ulao Posted May 15, 2017 Author Posted May 15, 2017 Quote Could you elaborate on the changes that make it compatible with retroarch? Expand Well when you said retroArch I assumed you meant the Linux version because it always worked on the windows version. If my assumption was correct, it's as simple as that. Dual device = fail. I simply had no choice but to remove the dual device in flavored of the retroPi users. I do believe at one point getting the windows version of retroArch to work required some hackery. This was because SDL 2.0 was favored by retroArch. Turns out SDL also had a bug with dual devices and was also resolved with this fix. So it was much easier to use retroArch in windows. 1
Avar Posted May 17, 2017 Posted May 17, 2017 Quick update: Bliss-Box has started selling standalone cables and standalone adapters in their store. Easier than ever to customize the exact kit you're after.
newoski Posted May 17, 2017 Posted May 17, 2017 On 5/15/2017 at 2:54 AM, ulao said: Quote Could you elaborate on the changes that make it compatible with retroarch? Well when you said retroArch I assumed you meant the Linux version because it always worked on the windows version. If my assumption was correct, it's as simple as that. Dual device = fail. I simply had no choice but to remove the dual device in flavored of the retroPi users. I do believe at one point getting the windows version of retroArch to work required some hackery. This was because SDL 2.0 was favored by retroArch. Turns out SDL also had a bug with dual devices and was also resolved with this fix. So it was much easier to use retroArch in windows.By always worked in Windows, do you mean with an autoconfig? With xpadder? What's the correct implementation? I had trouble during the kick starter, so hoping to get it right this timeSent from my HTC6535LVW using Tapatalk
ulao Posted May 17, 2017 Author Posted May 17, 2017 RetroArch changes a lot. When I installed it here, everything just worked. With the latest firmware I'd expect that to be the case still. As for getting it right, just know many users are using it with RetroArch now so you're good either way.
newoski Posted May 19, 2017 Posted May 19, 2017 On 5/17/2017 at 11:45 AM, ulao said: RetroArch changes a lot. When I installed it here, everything just worked. With the latest firmware I'd expect that to be the case still. As for getting it right, just know many users are using it with RetroArch now so you're good either way. 1. Which firmware has the Retroarch support?2. What exactly has been added? Sent from my HTC6535LVW using Tapatalk
Avar Posted May 19, 2017 Posted May 19, 2017 @newoski Within the last version or so I believe. The RA team has a 4-play for development and they seem pretty committed to maintaining compatibility with it. Here are the latest firmware Release Notes.
newoski Posted May 19, 2017 Posted May 19, 2017 On 5/19/2017 at 3:22 AM, Avar said: @newoski Within the last version or so I believe. The RA team has a 4-play for development and they seem pretty committed to maintaining compatibility with it. Here are the latest firmware Release Notes.There's no mention of RA or libretro. Can you explain what was updated and how it impacts RA? Just got mine and I'm struggling to find the balance between autoconfigs, mappings, and xpadderSent from my HTC6535LVW using Tapatalk
Avar Posted May 19, 2017 Posted May 19, 2017 I don't personally use RA att so I'm sorry I can't offer a more insightful answer I'm pretty confident it's fully compatible now though and @ulao just confirmed for me as well on FB that was the case. Did a little digging and found a udev Bliss-Box core from around the time I believe it became fully compatible. Does this help?
newoski Posted May 19, 2017 Posted May 19, 2017 On 5/19/2017 at 3:36 AM, Avar said: I don't personally use RA att so I'm sorry I can't offer a more insightful answer I'm pretty confident it's fully compatible now though and @ulao just confirmed for me as well on FB that was the case. Did a little digging and found a udev Bliss-Box core from around the time I believe it became fully compatible. Does this help? Expand Thanks, but unfortunately not very helpful. Autoconfigs have existed for quite some time and have nothing to do with BlissBox, directly. There just happens to be an autoconfig for BlissBox. @ulao implied that the firmware on BlissBox has been updated to support RetroArch, recently. But I can't find any reference to the changes in the ChangeLog or anywhere on his webpages (social and website). Hoping he can chime in here and explain what he changed and how it would benefit RetroArch usage
iNTiGOD Posted May 19, 2017 Posted May 19, 2017 I've been using retro arch with the blissbox for probably a year now.It works fine. But I have used the unofficial firmware updater so my ports are numbered in windows.This made configuration easy.Let me know if you have any questions. 1 MAME High Score Tutorial For HyperSpin
newoski Posted May 19, 2017 Posted May 19, 2017 On 5/19/2017 at 10:58 AM, iNTiGOD said: I've been using retro arch with the blissbox for probably a year now. It works fine. But I have used the unofficial firmware updater so my ports are numbered in windows. This made configuration easy. Let me know if you have any questions. Expand 1. How are you using it? - With xpadder? With joy2key? With autoconfigs? 2. How do you customize the mappings, so different controllers work with different systems? - Right now, I'm running into issues where A/B work on the SNES controller in NES, but then button Y also duplicates a function.
newoski Posted May 19, 2017 Posted May 19, 2017 Also, after flashing the custom firmware successfully and experimenting for the last 24 hours, my Port1 just completely disappeared. WTF. Reflashing, following the instructions (press button, plug USB, select firmware and hold til complete) isn't working at all, to reflash that port
iNTiGOD Posted May 19, 2017 Posted May 19, 2017 Have you tried plugging the blissbox into a different USB port and reflashing?Re my setup, I'll get back to you over the weekend and update in this thread. My setup hasn't been touched in a while so I can't remember which version of retroarch I'm using. MAME High Score Tutorial For HyperSpin
ninja2bceen Posted May 19, 2017 Posted May 19, 2017 On 5/19/2017 at 3:24 AM, newoski said: There's no mention of RA or libretro. Can you explain what was updated and how it impacts RA? Just got mine and I'm struggling to find the balance between autoconfigs, mappings, and xpadder Sent from my HTC6535LVW using Tapatalk Use joy to key instead of xpadder, it sucks to convert but it's a much better experience Also after you flash the official, also do the unofficial which allows each port to read as a separate usb. It allows the device to read al the ports individually Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
newoski Posted May 19, 2017 Posted May 19, 2017 The UI looks horrible. Does it allow for shifted functions? IE, hold Button 1 and Button 2 now sends a differnt function?
ulao Posted May 19, 2017 Author Posted May 19, 2017 Few small things to address here. 1. The 4-play fix is a fan project. Not support or endorsed by Bliss-Box in anyway. Soon the new API will fix the ID issues. Maybe this month! 2. RA is a beast in itself. When I said the new firmware now works on it, I only mean that is detects and can be used. As for as setting up goes, that is not anything I can help with. RA does do a few strange things because it was design to be used with many adapters. Since the Bliss-Box is self contained, they are braking the way it is designed to be used. A few things are being address here for that. a) The RA team has a unit and they are looking for a solution, please bug then LOL!https://forums.libretro.com/t/one-of-those-pesky-bliss-box-4-play-users/8815/16 b ) 1.56 and greater has 360/PS3 Mapping mode. This could be used to make the Bliss-Box act like those controllers. So the button layouts are the same. c) The API will allow user configure HID assignments. You can send a simple command to change the mappings on the fly! - should be out soon! If xpadder is an issue report it on the Bliss-Box forums, we need to know when things break?
newoski Posted May 19, 2017 Posted May 19, 2017 On 5/19/2017 at 2:13 PM, ulao said: Few small things to address here. 1. The 4-play fix is a fan project. Not support or endorsed by Bliss-Box in anyway. Soon the new API will fix the ID issues. Maybe this month! 2. RA is a beast in itself. When I said the new firmware now works on it, I only mean that is detects and can be used. As for as setting up goes, that is not anything I can help with. RA does do a few strange things because it was design to be used with many adapters. Since the Bliss-Box is self contained, they are braking the way it is designed to be used. A few things are being address here for that. a) The RA team has a unit and they are looking for a solution, please bug then LOL!https://forums.libretro.com/t/one-of-those-pesky-bliss-box-4-play-users/8815/16 b ) 1.56 and greater has 360/PS3 Mapping mode. This could be used to make the Bliss-Box act like those controllers. So the button layouts are the same. c) The API will allow user configure HID assignments. You can send a simple command to change the mappings on the fly! - should be out soon! If xpadder is an issue report it on the Bliss-Box forums, we need to know when things break? Where can I find more info on the 360 mode? I'll post on the forum about xpadderSent from my HTC6535LVW using Tapatalk
ulao Posted May 19, 2017 Author Posted May 19, 2017 We have a live manual. Any new option that is usable in the latest firmware will be in this doc. You may also be interested in the new save to port feature via eeprom feature.
ninja2bceen Posted May 19, 2017 Posted May 19, 2017 Yes you can do that just fine. You'll want to convert, trust me. I was where you were a year ago and it wasn't working with bliss box. Works great now Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
newoski Posted May 19, 2017 Posted May 19, 2017 I have like 100 systems and have yet to get the BlissBox functioning to the point that it's worth switching. Once I get the BlissBox going, I'll consider it. Think I need to RMA this one, as Port 1 appears to be bad -- based on the troubleshooting steps provided. Are you able to do unique layouts, per controller, per system? IE for Nintendo Entertainment System: NES controller layout SNES controller layout
newoski Posted May 19, 2017 Posted May 19, 2017 Also, after flashing the custom firmware successfully and experimenting for the last 24 hours, my Port1 just completely disappeared. WTF. Reflashing, following the instructions (press button, plug USB, select firmware and ho On 5/19/2017 at 5:42 PM, ulao said: Did all 4 ports before you used the 4-play fix? Expand They worked before, and after. Then, the next day, the Port1 disappeared
newoski Posted May 19, 2017 Posted May 19, 2017 I have tried using the jumper method, to fix the issue, as well. No progress...
iNTiGOD Posted May 20, 2017 Posted May 20, 2017 On 5/19/2017 at 11:01 AM, newoski said: 1. How are you using it? - With xpadder? With joy2key? With autoconfigs? 2. How do you customize the mappings, so different controllers work with different systems? - Right now, I'm running into issues where A/B work on the SNES controller in NES, but then button Y also duplicates a function. Expand Ok let me explain how I set this up. Forgive me because I haven't touched my setup in ages and i'm a little rusty. I have hyperspin and rocketlauncher running on my bartop. I have set it up to use both my ipac (in keyboard mode, for my joysticks, buttons etc) and the 4-play (for original gamepads). For example I can play a NES game using arcade controls or I plug my 4-play in for gamepad controls (but my setup does allow for you to use either of those options at the same time if the 4-play is connected). I setup up my ipac first for each system by selecting "bind mode" in retroarch to "Retrokeyboard". This allowed my to manually configure each keyboard input to my arcade controls. After that was completed I would change "bind mode" in retroarch to "retropad". Retroarch would then recognise gamepad inputs (4-play). The resulting example in the screen shot below shows for the "up" direction it is now configured to use both (-1 [axis] for the gamepad - 4play) and (key 8 for the arcade joystick - ipac). I always configured my controls with "autoconfig" disabled as I ran into some issues. I also needed to obviously save the retroarch config file and rename it to the system name (as per the RL requirements). I have set this up for any system I have controllers for i.e. snes, nes, MD, etc (I have about 50-60 systems setup in hyperspin, but about 10 of them use both the ipac and/or 4-play). I'm not sure these days if autoconfig has simplified the configuration of controllers but I have happy to do everything manually. Lastly, I would also manually go through my retroarch configs and remove any keyboard shortcuts e.g. fast forward or volume increase so that it wouldn't conflict with my ipac keys. I hope this gives you some direction. MAME High Score Tutorial For HyperSpin
newoski Posted May 20, 2017 Posted May 20, 2017 On 5/20/2017 at 2:01 PM, iNTiGOD said: Ok let me explain how I set this up. Forgive me because I haven't touched my setup in ages and i'm a little rusty. I have hyperspin and rocketlauncher running on my bartop. I have set it up to use both my ipac (in keyboard mode, for my joysticks, buttons etc) and the 4-play (for original gamepads). For example I can play a NES game using arcade controls or I plug my 4-play in for gamepad controls (but my setup does allow for you to use either of those options at the same time if the 4-play is connected). I setup up my ipac first for each system by selecting "bind mode" in retroarch to "Retrokeyboard". This allowed my to manually configure each keyboard input to my arcade controls. After that was completed I would change "bind mode" in retroarch to "retropad". Retroarch would then recognise gamepad inputs (4-play). The resulting example in the screen shot below shows for the "up" direction it is now configured to use both (-1 [axis] for the gamepad - 4play) and (key 8 for the arcade joystick - ipac). I always configured my controls with "autoconfig" disabled as I ran into some issues. I also needed to obviously save the retroarch config file and rename it to the system name (as per the RL requirements). I have set this up for any system I have controllers for i.e. snes, nes, MD, etc (I have about 50-60 systems setup in hyperspin, but about 10 of them use both the ipac and/or 4-play). I'm not sure these days if autoconfig has simplified the configuration of controllers but I have happy to do everything manually. Lastly, I would also manually go through my retroarch configs and remove any keyboard shortcuts e.g. fast forward or volume increase so that it wouldn't conflict with my ipac keys. I hope this gives you some direction. Expand Thanks! This all makes sense. Are you not using XBOX360 controllers, as well? If you use RetroPad mapping for BlissBox, it creates issues with XBOX360, since you're changing that mapping... Things get complicated, quickly... My goal is as follows: 1. RetroArch with keyboard mappings for my arcade control panel 2. XBOX360 autoconfig mappings as standard gamepad controller 3. 8BitDo SNES controller for SNES/NES systems, mapped via xpadder, with RetroArch autoconfigs disabled to prevent conflicts 4. BlissBox NES/SNES/GENESIS etc controllers, mapped via xpadder, with RetroArch autoconfigs disabled to prevent conflicts The issues I'm running into are: - Using the custom firmware to stabalize the ports complicates things immediately, because each port has a different USB input name and thus, a single xpadder profile folder won't work. - To solve that, I created xpadder profile folders, in my xpadder system folder (IE Super Nintendo Entertainment System), for each controller (IE 4PLAY PORT, 4PLAY 2, 4PLAY 3, 4PLAY 4) - Using this logic, then each folder would contain one "working" profile and 3 blanks. IE 4PLAY PORT's p1 mapping is active, 4PLAY 2's p2 mapping is active, 4PLAY 3's p3 mapping is active, 4PLAY 4's p4 mapping is active. All other mappings are blanks. This SHOULD work. But it doesn't. Instead, RocketLauncher is assinging the profiles in reverse. I'm still uncertain of the cause of this problem. - As a workaround to the above problem, I created identical profiles for p1, p2, p3, p4 in the 4PLAY PORT folder using the p1 mapping, identical profiles for p1, p2, p3, p4 in the 4PLAY 2 folder using the p2 mapping etc etc. This works, but it's absurdly complicated. From there, the other issues I'm trying to solve are: 1. Using the above logic, how can I customize the layouts between different joypads. For example, the SNES controller's buttons B and A don't work for Nintendo Entertainment System. Instead, buttons Y and B do. This is obviously due to my xpadder layout for the 4PLAY profiles, but the problem is, we can only use one global profile, since the USB device name is the same, no matter what original controller is plugged into the BlissBox... PHEW... that was a lot of typing... Thoughts?
