oldhag270 Posted January 28, 2016 Posted January 28, 2016 File Name: MAME x64 w/No Nag+Hi Score+Direct Input 0.170 File Submitter: oldhag270 File Submitted: 28 Jan 2016 File Category: Other Credits: MAME developers,oldhag270 Here is MAME x64 0.170 w/No Nag+Hi Score+Direct Input Click here to download this file
Dime333 Posted January 28, 2016 Posted January 28, 2016 Thank you, Could you please also do one with raw input? I'm sure everyone with dual lightguns would appreciate that.
rastan Posted January 29, 2016 Posted January 29, 2016 for some reason the input wasn't working for me because I can't use my mapped buttons I have setup for (ESC) and (TAB) player 1 start and coin.... when I switched back to the 169 with direct input my buttons for (ESC) and (TAB), etc. work fine..
Dime333 Posted January 29, 2016 Posted January 29, 2016 I'm a little confused. Can direct input be turned on and off in the settings on this version? Or is that only possible on mameuifx? Is that for all mame/mamuifx builds or only your builds?
Tribe Fan Posted January 29, 2016 Posted January 29, 2016 for some reason the input wasn't working for me because I can't use my mapped buttons I have setup for (ESC) and (TAB) player 1 start and coin.... when I switched back to the 169 with direct input my buttons for (ESC) and (TAB), etc. work fine.. I was having the exact same problem. The solution that the poster provides in this thread finally fixed it for me: http://forum.arcadecontrols.com/index.php?topic=141243.0 It's a little crude, but it works.
rastan Posted January 29, 2016 Posted January 29, 2016 tried the PATCH but didn't seem to work for me... I wanna use my hex editor to change it but I can't seem to find the line to change.. I tried searching for the hex that was listed in that thread but it isn't in the code.
rastan Posted January 29, 2016 Posted January 29, 2016 never mind it worked! My mame folder is a MESS (lol) you see I had a version of MAME 139 with a default cabinet ARTWORK for all the roms that did't have their own ARTWORK... and once I updated to newer versions of mame.. I would just rename mame64 to mame139_default_artwork (or whatever) because I was too lazy to go inside RL and HQ to change the paths to mame64.exe Basically I patched mame64.exe but after patching it I needed to rename it to the filename that my xpadder profile was looking for.
Tribe Fan Posted January 29, 2016 Posted January 29, 2016 Awesome! Glad it worked. This was driving me crazy before I found that fix.
oldhag270 Posted January 29, 2016 Author Posted January 29, 2016 I'm a little confused. Can direct input be turned on and off in the settings on this version? Or is that only possible on mameuifx? Is that for all mame/mamuifx builds or only your builds? It is only possible in mameuifx.
Dime333 Posted January 29, 2016 Posted January 29, 2016 It is only possible in mameuifx. OK. Thanks. Would it be possible for you to make a regular MAME with raw input.I would very much appreciate that.
