Mame chd files on android???
badhemi
I'm not aware of any problems with games that use CHD files.
There are some problems with the Retroarch mame cores at the moment.
Biggest hassle is ensuring you have the right format/rom set to match version of mame emulator.
Thanks rez. I have 4 games in my mame that won't play. Firefox, cliffhanger, cobra command, is vs them. They play in pc but not on android. All others play
No clue, have had no experience with those roms and chds. So if you are SURE the mame versions and rom sets are the same, the core must be broken.
All of my zips with chd file games load but pick back out. Pcmame they play so it must be broken. Thanks for reply. Can you tell me which reicast nightly guilty build to get I replied on dreamcast post. Good news and bad news
They do? Interesting. I thought they still didn't work in MAME.
yes all my chd game work on pc but won't play in mame4droid
Are you using v139 mame on PC? I doubt it so assuming you are using newer romset, try the mame2014 or mame git cores in retroarch.
how do I check an see what rom set they are. How do I set up paths of my chds are in a subfolder?
how do I check an see what rom set they are. How do I set up paths if my chds are in a subfolders since android can't find subfolders
Put the chd's in with your ROMs, they should automatically pair up. When you downloaded the rom set they normally have the number in the title :)
Ok I loaded area51 in retroarch mame git and opened the area51zip and I got the screen and trigger gun it moves around. Then I tried to load the chd the next time and it loaded but had a test screen. I have several area51 roms I have a mx,t and an a. As well as other chd games have many names of same game. Not sure how to load them both at once
You don't load the chd separately. If the game has a chd associated with it then mame knows to use it when you load the rom.
well then I guess it do,t work since I'm getting just a screen with the trigger
No luck I tried to load cliffhanger zip it kicks out. I even moved them in there own roms folder. I guess mame android can't handle chd
what is mame 2014? I only have mame and mame2003
I don't think android can load the laser disc games (https://en.m.wikipedia.org/wiki/Category:Laserdisc_video_games), but if you do get any of these to load, let me know :) (mame) is (mame2014) as far as I know, I think they dropped the (2014) off the core because its evolved further.
that blows. I hope they emulate singe or daphne. area 51 isn't laserdisc and it doesn't load. Anything with chd
  • 4 weeks later...
I'd be curious about which CHD-related games you guys would really like to play.   I agree the CD-based games would be nice until Daphne is ported to Android.   But most of the other games are going to be too slow.
I THINK the retroarch mame cores are a bit buggy on Android.   Area51 worked for me but other games didn't.
cliff hanger and chopper command
