KlopjerO Posted June 7, 2016 Posted June 7, 2016 Eya. Recently I have a found a great Cab schematic (The Metopolis cab). but I want to make a few modifications to it. I want it to have a rotating monitor.. the way that Connersdad has one..so a flat panel monitor mounted on a lazy suzan and driven by an electro motor and controlled by a polulu board. all that set aside.. the width of cab by design is 24"... and I have the unfortune that my (touch)screen has a diagonal of 25,7". now down to the question at hand... from an esthetic point of view would it be prudent to enlarge the entire cab relative to the increased width..or just widen ?the person who designed the cab was nice enough to provide the DWG files. I want to provide the dwg file to a CNC mill and have them cut the boards out what would I need to change in the DWG so that it takes into account this change in plans ? I provided a pdf of the DWG so you can see what I'm talking about. I also provided a pdf of my monitor with it's deminsions in (mm) METROPOLIS_ARCADE_CAB-PDF.pdf prolite t2452mts-b1 (1465280325).pdf | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
Goodboyparker Posted June 11, 2016 Posted June 11, 2016 I'm not sure I understand the issue. The cabinet is 24" wide and the pdf shows a monitor width of 22+ inches. It looks like it will fit in either orientation. If it spins do you need to put the monitor proud of the cabinet? Or, do you want the monitor to spin inside of the cabinet? (Hence it would not fit)...
KlopjerO Posted June 13, 2016 Author Posted June 13, 2016 I'm not sure I understand the issue. The cabinet is 24" wide and the pdf shows a monitor width of 22+ inches. It looks like it will fit in either orientation. If it spins do you need to put the monitor proud of the cabinet? Or, do you want the monitor to spin inside of the cabinet? (Hence it would not fit)... Sorry I did not get a message that you replied to my thread yes I want it to rotate internally. and it would not fit in that regard. my question is purely about looks.. should I enlarge the entire cab to match the increased width or should just widen it .? | My themes / downloads | Get the MS-DOS Wheel sound pack | Get your MS-DOS game themes here | Get the MS-DOS wheel set here | My YouTube channel | WarcrafT - Lord of the clans |ZeroJay's Ultimate DooM archive
Metalzoic Posted June 13, 2016 Posted June 13, 2016 Just widen it. Enlarging the entire thing will probably just make the monitor look like it is way to small for it.
