Sergio_di_Rio Posted April 22, 2016 Posted April 22, 2016 Hi. I've some problem with "rating" (fade folder) images in Hyperspin. If i run a game in RocketLauncher are ok, but when i use Hyperspin, images are not. Thank's for your answer. Forgive my basic english, hope you will hunderstand me.
Metalzoic Posted April 22, 2016 Posted April 22, 2016 Are you saying that straight from RocketLauncher the rating graphics show up on the Fade screen. But if you launch from HyperSpin they don't show up on the RocketLauncher Fade screen? Did you just start setting this up today or yesterday? Because RLauncher updated yesterday and there were issues with Fade screen code.
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 Are you saying that straight from RocketLauncher the rating graphics show up on the Fade screen. But if you launch from HyperSpin they don't show up on the RocketLauncher Fade screen? Did you just start setting this up today or yesterday? Because RLauncher updated yesterday and there were issues with Fade screen code. Yes, from Hyperspin they don't show up, but from RocketLauncher is all right. I do not know if it's my mistake, or is it a bug. Maybe someone more experienced than me can give me an answer. I'm a newbie with Hyperspin. I downloaded Hyperspin and Rocket Launcher last week.I've followed the Simple Austin tutorial on youtube for all settings.
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 Welcome Sergio. Hi, please to meet you
gigapig Posted April 23, 2016 Posted April 23, 2016 Do you see the fade screen when launching from Hyperspin? I ask because maybe HyperSpin is not set to use Rocketlauncher for that system.
Metalzoic Posted April 23, 2016 Posted April 23, 2016 Yes, from Hyperspin they don't show up, but from RocketLauncher is all right. I do not know if it's my mistake, or is it a bug. Maybe someone more experienced than me can give me an answer. I'm a newbie with Hyperspin. I downloaded Hyperspin and Rocket Launcher last week.I've followed the Simple Austin tutorial on youtube for all settings.I'm not sure what could cause that. The fade screen is controlled entirely by RocketLauncher. Nothing should change launching through Hyperspin as HS doesn't affect Fade screens in any way I know. So it should be the exact same fade screen that pops up either way. Do the other Fade items show up fine? (genre, times played, title, background, year etc...) Sent from my SM-G935V
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 I'm not sure what could cause that. The fade screen is controlled entirely by RocketLauncher. Nothing should change launching through Hyperspin as HS doesn't affect Fade screens in any way I know. So it should be the exact same fade screen that pops up either way. Do the other Fade items show up fine? (genre, times played, title, background, year etc...) Sent from my SM-G935V yes, other fade is ok, less rating. if i can i post some image with this problem.
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 Do you see the fade screen when launching from Hyperspin? I ask because maybe HyperSpin is not set to use Rocketlauncher for that system. yes, fade screen start in Hyperspin, less rating image. Maybe a problem with resolution? But are in fullscreen both. Is there some check settings to launch fade from Rocketlauncher path?
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 This is from Rocket Launcher And this is from Hyperspin
gigapig Posted April 23, 2016 Posted April 23, 2016 I know the ratings were moved to there own folder for a recent update, do you still have them in the Fade>Default folder? They should now be in :\RocketLauncher\Media\Rating\_Default Edit Just seen your screen shots. Do you have HyperSpin pointing at another version of RocketLauncher you have on your machine?
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 I know the ratings were moved to there own folder for a recent update, do you still have them in the Fade>Default folder? They should now be in :\RocketLauncher\Media\Rating\_Default Edit Just seen your screen shots. Do you have HyperSpin pointing at another version of RocketLauncher you have on your machine? i've only a version of Rocket Launcher in my pc. Rating folder is in :\RocketLauncher\Media\Fade\_Default\Rating Edit My Rocket Launcher version is 1.0.1.5 and Rocket LauncherUI 1.0.1.0
Dime333 Posted April 23, 2016 Posted April 23, 2016 Bleasby posted this in the RL forum about this. Maby this will fix your issue. Got to Settings>Fade - Info>Game Info Text>Appearance>Game Info Order> and set it to Description|SystemName|Year|Publisher|Genre|Rating |Developer
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 Bleasby posted this in the RL forum about this. Maby this will fix your issue. Got to Settings>Fade - Info>Game Info Text>Appearance>Game Info Order> and set it to Description|SystemName|Year|Publisher|Genre|Rating |Developer Doesn't work
gigapig Posted April 23, 2016 Posted April 23, 2016 If that did not work and you keep Rocketlauncher up to date, did you move the ratings to the correct folder as I mentioned?
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 This is the genre folder in Rocket Launch. Is correct?
gigapig Posted April 23, 2016 Posted April 23, 2016 This is the genre folder in Rocket Launch. Is correct? No not if you keep Rocketlauncher up to date. Look at post 11 for the correct path/folder.
Sergio_di_Rio Posted April 23, 2016 Author Posted April 23, 2016 My Rocket Launcher version is 1.0.1.5 and Rocket LauncherUI 1.0.1.0 is the last, right?
sevenseal Posted April 24, 2016 Posted April 24, 2016 all fade info is all gather from your hyperspin database files... if you system database file does not contain the additional information as such as rating, manufacturers, years and such it will not display... so please check your database if it has those parameters in the xml... using custom database often have those additions info data stripped out. normally sticking with official is a good idea which often maintain those info in the database even thought rocketlauncher has these description and data info... much is still pulled from the database.xml files of hyperspin to find it...
Metalzoic Posted April 24, 2016 Posted April 24, 2016 If it were missing from his database wouldn't the info also be missing when he launches straight through RL though. RL pulls it from the same xml either way.
Sergio_di_Rio Posted April 24, 2016 Author Posted April 24, 2016 Thank's to all for your support, i removed all and reinstalled. Now every thing is ok. Have a good night.
