Anyone use Ultimarc LED for thier track ball? OVERHEATING?
trailervert
Hi Guys, I finally got around to installing my track ball leds. I am using Ultimarc's "U-Trak RGB LED Illumination Kit".
I have it controlled with a Pac64Led. It works fine but the board gets SUPER hot in just a matter of minutes. It got hot enough that you could feel it through the ball, which is how I noticed it and then unhooked it. Anyone else experiencing anything like this?
The power and ground are both coming from the Pac64 board.
I have mine wired to my pacled64 and it works just fine. This is how it tells you to set it up on the ultimarc site.
Sent from my SM-N9005 using Tapatalk
sig2.png?raw=1sig.jpg?raw=1
I was wondering about that. I thought the PACLed was USB powered and therefore 5V unfortunately my cab is still in planning phase so all I my info is just theory.
How did you find you had 12V going into your trackball and where was it getting that current from?
The pacled64 is powered via a spare molex connector. I have this connected to the 5v (red) power line. Is the 5v power line not giving you the brightness you want ?
He is connecting to the 12v (yellow) power line.
" Connecting Power and USB
The PacLED64 is supplied with a power cable which plugs onto a spare PC power supply hard drive power connector.
When shipped, the + (positive) wire is not inserted into the connector housing. There is a choice of 5 volt or 12 volt power available on HDD power connectors.
Select as follows:
If you are using mainly LEDs with in-built resistors:
Select the location which mates with the YELLOW wire on the PC connector. This is 12 volts.
Examples of this type of LED are:
* Ultimarc Ultralux pushbutton LEDs
* Ultimarc U-Trak trackball illumination kit
* All 5 volt or 9 volt LED lamps
If you are using mainly LEDs without resistors (standard LEDs):
Select the location which mates with the RED wire (5 Volts).
Using 5 volts reduces power wastage and keeps the temperature of the driver ICs on the board to acceptable levels.
Also, connect the USB cable to a USB port on the PC."
