Will HyperSpin ever come for the Raspberry Pi?
Notsogood
  • 1 month later...
Shame - would be fantastic if it came to the Raspberry Pi. There's 2 main options already for the Pi regards emulating but another one would be nice.
Regards,
Ashley, the curator @
Someone mentioned recently that Attract Mode can use HS themes. I see there's a Pi build but don't know if it can do the same.
Anybody tested this? Too busy to try it myself right now.
Recalbox is also well worth a look in.
Has anyone worked the Windows 10 IoT core? I'm wondering if this can be an alternative - instead of wishing for HyperSpin to be on Raspberry Pi.
  • 3 weeks later...
HyperSpin in my favorite frontend and can do so much more then will ever happen on a Pi. There have been some great new improvements on other frontends that can use HyperSpin themes or have HyperSpin like themes that will run on the Pi.
If you're set on a Pi check out http://forum.attractmode.org/index.php?topic=705.0 . It has a HyperSpin like theme and can run HyperSpin themes. Don't expect the HyperSpin themes to run 100% but a lot work pretty well.
If you have a HyperSpin build you can use many parts of it on the Pi such as basic themes, wheels, videos (if not too high resolution), database imports, etc. If you don't have a good/full HyperSpin build you'll be better off with one of the HyperSpin type clone themes (layouts) on the Pi.
If you want the best frontend, HyperSpin is by far the best. If you want super cheap hardware or small and portable then there are other options.
