Strange little issue?...
sennerz
Hi guys,
I have a strange little issue...
I have HS setup and working perfectly for all my systems running via RetroArch, except one that seems to have acquired a little problem all on its own. For some reason when RocketLauncher opens the Mame Core, it does so behind HyperSpin.... or RocketLauncherUI. All other RetroArch cores open fine, infront of HS/RLUI.
It's probably a little setting somehwhere, it may have actually happened when I updated RL, I'm not quite sure as I haven't used this build for a while.
I've searched and searched but couldn't find an answer so here I am....
Any help form the pro's would be greatly appreciated.
Thanks
Andy
You could check the Desktop settings in RLUI on the settings tab, maybe one of those is different.
I did check those. They're all set the same throughout. 'Use Global'
RA sucks for mame. I would recommend going standalone on that.
Great advice.
Yes. And you're stuck with the annoying nag screens too. I recommend the no nag compiled version in the download section.
Thanks guys.
I have a build on a dedicated PC which is huge and run Mame 0.163 on there. However this is a stripped down version I've put on a Lynx Vision Tablet/Hand Held running Windows 10. I've actually had more success with the Mame core via RA than with Mame (Proper) to be honest.
Both worked fine initially so I stuck with RA as all the other systems on this stripped down version are run through RA. However, I just started the thing up for the first time in a while and it just got stuck behind HS. I updated RL but can't remember if that was before or after the issue.
