Retroarch Rom Extensions
pacgamer23
Hi! I have all the roms for Sega Genesis but when I run them with retroarch as the emulator it says:
"Couldn't find the rom "3 Ninjas Kick Back (USA)" inside the archive with any defined rom extensions. Check if you are missing the correct Rom Extension for this rom for RetroArch's Extensions, enable Rom_Match_Extension,"
1, How do I change the rom extension for Retroarch.
2, How do i enable Rom_Match_Extensions!
Hope you can help!
Turn off 7z and try again.
Are you an HTPC user? Do you like Kodi/XBMC?
If so, check out these Kodi Style Themes!
Aeon Nox 13 by @dark13
Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress
If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
You may also need to add the extension of the actual ROM inside the zip. Or try turning off 7z by changing it to false.
You say HyperLaunch, are you not using RocketLauncher?
What is the rom extension? Go to load core in retroarch and load then core your trying to use the go to the information tab and under core it should tell you what rom extension are supported for that core. If your extension isn't the right one download a different rom with the right extension.
Agent 47 is a very helpful person you shouldn't judge a book by it's cover he has helped me in the past.
I don't think (or at least I hope not) pacgamer was being negative towards Agents, he may have just read the avatar wrong.
And yes Agent47 has been a great help around here.
Agent47 is awesome! He modified a JSFL script for me and he didn't even know the language ;)
He also helped with other stuff and batching with my skin.
Gigapig it said HyperNewbie above his picture. I thought it was his username  :turned:
BTW my response fixed his issue, he told me in chat but he just didn't mark it solved or say it was solved in here lol.
