using parent only / wheels only on nvidia shield Hyperspin
Creezz67
Hi,
Is there some way to make Hyperspin use parent only/wheels only
When I am setting it in HyperHQ it just seems to ignore it and show all clones of every game.
Thanks in advance
The way to do this is generate a new .xml dbase file that removes the clones.   Hyperspin has no clone/parent rom filtering support.
  • 1 year later...
You should check out the thread.
mame clones worth playing: redux
cant link it now on my phone.
that has a recent mame xml with all decent games as parents.
also a program to update.
failing that use Dons Hyperspin Tools or HyperTools in the apps download section
needs a PC setup but you can filter the games list by parents only and add it to an output xml. That output would be the one you want
2 hours ago, thatman84 said:
Failing that use HyperTools in the apps download section
I can install a pc setup if it will get me what i want. Would i be able to create the "classics" xmls with just parents? sorry for all the questions, this is new to me. I was hoping the parent only xmls already existing but i guess not
There prob are some about...but for ease of use moving forward you may want to grab the PC download. You can create these things personal to your setup. You dont need a full blown setup.
Install the tools in your Hyperspin folder and set tour rompaths up. Copy your shield xmls into the databases folder and the tools will the read them and you can filter them as needed
Update @abodetti
See this thread
This post Specifically is a version of .180 (does included clones I believe)
And Dons tools
Use the filter list program
This is the most recent one I know of.
Ver .180 - mame (Phantasy's 7100_no clones_2789 originals).xml
