Complete Guide for Commodore Amiga in HyperSpin and HL3
rfancella
http://eab.abime.net/showthread.php?t=57057
But I should have read it carefully - 2011!
I agree games come out but how many newbies can install these games themselves? Is there an easy wake through for that? If so I'd like a copy too. ;-)
They are very easy to install. The issue is, you have to have an Amiga with a HDD or an Emulated desktop setup.
With the Amiga OS up and running. You have to have the WHDLoad installer and the disc images. Mount the disc images and run the installer.
If you have everything, it's easy.
Thanks,
Ron
  • Replies 164
Thanks,
Ron
Cheers never done it
eheh yeah KG isn't the one making the installs since a long time, Retroplay is taking care of it now and he pretty much keeps up to date with the new slaves on a weekly basis.
Installing them is simple enough if you know your way around AmigaOS and workbench (and have the required adf/ips files), but if you don't you'll struggle with it easier to just wait for the pre-installed packages ;)
I have also found that many of the disc images are cracked versions of the game. Quite often the WHDLoad installer won't work on those. Lucky for me, most of my favs are either already installed and available or I have the original discs. ;)
Thanks,
Ron
Yep, in most cases you'll need to use the ips dumps.
Brolly,
Ok, I think it's done. For your approval and review:
http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only
Thanks,
Ron
Thanks,
Ron
Ron,
Any chance of doing an emulated version walkthrough of an installation?
Ron,
Yes, on the list. Along with an .adf version for WinUAE. But for sure you need something like Amiga Forever. Or be knowledgeable on the Amiga OS and have the right software. So the guide will not be for the average user. ;)
Thanks,
Ron
I do have amiga forever...
Potts,
This would be better addressed in this thread: ;)
:D
Thanks,
Ron
  • 2 months later...
One of the steps needs changing slightly -
"Click on the Emulators tab on the top.
Hit the green plus next to Rom Paths and set the path to your Amiga roms.
Select your Default Emulator as WinUAE Loader [Global]:"
I found that I needed to click "Commodore Amiga" on the left first, before clicking the "Emulators" tab on the top.
Finally got this beast working though - great guide!! Thank you
Wow, you are correct. I have made the change. It is correct on the picture, but I forgot to add the step in the text.
Thanks again for the input!
Thanks,
Ron
:adore: No probs! Thanks for the guide - I had been struggling to set up winuae for ages and always like the simplicity of the loader. Works like a charm :)
Do you know if there an xml for the whdload set (ie to list the game names correctly in the wheel list)? I used dir2xml to create my own and it's a bit messy, although it works it would be a job to edit manually if someones already done it. I dowloaded a Commodore Amiga.xml from a diffrent thread but it wasn't valid (all the <crc> entries were malformed).
Thanks again :)
Thanks again :)
Yes, the xml in HyperList (unofficial system list) is correct for the KillerGorilla WHDLoad packs.
Thanks,
Ron
Just one last question if I may...
I want to configure the "display" output to 800x600,
do I chage the settings in WinUAE configuration file (default.aue)? or do I change the settings on WinUAEloader's GUI? or do I just set it in Hyperlaunch?
Same query for controller's "input" too please - WinUAE GUI or WinUAEloader's GUI?
Thanks a bunch :)
Thanks a bunch :)
Pete,
With WinUAELoader, those setting are done in the Loader, not WinUAE.
Thanks,
Ron
Thanks Ron, great stuff! :)
Pete,
Got it all squared away??
Thanks,
Ron
Ron I got a small problem. I had this all setup no problem on my other system, worked like a charm due to your guidance and extra help of course. Thanks again for that.
Problem I have now it that I chose the easy route to moving it over. Infact I just cut and pasted the system. I did set it back up once that was completed pointing the paths etc, finding the kickstarts etc. I now loads no problem so I set it aside and moved on.
Problem is that I have now tried to help Relic out with his setup of controls. When I tried to load it in Hyperspin, the fade popped up, its waits until Hyperlaunch is finished and then you get that error... THEN it kicks in and loads. I have tried to extend Fade to allow it time to load in background... again it just waits then loads. I have also turned fade off but then it looses focus and loads behind HS?
Have I missed something really silly when I moved it over?
Here is my log... I see the error but I cant see why it will not kick in till fade has finished or why its loosing focus?
15:55:34:164 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
15:55:34:250 | HL |     INFO  | +93    | Main - System Specs:
				HyperLaunch Dir: P:\Hyperspin
				OS: Microsoft Windows 8 Pro
				SKU: Professional
				Total Memory: 4095.11 MB
				Free Memory: 2227.96 MB
				Used Memory: 1867.152 MB
				SystemType: x64-based PC
				Physical Processors: 1
				Logical Processors: 4
				GPU 1 Name: AMD Radeon HD 6700 Series
				GPU 1 RAM: 1024.00 MB
				GPU 1 Driver Version: 14.100.0.0
				Sound 1 Device: High Definition Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: AMD High Definition Audio Device
				Sound 2 Status: Enabled
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1680x1050 (1680x1050 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
15:55:34:250 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
15:55:34:251 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\HyperLaunch.exe exists
15:55:34:251 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	3.0.1.1
				LegalCopyright          	�2013 HL squad
				File Size:			910336 bytes
				Created:			5/10/2014 - 1:35:11 PM
				Modified:			5/10/2014 - 1:34:28 PM
15:55:34:252 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\itextsharp.dll exists
15:55:34:253 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Created:			5/10/2014 - 1:35:10 PM
				Modified:			5/10/2014 - 1:34:29 PM
15:55:34:253 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\SevenZipSharp.dll exists
15:55:34:254 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
15:55:34:254 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\gsdll32.dll exists
15:55:34:255 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			8818688 bytes
15:55:34:255 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\BlockInput.exe exists
15:55:34:256 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
15:55:34:256 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\gdip.ahk exists
15:55:34:264 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
15:55:34:265 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
15:55:34:265 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\RIni.ahk exists
15:55:34:269 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:55:34:270 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
15:55:34:270 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\CLR.ahk exists
15:55:34:271 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:55:34:273 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10586 bytes
15:55:34:273 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\COM.ahk exists
15:55:34:274 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:55:34:276 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			26342 bytes
15:55:34:276 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\JSON.ahk exists
15:55:34:277 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:55:34:278 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
15:55:34:278 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Fade Init.ahk exists
15:55:34:279 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:280 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1145 bytes
15:55:34:280 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\HyperPause Init.ahk exists
15:55:34:281 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:282 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			691 bytes
15:55:34:282 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Keymapper Init.ahk exists
15:55:34:283 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:284 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3435 bytes
15:55:34:284 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\MultiGame Init.ahk exists
15:55:34:285 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:286 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
15:55:34:286 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Statistics Init.ahk exists
15:55:34:286 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:287 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			167 bytes
15:55:34:288 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Fade.ahk exists
15:55:34:289 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:290 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			25516 bytes
15:55:34:290 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\HyperPause.ahk exists
15:55:34:301 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:303 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			360180 bytes
15:55:34:303 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Keymapper.ahk exists
15:55:34:305 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:306 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			30775 bytes
15:55:34:306 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\MultiGame.ahk exists
15:55:34:308 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:309 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			36816 bytes
15:55:34:309 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Bezel.ahk exists
15:55:34:314 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:315 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			83008 bytes
15:55:34:315 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Statistics.ahk exists
15:55:34:316 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:317 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26153 bytes
15:55:34:318 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Rom Mapping Launch Menu.ahk exists
15:55:34:320 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:321 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			63798 bytes
15:55:34:321 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Shared.ahk exists
15:55:34:325 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:326 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			81966 bytes
15:55:34:326 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\XHotkey.ahk exists
15:55:34:328 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:329 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			28374 bytes
15:55:34:329 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Lib\Fade Animations.ahk exists
15:55:34:332 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:55:34:333 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			55410 bytes
				Modified:			5/11/2014 - 12:11:59 PM
15:55:34:333 | HL |     INFO  | +0     | Main - HyperLaunch received "Commodore Amiga" and "4DSportsDriving_v1.0_1461"
15:55:34:341 | HL |     INFO  | +16    | Main - 4DSportsDriving_v1.0_1461 is using the default emulator: WinUAE
15:55:34:341 | HL |     INFO  | +0     | Main - Checking for a [WinUAE] section in P:\Hyperspin\Settings\Commodore Amiga\Emulators.ini
15:55:34:341 | HL |     INFO  | +0     | Main - Checking for a [WinUAE] section in P:\Hyperspin\Settings\Global Emulators.ini
15:55:34:342 | HL |     INFO  | +0     | Main - Found [WinUAE] in P:\Hyperspin\Settings\Global Emulators.ini
15:55:34:343 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Modules\WinUAE\WinUAE.ahk exists
15:55:34:344 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			11546 bytes
15:55:34:345 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
15:55:34:345 | HL |     INFO  | +0     | Main - 4DSportsDriving_v1.0_1461 will use module: P:\Hyperspin\Modules\WinUAE\WinUAE.ahk
15:55:34:357 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
15:55:34:359 | HL |     INFO  | +0     | Main - INI Keys read
15:55:34:360 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\7z.exe exists
15:55:34:361 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
15:55:34:361 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Module Extensions\7z.dll exists
15:55:34:362 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
15:55:34:362 | HL |     INFO  | +0     | CheckPaths - Started
15:55:34:363 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461.7z
15:55:34:363 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461\4DSportsDriving_v1.0_1461.7z
15:55:34:363 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461\*.7z
15:55:34:363 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461.zip
15:55:34:365 | HL |     INFO  | +0     | CheckPaths - Found rom: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461.zip
15:55:34:365 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: 4DSportsDriving_v1.0_1461
15:55:34:365 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom
15:55:34:365 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
15:55:34:365 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\winuae.exe exists
15:55:34:367 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	WinUAE
				FileVersion             	2.7.0.0
				InternalName            	WinUAE
				LegalCopyright          	� 1996-2013 under the GNU Public License (GPL)
				OriginalFilename        	WinUAE.exe
				ProductName             	WinUAE
				ProductVersion          	2.7.0.0
				File Size:			10697728 bytes
				Created:			5/13/2014 - 11:23:18 AM
				Modified:			12/5/2013 - 4:21:46 PM
15:55:34:367 | HL |     INFO  | +0     | CheckPaths - Ended
15:55:34:368 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				hlMode =
				frontendPID = 0
				frontendPath = P:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = P:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\winuae.exe
				emuPath = P:\Hyperspin\Emulators\Commodore Amiga\WinUAE
				emuName = WinUAE
				emuExt = exe
				romPath = P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom
				romPathFromIni = P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = 7z|zip|adf|info|iso|cue|rom
				executable = winuae.exe
				systemName = Commodore Amiga
				dbName = 4DSportsDriving_v1.0_1461
				romName = 4DSportsDriving_v1.0_1461
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				blockInputTime = 0
				blockInputFile = P:\Hyperspin\Module Extensions\BlockInput.exe
				errorLevelReporting = true
				logFile = P:\Hyperspin\HyperLaunch.log
				logLevel = 10
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1680
				originalHeight = 1050
				dtEnabled = false
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2Pos = Center
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Animation = ZeroDreamsFade
				fadeLyr37zAnimation = ZeroDreamsFade
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = P:\Hyperspin\Media\Fade
				HLDataPath = P:\Hyperspin\Data
				HLMediaPath = P:\Hyperspin\Media
				HLErrSoundPath = P:\Hyperspin\Media\Sounds\Error
				modulesPath = P:\Hyperspin\Modules
				moduleFullName = P:\Hyperspin\Modules\WinUAE\WinUAE.ahk
				moduleName = WinUAE
				modulePath = P:\Hyperspin\Modules\WinUAE
				moduleExtension = ahk
				moduleExtensionsPath = P:\Hyperspin\Module Extensions
				libPath = P:\Hyperspin\Lib
				7zEnabled = false
				7zPath = P:\Hyperspin\Module Extensions\7z.exe
				7zDllPath = P:\Hyperspin\Module Extensions\7z.dll
				7zExtractPath = C:\Users\Gamer\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = P:\Hyperspin\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper =
				xpadderFullPath = P:\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = P:\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = P:\Hyperspin\Profiles\
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = P:\Hyperspin\Profiles\\HyperSpin
				defaultProfile = P:\Hyperspin\Profiles\\_Default
				systemProfile = P:\Hyperspin\Profiles\\Commodore Amiga
				xPadderSystemProfile = P:\Hyperspin\Profiles\\Commodore Amiga\_Default
				emuProfile = P:\Hyperspin\Profiles\\Commodore Amiga\WinUAE
				romProfile = P:\Hyperspin\Profiles\\Commodore Amiga\4DSportsDriving_v1.0_1461
				HyperLaunchProfile = P:\Hyperspin\Profiles\\HyperLaunch
				blankProfile = P:\Hyperspin\Profiles\\blank
				ahkFEProfile = P:\Hyperspin\Profiles\AHK\HyperSpin
				ahkDefaultProfile = P:\Hyperspin\Profiles\AHK\_Default
				ahkSystemProfile = P:\Hyperspin\Profiles\AHK\Commodore Amiga
				ahkEmuProfile = P:\Hyperspin\Profiles\AHK\Commodore Amiga\WinUAE
				ahkRomProfile = P:\Hyperspin\Profiles\AHK\Commodore Amiga\4DSportsDriving_v1.0_1461
				ahkHyperLaunchProfile = P:\Hyperspin\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
15:55:34:368 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
15:55:34:368 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
15:55:34:369 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
15:55:34:370 | HL |     INFO  | +15    | BuildScript - Module:
				MEmu = WinUAE
				MEmuV =  v2.6.0
				MURL = http://www.winuae.net/
				MAuthor = brolly
				MVersion = 2.0.2
				MCRC = 2283EB17
				iCRC = 587D7C70
				mId = 635138307631183750
				MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD"
				; Notes:
				; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
				; Just name them the same as the game name on the XML file.
				; Make sure you create a host config files with these names:
				; CD32 : cd32host.uae and cd32mousehost.uae;
				; CDTV : cdtvhost.uae and cdtvmousehost.uae;
				; Amiga : amigahost.uae;
				; Amiga CD : amigacdhost.uae;
				; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
				; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
				; a joystick and a mouse on Port1 and only a joystick on Port2.
				; Set all your other preferences like video display settings. And make sure you are saving a HOST
				; configuration file and not a general configuration file.
				; If you want to configure an exit key through WinUAE:
				; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
				; If you want to configure a key to toggle fullscreen/windowed mode:
				; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
				; CD32 and CDTV:
				; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
				; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
				; [Lemmings (Europe)]
				; UseMouse=true
				; [Project-X & F17 Challenge (Europe)]
				; DelayHack=true
				; Amiga:
				; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
				; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
				; END+SHIFT+1-0 = insert image from swapper slot 11-20
				; END+CTRL+1-4 = select drive
				; To do that follow the same procedure as above for the exit
				; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
				; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
				; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
				; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
				; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
				; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
				StartModule()
				FadeInStart()
				settingsFile := modulePath . "\" . systemName . ".ini"
				PathToWHDFolder := IniReadCheck(settingsFile, "Settings", "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
				PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings", "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
				PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
				PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
				; This object controls how the module reacts to different systems. MESS can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
				mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd")
				ident := mType[systemName]	; search object for the systemName identifier MESS uses
				If !ident
					ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
				windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
				If ( Fullscreen = "true" )
					windowClass = AmigaPowah
				specialcfg = %emuPath%Configurations\%romName%.uae
				If romExtension in .hdf,.vhd
					DefaultRequireWB := "true"
				Else
					DefaultRequireWB := "false"
				If romExtension in .zip,.lha,.rar,.7z
					SlaveFile := COM_Invoke(HLObject, "findByExtension", romPath . "\" . romName . romExtension, "slave")
					If (SlaveFile)
						If romName contains (AGA)
							DefaultOptions := "-s cycle_exact=false " . "-s immediate_blits=false " . "-s cpu_compatible=false " . "-s cpu_speed=max " . "-s cachesize=8192" ;AGA
						Else
							DefaultOptions := "-s cycle_exact=true " . "-s immediate_blits=false " . "-s cpu_compatible=false " . "-s cpu_speed=real " . "-s cachesize=8192 " ;Non-AGA
				usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1)
				delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1)
				options := IniReadCheck(settingsFile, romName, "Options",DefaultOptions,,1)
				videomode := IniReadCheck(settingsFile, romName, "VideoMode","PAL",,1)
				floppyspeed := IniReadCheck(settingsFile, romName, "FloppySpeed","turbo",,1)
				quickstartmode := IniReadCheck(settingsFile, romName, "QuickStartMode",A_Space,,1)
				immediateblitter := IniReadCheck(settingsFile, romName, "ImmediateBlitter","false",,1)
				requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
				customwb := IniReadCheck(settingsFile, romName, "CustomWB",A_Space,,1)
				whdloadoptions := IniReadCheck(settingsFile, romName, "WHDLoadOptions","PRELOAD",,1)
				neverextract := IniReadCheck(settingsFile, romName, "NeverExtract","false",,1)
				fs := If (Fullscreen = "true") ? "true" : "false"
				videomode := (If videomode = "NTSC" ? ("-s ntsc=true") : (""))
				floppyspeed := (If floppyspeed ? ("-s floppy_speed=" . floppyspeed) : (""))
				If (requireswb = "true")
					ident := "a1200"
					If (customwb)
						PathToWorkBenchBase := %EmuPath% . "\" . customwb
					CheckFile(PathToWorkBenchBase)
					wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
					ident := "a1200"
					gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
				If (immediateblitter = "true")
					options := options . " " . "-s immediate_blits=true"
				options := options . " " . videomode
				If (ident = "a500" or ident = "a1200")
					If romName contains (AGA),(LW)
						ident := "a1200"
					If (SlaveFile)
						CheckFile(PathToWHDFolder)
						ident := "a1200"
						;Create the user-startup file to launch the game
						WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
						SplitPath, SlaveFile, SlaveName, SlaveFolder
						FileDelete, %WHDUserStartupFile%
						FileAppend, echo "";`n, %WHDUserStartupFile%
						FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
						FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
						FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
				If FileExist(specialcfg)
					;Game specific configuration file exists
					configFile = %romName%.uae
				Else
					;Game specific configuration file doesn't exist
					If (ident = "cd32" or ident = "cdtv")
						configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
						quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					Else
						;Amiga or Amiga CD game
						configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
						If quickstartmode
							quickcfg := "-s quickstart=" . quickstartmode
						Else
							quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : "-s quickstart=a1200`,1"
						If (SlaveFile)
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive)
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
						Else If romExtension in .cue,.iso
							;Amiga CD game
							options := options . " " . wbDrive . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						Else
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through HyperLaunch MG menu
								if romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							if romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
				param1 := "-f " . """" . EmuPath . "\Configurations\" . configFile . """" . " " . quickcfg
				param2 := "-s use_gui=no -s gfx_fullscreen_amiga=" . fs
				param3 := options
				;MsgBox, %param1% %param2% %param3% %param4% %param5% %param6%
				;ExitApp
				;disableActivateBlackScreen = true
				Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . param4 . A_Space . param5 . A_Space . param6 . A_Space . " -portable", emuPath)
				WinWait("ahk_class " . windowClass)
				WinWaitActive("ahk_class " . windowClass)
				FadeInExit()
				Process("WaitClose",executable)
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				MultiGame:
					If currentButton = 10
						diskslot = 0
					Else If currentButton > 10
						diskslot := currentButton - 10
					Else
						Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
					Else
						Send, {End Down}%diskslot%{End Up}
				return
				CloseProcess:
						If (SlaveFile)
							;Copy default-user-startup to user-startup if file exists
							IfExist, %PathToWHDFolder%\S\default-user-startup
								FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
					FadeOutStart()
					WinClose, ahk_class %windowClass%
				return
				AbsoluteFromRelative(MasterPath, RelativePath)
				   VarSetCapacity(AbsP,260,0)
				   DllCall( "shlwapi\PathCombineA", Str,AbsP, Str,MasterPath, Str,RelativePath )
				   Return AbsP
15:55:34:371 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
15:55:34:371 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
15:55:34:371 | HL |     INFO  | +0     | Main - Module is built
15:55:34:371 | HL |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\AutoHotkey.dll exists
15:55:34:373 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			785408 bytes
				Modified:			5/10/2014 - 1:34:27 PM
15:55:34:375 | HL |     INFO  | +0     | Main - Running module
15:55:34:375 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
15:55:34:488 | MD |     INFO  | +N/A   | Module initialized
15:55:34:490 | MD |     INFO  | +0     | StartModule - Started
15:55:34:490 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
				MEmuV: v2.6.0
				MURL: http://www.winuae.net/
				MAuthor: brolly
				MVersion: 2.0.2
				MCRC: 2283EB17
				iCRC: 587D7C70
				MID:
				MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD"
15:55:34:491 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
15:55:34:491 | MD |   DEBUG1  | +0     | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: 4DSportsDriving_v1.0_1461
15:55:34:491 | MD |     INFO  | +0     | StartModule - Ended
15:55:34:492 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
15:55:34:492 | MD |     INFO  | +0     | Module Setting - [settings] - PathToWHDFolder: .\WHD
15:55:34:492 | MD |     INFO  | +0     | Module Setting - [settings] - PathToWorkBenchBase: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\HDD\Workbench31_Lite.vhd
15:55:34:595 | MD |     INFO  | +110   | Module Setting - [4DSportsDriving_v1.0_1461] - UseMouse: false
15:55:34:595 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - DelayHack: false
15:55:34:595 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - Options: -s cycle_exact=true -s immediate_blits=false -s cpu_compatible=false -s cpu_speed=real -s cachesize=8192
15:55:34:596 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - VideoMode: PAL
15:55:34:596 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - FloppySpeed: turbo
15:55:34:596 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - QuickStartMode:
15:55:34:597 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - ImmediateBlitter: false
15:55:34:597 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - RequiresWB: false
15:55:34:597 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - CustomWB:
15:55:34:598 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - WHDLoadOptions: PRELOAD
15:55:34:598 | MD |     INFO  | +0     | Module Setting - [4DSportsDriving_v1.0_1461] - NeverExtract: false
15:55:34:598 | MD |     INFO  | +0     | CheckFile - Checking if P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\WHD exists
15:55:34:599 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			0 bytes
				Created:			5/13/2014 - 11:26:19 AM
				Modified:			5/13/2014 - 11:26:32 AM
15:55:34:601 | MD |     INFO  | +0     | Run - Running: P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\winuae.exe -f "P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s use_gui=no -s gfx_fullscreen_amiga=true -s cycle_exact=true -s immediate_blits=false -s cpu_compatible=false -s cpu_speed=real -s cachesize=8192  -s filesystem=rw,WHD:"P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\WHD" -s filesystem=ro,Games:"P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461.zip"     -portable
15:55:34:640 | MD |   DEBUG1  | +46    | Run - Error Level for winuae.exe -f "P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s use_gui=no -s gfx_fullscreen_amiga=true -s cycle_exact=true -s immediate_blits=false -s cpu_compatible=false -s cpu_speed=real -s cachesize=8192  -s filesystem=rw,WHD:"P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\WHD" -s filesystem=ro,Games:"P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461.zip"     -portable reported as: 0
15:55:34:640 | MD |   DEBUG1  | +0     | Run - "winuae.exe -f "P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s use_gui=no -s gfx_fullscreen_amiga=true -s cycle_exact=true -s immediate_blits=false -s cpu_compatible=false -s cpu_speed=real -s cachesize=8192  -s filesystem=rw,WHD:"P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\WHD" -s filesystem=ro,Games:"P:\Hyperspin\Emulators\Commodore Amiga\WinUAE\rom\4DSportsDriving_v1.0_1461.zip"     -portable" Process ID: 5616
15:55:34:640 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;93238642-415e-4350-9b24-0dbb2994e487] | State: 0 | X: 1 | Y: 1 | Width: 1434 | Height: 880 | Window HWND: 0x304c2 | Process ID: 3232 | Process Path: P:\Hyperspin\HyperLaunchHQ\HyperLaunchHQ.exe
15:55:34:641 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
15:56:04:639 | MD |   DEBUG1  | +29999 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;93238642-415e-4350-9b24-0dbb2994e487] | State: 0 | X: 1 | Y: 1 | Width: 1434 | Height: 880 | Window HWND: 0x304c2 | Process ID: 3232 | Process Path: P:\Hyperspin\HyperLaunchHQ\HyperLaunchHQ.exe
15:56:04:987 | MD |   DEBUG1  | +344   | ScriptError - Playing error sound: error8.mp3
15:56:20:849 | MD |    ERROR  | +15865 | There was an error waiting for the window "ahk_class AmigaPowah". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
15:56:20:849 | MD |     INFO  | +0     | ExitModule - Started
15:56:20:849 | MD |     INFO  | +0     | Starting Updating Statistics:
15:56:20:849 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
15:56:20:849 | MD |   DEBUG2  | +0     | gameSectionStartTime:36811165
15:56:20:850 | MD |   DEBUG2  | +0     | ElapsedTime:46
15:56:20:850 | MD |     INFO  | +0     | CreateRomTable - Started
15:56:20:850 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Disc"
15:56:20:850 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Disk"
15:56:20:851 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Cart"
15:56:20:851 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Tape"
15:56:20:851 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Cassette"
15:56:20:851 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Part"
15:56:20:851 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "4DSportsDriving_v1.0_1461" and "(Side"
15:56:20:852 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
15:56:20:852 | MD |   DEBUG2  | +0     | Statistics cleared game name: 4DSportsDriving_v1.0_1461
15:56:20:875 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
				Number_of_Times_Played: 0
				Last_Time_Played: 0
				Average_Time_Played: 0
				Total_Time_Played: 0
				System_Total_Played_Time: 674
				Total_Global_Played_Time: 32030
15:56:20:876 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 1
				Last_Time_Played: Saturday May 24, 2014 03:55:34 PM
				Average_Time_Played: 46
				Total_Time_Played: 46
				System_Total_Played_Time: 720
				Total_Global_Played_Time: 32076
15:56:20:900 | MD |     INFO  | +16    | Game section statistics updated.
15:56:20:901 | MD |     INFO  | +0     | ExitModule - Ended
15:56:20:901 | MD |     INFO  | +0     | End of Module Logs
15:56:20:967 | HL |     INFO  | +46598 | Main - Module ended, exiting HyperLaunch normally
15:56:20:967 | HL |     INFO  | +0     | ExitScript - Started
15:56:20:983 | HL |     INFO  | +15    | SystemCursor - Restoring mouse cursor
15:56:20:994 | HL |     INFO  | +0     | ExitScript - Ended
Austin,
What version of WinUAE are you running? And If you paste your run command into a command line, does it run without errors?
Thanks,
Ron
Version=WinUAE 2.7.0 (2013.12.05) is the version I am currently running Ron. Sorry its taken me so long to get back to you. Bank Holiday weekend over here and there was far too many beverages being passed around to say no :D
As for the command line Im not sure when it comes to this thing. I cut and pasted into the CMD Prompt but it just comes back saying its not a batch file?
