Please Help!!!
romeclientel
Having all types of issues. Launch Hyperspin and the wheel goes nuts! Also, for some reason when I try to launch a game in rocketlauncher I get this...
Error "use global" is not a valid key name. All games work in Mame and I love this platform but after 2 weeks Hyperspin has never worked for me. Can someone tell me what I'm doing wrong?
HyperSpin is VERY tricky and even helping someone troubleshoot problems is nearly impossible because of all the variables at work.
I would second the above post. Following Simply Austin's setup playlist will not only set you up on almost everything, but help you learn how things work along the way: Click Here
That global error sounds like an AHK module error? Make sure you haven't set multiple keys for something.
As for the wheel spinning, are you using a joystick or controller with analog stick? If so it sounds like it's stuck, you might try opening HyperHQ go to Controls and click on Joystick, change the analog threshold on the bottom from 40 to something else
(try 20 or something)
Are you an HTPC user? Do you like Kodi/XBMC?
If so, check out these Kodi Style Themes!
Aeon Nox 13 by @dark13
Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress
If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
Make sure you don't have control wheel with mouse enabled. I tried that cuz I thought it would be cool with my tracball. Ended up causing more issues and would do things like you described constantly.
