Help setting up Taito Type X
vaderag
  • Replies 58
still working on it....
copied the bezel.png and bezel.ini to the RL bezels, RL UI can see the media in the game options... turned on bezels for Chaos Break. set the main taito type x bezel settings to false & full screen false.. etc. launch the games and the bezel doesn't show up.. I'll continue to play with it...
So make sure you have a RocketLauncher>media>bezels>Taito Type X>Chaos Breaker folder (you might also need to have a _Default folder, can't remember).
Put the bezel.png and bezel.ini in that folder. If the bezel doesn't pop up cycle to the next bezel until it appears (set up your bezel controls).
If it isn't cycling then turn Save last Bezel to False, or copy/paste the bezel png & ini back into the folder (so it has something to cycle between)
I'll add the default to see if that's it.
  • 1 month later...
  • 3 weeks later...
Ok, so I started looking into "Game Loader All RH" (Thanks to Gigapig for the link: https://www.mediafire.com/?wix803bszhyxr)
and discovered it supports multiple languages, but the developer has only supplied Japanese.
To change the displayed text edit Language.ini
* In Windows7 x64 "C:\Users\USER NAME\AppData\Roaming\Game Loader All RH"
* In WindowsXP "C:\Documents and Settings\USER NAME\Application Data\Game Loader All RH"
Unfortunatlly I don't speak any Japanese, so I dumped all the text through Google Translate.
Attached are the results. I also got google to translate the comments of the Readme, Pad.ini and TTX.ini.
Although google is not great, you can basically understand what the options are.
I started trying to improve the translations, but it has been very time consuming.
So I am hoping others in the community can help improve the text.
In the attached zip file are both the original Japanese and my English translation.
If you are using a non-Japanese version of windows, the generated text files (and display)
will show all the charters as "?""
To generate the correct Japanese files, you need to change the windows system locale.
Hope this helps.
Cheers
Nomis
  • 6 months later...
English is supplied already, it's just that it defaults to Japanese. I guess the developers are Japanese. All you need to do is make the program create a new language.ini file. You can do it all automatically by using a button in the settings. Second to last tab, near the bottom I believe.
  • 1 year later...
Hey Folks - sorry to dig up an old thread, but I need a little bit of help. The original poster managed to get SSIVAE 2012 working with 2 players...Im struggling with that. I have SSIVAE working ok, with 2 players and the additional characters but I seem to be going around in circles with 2012 - can anyone help?
