Atari 5200 with retroarch mame core !!!
Sting
Advision isn't perfect, check the hash folder for a (advision.xml) to name your roms, and then it'll be trial and error.
  • Replies 87
do I name the folders revision and what about bios. It loads in hyperspin but takes you to ra menu
  On 3/4/2016 at 12:13 PM, Sting said:
Does it load outside of Hyperspin???
do I need to rename games or just put my xml in the hash folder? Also what did you name folders and bios zip? Arcadia 2001 says it doesn't require bios and when I set everything up it goes to menu like adventure vision
  On 3/5/2016 at 9:32 AM, Sting said:
Where did you get your hash folder???
from mame hash. Ones advision and the other arcadia.
  On 3/5/2016 at 6:26 PM, Sting said:
You need to name your ROMs exactly how they are in the hash folders .xml files.
how do I set up this controller in mame so I don't keep hitting the master volume when I hit the b button. Very annoying. I don't see it in mame settings
so I got Atari 5200, intellivision and arcadia to run but adventure vision is not loading even in retroarch it goes to load then kicks back. I have bios in advision folder and I even try to rename bios to advision.zip and still nothing. What's up sting?
  On 3/6/2016 at 11:15 AM, Sting said:
I'd suggest trying to load different ROMs, Advision isn't perfect and neither is (mame/mess) :/ Here's a guide on which emulator (core/systems) work and which ones have issues along with settings. http://www.progettoemma.net/mess/sysset.php
awesome Thanks. It's saying that advision should be in bin format to emulate. Did you?
I didn't have it setup yet, so just set it up now :) It literally took me 5 minutes to get everything running. Created an (advision) folder in my system folder put my ROMs in there, and then created another folder named (advision) inside my (advision) folder for my (BIOS) files. So I have (system/advision/advision). My ROMs are (.bin) but they are all in (.zip) folders, and named exactly how they are they are in the (advision.xml) in the hash folder. I set everything up on my phone, and then sent it to my shield, I'm off work tomorrow so will do a video guide.
that's how I have my folders set up just don't know how or what to mame bios
Here's my setup from my phone :) In my BIOS folder I have the 2 BIOS files in there raw format, and I have them both in a (zip) folder named advision :)
Google (mess bios) and the first result is the only one you need, rename them to match mine and hey presto :)
tank you
ok sting dowloaded advision bios extracted and renamed accordingly moved to advision bios folder and still does same thing. Loads and kicks out
