epicfatigue Posted July 14, 2013 Posted July 14, 2013 Hello Everyone, I am just wanting to know how i can go about getting Hyperspin to launch an exe file for vertical Mame games and another for Horizontal games. My reason is for my rotating monitor i have built a USB rotating system and just want to implement it into my cabinet. This is what the GUI looks like and a demo of the system, You can view the full project here. http://www.hyperspin-fe.com/forum/showthread.php?26691-My-first-Arcade-Build-Rotating-CRT-amp-More
connorsdad Posted July 15, 2013 Posted July 15, 2013 Take a look here: http://forum.arcadecontrols.com/index.php/topic,110471.80.html I followed that thread and now my monitor automatically rotates depending on which rom is loaded. The only thing I'd change is don't put any code directly into the mame module because obviously you will overwrite it when you update. I need to change this myself now I'm using RL, I currently have it inside the module but I'm sure there's a cleaner way for this to work.
djvj Posted July 15, 2013 Posted July 15, 2013 Better way? Yep: https://sites.google.com/site/hyperlaunch2/home/development#TOC-StartGlobalUserFeatures- "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
connorsdad Posted July 15, 2013 Posted July 15, 2013 I tried putting the code into StartGlobalUserFeatures() and StopGlobalUserFeatures() but couldnt get it to work. Here are the lines in red that I originally added to the module to get the auto rotate to work. MEmu = MAME MEmuV = v0.148 MURL = http://www.mame.net/ MAuthor = djvj MVersion = 2.0 MCRC = 2C317D7A iCRC = 8E4C99AB MID = 635038268903403479 MSystem = "Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES" ;---------------------------------------------------------------------------- ; Notes: ; No need to edit mame.ini and set your rom folder, module sends the rompath for you. ; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html ; High Scores DO NOT SAVE when cheats are enabled! ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini") Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1) pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1) ; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1) ; "layout" or "normal" cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1) cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1) ; user defined key to be held down before launching a mame rom. sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1) romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1) mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1) If bezelEnabled = true { ListXMLtable := [] ListXMLtable := ListXMLInfo(romName) } If bezelMode = layout { useBezels := If (bezelEnabled = "true") ? "-use_bezels" : "-nouse_bezels" useOverlays := If (bezelEnabled = "true") ? "-use_overlays" : "-nouse_overlays" useBackdrops := If (bezelEnabled = "true") ? "-use_backdrops" : "-nouse_backdrops" BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4]) } Else { useBezels := "-nouse_bezels" useOverlays := "-nouse_overlays" useBackdrops := "-nouse_backdrops" BezelStart(,,ListXMLtable[2]) } ; -romload part of 147u2 that shows what roms were checked when missing roms winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel" fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window" videomode := If (Videomode != "" ) ? "-video " . videomode : "" sysParams := If sysParams != "" ? sysParams : "" romParams := If romParams != "" ? romParams : "" StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1 ; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms mameRomPaths := "-rompath """ . (If mameRomName ? romPath : mameRomPaths) . """" ; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom If InStr(romParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If InStr(sysParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If mameRomName { FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension% ; rename rom to match what mame needs originalRomName := romName ; store romName from database so we know what to rename it back to later romName := mameRomName If ErrorLevel ScriptError("There was a problem renaming " . romName . " to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8) Else ; if rename was successful, set var so we know to move it back later fileRenamed = 1 } If cheatMode = true { If cheatModeKey ; if user wants to use a key to enable CheatMode cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : "" Else ; no cheat mode key defined cheatEnabled := "-cheat" } [color="#FF0000"]Runwait, %emupath%\Rotation.exe "%romName%"[/color] Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate) If(ErrorLevel != 0){ If (ErrorLevel = 1) Error = Failed Validity Else If(ErrorLevel = 2) Error = Missing Files Else If(ErrorLevel = 3) Error = Fatal Error Else If(ErrorLevel = 4) Error = Device Error Else If(ErrorLevel = 5) Error = Game Does Not Exist Else If(ErrorLevel = 6) Error = Invalid Config Else If ErrorLevel in 7,8,9 Error = Identification Error Else Error = MAME Error ScriptError("MAME Error - " . Error) } WinWait("MAME ahk_class MAME") WinWaitActive("MAME ahk_class MAME") BezelDraw() FadeInExit() Process("WaitClose", executable) [color="#FF0000"]Runwait, %emupath%\Rotation.exe "reset"[/color] BezelExit() If fileRenamed { ; rename file back to alternate name for next launch FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension% If ErrorLevel ; if rename was successful, set var so we know to move it back later ScriptError("There was a problem renaming " . romName . " back to " . originalRomName) } FadeOutExit() ExitModule() ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution Global emuFullPath, emuPath ListXMLtable := [] RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide Fileread, ListxmlContents, %emuPath%\tempBezel.txt RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent) RegExMatch(parent,"cloneof=" . """" . ".*", parent) RegExMatch(parent,"""" . ".*", parent) StringTrimLeft, parent, parent, 1 RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle) RegExMatch(angle,"[0-9]+", angle, "-6") RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width) RegExMatch(width,"[0-9]+", width, "-6") RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height) RegExMatch(Height,"[0-9]+", Height, "-6") ListXMLtable[1] := parent ListXMLtable[2] := angle If (ListXMLtable[2]<>0) ListXMLtable[3] := height Else ListXMLtable[3] := width If (ListXMLtable[2]<>0) ListXMLtable[4] := width Else ListXMLtable[4] := height FileDelete, %emuPath%\tempBezel.txt Return ListXMLtable } HaltEmu: If pauseMethod = 1 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,0x211, 1, , , MAME ahk_class MAME } Else If pauseMethod = 2 { disableSuspendEmu = true PostMessage,0x211, 1, , , MAME ahk_class MAME } Else If pauseMethod = 3 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,% 0x0400+6, 1, , , MAME ahk_class MAME } Else If pauseMethod = 4 { disableSuspendEmu = true PostMessage,% 0x0400+6, 1, , , MAME ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} } Return RestoreEmu: If pauseMethod = 1 { PostMessage,0x212, 1, , , MAME ahk_class MAME WinActivate, MAME ahk_class MAME } Else If pauseMethod = 2 { PostMessage,0x212, 1, , , MAME ahk_class MAME WinActivate, MAME ahk_class MAME } Else If pauseMethod = 3 { PostMessage,% 0x0400+6, 0, , , MAME ahk_class MAME WinActivate, MAME ahk_class MAME } Else If pauseMethod = 4 { PostMessage,% 0x0400+6, 0, , , MAME ahk_class MAME WinActivate, MAME ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} WinActivate, MAME ahk_class MAME } Else If pauseMethod = 6 WinActivate, MAME ahk_class MAME Return CloseProcess: FadeOutStart() WinClose("MAME ahk_class MAME") Return Not sure if its needed but here is the rotate.ahk to see whats going on. ;[Rotation.exe] ; ; #SingleInstance force romName = %1% If ((romName = "ace") | (romName = "maze") | (romName = "bang") | (romName = "batman") | (romName = "blasto") | (romName = "bullfgt") | (romName = "cannball") | (romName = "circus") | (romName = "combat") | (romName = "cotton") | (romName = "smash") | (romName = "dday") | (romName = "zero") | (romName = "edf") | (romName = "esb") | (romName = "flyball") | (romName = "gaia") | (romName = "galaxi") | (romName = "gng") | (romName = "grdnstrm") | (romName = "headon") | (romName = "car2") | (romName = "hustle") | (romName = "island") | (romName = "island2") | (romName = "joust") | (romName = "eto") | (romName = "le2") | (romName = "msh") | (romName = "mk") | (romName = "mk2") | (romName = "news") | (romName = "orbit") | (romName = "pass") | (romName = "pgm") | (romName = "phrcraze") | (romName = "popeye") | (romName = "kok") | (romName = "spy") | (romName = "safari") | (romName = "sonic") | (romName = "skyraid") | (romName = "sss") | (romName = "sf") | (romName = "roul") | (romName = "jleague") | (romName = "atetris") | (romName = "tetris") | (romName = "tictac") | (romName = "toki") | (romName = "tm") | (romName = "statriv2") | (romName = "vf") | (romName = "vr") | (romName = "topgun") | (romName = "ws") | (romName = "swa")) { goto horizontalrotation } param := "%romName%" ;reads verticalRoms controlled roms list IniRead, verticalRoms, %A_ScriptDir%\Rotation.ini, controls, Set2_vertical ;reads state of vertical, horizontal rotation (user added line in "controls.ini") iniread, state, %a_scriptdir%\Rotation.ini, Controls, PrevState ifnotinstring, verticalRoms, %romname%, gosub, horizontalrotation verticalrotation: if ( State = "vertical") { exitapp } else if ( State = "horizontal") { Run, %COMSPEC% /c "smccmd --resume --speed 2050", ,{enter},hide ;run C:\Program Files (x86)\iRotate\irotate.exe /1:rotate=90 iniwrite, vertical, C:\HyperSpin\Emulators\MAME\Rotation.ini, controls, PrevState exitapp } horizontalrotation: if ( State = "horizontal" ) { exitapp } else if ( State = "vertical") { Run, %COMSPEC% /c "smccmd --resume --speed -2050", ,{enter},hide ;run C:\Program Files (x86)\iRotate\irotate.exe /1:rotate=0 iniwrite, horizontal, C:\HyperSpin\Emulators\MAME\Rotation.ini, controls, PrevState exitapp } Last but not least my log. 16:59:57:572 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.7 16:59:57:573 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin\HyperLaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: 0409 OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) Monitor #2 (\\.\DISPLAY2): 3200x1024 (3200x1024 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 16:59:57:573 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080 16:59:57:573 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\HyperLaunch.exe exists 16:59:57:574 | HL | INFO | +0 | Main - HyperLaunch received "MAME" and "1944" 16:59:57:583 | HL | INFO | +15 | Main - 1944 is using the default emulator: MAME 16:59:57:583 | HL | INFO | +0 | Main - Checking for a [MAME] section in C:\HyperSpin\HyperLaunch\Settings\MAME\Emulators.ini 16:59:57:583 | HL | INFO | +0 | Main - Checking for a [MAME] section in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini 16:59:57:584 | HL | INFO | +0 | Main - Found [MAME] in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini 16:59:57:584 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk exists 16:59:57:591 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 16:59:57:591 | HL | INFO | +0 | Main - 1944 will use module: C:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk 16:59:57:608 | HL | INFO | +16 | Main - INI Keys read 16:59:57:608 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists 16:59:57:611 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists 16:59:57:611 | HL | INFO | +0 | CreateRomMapTable - Started 16:59:57:611 | HL | INFO | +0 | CreateRomMapTable - Could not find any roms for the Rom Map Table 16:59:57:611 | HL | INFO | +0 | CreateRomMapTable - Ended, No mapping inis found. 16:59:57:611 | HL | INFO | +0 | CheckPaths - Started 16:59:57:611 | HL | INFO | +0 | CheckPaths - Found rom: C:\HyperSpin\Emulators\MAME\roms\1944.zip 16:59:57:611 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Emulators\MAME\mame64.exe exists 16:59:57:611 | HL | INFO | +0 | CheckPaths - Ended 16:59:57:613 | HL | INFO | +16 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 frontendPID = 2868 frontendPath = C:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = true exitScriptKey = ~[ & ~] emuFullPath = C:\HyperSpin\Emulators\MAME\mame64.exe emuPath = C:\HyperSpin\Emulators\MAME emuName = MAME emuExt = exe romPath = C:\HyperSpin\Emulators\MAME\roms romPathFromIni = C:\HyperSpin\Emulators\MAME\roms romExtension = .zip romExtensionOrig = .zip romExtensions = zip|7z|chd executable = mame64.exe systemName = MAME dbName = 1944 romName = romMapPath = C:\HyperSpin\HyperLaunch\Settings\MAME\Rom Mapping romMappingEnabled = true romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = true romMappingShowAllRomsInArchive = false romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = False romMatchExt = true logFile = C:\HyperSpin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 3 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up|R navDownKey = Down|F navLeftKey = Left navRightKey = Right navSelectKey = Enter originalWidth = 1920 originalHeight = 1080 dtEnabled = true dtPath = dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = true hideFE = true fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 0 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\HyperSpin\HyperLaunch\Media\Fade HLDataPath = C:\HyperSpin\HyperLaunch\Data HLMediaPath = C:\HyperSpin\HyperLaunch\Media HLErrSoundPath = C:\HyperSpin\HyperLaunch\Media\Sounds\Error modulesPath = C:\HyperSpin\HyperLaunch\Modules moduleFullName = C:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk moduleName = MAME modulePath = C:\HyperSpin\HyperLaunch\Modules\MAME moduleExtension = ahk moduleExtensionsPath = C:\HyperSpin\HyperLaunch\Module Extensions libPath = C:\HyperSpin\HyperLaunch\Lib 7zEnabled = false 7zPath = C:\HyperSpin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = C:\HyperSpin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\Mark\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 1 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up} hpLoadStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up} keymapperEnabled = false keymapper = ahk xpadderFullPath = C:\HyperSpin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\HyperSpin\HyperLaunch\Profiles\ahk keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\HyperSpin defaultProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\_Default systemProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\MAME xPadderSystemProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\MAME\_Default emuProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\MAME\MAME romProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\MAME\1944 blankProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\blank HyperLaunchProfile = C:\HyperSpin\HyperLaunch\Profiles\ahk\HyperLaunch bezelEnabled = false statisticsEnabled = true 16:59:57:613 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 16:59:57:613 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 16:59:57:613 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 16:59:57:613 | HL | INFO | +0 | BuildScript - Module: MEmu = MAME MEmuV = v0.148 MURL = http://www.mame.net/ MAuthor = djvj MVersion = 2.0.1 MCRC = EEC5F04B iCRC = 8E4C99AB MID = 635038268903403479 MSystem = "Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES" ;---------------------------------------------------------------------------- ; Notes: ; No need to edit mame.ini and set your rom folder, module sends the rompath for you. ; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html ; High Scores DO NOT SAVE when cheats are enabled! ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini") Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1) pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1) ; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1) ; "layout" or "normal" cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1) cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1) ; user defined key to be held down before launching a mame rom. sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1) romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1) mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1) If bezelEnabled = true { ListXMLtable := [] ListXMLtable := ListXMLInfo(romName) } If bezelMode = layout { useBezels := If (bezelEnabled = "true") ? "-use_bezels" : "-nouse_bezels" useOverlays := If (bezelEnabled = "true") ? "-use_overlays" : "-nouse_overlays" useBackdrops := If (bezelEnabled = "true") ? "-use_backdrops" : "-nouse_backdrops" BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4]) } Else { useBezels := "-nouse_bezels" useOverlays := "-nouse_overlays" useBackdrops := "-nouse_backdrops" BezelStart(,,ListXMLtable[2]) } ; -romload part of 147u2 that shows what roms were checked when missing roms winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel" fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window" videomode := If (Videomode != "" ) ? "-video " . videomode : "" sysParams := If sysParams != "" ? sysParams : "" romParams := If romParams != "" ? romParams : "" StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1 ; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms mameRomPaths := "-rompath """ . (If mameRomName ? romPath : mameRomPaths) . """" ; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom If InStr(romParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If InStr(sysParams,"-rompath") ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.") If mameRomName { FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension% ; rename rom to match what mame needs originalRomName := romName ; store romName from database so we know what to rename it back to later romName := mameRomName If ErrorLevel ScriptError("There was a problem renaming " . romName . " to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8) Else ; if rename was successful, set var so we know to move it back later fileRenamed = 1 } If cheatMode = true { If cheatModeKey { ; if user wants to use a key to enable CheatMode ; cheatEnabled := ; cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : "" Loop 5 { Sleep, 500 cheatEnabled := XHotkeyAllKeysPressed(cheatModeKey) tooltip, Index: %A_Index%`ncheatEnabled: %cheatEnabled% Sleep, 500 } msgbox cheatModeKey: %cheatModeKey%`n cheatEnabled: %cheatEnabled% ExitApp } Else ; no cheat mode key defined cheatEnabled := "-cheat" } Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate) If(ErrorLevel != 0){ If (ErrorLevel = 1) Error = Failed Validity Else If(ErrorLevel = 2) Error = Missing Files Else If(ErrorLevel = 3) Error = Fatal Error Else If(ErrorLevel = 4) Error = Device Error Else If(ErrorLevel = 5) Error = Game Does Not Exist Else If(ErrorLevel = 6) Error = Invalid Config Else If ErrorLevel in 7,8,9 Error = Identification Error Else Error = MAME Error ScriptError("MAME Error - " . Error) } WinWait("ahk_class MAME") WinWaitActive("ahk_class MAME") BezelDraw() FadeInExit() Process("WaitClose", executable) BezelExit() If fileRenamed { ; rename file back to alternate name for next launch FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension% If ErrorLevel ; if rename was successful, set var so we know to move it back later ScriptError("There was a problem renaming " . romName . " back to " . originalRomName) } FadeOutExit() ExitModule() ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution Global emuFullPath, emuPath ListXMLtable := [] RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide Fileread, ListxmlContents, %emuPath%\tempBezel.txt RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent) RegExMatch(parent,"cloneof=" . """" . ".*", parent) RegExMatch(parent,"""" . ".*", parent) StringTrimLeft, parent, parent, 1 RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle) RegExMatch(angle,"[0-9]+", angle, "-6") RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width) RegExMatch(width,"[0-9]+", width, "-6") RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height) RegExMatch(Height,"[0-9]+", Height, "-6") ListXMLtable[1] := parent ListXMLtable[2] := angle If (ListXMLtable[2]<>0) ListXMLtable[3] := height Else ListXMLtable[3] := width If (ListXMLtable[2]<>0) ListXMLtable[4] := width Else ListXMLtable[4] := height FileDelete, %emuPath%\tempBezel.txt Return ListXMLtable } HaltEmu: If pauseMethod = 1 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,0x211, 1, , , ahk_class MAME } Else If pauseMethod = 2 { disableSuspendEmu = true PostMessage,0x211, 1, , , ahk_class MAME } Else If pauseMethod = 3 { disableSuspendEmu = true disableRestoreEmu = true PostMessage,% 0x0400+6, 1, , , ahk_class MAME } Else If pauseMethod = 4 { disableSuspendEmu = true PostMessage,% 0x0400+6, 1, , , ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} } Return RestoreEmu: If pauseMethod = 1 { PostMessage,0x212, 1, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 2 { PostMessage,0x212, 1, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 3 { PostMessage,% 0x0400+6, 0, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 4 { PostMessage,% 0x0400+6, 0, , , ahk_class MAME WinActivate, ahk_class MAME } Else If pauseMethod = 5 { disableSuspendEmu = true Send, {P down} Sleep, 1000 Send, {P up} WinActivate, ahk_class MAME } Else If pauseMethod = 6 WinActivate, ahk_class MAME Return CloseProcess: FadeOutStart() WinClose("ahk_class MAME") Return 16:59:57:616 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 16:59:57:616 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 16:59:57:616 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 16:59:57:616 | HL | INFO | +0 | Main - Module is built 16:59:57:616 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\AutoHotkey.dll exists 16:59:57:625 | HL | INFO | +0 | Main - Hiding taskbar 16:59:57:840 | HL | INFO | +218 | Main - Hiding desktop 16:59:57:855 | HL | INFO | +16 | Main - Running module 17:00:05:906 | HL | INFO | +8049 | Main - Module ended, exiting HyperLaunch normally 17:00:05:906 | HL | INFO | +0 | ExitScript - Started 17:00:06:388 | HL | INFO | +484 | SystemCursor - Restoring mouse cursor 17:00:06:396 | HL | INFO | +15 | ExitScript - Ended
bleasby Posted July 15, 2013 Posted July 15, 2013 you will need something like: StartGlobalUserFeatures(){ Global emupath, romName Runwait, %emupath%\Rotation.exe "%romName%" return } and StopGlobalUserFeatures(){ Global emupath Runwait, %emupath%\Rotation.exe "reset" return } Be aware that this is a non tested code. Just try that and use tooltips to see if everything works as it should When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
connorsdad Posted July 15, 2013 Posted July 15, 2013 It shows me the fade in loading screen with a tool tip thats shows "index:1" which counts up to "index:5", also in the tooltip is "cheatenabled:0". Once its counted to "index:5" it does nothing and I have to exit out.
connorsdad Posted July 27, 2013 Posted July 27, 2013 Still can't find a way of incorporating these lines of code without editing the module
djvj Posted July 27, 2013 Posted July 27, 2013 How can you not find a way, we already gave you the answer above. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
connorsdad Posted July 27, 2013 Posted July 27, 2013 I tried adding code where you said and I can't get it to work.
sandman7793 Posted July 27, 2013 Posted July 27, 2013 It shows me the fade in loading screen with a tool tip thats shows "index:1" which counts up to "index:5", also in the tooltip is "cheatenabled:0". Once its counted to "index:5" it does nothing and I have to exit out. You sure you have the newest module because my mame was doing that and djvj had some debugging code enabled, the next day he fixed that.. It did exactly this until I updated... A boy stuck in a mans body
Drkdweller Posted July 27, 2013 Posted July 27, 2013 how does it know what games to rotate, is that a setting in mame it looks for, or is it on its own wheel?
bleasby Posted July 27, 2013 Posted July 27, 2013 I don't know how everybody else does, but if you take a look at the mame module, I wrote a function named ListXMLInfo that can give you the game orientation based on the listxml file that MAME creates. ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution You could use the same function, by simply adding these lines to a ahk script. ListXMLtable := [] ListXMLtable := ListXMLInfo(romName) RotationAngle := ListXMLtable[2] When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
connorsdad Posted July 27, 2013 Posted July 27, 2013 You sure you have the newest module because my mame was doing that and djvj had some debugging code enabled, the next day he fixed that.. It did exactly this until I updated... It works now Cheers sandman I just hope it wont affect my other systems as this code is global. Edit It affects other systems, back to the drawing board
bleasby Posted July 27, 2013 Posted July 27, 2013 just add a conditional to work only on the systems that you want. something like: StartGlobalUserFeatures(){ Global emupath, romName, systemName if systemName="MAME" Runwait, %emupath%\Rotation.exe "%romName%" return } When asking for help for RocketLauncher, POST ON THE RLAUNCHER.NET FORUMS! Also, please post your RocketLauncher.log with logging level set to troubleshooting in pastebin (set the log level in RocketLauncherUI, global system > General Settings -> RocketLauncher). Ass. Bleasby - RocketLauncher Development Team.
connorsdad Posted July 27, 2013 Posted July 27, 2013 just add a conditional to work only on the systems that you want.something like: StartGlobalUserFeatures(){ Global emupath, romName, systemName if systemName=[color="#FF0000"]"[/color]MAME[color="#FF0000"]"[/color] Runwait, %emupath%\Rotation.exe "%romName%" return } Just had to remove the quotation marks and it works , thank you.
sandman7793 Posted July 27, 2013 Posted July 27, 2013 Glad you got it. Had me baffled for a couple days.. A boy stuck in a mans body
USRFobiwan Posted June 21, 2014 Posted June 21, 2014 I have combine the functions to handle the rotation of the monitor if there is a vertical rom selected within hyperspin MAME. I use the listXMLinfo function mentioned by Bleasby a couple of reply's above. In the logs its working very good. With this you do not have to make a vertical or horizontal gamelist for MAME. It reads it from the listXMLinfo. It's still in test phase but maybe people with rotating monitors using SMCMD or people using iRotate (or both) can test the scripts since my rotating arcrade cab is not finished yet so I cannot test. UPDATE: Added some logging to the roation.ahk and optimized the userFunctions to see all others then RotationAngle=0 as vertical UPDATE: 06-21-14: fixed error on ListXMLinfo when launching emulator other then mame. Added %zz% wildcard trick to ListXMLinfo() function UserFunctions.ahk ( located in hyperspin/hyperlaunch/lib/ ) ; Use this function to define any code you want to run in every module on start StartGlobalUserFeatures(){ Log("############### START USERFUNCTIONS ##############") Log("StartGlobalUserFeatures - Starting") Global emupath, romName, systemName If ( systemName = "MAME" ){ ListMameTable := [] ListMameTable := ListXMLInfo%zz%(romName) RotationAngle := ListMameTable[2] Rotation := 0 ;0 = horizontal Log("USER Function - Rotation:" . RotationAngle . " ROM:" . romName) If (RotationAngle != "0"){ Rotation :=1 Log("USER Functions - Rotating Vertical") } Runwait, %emupath%\Rotation.exe %Rotation% Log("USER Functions - Rotation.exe Executed") return } Log("StartGlobalUserFeatures - Ending") } ; Use this function to define any code you may need to stop or clean up in every module on exit StopGlobalUserFeatures(){ Log("############### STOP USERFUNCTIONS ##############") Log("StopGlobalUserFeatures - Starting") Global emupath, systemName If ( systemName = "MAME" ) { ;REMARK below if you want to prevent turning back to horizontal state: RotHor := 0 Runwait, %emupath%\Rotation.exe %RotHor% Log("USER Function - Rotation.exe back to horizontal") return } Log("StopGlobalUserFeatures - Ending") } It fires the rotation.exe (compiled ahk) in the hyperspin\emulators\mame\ mame*.exe root if you want to turn the monitor back to horizontal position umremark the runwait in the StopGlobalUserFeatures function The source for Rotation.exe/ahk that is fired by UserFunctions.ahk ;[Rotation.exe] #SingleInstance force SetWorkingDir %A_ScriptDir% ;parsed value from UserFunctions.ahk Rotation = %1% ;read Current state iniread, state, %A_scriptdir%\Rotation.ini, Controls, PrevState If ( Rotation = 0) { iniwrite, "Selected horizontal game", %A_scriptdir%\Rotation.ini, log, rotlog goto horizontalRotation } Else If (Rotation = 1) { iniwrite, "Selected Vertical game", %A_scriptdir%\Rotation.ini, log, rotlog goto verticalRotation } verticalRotation: If ( state = 1) { ; Monitor already vertical position. iniwrite, "vertical state was 1", %A_scriptdir%\Rotation.ini, log, loging exitapp } Else If ( state = 0) { ; Rotate monitor to vertical position: ;Run, %COMSPEC% /c "smccmd --resume --speed -530", ,{enter},hide ;Or/And use iRotate: ; Run, irotate.exe /rotate=90 ; Write rotation state: iniwrite, 1, %A_scriptdir%\Rotation.ini, controls, PrevState iniwrite, "vertical state was 0", %A_scriptdir%\Rotation.ini, log, loging exitapp } horizontalRotation: If ( state = 0) { ; Monitor already horizontal position. iniwrite, "horizontal state was 0", %A_scriptdir%\Rotation.ini, log, loging exitapp } Else If( state = 1) { ; Rotate monitor to horizontal position: ;Run, %COMSPEC% /c "smccmd --resume --speed 520", ,{enter},hide ;Or/And use iRotate: ; Run, irotate.exe /rotate=90 ; Write rotation state: iniwrite, 0, %A_scriptdir%\Rotation.ini, controls, PrevState iniwrite, "horizontal state was 1", %A_scriptdir%\Rotation.ini, log, loging exitapp } You also need a rotationstate.ini in the hyperspin\emulators\mame\ mame*.exe root to read/write the state the monitor is in ( vertical OR horizontal = 1 OR 0 ): [Controls] PrevState=1 [log] loging="vertical state was 1" rotlog="Selected Vertical game" You also have to set the rotation mode in MAME.ini which way the scree rotates. set autoror to 1 if you want the screen to be displayed ClockWise. set the autorol to 1 if you want to screen to be displayed CounterClockwise. # # CORE ROTATION OPTIONS # autoror 0 autorol 1 Please test or if you are an AHK guru please let me know how to improve the code.
USRFobiwan Posted July 12, 2014 Posted July 12, 2014 Finally had the time to let the above script do the work on my WIP slimline arcade build. I use a controller and motor from Pololu to turn the 24" LCD screen. The code works flawlessly and turning the monitor if a mame rom is vertical based, and turning back to horizontal when 'escaping' the emulator. So no need for vertical or horizontal lists anymore it is all auto-detecting. If you also do NEO-GEO in MAME it will turn those also, With a little bit of code exploration I can probably turn the monitor for Taito Type X vertical games based on the same userfunction.ahk script. But probably need the TTX games manualy bases on the game name. To make a long story short. It works!
connorsdad Posted July 12, 2014 Posted July 12, 2014 For TTX and any other vertical games such as the naomi ones I have a simple script that rotates the screen before launching the game and another script that rotates the screen back on exit.
USRFobiwan Posted July 12, 2014 Posted July 12, 2014 Are you willing to share? I want to know how to fire the rotate commands before and after TTX launches.
connorsdad Posted July 12, 2014 Posted July 12, 2014 Are you willing to share? I want to know how to fire the rotate commands before and after TTX launches. Rotate run C:\HyperSpin\HyperLaunch\Module Extensions\iRotate.exe /1:rotate=180 run smccmd --resume --speed 2250,,Hide Return run C:\HyperSpin\HyperLaunch\Module Extensions\iRotate.exe /1:rotate=0 /exit run smccmd --resume --speed -2250,,Hide run C:\HyperSpin\HyperLaunch\Module Extensions\bring back focus.ahk Bring back focus.ahk <-- Only required for raiden IV Process, Exist, Hyperspin.exe frontendPID := ErrorLevel ControlClick, , ahk_pid %frontendPID% sleep, 2000 MouseClick, left The rotate.ahk would go in the Prelaunch box and return.ahk would go in the postexit box.
USRFobiwan Posted July 13, 2014 Posted July 13, 2014 For everyone who struggles with this. I extended the /hyperlaunch/lib/user functions.ahk script for Taito Type X vertical games. It now supports auto vertical detection for mame and TTX games (see previous post of mine) Change /hyperlaunch/lib/user functions.ahk script to this: ; Use this function to define any code you want to run in every module on start StartGlobalUserFeatures(){ Log("############### START USERFUNCTIONS ##############") Log("StartGlobalUserFeatures - Starting") Global emupath, romName, systemName, dbName, moduleExtensionsPath rotation:=0 ;0 = horizontal Log("USER Function - System NAME:" . systemName) Log("USER Function - ROM NAME:" . romName) Log("USER Function - DB NAME:" . dbName) If ( systemName = "MAME" ){ Log("USER Function - MAME - ROM:" . romName) ListMameTable := [] ListMameTable := ListXMLInfo%zz%(romName) RotationAngle := ListMameTable[2] Log("USER Function - Rotation:" . RotationAngle . " ROM:" . romName) If (RotationAngle != "0"){ Rotation :=1 Log("USER Functions - Rotating Vertical") } Runwait, %emupath%\Rotation.exe %Rotation% Log("USER Functions - Rotation.exe Executed") } else if ( systemName = "SNK Neo Geo" ){ Log("USER Function - NEOGEO - ROM:" . romName) } else if ( systemName = "Taito Type X" ){ Log("USER Function - TTX - ROM:" . romName) ;Vertical game list: if( romName = "Homura" || romName = "Shikigami no Shiro III" || "Raiden III" || "Raiden IV" ){ Log("USER Function - TTX - Vertical switch:" . romName) Rotation:=1 TTXRotation := moduleExtensionsPath . "\TTX-Rotation.ahk" RunWait, %TTXRotation% %Rotation% %romName% } } Log("StartGlobalUserFeatures - Ending") } ; Use this function to define any code you may need to stop or clean up in every module on exit StopGlobalUserFeatures(){ Log("############### STOP USERFUNCTIONS ##############") Log("StopGlobalUserFeatures - Starting") Global emupath, systemName, romName, dbName, moduleExtensionsPath Rotation:=0 Log("USER Function - System NAME:" . systemName) Log("USER Function - ROM NAME:" . romName) Log("USER Function - DB NAME:" . dbName) If ( systemName = "MAME" ) { ;REMARK below if you want to prevent turning back to horizontal state: Runwait, %emupath%\Rotation.exe %Rotation% Log("USER Function - Rotation.exe back to horizontal") } else if ( systemName = "Taito Type X" ){ Log("USER Function - Taito Type X- Return horizontal:" .dbName) Rotation:=0 TTXRotation := moduleExtensionsPath . "\TTX-Rotation.ahk" RunWait, %TTXRotation% %Rotation% } Log("StopGlobalUserFeatures - Ending") } Now add following script to the /hyperlaunch/module extensions/ directory: TTX-Rotation.ahk ;[TTX-Rotation] #SingleInstance force SetWorkingDir %A_ScriptDir% ;parsed value from UserFunctions.ahk Rotation = %1% TTXgame = %2% iniwrite, %TTXgame%, %A_scriptdir%\ttxrotation.ini, ROTATION, Game iniwrite, %Rotation%, %A_scriptdir%\ttxrotation.ini, ROTATION, Mode If ( Rotation = 0) { goto horizontalRotation } Else If (Rotation = 1) { goto verticalRotation } verticalRotation: iniwrite, "switch vertical", %A_scriptdir%\ttxrotation.ini, ROTATION, Switch ; Rotate monitor to vertical position: ;Run, %COMSPEC% /c "smccmd --resume --speed -530", ,{enter},hide ;Or/And use iRotate: Run %comspec% /c "irotate.exe /1:rotate=180 /exit" exitapp horizontalRotation: iniwrite, "switch horizontal", %A_scriptdir%\ttxrotation.ini, ROTATION, Switch ; Rotate monitor to horizontal position: ;Run, %COMSPEC% /c "smccmd --resume --speed 520", ,{enter},hide ;Or/And use iRotate: Run %comspec% /c "irotate.exe /1:rotate=0 /exit" iniwrite, "switch horizontal", %A_scriptdir%\ttxrotation.ini, ROTATION, Switch exitapp I also added a ttxrotation.ini to log ttxrotation.ahk settings to, you can use it to hold a state if you want, or remark the initwrite lines if you do not want it Place it in the /hyperlaunch/module extensions/ directory: ttxrotation.ini [PRELAUNCH] Game= Mode=0 Switch="switch horizontal" Test and enjoy!
