thenoob Posted February 28, 2016 Posted February 28, 2016 Hey everyone Just finished updating my system to Windows 10, but the wheel in HS is acting weird. It goes through the main loading video, then to the system wheels, and just keeps spinning and spinning I can't make it stop?? I'm using my xarcade tankstick and it's never ever been an issue. My controls are setup properly in HQ for the tabkstick for HS navigation. My emulators work fine outside of HS and the controls work properly but Inside HS after the Main launch, I can't stop the wheel from spinning???
thenoob Posted February 28, 2016 Author Posted February 28, 2016 Friggin HQ, found the setting All good mods delete this.
Rincewind Posted February 29, 2016 Posted February 29, 2016 Could you let's us know what you did please , incase someone else has the problem
Min2001 Posted March 7, 2016 Posted March 7, 2016 Could you let's us know what you did please , incase someone else has the problem I suffered with the same problem before. You just needed to disable the joystick in HyperHQ as it is buggy with certain joysticks that have 3rd party applications. That or the deadzone of the joystick needs highering or lowering to compensate for different controller movement.
Rincewind Posted March 7, 2016 Posted March 7, 2016 Yes I was advised to use this http://www.hyperspin-fe.com/files/file/7415-hyperspin-startup-script/ and it worked perfectly. also I am using a control panel so its not just for 360 pads
