Video Snaps Stop after first play
crazyfiz
I have been an Hyperspin user for a while now and with the support of this web site i have been able to answer any question, but now i am stumped.  I have the latest version of hyperspin and rocket launcher and my game snaps will only load for the first selected title, if i change to another game no snaps including the one that had played will play.  If I go back to the main menu those snaps work but upon entering a system only the first selected video plays ONCE.  These did work for me previously and i have the same result on every machine i have tried this on as my setup in on a portable drive. Please help i am lost.
Im using the old flvs that I acquired from pleasure dome.  But as a test I removed the flvs and left the one  .mp4 i have a double of, and it still only plays once then no more until i exit back to the main menu then back.  I can have any snap load i want as long as its the first. so i believe its not in the videos.
Don't know if it will help but a quick look at RocketLauncher and the only thing I can see to do with videos is:
"Global" tab > "Pause" tab > scroll down to "Videos". "Enable Loop" set to "True"
I know this is for the "Pause" menu but I can't see anything else!?!
I am running windows 10 and have exceptions for all related hyperspin exes or else I get excessive lag. I also have speakers on my main cab and have tried on laptops with internal speakers. I will check the enable loop when I am back @ a pc. Thanks for the help so far everyone. I also haven't heard of this b4 and only found 1 person on the Web with this issue but they were running Linux and never got it resolved to my knowledge
I found enable loop on the global>pause>menu tab under video and yes it is set to true also under supported extensions there was no flv so I added it with no luck
GPU is up to date plus this spans every machine I have tried regardless of video card. Laptops desktops Nvidia ATI internal or add on.
THANK YOU volumetric!!!  In hyperHQ under the Wheel Settings> (Choose wheel) > navigation/themes tab there is a check box for reload backgrounds.  and when checked the problem is resolved for that wheel.  i guess i will have to change them all manually but at least the problem is resolved :thanks:  :thumbsup:
