Dolphin support!
reznnate
  • Replies 69
Just watching your video it looks like you get the same randome frame drops that I do on default settings.
What all did you change if your settings ?
doesnt hickup at all when in normal usage, it because the system recording turning and ate the performance, didnt realize how much a resource hog that option was....
my setting are uploaded in my post, check it out if you like?
Yea I was looking at them but didn't have mine next to them to compare, was hoping you could discuss a couple changes you made that improved performance.
Does the game lag when you first boot it ?
Connorsdad I haven't had any issues with controls since using the Dolphinbar and Wii motes.
I could not get to the controller mapping otherwise, unless they fixed that in a recent release.
I see these settings work great with the likes of 'Newer super Mario bros' for the wii but not so good for 'Soul Calibur' on the gamecube. Does the Android version of hyperspin allow loading of ini's on the fly, settings for each game if you like, or is there a way of having multiple versions of dolphin exist on 1 device ?
Sent from my SM-G930F using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
Thanks for sharing these settings, anyone have the controls working correctly for the shield tv ?
The only way I figured out was to download the store app and copy over config file after setting up controller then to download latest nightly and copy over config files but then it has lag
I think I read dolphin itself does it on a per game basis, is that right ?
I'm a newb re this version of HS, I haven't even installed it yet I just want to get my head around the emulators first.
Dolphin is a stand alone emulator and the last version I used trying to map the controller button was impossible, literally the option was gone.
So I added the Dolphinbar a sensor that works with Wiimotes and Dolphin.
If your family limes the Wii I highly recommend looking into the Dolphinbar.
I tried this and got the same result. I found the code for the gamecube controller to work, I added just this code to the bottom of the dolphin.ini shared in this thread and that controller is fine, I need the snippet of code that binds the wiimote controls to the shield tv controller.
The code to bind the gamecube controls to the shield tv controller:
[Android]
ScreenControls = False
InputA_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 96
InputB_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 97
InputX_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 99
InputY_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 100
InputZ_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 104
InputStart_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 108
DPadUp_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 16+
DPadDown_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 16-
DPadLeft_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 15-
DPadRight_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 15+
MainUp_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 1-
MainDown_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 97
MainLeft_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 0-
MainRight_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 0+
CStickUp_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 14-
CStickDown_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 14+
CStickLeft_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 11-
CStickRight_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 11+
InputL_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 102
InputR_0 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 103
[Android]
awesome thank you
My Dolphin.ini as it stands at the minute, wiimote dpad now working correctly.
**Backup yours before trying this**
[FifoPlayer]
LoopReplay = True
[DSP]
DumpAudio = False
DumpUCode = False
CaptureLog = False
Volume = 100
EnableJIT = True
Backend = OpenSLES
[interface]
MainWindowHeight = 600
AutoHideCursor = False
ExtendedFPSInfo = False
Language = 0
PauseOnFocusLost = False
OnScreenDisplayMessages = True
ShowToolbar = True
ShowLogWindow = False
ThemeName40 = Clean
ShowLogConfigWindow = False
HideCursor = False
ShowStatusbar = True
MainWindowWidth = 800
MainWindowPosY = 100
ConfirmStop = True
UsePanicHandlers = True
MainWindowPosX = 100
[input]
BackgroundInput = False
[GameList]
ListSortSecondary = 0
ColorCompressed = True
ListWad = True
ListSpain = True
ListUnknown = True
ListGermany = True
ColumnFileName = False
ListGC = True
ColumnBanner = True
ListUsa = True
ColumnNotes = True
ListRussia = True
ColumnID = False
ColumnSize = True
ListItaly = True
ListDrives = False
ListWii = True
ListJap = True
ListWorld = True
ListElfDol = True
ColumnRegion = True
ListSort = 3
ListNetherlands = True
ListFrance = True
ColumnPlatform = True
ColumnState = True
ListAustralia = True
ListKorea = True
ListTaiwan = True
ListPal = True
[Core]
SerialPort1 = 255
WiiKeyboard = False
SelectedLanguage = 0
AdapterRumble1 = True
SlotA = 1
SlotB = 255
EnableCheats = False
DSPHLE = True
SimulateKonga0 = False
EmulationSpeed = 1.00000000
AgpCartBPath =
SyncGPU = False
RunCompareClient = False
DPL2Decoder = False
GPUDeterminismMode = auto
OverrideGCLang = False
AdapterRumble3 = True
Fastmem = True
FPRF = False
Overclock = 2.00000000
CPUThread = True
SIDevice3 = 0
Apploader =
AgpCartAPath =
WiimoteContinuousScanning = True
MemcardBPath = //sdcard/dolphin-emu/GC/MemoryCardB.USA.raw
SimulateKonga2 = False
SyncOnSkipIdle = True
HLE_BS2 = True
Latency = 2
SIDevice0 = 6
OverclockEnable = True
DefaultISO =
GFXBackend =
TimingVariance = 40
SimulateKonga1 = False
AdapterRumble2 = True
PerfMapDir =
BBA_MAC =
SyncGpuMinDistance = -200000
AccurateNaNs = False
SkipIdle = True
RunCompareServer = False
FrameSkip = 0x00000000
SIDevice2 = 0
CPUCore = 4
DVDRoot =
MemcardAPath = //sdcard/dolphin-emu/GC/MemoryCardA.USA.raw
WiiSDCard = False
SimulateKonga3 = False
AdapterRumble0 = True
WiimoteEnableSpeaker = True
SyncGpuMaxDistance = 200000
SyncGpuOverclock = 1.00000000
SIDevice1 = 0
[Display]
ForceNTSCJ = False
KeepWindowOnTop = False
Fullscreen = False
PAL60 = False
DisableScreenSaver = True
RenderWindowAutoSize = False
ProgressiveScan = False
FullscreenResolution = Auto
RenderWindowXPos = -1
RenderToMain = False
RenderWindowWidth = 640
RenderWindowYPos = -1
RenderWindowHeight = 480
[Movie]
ShowInputDisplay = False
Author =
DumpFrames = False
DumpFramesSilent = False
PauseMovie = False
[General]
ShowLag = False
ShowFrameCount = False
LastFilename = /storage/emulated/0/Hyperspin/Roms/Nintendo Wii/New SUPER MARIO BROS. Wii.iso
WirelessMac =
RecursiveISOPaths = False
ISOPaths = 0
NANDRootPath =
[Android]
WiimoteA_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 99
WiimoteB_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 100
Wiimote1_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 96
Wiimote2_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 97
WiimoteHome_4 = Device 'a718a782d34bc767f4689c232d64d527998ea7fd'-Button 84
WiimoteUp_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 15-
WiimoteDown_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 15+
WiimoteLeft_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 16+
WiimoteRight_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 16-
WiimoteMinus_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 23-
WiimotePlus_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 22+
ClassicA_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 96
ClassicB_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 97
ClassicX_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 99
ClassicY_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 100
ClassicHome_4 = Device 'a718a782d34bc767f4689c232d64d527998ea7fd'-Button 84
ClassicUp_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 16+
ClassicDown_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 16-
ClassicLeft_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 15+
ClassicRight_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 15-
ClassicLeftStickUp_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 1-
ClassicLeftStickDown_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 1+
ClassicLeftStickLeft_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 0-
ClassicLeftStickRight_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 0+
ClassicRightStickUp_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 14-
ClassicRightStickDown_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 14+
ClassicRightStickLeft_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 11-
ClassicRightStickRight_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 11+
ClassicTriggerL_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 23+
ClassicTriggerR_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Axis 22+
ClassicMinus_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 102
ClassicPlus_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 103
ClassicZL_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 106
ClassicZR_4 = Device 'a691ea53a0f5aabd5e2dd0674f6ce7c0c6aca61f'-Button 107
ScreenControls = True
  • 1 month later...
  • 8 months later...
I don't know where this stands but I figured I'd post the latest settings that work, just to keep it simple for the next person.
exe=org.dolphinemu.dolphinemu/org.dolphinemu.dolphinemu.ui.main.TvMainActivity
romextension=zip,iso
parameters=AutoStartFile
I have the latest dolphin nightly downloaded through f-droid
[sIGPIC][/sIGPIC]
