HyperLaunchHQ don't save exit emulator key
fuzzi23
If I add a new key in General Settings>Controls>Exit Emulator Key, the new key works fine, but only for some times. After a couple of times (2 or 3) I use the new key, the key has no longer any effect until I restart Windows. Then it repeats, works 2 or 3 times and then it has no longer any effect until I restart Windows. It works for me fine for a long time, but now it makes trouble.
This seems like strange behavior. Is there any logging information your can provide. Specifically a log from when it works, and then one from when it does not work.
Yes it's strange. Forgot to say: I make a test for this, I totaly delete HS + HL and set it up from scratch only with zsnes to test it and make sure there is nothing other that can cause this issue. Also, the new key entry stays in HL if it not works. HL don't kick the entry from the key list, it only don't works then. Also want to say I try all this on my desktop PC and there it's the same issue.
Ok, I make a clear new log. I try with Mr. Nutz Rom. Three times the "F" key works, the 4th time it refuses. If I delete the "F" key and set it again, it works again for 2 or 3 times. Here the log:
00:41:16:453 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.0.9
00:41:16:453 | HL |     INFO  | +0     | Main - System Specs:
				HyperLaunch Dir: D:\---\Hyperspin\HyperLaunch
				OS: WIN_XP
				Architecture: 32-bit (might not be accurate)
				OS Language: German_Standard
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 1680x1050 (1680x1050 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
00:41:16:453 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1680 h1050
00:41:16:453 | HL |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\HyperLaunch\HyperLaunch.exe exists
00:41:16:453 | HL |     INFO  | +0     | Main - HyperLaunch received "Super Nintendo Entertainment System" and "Mr. Nutz"
00:41:16:468 | HL |     INFO  | +16    | Main - Mr. Nutz is using the default emulator: ZSNESw
00:41:16:468 | HL |     INFO  | +0     | Main - Checking for a [ZSNESw] section in D:\---\Hyperspin\HyperLaunch\Settings\Super Nintendo Entertainment System\Emulators.ini
00:41:16:468 | HL |     INFO  | +0     | Main - Checking for a [ZSNESw] section in D:\---\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
00:41:16:468 | HL |     INFO  | +0     | Main - Found [ZSNESw] in D:\---\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
00:41:16:468 | HL |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk exists
00:41:16:484 | HL |  WARNING  | +15    | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk.
00:41:16:484 | HL |     INFO  | +0     | Main - Mr. Nutz will use module: D:\---\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk
00:41:16:500 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
00:41:16:500 | HL |     INFO  | +0     | Main - INI Keys read
00:41:16:500 | HL |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
00:41:16:500 | HL |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
00:41:16:500 | HL |     INFO  | +0     | CheckPaths - Started
00:41:16:500 | HL |     INFO  | +0     | CheckPaths - Found rom: D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Mr. Nutz.smc
00:41:16:500 | HL |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe exists
00:41:16:500 | HL |     INFO  | +0     | CheckPaths - Ended
00:41:16:500 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				frontendPID = 4012
				frontendPath = D:\---\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = ~Esc|F
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				emuFullPath = D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe
				emuPath = D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System
				emuName = ZSNESw
				emuExt = exe
				romPath = D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms
				romPathFromIni = D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms
				romExtension = .smc
				romExtensionOrig = .smc
				romExtensions = 7z|zip|sfc|smc
				executable = zsnesw.exe
				systemName = Super Nintendo Entertainment System
				dbName = Mr. Nutz
				romName =
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				logFile = D:\---\Hyperspin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1680
				originalHeight = 1050
				dtEnabled = true
				dtPath = C:\Programme\DAEMON Tools Lite\DTLite.exe
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\---\Hyperspin\HyperLaunch\Media\Fade
				HLDataPath = D:\---\Hyperspin\HyperLaunch\Data
				HLMediaPath = D:\---\Hyperspin\HyperLaunch\Media
				HLErrSoundPath = D:\---\Hyperspin\HyperLaunch\Media\Sounds\Error
				modulesPath = D:\---\Hyperspin\HyperLaunch\Modules
				moduleFullName = D:\---\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk
				moduleName = ZSNESw
				modulePath = D:\---\Hyperspin\HyperLaunch\Modules\ZSNESw
				moduleExtension = ahk
				moduleExtensionsPath = D:\---\Hyperspin\HyperLaunch\Module Extensions
				libPath = D:\---\Hyperspin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = D:\---\Hyperspin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = D:\---\Hyperspin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Dokumente und Einstellungen\Steve\Lokale Einstellungen\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 1
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\---\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapper = ahk
				xpadderFullPath = D:\---\Hyperspin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = D:\---\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = D:\---\Hyperspin\HyperLaunch\Profiles\ahk
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\HyperSpin
				defaultProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\_Default
				systemProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System
				xPadderSystemProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System\_Default
				emuProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System\ZSNESw
				romProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System\Mr. Nutz
				blankProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\blank
				HyperLaunchProfile = D:\---\Hyperspin\HyperLaunch\Profiles\ahk\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
00:41:16:500 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
00:41:16:500 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
00:41:16:500 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
00:41:16:515 | HL |     INFO  | +16    | BuildScript - Module:
				MEmu = ZSNESw
				MEmuV =  v1.51
				MURL = http://www.zsnes.com/
				MAuthor = djvj
				MVersion = 2.0
				MCRC = 90F089AF
				iCRC = 3B0E8F48
				MID = 635038268938832977
				MSystem = "Super Nintendo Entertainment System"
				; Notes:
				; Make sure you set quickexit to your Exit_Emulator_Key key while in ZSNES.
				; If you want to use Esc as your quick exit key, open zsnesw.cfg with a text editor and find the lines below.
				; Set KeyQuickExit to 1, as shown below. You can't set the quick exit key to escape while in the emulator, because that's the exit key to configuring keys.
				; Quit ZSNES / Load Menu / Reset Game / Panic Key
				; KeyQuickExit=1
				; KeyQuickLoad=0
				; KeyQuickRst=0
				; KeyResetAll=42
				StartModule()
				FadeInStart()
				Stretch := IniReadCheck(settingsFile, "Settings", "Stretch","true",,1)
				resX := IniReadCheck(settingsFile, "Settings", "resX","1280",,1)
				resY := IniReadCheck(settingsFile, "Settings", "resY","1024",,1)
				DisplayRomInfo := IniReadCheck(settingsFile, "Settings", "DisplayRomInfo","false",,1)	; Display rom info on load along bottom of screen
				SetKeyDelay, 50
				zsnesFile := CheckFile(emuPath . "\zsnesw.cfg")
				FileRead, zsnesCfg, %zsnesFile%
				xLine := TF_Find(zsnesCfg,"","","CustomResX=") ; find location in zsnes cfg where it stores its custom X res
				yLine := TF_Find(zsnesCfg,"","","CustomResY=") ; find location in zsnes cfg where it stores its custom Y res
				modeLine := TF_Find(zsnesCfg,"","","cvidmode=") ; find location in zsnes cfg where it stores its custom vid mode
				zsnesCfg := TF_ReplaceLine(zsnesCfg,xLine,xLine,"CustomResX=" . resX) ; update custom X res in zsnes cfg file
				zsnesCfg := TF_ReplaceLine(zsnesCfg,yLine,yLine,"CustomResY=" . resY) ; update custom Yres in zsnes cfg file
				If ( Fullscreen = "true" && Stretch = "true" ) ; sets fullscreen, stretch, and filter support
					vidMode = 39
				Else If ( Fullscreen = "true" && Stretch != "true" ) ; sets fullscreen, correct aspect ratio, and filter support
					vidMode = 42
				Else ; sets windowed mode with filter support
					vidMode = 38
				zsnesCfg := TF_ReplaceLine(zsnesCfg,modeLine,modeLine,"cvidmode=" . vidMode) ; update custom vid mode in zsnes cfg file
				; Setting DisplayRomInfo setting in cfg if it doesn't match what user wants above
				currentDRI := (InStr(zsnesCfg, "DisplayInfo=1") ? ("true") : ("false"))
				If ( DisplayRomInfo != "true" And currentDRI = "true" ) {
					StringReplace, zsnesCfg, zsnesCfg, DisplayInfo=1, DisplayInfo=0
				} Else If ( DisplayRomInfo = "true" And currentDRI = "false" ) {
					StringReplace, zsnesCfg, zsnesCfg, DisplayInfo=0, DisplayInfo=1
				SaveFile(zsnesCfg, zsnesFile) ; save changes to zsnesw.cfg
				Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
				WinWait("ZSNES ahk_class ZSNES")
				WinWaitActive("ZSNES ahk_class ZSNES")
				FadeInExit()
				Process("WaitClose",executable)
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				SaveFile(text,file) {
					FileDelete, %file%
					FileAppend, %text%, %file%
				CloseProcess:
					FadeOutStart()
					SetWinDelay, 50
					Send, {Alt Down}{F4 Down}{F4 Up}{Alt Up} ; No other closing method seems to work
				Return
				TF_Find(Text, StartLine = 1, EndLine = 0, SearchText = "", ReturnFirst = 1, ReturnText = 0)
					{ ; complete rewrite for 3.1
					 TF_GetData(OW, Text, FileName)
					 If (RegExMatch(Text, SearchText) < 1)
					 	Return "0" ; SearchText not in file or error, do nothing
				     	 TF_MatchList:=_MakeMatchList(Text, StartLine, EndLine) ; create MatchList
					 Loop, Parse, Text, `n
						 If A_Index in %TF_MatchList%
							 If (RegExMatch(A_LoopField, SearchText) > 0)
								 If (ReturnText = 0)
									Lines .= A_Index "," ; line number
								 Else If (ReturnText = 1)
									Lines .= A_LoopField "`n" ; text of line
								 Else If (ReturnText = 2)
									Lines .= A_Index ": " A_LoopField "`n" ; add line number
								 If (ReturnFirst = 1) ; only return first occurence
									Break
					 If (Lines <> "")
						StringTrimRight, Lines, Lines, 1 ; trim trailing , or `n
					 Else
						Lines = 0 ; make sure we return 0
					 Return Lines
				TF_ReplaceLine(Text, StartLine = 1, Endline = 0, ReplaceText = "")
					 Loop, Parse, Text, `n, `r
							Output .= ReplaceText "`n"
						 Else
							Output .= A_LoopField "`n"
					 Return TF_ReturnOutPut(OW, OutPut, FileName)
				TF_GetData(byref OW, byref Text, byref FileName)
					OW=0 ; default setting: asume it is a file and create file_copy
					IfNotInString, Text, `n ; it can be a file as the Text doesn't contact a newline character
						 If (SubStr(Text,1,1)="!") ; first we check for "overwrite"
							 Text:=SubStr(Text,2)
							 OW=1 ; overwrite file (if it is a file)
						 IfNotExist, %Text% ; now we can check if the file exists, it doesn't so it is a var
						  If (OW=1) ; the variable started with a ! so we need to put it back because it is variable/text not a file
							Text:= "!" . Text
						  OW=2 ; no file, so it is a var or Text passed on directly to TF
					Else ; there is a newline character in Text so it has to be a variable
						 OW=2
				    If (OW = 0) or (OW = 1) ; it is a file, so we have to read into var Text
					 	 Text := (SubStr(Text,1,1)="!") ? (SubStr(Text,2)) : Text
						 FileName=%Text% ; Store FileName
						 FileRead, Text, %Text% ; Read file and return as var Text
						 If (ErrorLevel > 0)
					 		 MsgBox, 48, TF Lib Error, % "Can not read " FileName
							 ExitApp
					Return
				TF_Count(String, Char)
					StringReplace, String, String, %Char%,, UseErrorLevel
					Return ErrorLevel
				TF_ReturnOutPut(OW, Text, FileName, TrimTrailing = 1, CreateNewFile = 0) { ; HugoV
					If (OW = 0) ; input was file, file_copy will be created, if it already exist file_copy will be overwritten
						 IfNotExist, % FileName ; check if file Exist, if not return otherwise it would create an empty file. Thanks for the idea Murp|e
						 	 If (CreateNewFile = 1) ; CreateNewFile used for TF_SplitFileBy* and others
								 OW = 1
						 		 Goto CreateNewFile
							 Else
								Return
						 If (TrimTrailing = 1)
							 StringTrimRight, Text, Text, 1 ; remove trailing `n
						SplitPath, FileName,, Dir, Ext, Name
						 If (Dir = "") ; if Dir is empty Text & script are in same directory
							Dir := A_ScriptDir
						 IfExist, % Dir "\backup" ; if there is a backup dir, copy original file there
							FileCopy, % Dir "\" Name "_copy." Ext, % Dir "\backup\" Name "_copy.bak", 1
						 FileDelete, % Dir "\" Name "_copy." Ext
						 FileAppend, %Text%, % Dir "\" Name "_copy." Ext
						 Return Errorlevel ? False : True
					 CreateNewFile:
					 If (OW = 1) ; input was file, will be overwritten by output
						 	If (CreateNewFile = 0) ; CreateNewFile used for TF_SplitFileBy* and others
						 		Return
							Dir := A_ScriptDir
							FileCopy, % Dir "\" Name "." Ext, % Dir "\backup\" Name ".bak", 1
						 FileDelete, % Dir "\" Name "." Ext
						 FileAppend, %Text%, % Dir "\" Name "." Ext
					If (OW = 2) ; input was var, return variable
						 Return Text
				_MakeMatchList(Text, Start = 1, End = 0)
					ErrorList=
					 (join|
					 Error 01: Invalid StartLine parameter (non numerical character)
					 Error 02: Invalid EndLine parameter (non numerical character)
					 Error 03: Invalid StartLine parameter (only one + allowed)
					 StringSplit, ErrorMessage, ErrorList, |
					 Error = 0
				 	 TF_MatchList= ; just to be sure
					 If (Start = 0 or Start = "")
						Start = 1
					 ; some basic error checking
					 ; error: only digits - and + allowed
					 If (RegExReplace(Start, "[ 0-9+\-\,]", "") <> "")
						 Error = 1
					 If (RegExReplace(End, "[0-9 ]", "") <> "")
						 Error = 2
					 ; error: only one + allowed
					 If (TF_Count(Start,"+") > 1)
						 Error = 3
					 If (Error > 0 )
						 MsgBox, 48, TF Lib Error, % ErrorMessage%Error%
						 ExitApp
				 	 ; Option #1
					 ; StartLine has + character indicating startline + incremental processing.
					 ; EndLine will be used
					 ; Make TF_MatchList
					 IfInString, Start, `+
						 If (End = 0 or End = "") ; determine number of lines
							End:= TF_Count(Text, "`n") + 1
						 StringSplit, Section, Start, `, ; we need to create a new "TF_MatchList" so we split by ,
						 Loop, %Section0%
							 StringSplit, SectionLines, Section%A_Index%, `+
							 LoopSection:=End + 1 - SectionLines1
							 Counter=0
					         	 TF_MatchList .= SectionLines1 ","
							 Loop, %LoopSection%
								 If (A_Index >= End) ;
									Break
								 If (Counter = (SectionLines2-1)) ; counter is smaller than the incremental value so skip
									 TF_MatchList .= (SectionLines1 + A_Index) ","
									 Counter=0
								 Else
									Counter++
						 StringTrimRight, TF_MatchList, TF_MatchList, 1 ; remove trailing ,
						 Return TF_MatchList
					 ; Option #2
					 ; StartLine has - character indicating from-to, COULD be multiple sections.
					 ; EndLine will be ignored
					 ; Make TF_MatchList
					 IfInString, Start, `-
						 Loop, %Section0%
							 StringSplit, SectionLines, Section%A_Index%, `-
							 LoopSection:=SectionLines2 + 1 - SectionLines1
							 Loop, %LoopSection%
								 TF_MatchList .= (SectionLines1 - 1 + A_Index) ","
						 Return TF_MatchList
					 ; Option #3
					 ; StartLine has comma indicating multiple lines.
					 IfInString, Start, `,
						 TF_MatchList:=Start
						 Return TF_MatchList
					 ; Option #4
					 ; parameters passed on as StartLine, EndLine.
					 ; Make TF_MatchList from StartLine to EndLine
					 LoopTimes:=End-Start
					 Loop, %LoopTimes%
						 TF_MatchList .= (Start - 1 + A_Index) ","
					 TF_MatchList .= End ","
					 Return TF_MatchList
00:41:16:515 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
00:41:16:515 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
00:41:16:515 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
00:41:16:515 | HL |     INFO  | +0     | Main - Module is built
00:41:16:515 | HL |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\HyperLaunch\AutoHotkey.dll exists
00:41:16:515 | HL |     INFO  | +0     | Main - Running module
00:41:16:609 | MD |     INFO  | +N/A   | Module initialized
00:41:16:640 | MD |     INFO  | +32    | StartModule - Started
00:41:16:640 | MD |     INFO  | +0     | StartModule - MEmu: ZSNESw
				MEmuV: v1.51
				MURL: http://www.zsnes.com/
				MAuthor: djvj
				MVersion: 2.0
				MCRC: 90F089AF
				iCRC: 3B0E8F48
				MID:
				MSystem: "Super Nintendo Entertainment System"
00:41:16:640 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Super Nintendo Entertainment System"
00:41:16:640 | MD |     INFO  | +0     | StartModule - Ended
00:41:16:640 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
00:41:16:640 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
00:41:16:640 | MD |     INFO  | +0     | Module Setting - Fullscreen: true
00:41:16:640 | MD |     INFO  | +0     | Module Setting - Stretch: true
00:41:16:640 | MD |     INFO  | +0     | Module Setting - resX: 1280
00:41:16:640 | MD |     INFO  | +0     | Module Setting - resY: 1024
00:41:16:640 | MD |     INFO  | +0     | Module Setting - DisplayRomInfo: false
00:41:16:640 | MD |     INFO  | +0     | CheckFile - Checking if D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.cfg exists
00:41:16:656 | MD |     INFO  | +15    | Module Run - Running: D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe "D:\---\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Mr. Nutz.smc"
00:41:16:687 | MD |     INFO  | +31    | Module WinWait - Waiting for ZSNES ahk_class ZSNES
00:41:17:156 | MD |     INFO  | +469   | Module WinWaitActive - Waiting for "ZSNES ahk_class ZSNES"
00:41:17:265 | MD |     INFO  | +110   | Module Process - WaitClose zsnesw.exe
00:41:30:062 | MD |     INFO  | +12796 | StopGlobalUserFeatures - Starting
00:41:30:062 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
00:41:30:062 | MD |     INFO  | +0     | ExitModule - Started
00:41:30:062 | MD |     INFO  | +0     | Starting Updating Statistics:
00:41:30:062 | MD |     INFO  | +0     | CreateRomTable - Started
00:41:30:062 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
00:41:30:171 | MD |     INFO  | +110   | Game section statistics updated.
00:41:30:171 | MD |     INFO  | +0     | ExitModule - Ended
00:41:30:171 | MD |     INFO  | +0     | End of Module Logs
00:41:30:281 | HL |     INFO  | +13765 | Main - Module ended, exiting HyperLaunch normally
00:41:30:281 | HL |     INFO  | +0     | ExitScript - Started
00:41:30:296 | HL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
00:41:30:296 | HL |     INFO  | +0     | ExitScript - Ended
I just tried it with ePSXe and it seems to be that there is no problem. Maybe could it be... in the log I read "Main - CRC check - crc does not match official module...", but I use the correct 1.51 Version?
So if it only does it with one emu, stop using that emu. Hl doesn't leave anything behind. So this has nothing to do with HL. Something with zsnes is getting left behind or something it uses to function.
If you insist on using that one emu, you want to start playing with its options and see if you can make it stop happening. Possibly scan your running processes before and after to see if there are any differences.
Sent from my Samsung Galaxy S3 using Tapatalk 4.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Yea but then HL wouldn't launch again if it did. He is saying he is able to open zsnes after this happens and not close. Unless that is not the truth.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Just tried it again and had the same issue in ePSXe, so it seems to be that it is not only an zsnes problem. What happens in zsnes is: If the error appears I have to press esc, then the emu menu pops up in HS and I have to close the emu via the "x" icon of the emu. So, I think HS loses control over zsnesw at the point where the key problem appears. After closing the emu HS takes back control because then I can navigate again in HS menus/wheels. Only the new key is still not working until I restart windows. Sometimes, but only sometimes, it suffices to restart HS and it recognized the key again.
Why not djvj? As long as HL doesn't stay running it will launch another instance of the emu just fine.
fuzzi, like it was already suggested make sure you check your running processes after that problem happens. Also first you mention znes now snes9x so which one is it after all?
Ups.. sorry, I mean zsnes. Slowly I get into a mess with all that testing and changing emus to arrive at a positive result. :P Also, it's pretty hard to realize what's really happens. As I say before, eG ePSXe, I try closing it 20 times and 1 times the issue appears, so I can not really say if it's on zsnes. What running processes do you mean? HL or zsnes? Because they all close correctly, no process is runnung after problem appears.
I mean zsnes, because if HL was left running you'd never be able to launch any other game from that point on. Are you actually checking the task manager for running processes after the problem appears? Because it would be very very strange for the exit key to stop working out of the blue unless emulator isn't running in the background.
Also post a log for when the exit key isn't working because in your log above it appears everything was exiting just fine.
brolly, 2 things happen to prevent HL from accidentally being launched a 2nd time.
1) If the executable is currently running (emu), HL will not start
2) Multiple launches of HL are not allowed via #SingleInstance Ignore
I'm sure you remember all those complaints about multiple HLs being allowed to open. The above is what I had to put in place to try to prevent that.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I knew about #2, but wasn't aware of #1 I guess you added meanwhile and I missed it somehow. Will you show any error if the emulator is already running?
Yes it shows in an error, but only in the log. Otherwise I can't for good reason. You don't want to see errors on your screen when you launch HL twice and the first was legitimate. I have no way to differentiate between an accidental launch and a properly mitigated 2nd launch. If I did, I would utilize that difference and script around it to identify one or the other and handle it all differently.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Ok, again to make it clear (I hope). Just tried it again, this time the error is different. I launch zsnes, close it via "f", the 3rd time the issue appears and "f" has no effect. But this time, if I press esc, HL works fine. Esc closed zsnes and I can start zsnes via HL again but only "f" still desen't work until I restart HL. This are my processes exactly after the effect appears (sorry but I use a german XP but I think the processes are clear):
And here are the logfile directly after it appears, and before closing zsnes or HL:
16:20:46:796 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9
16:20:46:796 | HL | INFO | +0 | Main - System Specs:
HyperLaunch Dir: D:\Hyperspin\HyperLaunch
OS: WIN_XP
Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x1024 work)
AutoHotkey Path:
Unicode: No
16:20:46:796 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1280 h1024
16:20:46:796 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
16:20:46:796 | HL | INFO | +0 | Main - HyperLaunch received "Super Nintendo Entertainment System" and "Super Mario World"
16:20:46:796 | HL | INFO | +0 | Main - Super Mario World is using the default emulator: ZSNESw
16:20:46:796 | HL | INFO | +0 | Main - Checking for a [ZSNESw] section in D:\Hyperspin\HyperLaunch\Settings\Super Nintendo Entertainment System\Emulators.ini
16:20:46:796 | HL | INFO | +0 | Main - Checking for a [ZSNESw] section in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
16:20:46:796 | HL | INFO | +0 | Main - Found [ZSNESw] in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
16:20:46:796 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk exists
16:20:46:796 | HL | WARNING | +0 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk.
16:20:46:796 | HL | INFO | +0 | Main - Super Mario World will use module: D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk
16:20:46:812 | HL | INFO | +15 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
16:20:46:812 | HL | INFO | +0 | Main - INI Keys read
16:20:46:812 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
16:20:46:812 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
16:20:46:812 | HL | INFO | +0 | CheckPaths - Started
16:20:46:812 | HL | INFO | +0 | CheckPaths - Found rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.smc
16:20:46:812 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe exists
16:20:46:812 | HL | INFO | +0 | CheckPaths - Ended
16:20:46:812 | HL | INFO | +0 | BuildScript - User Variables:
#NoTrayIcon
#InstallKeybdHook
SendMode, Event
0 = 2
frontendPID = 3532
frontendPath = D:\Hyperspin
frontendExt = exe
frontendDrive = D:
forceHoldKey = ~Esc
restoreFE = false
emuFullPath = D:\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe
emuPath = D:\Hyperspin\Emulators\Super Nintendo Entertainment System
emuName = ZSNESw
emuExt = exe
romPath = D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms
romPathFromIni = D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms
romExtension = .smc
dbName = Super Mario World
romName =
romMapPath =
skipchecks = false
romMatchExt = true
logFile = D:\Hyperspin\HyperLaunch\HyperLaunch.log
logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"]
logLevel = 3
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
originalWidth = 1280
originalHeight = 1024
dtEnabled = true
dtPath =
dtUseSCSI = true
dtAddDrive = true
emuIdleShutdown = 0
hideEmu = false
hideFE = false
fadeIn = false
fadeInDelay = 0
fadeInExitDelay = 0
fadeOut = false
fadeOutDelay = 0
fadeLyr2X = 300
fadeLyr2Y = 300
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3X = 300
fadeLyr3Y = 300
fadeLyr3Speed = 750
fadeLyr3Repeat = 1
fadeLyr3PicPad = 0
fadeLyr4X = 100
fadeLyr4Y = 100
fadeLyr4FPS = 10
fadeLyr4PicPad = 0
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowR = 20
fadeBarWindowM = 20
fadeBarBack = true
fadeBarH = 20
fadeBarR = 5
fadeBarXOffset = 0
fadeText1X = 0
fadeText1Y = 0
fadeText2X = 0
fadeText2Y = 0
fadeFont = Arial
fadeInterruptKey =
fadeImgPath = D:\Hyperspin\HyperLaunch\Media\Fade
HLDataPath = D:\Hyperspin\HyperLaunch\Data
HLMediaPath = D:\Hyperspin\HyperLaunch\Media
HLErrSoundPath = D:\Hyperspin\HyperLaunch\Media\Sounds\Error
modulesPath = D:\Hyperspin\HyperLaunch\Modules
moduleFullName = D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk
moduleName = ZSNESw
modulePath = D:\Hyperspin\HyperLaunch\Modules\ZSNESw
moduleExtensionsPath = D:\Hyperspin\HyperLaunch\Module Extensions
libPath = D:\Hyperspin\HyperLaunch\Lib
7zEnabled = false
7zPath = D:\Hyperspin\HyperLaunch\Module Extensions\7z.exe
7zDllPath = D:\Hyperspin\HyperLaunch\Module Extensions\7z.dll
7zExtractPath = C:\Dokumente und Einstellungen\Arcade Machine\Lokale Einstellungen\Temp\HS
7zExtractPathOrig =
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgSidePadding = 0.2
mgYOffset = 500
mgImageAdjust = 1
mgFont = Arial
mgText2Offset = 70
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
hpEnabled = false
hpKey = ~NumpadAdd
hpZoomInKey = C
hpZoomOutKey = V
hpHiToTextPath = D:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe
keymapper = ahk
xpadderFullPath = D:\Hyperspin\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = D:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
keymapperProfilePath = D:\Hyperspin\HyperLaunch\Profiles\ahk
CustomJoyNames =
FEProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\HyperSpin
defaultProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\_Default
systemProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System
xPadderSystemProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System\_Default
emuProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System\ZSNESw
romProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\Super Nintendo Entertainment System\Super Mario World
blankProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\blank
HyperLaunchProfile = D:\Hyperspin\HyperLaunch\Profiles\ahk\HyperLaunch
16:20:46:812 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts
16:20:46:812 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts
16:20:46:812 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script
16:20:46:812 | HL | INFO | +0 | BuildScript - Module:
MEmu = ZSNESw
MEmuV = v1.51
MAuthor = djvj
MVersion = 2.0
MCRC = 90F089AF
iCRC = 3B0E8F48
; Notes:
; KeyQuickExit=1
; KeyQuickLoad=0
; KeyQuickRst=0
; KeyResetAll=42
StartModule()
FadeInStart()
SetKeyDelay, 50
vidMode = 39
vidMode = 42
vidMode = 38
FadeInExit()
7zCleanUp()
FadeOutExit()
ExitModule()
FileDelete, %file%
CloseProcess:
FadeOutStart()
SetWinDelay, 50
Return
If (ReturnText = 0)
Break
If (Lines <> "")
Else
Return Lines
Else
Text:= "!" . Text
OW=2
If (ErrorLevel > 0)
ExitApp
Return
Return ErrorLevel
OW = 1
Goto CreateNewFile
Else
Return
Dir := A_ScriptDir
CreateNewFile:
Return
Dir := A_ScriptDir
Return Text
ErrorList=
(join|
Error = 0
Start = 1
Error = 1
Error = 2
Error = 3
If (Error > 0 )
ExitApp
; Option #1
; Make TF_MatchList
Loop, %Section0%
Counter=0
Loop, %LoopSection%
Break
Counter=0
Else
Counter++
Return TF_MatchList
; Option #2
; Make TF_MatchList
Loop, %Section0%
Loop, %LoopSection%
Return TF_MatchList
; Option #3
TF_MatchList:=Start
Return TF_MatchList
; Option #4
Loop, %LoopTimes%
Return TF_MatchList
16:20:46:812 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script
16:20:46:812 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script
16:20:46:812 | HL | INFO | +0 | BuildScript - Finished injecting functions into module
16:20:46:812 | HL | INFO | +0 | Main - Module is built
16:20:46:812 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
16:20:46:812 | HL | INFO | +0 | Main - Running module
As I wrote before: Sometimes I have to completely restart windows to make "f" working again in HL (or set "f" again in HLHQ). Sometimes it suffices to restart HL. And sometimes HL loses completely control and zsnes runs in the background, so I then have to close the emu itself and also kill the HL process to return to normality.
You forgot to set your log level to DEBUG1, it's in INFO level. But yeah it doesn't seem like it's entering the ExitModule function, even though I'm not sure if that gets logged at INFO level. Is that log AFTER you pressed 'f' and the emulator didn't close?
Also this seem suspect:
Did you edit anything in the module?
And finally, did you set your exit key in ZSNES as per the module notes?
1. I can only set min. to Debug1, is this correct? OK, here are the log with Debug1 set (ah and yes, it's AFTER pressing "f" and emu does not closed via HL):
22:09:14:828 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9
22:09:14:828 | HL | INFO | +0 | Main - System Specs:
OS: WIN_XP
AutoHotkey Path:
Unicode: No
22:09:14:828 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1280 h1024
22:09:14:828 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
22:09:14:828 | HL | INFO | +0 | Main - HyperLaunch received "Super Nintendo Entertainment System" and "Super Mario World"
22:09:14:828 | HL | INFO | +0 | Main - Super Mario World is using the default emulator: ZSNESw
22:09:14:828 | HL | INFO | +0 | Main - Checking for a [ZSNESw] section in D:\Hyperspin\HyperLaunch\Settings\Super Nintendo Entertainment System\Emulators.ini
22:09:14:828 | HL | INFO | +0 | Main - Checking for a [ZSNESw] section in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
22:09:14:828 | HL | INFO | +0 | Main - Found [ZSNESw] in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
22:09:14:828 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk exists
22:09:14:843 | HL | WARNING | +16 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk.
22:09:14:843 | HL | INFO | +0 | Main - Super Mario World will use module: D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk
22:09:14:843 | HL | INFO | +0 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
22:09:14:843 | HL | INFO | +0 | Main - INI Keys read
22:09:14:843 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
22:09:14:843 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
22:09:14:843 | HL | INFO | +0 | CheckPaths - Started
22:09:14:843 | HL | INFO | +0 | CheckPaths - Found rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.smc
22:09:14:843 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe exists
22:09:14:843 | HL | INFO | +0 | CheckPaths - Ended
22:09:14:843 | HL | INFO | +0 | BuildScript - User Variables:
#NoTrayIcon
#InstallKeybdHook
SendMode, Event
0 = 2
frontendPID = 1344
frontendExt = exe
frontendDrive = D:
forceHoldKey = ~Esc
restoreFE = false
emuName = ZSNESw
emuExt = exe
romExtension = .smc
romName =
romMapPath =
skipchecks = false
romMatchExt = true
logLevel = 3
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
dtEnabled = true
dtPath =
dtUseSCSI = true
dtAddDrive = true
emuIdleShutdown = 0
hideEmu = false
hideFE = false
fadeIn = false
fadeInDelay = 0
fadeInExitDelay = 0
fadeOut = false
fadeOutDelay = 0
fadeLyr2X = 300
fadeLyr2Y = 300
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3X = 300
fadeLyr3Y = 300
fadeLyr3Speed = 750
fadeLyr3Repeat = 1
fadeLyr3PicPad = 0
fadeLyr4X = 100
fadeLyr4Y = 100
fadeLyr4FPS = 10
fadeLyr4PicPad = 0
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowR = 20
fadeBarWindowM = 20
fadeBarBack = true
fadeBarH = 20
fadeBarR = 5
fadeBarXOffset = 0
fadeText1X = 0
fadeText1Y = 0
fadeText2X = 0
fadeText2Y = 0
fadeFont = Arial
fadeInterruptKey =
moduleName = ZSNESw
7zEnabled = false
7zExtractPathOrig =
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgSidePadding = 0.2
mgYOffset = 500
mgImageAdjust = 1
mgFont = Arial
mgText2Offset = 70
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
hpEnabled = false
hpKey = ~NumpadAdd
hpZoomInKey = C
hpZoomOutKey = V
keymapper = ahk
CustomJoyNames =
22:09:14:843 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts
22:09:14:843 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts
22:09:14:843 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script
22:09:14:859 | HL | INFO | +15 | BuildScript - Module:
MEmu = ZSNESw
MEmuV = v1.51
MAuthor = djvj
MVersion = 2.0
MCRC = 90F089AF
iCRC = 3B0E8F48
; Notes:
; KeyQuickExit=1
; KeyQuickLoad=0
; KeyQuickRst=0
; KeyResetAll=42
StartModule()
FadeInStart()
SetKeyDelay, 50
vidMode = 39
vidMode = 42
vidMode = 38
FadeInExit()
7zCleanUp()
FadeOutExit()
ExitModule()
FileDelete, %file%
CloseProcess:
FadeOutStart()
SetWinDelay, 50
Return
If (ReturnText = 0)
Break
If (Lines <> "")
Else
Return Lines
Else
Text:= "!" . Text
OW=2
If (ErrorLevel > 0)
ExitApp
Return
Return ErrorLevel
OW = 1
Goto CreateNewFile
Else
Return
Dir := A_ScriptDir
CreateNewFile:
Return
Dir := A_ScriptDir
Return Text
ErrorList=
(join|
Error = 0
Start = 1
Error = 1
Error = 2
Error = 3
If (Error > 0 )
ExitApp
; Option #1
; Make TF_MatchList
Loop, %Section0%
Counter=0
Loop, %LoopSection%
Break
Counter=0
Else
Counter++
Return TF_MatchList
; Option #2
; Make TF_MatchList
Loop, %Section0%
Loop, %LoopSection%
Return TF_MatchList
; Option #3
TF_MatchList:=Start
Return TF_MatchList
; Option #4
Loop, %LoopTimes%
Return TF_MatchList
22:09:14:859 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script
22:09:14:859 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script
22:09:14:859 | HL | INFO | +0 | BuildScript - Finished injecting functions into module
22:09:14:859 | HL | INFO | +0 | Main - Module is built
22:09:14:859 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
22:09:14:859 | HL | INFO | +0 | Main - Running module
2. Yes, as I said before. This wondered me too. And yes, I change x and y resolution to my res. 1280x1024, and change stretch to 'true'.
3. Yes that's also correct. I set KeyQuickExit to "1" in zsnesw config. But that issue appears also without set it to "1".
I didn't mean setting it to 1, I meant this part:
Sounds like you aren't setting the exit key properly in ZSNES. Also why did you edit the module for that? Those settings should be changed in the ini through HLHQ you should never need to edit anything in the modules.
Log is still wrong, you set the log level in the General Settings tab not in the log tab that's only for the log viewer filter.
I do not understand what you mean with quickexit. I do exactly what is suggested in the notes, I change "0" to "1" in the zsnesw cfg file to set the quickexit key in zsnesw, because (as it's written in the notes) I can't change them in zsnes menu because esc is the exit key to configuring keys. So, what's wrong? What should I do? Or do you mean I should set it to my new key "f"?
I do make changes in the module because, when I set the resolution in zsnes to 1280x1024 it does not shows these resolution in the emu if I start it via HL. Emulator itself starts in 1280x1024.
Ok, set the log correct in general settings. Here it is (direct after the issue appears and beforce closing zsnes or HL):
20:48:28:453 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9
20:48:28:453 | HL | INFO | +0 | Main - System Specs:
OS: WIN_XP
AutoHotkey Path:
Unicode: No
20:48:28:453 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1280 h1024
20:48:28:453 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
20:48:28:453 | HL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription Your favorite Front End companion!
FileVersion 3.0.0.9
LegalCopyright ©2013 HL squad
ProductName djvj's one swell guy!
ProductVersion 1.1.9.4
CompanyName djvj's one swell guy!
File Size: 899072 bytes
Created: 9/6/2013 - 8:06:33
Modified: 9/6/2013 - 8:06:34
20:48:28:453 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists
20:48:28:453 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
File Size: 88789 bytes
Created: 9/6/2013 - 8:06:30
Modified: 9/6/2013 - 8:06:32
20:48:28:453 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists
20:48:28:468 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension.
20:48:28:468 | HL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 67561 bytes
Created: 9/6/2013 - 8:06:31
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists
20:48:28:468 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension.
File Size: 10586 bytes
Created: 9/6/2013 - 8:06:29
Modified: 9/6/2013 - 8:06:30
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists
File Size: 26342 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists
File Size: 9203 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists
20:48:28:468 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
File Size: 1145 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists
File Size: 691 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists
File Size: 2485 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists
File Size: 161 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists
File Size: 167 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists
File Size: 26644 bytes
20:48:28:468 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists
20:48:28:484 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library.
20:48:28:484 | HL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 326352 bytes
20:48:28:484 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists
20:48:28:484 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
File Size: 27844 bytes
20:48:28:484 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists
File Size: 28070 bytes
20:48:28:484 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists
File Size: 21407 bytes
20:48:28:484 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists
File Size: 26089 bytes
20:48:28:484 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
20:48:28:500 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library.
20:48:28:500 | HL | DEBUG1 | +0 | CheckFile - Attributes:
File Size: 63798 bytes
20:48:28:500 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists
20:48:28:500 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library.
File Size: 65137 bytes
20:48:28:500 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists
File Size: 28659 bytes
20:48:28:500 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists
File Size: 48181 bytes
20:48:28:500 | HL | INFO | +0 | Main - HyperLaunch received "Super Nintendo Entertainment System" and "Super Mario World"
20:48:28:500 | HL | INFO | +0 | Main - Super Mario World is using the default emulator: ZSNESw
20:48:28:500 | HL | INFO | +0 | Main - Checking for a [ZSNESw] section in D:\Hyperspin\HyperLaunch\Settings\Super Nintendo Entertainment System\Emulators.ini
20:48:28:500 | HL | INFO | +0 | Main - Checking for a [ZSNESw] section in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
20:48:28:500 | HL | INFO | +0 | Main - Found [ZSNESw] in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
20:48:28:500 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk exists
File Size: 10997 bytes
Modified: 9/6/2013 - 8:20:16
20:48:28:515 | HL | WARNING | +16 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk.
20:48:28:515 | HL | INFO | +0 | Main - Super Mario World will use module: D:\Hyperspin\HyperLaunch\Modules\ZSNESw\ZSNESw.ahk
20:48:28:515 | HL | INFO | +0 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
20:48:28:515 | HL | INFO | +0 | Main - INI Keys read
20:48:28:515 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
20:48:28:515 | HL | DEBUG1 | +0 | CheckFile - Attributes:
FileDescription 7-Zip Console
FileVersion 9.20
InternalName 7z
LegalCopyright Copyright © 1999-2010 Igor Pavlov
OriginalFilename 7z.exe
ProductName 7-Zip
ProductVersion 9.20
CompanyName Igor Pavlov
File Size: 163840 bytes
20:48:28:515 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
FileDescription 7z Standalone Plugin
FileVersion 9.20
InternalName 7za
OriginalFilename 7za.dll
ProductName 7-Zip
ProductVersion 9.20
File Size: 914432 bytes
20:48:28:515 | HL | INFO | +0 | CheckPaths - Started
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.7z
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World\Super Mario World.7z
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World\*.7z
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.zip
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World\Super Mario World.zip
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World\*.zip
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.sfc
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World\Super Mario World.sfc
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World\*.sfc
20:48:28:515 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.smc
20:48:28:515 | HL | INFO | +0 | CheckPaths - Found rom: D:\Hyperspin\Emulators\Super Nintendo Entertainment System\Roms\Super Mario World.smc
20:48:28:515 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\Emulators\Super Nintendo Entertainment System\zsnesw.exe exists
File Size: 535552 bytes
Created: 9/6/2013 - 7:03:10
Modified: 7/20/2008 - 3:01:18
20:48:28:515 | HL | INFO | +0 | CheckPaths - Ended
20:48:28:515 | HL | INFO | +0 | BuildScript - User Variables:
#NoTrayIcon
#InstallKeybdHook
SendMode, Event
0 = 2
frontendPID = 2108
frontendExt = exe
frontendDrive = D:
forceHoldKey = ~Esc
restoreFE = false
emuName = ZSNESw
emuExt = exe
romExtension = .smc
romName =
romMapPath =
skipchecks = false
romMatchExt = true
logLevel = 4
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
dtEnabled = true
dtPath =
dtUseSCSI = true
dtAddDrive = true
emuIdleShutdown = 0
hideEmu = false
hideFE = false
fadeIn = false
fadeInDelay = 0
fadeInExitDelay = 0
fadeOut = false
fadeOutDelay = 0
fadeLyr2X = 300
fadeLyr2Y = 300
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3X = 300
fadeLyr3Y = 300
fadeLyr3Speed = 750
fadeLyr3Repeat = 1
fadeLyr3PicPad = 0
fadeLyr4X = 100
fadeLyr4Y = 100
fadeLyr4FPS = 10
fadeLyr4PicPad = 0
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowR = 20
fadeBarWindowM = 20
fadeBarBack = true
fadeBarH = 20
fadeBarR = 5
fadeBarXOffset = 0
fadeText1X = 0
fadeText1Y = 0
fadeText2X = 0
fadeText2Y = 0
fadeFont = Arial
fadeInterruptKey =
moduleName = ZSNESw
7zEnabled = false
7zExtractPathOrig =
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgSidePadding = 0.2
mgYOffset = 500
mgImageAdjust = 1
mgFont = Arial
mgText2Offset = 70
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
hpEnabled = false
hpKey = ~NumpadAdd
hpZoomInKey = C
hpZoomOutKey = V
keymapper = ahk
CustomJoyNames =
20:48:28:515 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts
20:48:28:515 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts
20:48:28:515 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script
20:48:28:515 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 285
20:48:28:515 | HL | INFO | +0 | BuildScript - Module:
MEmu = ZSNESw
MEmuV = v1.51
MAuthor = djvj
MVersion = 2.0
MCRC = 90F089AF
iCRC = 3B0E8F48
; Notes:
; KeyQuickExit=1
; KeyQuickLoad=0
; KeyQuickRst=0
; KeyResetAll=42
StartModule()
FadeInStart()
SetKeyDelay, 50
vidMode = 39
vidMode = 42
vidMode = 38
FadeInExit()
7zCleanUp()
FadeOutExit()
ExitModule()
FileDelete, %file%
CloseProcess:
FadeOutStart()
SetWinDelay, 50
Return
If (ReturnText = 0)
Break
If (Lines <> "")
Else
Return Lines
Else
Text:= "!" . Text
OW=2
If (ErrorLevel > 0)
ExitApp
Return
Return ErrorLevel
OW = 1
Goto CreateNewFile
Else
Return
Dir := A_ScriptDir
CreateNewFile:
Return
Dir := A_ScriptDir
Return Text
ErrorList=
(join|
Error = 0
Start = 1
Error = 1
Error = 2
Error = 3
If (Error > 0 )
ExitApp
; Option #1
; Make TF_MatchList
Loop, %Section0%
Counter=0
Loop, %LoopSection%
Break
Counter=0
Else
Counter++
Return TF_MatchList
; Option #2
; Make TF_MatchList
Loop, %Section0%
Loop, %LoopSection%
Return TF_MatchList
; Option #3
TF_MatchList:=Start
Return TF_MatchList
; Option #4
Loop, %LoopTimes%
Return TF_MatchList
20:48:28:515 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script
20:48:28:515 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script
20:48:28:515 | HL | INFO | +0 | BuildScript - Finished injecting functions into module
20:48:28:515 | HL | INFO | +0 | Main - Module is built
20:48:28:515 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
20:48:28:531 | HL | DEBUG1 | +15 | CheckFile - Attributes:
FileDescription AutoHotkey_H ANSI 32-bit
FileVersion 1.1.09.04
InternalName AutoHotkey_H
LegalCopyright Copyright © 2012
OriginalFilename AutoHotkey.exe
ProductName AutoHotkey_H
ProductVersion 1.1.09.04
File Size: 785408 bytes
20:48:28:531 | HL | INFO | +0 | Main - Running module
  • 10 months later...
I got the same problem and many many more eg: videos not showing up for random systems, settings saving not taking hold at all. always forums lead to No answer or people making excuses "you dont need your windows taskbar anyways" "xpadder is a beautiful program" honestly i don't care anymore all i need to know is. dose anyone ever play a game on hyperspin ? or do people just dedicate there lives changing settings that may or may not take hold ? im sick of it its like going to gun range to see how well your shooting with blanks ! and seriously that's the last straw! why complain about a free program ? 2 years of precious life is not free far from it ive payed in literal blood, sweat, tears time and space. far more valuable than any currency.. well goodbye now !
??? Only 9 posts since joining in Jan 2013 and you are complaining about not getting any answers? Perhaps you should start again from first principles. Check the link in my sig and read Ron's guide to posting, then you should get some help if you still need it.
I personally have a policy of only answering questions that have proper capitalization and mostly correct spelling. I have a hard time reading badly written posts due to some personal difficulties so I don't answer them. Also I think if you can't take the time to correctly write a question, that you probably wouldn't read instructions because your time is obviously too valuable.
