ghutch92 Posted September 6, 2014 Posted September 6, 2014 Great write up. Question I have is will this work with the newest version, 0.154 of mame and hyperspin? I have been having problems for a good week with this x-arcade tank stick. Please read my post to the controllers site and comment if you can help!!!! I am at wits end with this thing and was thinking of trying to build my own. Thanks. New here so please be patient. I have installed the new hyperspin, applied all roms, themes, etc. It works great with keyboard but I am having problems with the x-arcade tank stick. It has the default setting but that doesnt seem to be working as it should. Anyhow what I would like is to set up my controls to work without using the keyboard at all. Is there a configuration of settings for the mapping of the x-arcade that works such as this? Is there something else that I need to purchase to get what I want? I know all games will not work with any one set of settings but I just want the best that I can get for what I have. Also when I go into a game such as spiderman, I change the general settings to move the player arounfd, 1 and 2 but it never seems to take. I thought that once this was done it was for all game inputs. Am I wrong here? Can someone give me some input on what I need to do here to make this x-arcade tank stick work well with the mame emulator that I have? I have read tons of website links but just cannot get the right combination to work right. A tutorial would be awsome as I am not the brightest at setting this up and I dont feel that it should be this difficult. I have tried setting as the manual suggests but somehow this is not working correctly. PLEASE GUIDE ME ON THIS!!!! http://www.xgaming.com/support/questions/12/Advanced+MAME%E2%84%A2+Configuration+%26+Config+File+Download How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
chevyy57 Posted September 7, 2014 Posted September 7, 2014 I have been through the xgaming site and have followed everything several times. I have only had the problems since loading up the new systems. 0.154 and HS. The test utility works fine. I just cant find a combination to play a game such as Donkey Kong and then Spiderman using the Default settings. Somewhere something is just not clicking. I use to be able to play with the mame.ini files but cannot seem to find this in the new mame.
ghutch92 Posted September 7, 2014 Posted September 7, 2014 I have been through the xgaming site and have followed everything several times. I have only had the problems since loading up the new systems. 0.154 and HS. The test utility works fine. I just cant find a combination to play a game such as Donkey Kong and then Spiderman using the Default settings. Somewhere something is just not clicking. I use to be able to play with the mame.ini files but cannot seem to find this in the new mame. So you are saying your problems exist because the new mame is missing the mame.ini file that the old ones had. http://forum.arcadecontrols.com/index.php?topic=38917.0 http://mamedev.org/source/docs/config.txt.html How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
chevyy57 Posted September 7, 2014 Posted September 7, 2014 No not at all. I just dont have the ability to change within the controller as I use to. I am not as knowledgeable with the new setup as of the old one. Just another learning curve I guess. The xarcade config file may need configured to my needs? I just dont know. I am told that the xarcade will work from the default setting with most games of mame. It just doesnt seem to work that way for me with the games that are pretty common old games.
ghutch92 Posted September 7, 2014 Posted September 7, 2014 The new mame version still have and use the mame.ini settings. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
chevyy57 Posted September 7, 2014 Posted September 7, 2014 Where can I find the mame.ini file for editing? I cant seem to find?
ghutch92 Posted September 7, 2014 Posted September 7, 2014 open command prompt type cd (insert path to folder containing mame executable here) (insert name of mame executable) -createconfig How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
chevyy57 Posted September 7, 2014 Posted September 7, 2014 open command prompttype cd (insert path to folder containing mame executable here) (insert name of mame executable) -createconfig So the command would look like: c:\hyperspin\emulators\mame>mame64-createconfig this does not open up anything in cmd. I tried various commands and did get the command line to read c:hyperspin\emulators\MAME> butcould not go past that point to open or make anything with the cmd prompt
ghutch92 Posted September 7, 2014 Posted September 7, 2014 c:\hyperspin\emulators\mame>mame64(SPACE)-createconfig should be a space between the command line switch and the name of the executable program. c:\hyperspin\emulators\mame>mame64 -createconfig How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
chevyy57 Posted September 7, 2014 Posted September 7, 2014 in the cmd prompt, run as admin, I type in my paths exactly but nothing. cannot find path specified
darealdoomer Posted November 17, 2014 Posted November 17, 2014 Sorry for resurrecting this thread, but I ran into some trouble after following these instructions. Even though I ensured the settings were precisely as detailed (I think), the remapped keys work perfectly when testing them by clicking the lightning bolt, but when the game is launched, the keys do not work in the emu/system. I can remap keys in the emu outside of HS and this works, but after trying several systems using the instructions above, they do not seem to take effect using HL. I am using the latest hyperspin and HL and my x-arcade tankstick. Any suggestion would be great. -D
Turranius Posted November 19, 2014 Posted November 19, 2014 Sorry for resurrecting this thread, but I ran into some trouble after following these instructions. Even though I ensured the settings were precisely as detailed (I think), the remapped keys work perfectly when testing them by clicking the lightning bolt, but when the game is launched, the keys do not work in the emu/system. I can remap keys in the emu outside of HS and this works, but after trying several systems using the instructions above, they do not seem to take effect using HL. I am using the latest hyperspin and HL and my x-arcade tankstick. Any suggestion would be great.-D From my guide? Make sure AHK is set to internal In HyperLaunchHQ, select your system you want to remap on the left. Go to Settings and make sure "Ahk Method" is set to "Internal". This enables the whole thing. Mame related stuff: FTP: grandis.nu, port 21, user:misc, pass:misc http://grandis.nu/software Tur-Matcher - Match your roms/media/XML files. Another Idle Volume Adjuster - Automatically control the volume. How to: Use MAME Extras as material for HyperPause How to: Use eXoDOS 2.0 as material for HyperPause
darealdoomer Posted November 20, 2014 Posted November 20, 2014 From my guide? Make sure AHK is set to internal Yes, sadly. That was how I had it set. I'm a bit at a loss on this. It may be related to the x-arcade tankstick. When I gave up and reverted all settings to defaults, and just tried to set the tankstick up to control HS form the keyboard settings in HSHQ, the tankstick buttons still did not work. My keyboard did as P2, but the C & 5 keys on the tankstick did not work for me inside HS. I can use notepad and check the buttons and they work fine outside of HS. Weird. EDIT: I'm a sleep deprived idiot. The C & 5 keys we used twice in HSHQ. Easy fix, so that works at least.
subwolf36 Posted December 24, 2014 Posted December 24, 2014 Hi I just got a x-arcade dual tank stick I have it hooked up correctly but I cant get the left joystick to be seen as the number pad keys when I run the test utility. My number lock is enabled when my system starts but it is still seen as arrow keys. is there anyway to fix this. Also im running windows 7 ultimate. Thanks
dragon57 Posted December 25, 2014 Posted December 25, 2014 Subwolf, do you get the expected results when you check the joystick output in Notepad? If not, what do you get?
subwolf36 Posted December 25, 2014 Posted December 25, 2014 I don't get the expected result thru note pad I end up getting arrow key movements from the left stick instead of the 8462 I should be getting. Thanks
dragon57 Posted December 25, 2014 Posted December 25, 2014 Have you tried hitting Num Lock on your regular keyboard?
subwolf36 Posted December 25, 2014 Posted December 25, 2014 yes it is on like its supposed to be I even tried switching it off just and on again
dragon57 Posted December 25, 2014 Posted December 25, 2014 OK, have you tried force loading the default configuration by making sure the switch on the back is in the correct position, then hitting the load button twice?
dragon57 Posted December 25, 2014 Posted December 25, 2014 Does your regular numeric keypad mirror your X-Arcade left joystick as far as what is outputs when you hit the 2, 4, 6, and 8 keys? Do you get up, down, left, and right? If so, does hitting numlock once allow your regular numeric keypad to output numbers?
subwolf36 Posted December 25, 2014 Posted December 25, 2014 when I hit those numbers on the regular key pad no affect but if I run the x-arcade test thing and hit them on the number pad the stick in the pic will move but manually moving the stick wont give the same output.
dragon57 Posted December 25, 2014 Posted December 25, 2014 Wow, that is so weird. If you can't numbers from the regular keypad no matter what, you aren't going to get them from the X-Arcade. I wonder if you have some type of bios setting forcing the key pad to be in 'arrow mode', or something. Have you went into your bios and looked around?
subwolf36 Posted December 25, 2014 Posted December 25, 2014 I tried messing around in the bios to the only thing in their is the number lock on or off at boot-up so I played around with that setting as well I am starting to think this x-arcade might be defective.
dragon57 Posted December 25, 2014 Posted December 25, 2014 Do you have another computer you can plug it in to for a quick test? Also, I assume you are using the USB connection it offers?
