4, 2016 Anyone.........? Could really use some help on this.
Undertow76 Posted January 4, 2016 Posted January 4, 2016 Never had that happen with roms before, sounds like HS isn't switching over to your emulator properly , hard to say without a logfile, If you post your rocketlauncher log file, mabe someone could spot something.
NewYears1978 Posted January 4, 2016 Posted January 4, 2016 I tried to reproduce this but I can't. The only thing I could even come close to reproducing was once I hit enter twice real fast and it launched the emulator twice..so I heard the game playing twice. Other than that I can't produce the error. Is it every time, all systems? Only some systems? Any other info? Are you an HTPC user? Do you like Kodi/XBMC?If so, check out these Kodi Style Themes!-----------------------------------------------------------------------------------------------------Aeon Nox 13 by @dark13Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress-----------------------------------------------------------------------------------------------------If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
shinobi68 Posted January 4, 2016 Posted January 4, 2016 Hi, In hyperHQ, you have to disable trackball and disabled keyboard delay. Try this
Rotgut Posted January 4, 2016 Author Posted January 4, 2016 Hi, In hyperHQ, you have to disable trackball and disabled keyboard delay. Try this Disabling "Keyboard Delay" did it! Thank you so much, man!
Rotgut Posted January 4, 2016 Author Posted January 4, 2016 I tried to reproduce this but I can't. The only thing I could even come close to reproducing was once I hit enter twice real fast and it launched the emulator twice..so I heard the game playing twice. Other than that I can't produce the error. Is it every time, all systems? Only some systems? Any other info? It was happening with multiple systems. It's fixed now thanks to shinobi68. : )
shinobi68 Posted January 10, 2016 Posted January 10, 2016 i would like to know also Hi, what would you like to know exactly? This problem was fixed, just read the post...
