Casual Games - PopCap
DrTechnolust
I receive the following error when I try to launch Alchemy within HLHQ.
00:52:45:758 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1
00:52:45:852 | HL |     INFO  | +94    | Main - System Specs:
				HyperLaunch Dir: I:\HyperSpin\HyperLaunch
				OS: Microsoft Windows 8.1 Enterprise
				SKU: Enterprise
				Total Memory: 4095.30 MB
				Free Memory: 1927.77 MB
				Used Memory: 2167.531 MB
				SystemType: x64-based PC
				Physical Processors: 1
				Logical Processors: 4
				GPU 1 Name: NVIDIA GeForce GTS 250
				GPU 1 RAM: 512.00 MB
				GPU 1 Driver Version: 9.18.13.3221
				Sound 1 Device: High Definition Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
				Sound 2 Status: Enabled
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x984 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
00:52:45:860 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
00:52:45:867 | HL |     INFO  | +15    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
00:52:45:875 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Your favorite Front End companion! BETA
				FileVersion             	3.0.1.1
				File Size:			909824 bytes
				Created:			1/7/2014 - 11:09:33 PM
				Modified:			1/16/2014 - 10:57:57 PM
00:52:45:883 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\itextsharp.dll exists
00:52:45:892 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Created:			1/7/2014 - 11:10:23 PM
				Modified:			1/16/2014 - 10:57:59 PM
00:52:45:900 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists
00:52:45:911 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
				Modified:			1/16/2014 - 10:57:58 PM
00:52:45:919 | HL |     INFO  | +15    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\gsdll32.dll exists
00:52:45:929 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			8818688 bytes
				Created:			1/7/2014 - 11:10:22 PM
00:52:45:938 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe exists
00:52:45:949 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
				Created:			1/16/2014 - 11:03:42 PM
00:52:45:958 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists
00:52:45:994 | HL |   DEBUG1  | +46    | CRC Check - CRC matches, this is an official unedited Extension.
00:52:45:005 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
				Created:			1/7/2014 - 11:10:21 PM
00:52:46:014 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists
00:52:46:036 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
00:52:46:048 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			67561 bytes
00:52:46:056 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists
00:52:46:069 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:52:46:078 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			10586 bytes
				Created:			1/7/2014 - 11:10:20 PM
00:52:46:091 | HL |     INFO  | +15    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists
00:52:46:105 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
00:52:46:115 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
00:52:46:123 | HL |     INFO  | +15    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists
00:52:46:134 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
00:52:46:144 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
00:52:46:148 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists
00:52:46:151 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:154 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1145 bytes
				Created:			1/7/2014 - 11:09:39 PM
00:52:46:158 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists
00:52:46:161 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:165 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			691 bytes
00:52:46:168 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists
00:52:46:172 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:175 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3435 bytes
00:52:46:179 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists
00:52:46:182 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:186 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
00:52:46:189 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists
00:52:46:193 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:196 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			167 bytes
00:52:46:199 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists
00:52:46:204 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:208 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			25516 bytes
00:52:46:210 | HL |     INFO  | +15    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists
00:52:46:235 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:249 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			360180 bytes
00:52:46:258 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists
00:52:46:271 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:285 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			30775 bytes
00:52:46:294 | HL |     INFO  | +15    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists
00:52:46:313 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:323 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			36816 bytes
00:52:46:333 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists
00:52:46:352 | HL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:355 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			83008 bytes
00:52:46:358 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists
00:52:46:363 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:367 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			26153 bytes
00:52:46:370 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
00:52:46:376 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:380 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			63798 bytes
00:52:46:383 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists
00:52:46:390 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:394 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			80791 bytes
00:52:46:397 | HL |     INFO  | +16    | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists
00:52:46:402 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:406 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			28374 bytes
00:52:46:410 | HL |     INFO  | +0     | CheckFile - Checking if I:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists
00:52:46:416 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:52:46:420 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			49050 bytes
00:52:46:424 | HL |     INFO  | +0     | Main - HyperLaunch received "PopCap" and "Alchemy"
00:52:46:435 | HL |     INFO  | +16    | Main - Alchemy is using the default emulator: Casual Games
00:52:46:440 | HL |     INFO  | +0     | Main - Checking for a [Casual Games] section in I:\HyperSpin\HyperLaunch\Settings\PopCap\Emulators.ini
00:52:46:443 | HL |     INFO  | +0     | Main - Checking for a [Casual Games] section in I:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
00:52:46:446 | HL |     INFO  | +16    | Main - Found [Casual Games] in I:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
00:52:46:449 | HL |     INFO  | +0     | CheckFile - Checking if I:\Hyperspin\HyperLaunch\Modules\Casual Games\Casual Games.ahk exists
00:52:46:453 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			5283 bytes
				Created:			1/7/2014 - 11:10:24 PM
00:52:46:456 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
00:52:46:460 | HL |     INFO  | +15    | Main - Alchemy will use module: I:\Hyperspin\HyperLaunch\Modules\Casual Games\Casual Games.ahk
00:52:46:476 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
00:52:46:844 | HL |   DEBUG1  | +359   | ScriptError - Playing error sound: error9.mp3
00:52:49:991 | HL |    ERROR  | +3156  | Could not find an Emu_Path for Casual Games in either of these two files:
00:52:49:996 | HL |     INFO  | +0     | ExitScript - Started
00:52:49:018 | HL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
00:52:50:066 | HL |     INFO  | +47    | ExitScript - Ended
The error is telling you the problem...
Did you read the module notes for casual games?
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
*grins* I think we know the answer to that question
Do you know where to find the module notes? The info in these notes makes your job setting up each emulator much easier.
Prior to posting a thread it is always asked that you post your troubleshooting log which you did. It is also a good idea to read your troubleshooting log before posting it as your answers are in the log for most issues.
No I did not read it I didn't even know that feature existed until you pointed it out.
Now after reading the notes. I am still unclear what I have incorrect here.
In global settings editor for Casual Games.ahk - Rom Settings - Alchemy was added and I added the gamePath to the "Alchemy" .exe file.
In the Edit Casual Games Emulator - Path is blank \ Rom Extensions is blank \ Module has Casual Games.ahk \ Virtual Emulator is checked
Not sure what else I'm missing here?
Ghutch already gave you the answer.
Sent from my Samsung Galaxy S3 using Tapatalk 4.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Turn skipchecks on to rom and emu for the module casual games.
Thanks that worked!!!!!!!!!!!! After 3 days of researching this and finally making a post on here about it.
The key to look for in the log is the errors and then work your way back from there:
I love this stuff man!
  • 5 months later...
