crgnjul Posted January 29, 2014 Posted January 29, 2014 I am in the early stages of building a HyperPin cabinet. I am waiting on my lockdown bar so that I can get correct measurements for the cabinet. In the meantime I've started building the PC and getting the software running. The problem I'm having right now seem like it should be simple, so I'm probably just missing something. I'm using HyperPin, VP9 and FPLaunch 1.295 WIP 10. In the table, if I hit ESC I get the VP pause menu (not what I want). If I tap e I get the hyperpin exit menu (back, instructions, flyer, service, exit) if I hold e I get the exiting in 3..2..1 I like it this way and plan on making my "exit" button on the cabinet map the e on the ipac. The problem I have is that when I exit back to the Wheel Menu e no longer brings up the HyperPin exit menu. I have to use ESC. Of course I only want 1 button for this on the cabinet. So I went into the settings.ini and change keyboard exit = 27 to keyboard exit = 65 which I believe is HEX for e. However when I do that the e does not work, nor does the ESC any more. I can't exit at all. What am I missing?
MTPPC Posted January 31, 2014 Posted January 31, 2014 The setting in vp needs to be switched to 'e'. Keyboard exit should still be esc and 'exit emulator' setting that needs to be 'e' in the settings.ini
crgnjul Posted February 5, 2014 Author Posted February 5, 2014 In case anyone else needs this, hyperpin does not use HEX codes, it uses Action Script. e in Action Script is 69. http://people.uncw.edu/tompkinsj/112/FlashActionScript/keyCodes.htm is the full list.
otherguy Posted March 19, 2014 Posted March 19, 2014 Hi, I am using the latest version of FP Launch and everything works okay until I want to exit a game back to Hyperspin. I have my E key mapped and the pause screen comes up, then I select exit table and it exits out fine however, then the screen sits at hyperspin and freezes. I cannot select a new table to play. If I hit Alt-Tab just to refresh the screen, then it starts working again and I can select a new pinball board. Anyone able to help with this please?
zebulon Posted March 22, 2014 Posted March 22, 2014 It's losing focus on hyperpin, reduce the screen and see what other window is open below it and you'll have found the problem. I know so much about so little that I could teach you everything there is to know about nothing....
