majorspawn Posted October 24, 2013 Posted October 24, 2013 Hi Guys, is there a way to permanently enable cheats for certain games without manually doing so? e.g. enable boss selection in kof95? i couldn't find anything concrete.. My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
majorspawn Posted October 25, 2013 Author Posted October 25, 2013 anyone has any ideas? My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
B2K24 Posted October 30, 2013 Posted October 30, 2013 I think even with running cheat 1 in your .ini or -cheat you still have to activate the ones you want. If it doesn't save on exit what you want enabled then you might need to enable what you want then create a savestate. I'm unsure if savestate/load a state will get the results you want however.
DeLuSioNaL29 Posted October 30, 2013 Posted October 30, 2013 A while back, I wanted Jr. Pacman to be FAST but I could only enable that in the cheat menu. It would lose it's settings when you exited the game. However, in the latest version of MAME, they now have jrpacmanf which is similar to mspacmanf where it's the FAST version. Lucky! So to answer your question, no there isn't a way to have the cheat functions saved. You have to enable it each and every time. DeLuSioNaL29
mameshane Posted October 31, 2013 Posted October 31, 2013 DeLuSioNaL29 said: A while back, I wanted Jr. Pacman to be FAST but I could only enable that in the cheat menu. It would lose it's settings when you exited the game. However, in the latest version of MAME, they now have jrpacmanf which is similar to mspacmanf where it's the FAST version. Lucky!So to answer your question, no there isn't a way to have the cheat functions saved. You have to enable it each and every time. DeLuSioNaL29 I'm the same with double dragon. I use cheat to overlock the CPU for that game. hate the slow downs My Cab.. 1-UP ARCADE new hyperspin irc details.. come hang out!
connorsdad Posted October 31, 2013 Posted October 31, 2013 What if you enable the cheat then set a save state, then launch the game straight into that savestate? Sent from my SM-N9005 using Tapatalk
mameshane Posted October 31, 2013 Posted October 31, 2013 connorsdad said: What if you enable the cheat then set a save state, then launch the game straight into that savestate?Sent from my SM-N9005 using Tapatalk that's interesting. would have to check that. but what would happen if u turned cheats off in mame.ini file between loading the save states. I couldn't see save state changing the mame.ini file when loaded. My Cab.. 1-UP ARCADE new hyperspin irc details.. come hang out!
DeLuSioNaL29 Posted November 21, 2013 Posted November 21, 2013 Hmm. I think I tried the save state thingy and it didn't work. But how about this. What about an AHK script that automatically presses, "Tab", "Cheats" and then selects the item you want? Couldn't RocketLauncher.0 theoretically do this with a script for a particular game? (You can use Hyperlaunch HQ to create a different emulator for the particular game to use and then set an AHK module to execute the steps above for the cheat every time you launch the game). Thoughts? DeLuSioNaL29
DBIZZZZ Posted June 22, 2014 Posted June 22, 2014 Does anyone have the lines of text needed for the ddragon.xml file to increase speed ?
dougan78 Posted June 22, 2014 Posted June 22, 2014 :ddragon:65004000:00000000:00080000:00000000:Overclock to 800% Sent from my SCH-I545 using Tapatalk
