Complete Guide for Commodore Amiga in HS and HL3 Using WinUAE Only
rfancella
Hi Ron, great tutorial thanks for that, its really helpful.
Ive got one question, It all works ok but I seem to have a few games that will launch, and you see the company/game name etc then it seems to try to get to the actual 'game' but the screen just stays black. This only happens on some and not all, so im wondering if this is an actual individual configuration to the game setting rather than an emu one. For example it does it on the Alien Breed games for me.
Any ideas?
Cheers,
Foz.
Actually the above seems to happen when i follow Austins video guide but not if i start again and follow Rons guide - but my Ipac controls dont seem with Rons, even when i remap them all as i had to do this in Austins guide and they worked fine.
Think ill start again and see where im going wrong after taking a break!
Cheers guys.
  • Replies 420
Thanks much for the props guys!
Thanks,
Ron
Hi Foz,
Yea, the forum software changed and got re-indexed since I wrote that guide.
Not much to do about it but figure out the post and re-do the links.  All those posts are in the thread.  Just scan through it for now.  ;)
Thanks,
Ron
Lots of help here in the form of links to other pages from this site, but a lot (not all) of them dont actually goto the page youre trying to get to. They display the link in the bar ok but only show the same page which seems to be the forums?
Any one else have this? For example if i click on the link below it just takes me to the forum pages:
http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only&p=347401&viewfull=1#post347401
Ive tried different PCs and browsers but still the same issue?
Thanks all.
Foz.
  • 4 weeks later...
Settings that I save to amigahost.uae in WinUAE, doesn´t seem to be saved/loaded. Every time I try to start a game from RL I get the error message:
"The selected system ROM requires a 68020 with 32-bit adressing or 68030 or higher CPU", and throws me back to the config window, even if I saved the CPU setting to amigahost earlier.
If I then set the CPU manually and press start, the game starts.
Any ideas?
Any ideas?
Hi,
Couple things to check.
Is your amigahost.uae file in the Host directory?
What are your CPU settings in the module settings?
Set your logging level to "Troubleshooting" and post your RocketLauncher log.
Thanks,
Ron
Thanks for your answer, Ron.
If I just open WinUAE, CPU defaults to 68000. When I then load amigahost it´s set to 68030 (that the error asked for).
Amigahost.uae is in the "Host" folder.
Also I`m on Windows 10. Found this webpage: "http://www.tweakguides.com/Amiga_3.html", under "Paths: Important" it mentions possible problems
with the paths. My hyperspin setup is on my D drive, difficult to change this. I tried to give WinUAE admin privileges and moved the UAC bar all the way down, but still the same.
​Here is the log:
[code=auto:0]10:58:59:568 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)10:59:00:310 | RL |     INFO  | +735   | Main - System Specs:RocketLauncher Dir: D:\RocketLauncherRocketLauncher is: 32-bitOS: Microsoft Windows 10 ProSKU: ProfessionalTotal Memory: 6142.49 MBFree Memory: 1869.10 MBUsed Memory: 4273.387 MBSystemType: 64-bitPhysical Processors: 1Logical Processors: 8GPU 1 Name: NVIDIA GeForce GTX 970GPU 1 RAM: -1.00 MBGPU 1 Driver Version: 10.18.13.5850Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)Sound 1 Status: EnabledSound 2 Device: Realtek High Definition AudioSound 2 Status: EnabledSound 3 Device: HD Webcam C270Sound 3 Status: EnabledSound 4 Device: NVIDIA High Definition AudioSound 4 Status: EnabledSound 5 Device: PlayOn Virtual Audio DeviceSound 5 Status: EnabledOS Language: English_United_StatesOS Admin Status: NoLatest .Net Version: v4.0.30319Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [Landscape] (Primary)Current AHK Desktop Width: 1920Current AHK Desktop Height: 1080AutoHotkey Path:AHK Version: 1.1.09.04Unicode: No10:59:00:311 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\RocketLauncher.exe exists10:59:00:311 | RL |   DEBUG1  | +0     | CheckFile - Attributes:FileDescription         RocketLauncherFileVersion             1.0.1.3LegalCopyright           �2015 RocketLauncherProductName             djvj's one swell guy!ProductVersion           1.1.9.4CompanyName             Your favorite Front End companion! Visit us @ www.rlauncher.comFile Size: 2061824 bytesCreated: 10/2/2015 - 1:27:09Modified: 10/2/2015 - 1:51:2510:59:00:311 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\BinHexRW.ahk exists10:59:00:316 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:317 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 4961 bytesCreated: 10/2/2015 - 1:27:11Modified: 6/4/2014 - 11:48:1210:59:00:317 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\BlockInput.exe exists10:59:00:349 | RL |   DEBUG1  | +31    | CheckFile - Attributes:FileDescriptionFileVersion             1.1.09.04InternalNameOriginalFilenameProductNameProductVersion           1.1.09.04File Size: 657920 bytesCreated: 10/2/2015 - 1:27:11Modified: 1/2/2014 - 10:27:3410:59:00:349 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\CLR_L.ahk exists10:59:00:350 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:350 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 5474 bytesCreated: 10/2/2015 - 1:52:07Modified: 10/2/2015 - 1:52:0810:59:00:351 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\Control_AniGif.ahk exists10:59:00:351 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:352 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 5716 bytesCreated: 10/2/2015 - 1:27:11Modified: 4/29/2013 - 2:56:0210:59:00:352 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\gdip.ahk exists10:59:00:354 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:355 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 88789 bytesCreated: 10/2/2015 - 1:27:11Modified: 1/13/2013 - 5:07:3010:59:00:355 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\gdip_alt.ahk exists10:59:00:356 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:357 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 5895 bytesCreated: 10/2/2015 - 1:27:11Modified: 6/26/2015 - 10:28:4210:59:00:357 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.210:59:00:357 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\gsdll32.dll exists10:59:00:442 | RL |   DEBUG1  | +94    | CheckFile - Attributes:File Size: 13090816 bytesCreated: 10/2/2015 - 1:27:11Modified: 1/6/2015 - 9:20:4210:59:00:443 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\itextsharp.dll exists10:59:00:532 | RL |   DEBUG1  | +78    | CheckFile - Attributes:FileDescription         iTextSharpFileVersion             5.4.2.0InternalName             itextsharp.dllLegalCopyright           Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.OriginalFilename         itextsharp.dllProductName             iTextSharpProductVersion           5.4.2.0CompanyName             1T3XT BVBAFile Size: 3743744 bytesCreated: 10/2/2015 - 1:27:11Modified: 6/14/2013 - 3:06:2010:59:00:532 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\Java.ahk exists10:59:00:533 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:534 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 7841 bytesCreated: 10/2/2015 - 1:27:11Modified: 12/23/2014 - 11:02:3610:59:00:534 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.010:59:00:534 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\JSON.ahk exists10:59:00:535 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:536 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 9203 bytesCreated: 10/2/2015 - 1:27:11Modified: 5/5/2013 - 3:22:2410:59:00:536 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\Origin.ahk exists10:59:00:537 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:537 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 4904 bytesCreated: 10/2/2015 - 1:27:11Modified: 3/22/2015 - 3:51:4010:59:00:538 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.210:59:00:538 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\RegRW64.ahk exists10:59:00:539 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:539 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 6915 bytesCreated: 10/2/2015 - 1:27:11Modified: 5/8/2014 - 4:06:3810:59:00:539 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\RIni.ahk exists10:59:00:541 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:542 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 67561 bytesCreated: 10/2/2015 - 1:27:11Modified: 6/5/2013 - 7:56:2210:59:00:542 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists10:59:00:563 | RL |   DEBUG1  | +16    | CheckFile - Attributes:FileDescription         SevenZipSharpFileVersion             0.64.5717.6837InternalName             SevenZipSharp.dllLegalCopyright           Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3OriginalFilename         SevenZipSharp.dllProductName             SevenZipSharpProductVersion           0.64.5717.6837CompanyName             Markovtsev VadimFile Size: 167424 bytesCreated: 10/2/2015 - 1:27:11Modified: 10/2/2015 - 1:51:1710:59:00:563 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\Steam.ahk exists10:59:00:564 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:565 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 5347 bytesCreated: 10/2/2015 - 1:27:11Modified: 3/22/2015 - 3:52:2410:59:00:565 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.210:59:00:565 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\VA.ahk exists10:59:00:566 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.10:59:00:567 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 34688 bytesCreated: 10/2/2015 - 1:27:11Modified: 3/1/2013 - 9:05:4610:59:00:567 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\VA_Extension.ahk exists10:59:00:568 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:569 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 3833 bytesCreated: 10/2/2015 - 1:27:11Modified: 1/13/2015 - 8:16:5610:59:00:569 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.110:59:00:569 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\7z.ahk exists10:59:00:570 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:571 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 29013 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:0710:59:00:571 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.110:59:00:571 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Bezel.ahk exists10:59:00:574 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:574 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 102587 bytesCreated: 10/2/2015 - 1:27:10Modified: 6/17/2015 - 10:54:2610:59:00:575 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.210:59:00:575 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Fade.ahk exists10:59:00:576 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:577 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 38048 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:52:1110:59:00:577 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.210:59:00:577 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Fade Init.ahk exists10:59:00:578 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:578 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 999 bytesCreated: 10/2/2015 - 1:27:10Modified: 12/23/2014 - 11:21:0210:59:00:579 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.110:59:00:579 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Fade Animations.ahk exists10:59:00:581 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:582 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 79882 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:4810:59:00:582 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.810:59:00:583 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Pause.ahk exists10:59:00:589 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:590 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 392698 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:3110:59:00:590 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.410:59:00:590 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Pause Init.ahk exists10:59:00:591 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:591 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 553 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:3410:59:00:592 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.310:59:00:592 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Keymapper.ahk exists10:59:00:593 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:594 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 33453 bytesCreated: 10/2/2015 - 1:27:10Modified: 5/21/2015 - 9:44:5210:59:00:594 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.210:59:00:594 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Keymapper Init.ahk exists10:59:00:595 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:595 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 3461 bytesCreated: 10/2/2015 - 1:27:10Modified: 5/21/2015 - 9:44:4210:59:00:596 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.410:59:00:596 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\MultiGame.ahk exists10:59:00:597 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:598 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 40753 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:2810:59:00:598 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.810:59:00:598 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\MultiGame Init.ahk exists10:59:00:599 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:600 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 161 bytesCreated: 10/2/2015 - 1:27:10Modified: 4/14/2013 - 2:33:1810:59:00:600 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.010:59:00:600 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\MultiPlayer.ahk exists10:59:00:602 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:602 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 58770 bytesCreated: 10/2/2015 - 1:27:10Modified: 7/7/2015 - 9:35:4810:59:00:603 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.610:59:00:603 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Password.ahk exists10:59:00:603 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:604 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 10025 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:52:1310:59:00:604 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.210:59:00:605 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists10:59:00:607 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:607 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 73772 bytesCreated: 10/2/2015 - 1:27:10Modified: 7/7/2015 - 9:35:4210:59:00:608 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.510:59:00:608 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Shared.ahk exists10:59:00:610 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:611 | RL |   DEBUG1  | +16    | CheckFile - Attributes:File Size: 116503 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:5310:59:00:611 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.210:59:00:611 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Statistics.ahk exists10:59:00:640 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:641 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 26143 bytesCreated: 10/2/2015 - 1:27:10Modified: 4/9/2015 - 5:16:5610:59:00:641 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.310:59:00:641 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Statistics Init.ahk exists10:59:00:642 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.10:59:00:643 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 33 bytesCreated: 10/2/2015 - 1:27:10Modified: 12/23/2014 - 11:23:4810:59:00:643 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.110:59:00:643 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\Virtual Drive.ahk exists10:59:00:644 | RL |    ERROR  | +0     | CRC Check - CRC does not match for this Library. Please re-download this file to continue using RocketLauncher: D:\RocketLauncher\Lib\Virtual Drive.ahk10:59:00:645 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 18330 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/31/2015 - 4:39:1610:59:00:645 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.210:59:00:645 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\XHotkey.ahk exists10:59:00:646 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:647 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 26540 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:3210:59:00:647 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.410:59:00:647 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Lib\XHotkey Init.ahk exists10:59:00:648 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.10:59:00:649 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 1063 bytesCreated: 10/2/2015 - 1:27:10Modified: 10/2/2015 - 1:51:1910:59:00:649 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.210:59:00:649 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r AddamsFamily_v1.3_0419 -f D:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"10:59:00:649 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "AddamsFamily_v1.3_0419"10:59:00:650 | RL |   DEBUG1  | +0     | Main - dbName: AddamsFamily_v1.3_041910:59:00:650 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"10:59:00:650 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "AddamsFamily_v1.3_0419"10:59:00:658 | RL |     INFO  | +16    | Main - Did not find a "D:\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.10:59:00:658 | RL |     INFO  | +0     | Main - AddamsFamily_v1.3_0419 is using the default emulator: WinUAE10:59:00:658 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\RocketLauncher\Settings\Commodore Amiga\Emulators.ini10:59:00:658 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\RocketLauncher\Settings\Global Emulators.ini10:59:00:659 | RL |     INFO  | +0     | Main - Found [WinUAE] in D:\RocketLauncher\Settings\Global Emulators.ini10:59:00:660 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists10:59:00:661 | RL |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 23651 bytesCreated: 10/2/2015 - 1:27:13Modified: 10/2/2015 - 1:51:1310:59:00:662 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.10:59:00:662 | RL |     INFO  | +0     | Main - AddamsFamily_v1.3_0419 will use module: D:\RocketLauncher\Modules\WinUAE\WinUAE.ahk10:59:00:677 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.10:59:00:682 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\winuae.exe exists10:59:00:682 | RL |   DEBUG1  | +0     | CheckFile - Attributes:FileDescription         WinUAEFileVersion             3.1.0.0InternalName             WinUAELegalCopyright           � 1996-2015 under the GNU Public License (GPL)OriginalFilename         WinUAE.exeProductName             WinUAEProductVersion           3.1.0.0File Size: 12417112 bytesCreated: 10/16/2015 - 10:02:10Modified: 6/7/2015 - 4:41:1010:59:00:683 | RL |     INFO  | +0     | Main - INI Keys read10:59:00:683 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\7z.exe exists10:59:00:706 | RL |   DEBUG1  | +31    | CheckFile - Attributes:FileDescription         7-Zip ConsoleFileVersion             15.06 betaInternalName             7zLegalCopyright           Copyright (c) 1999-2015 Igor PavlovOriginalFilename         7z.exeProductName             7-ZipProductVersion           15.06 betaCompanyName             Igor PavlovFile Size: 262144 bytesCreated: 10/2/2015 - 1:27:11Modified: 10/2/2015 - 1:52:0910:59:00:706 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\Module Extensions\7z.dll exists10:59:00:817 | RL |   DEBUG1  | +109   | CheckFile - Attributes:FileDescription         7z PluginFileVersion             15.06 betaInternalName             7zLegalCopyright           Copyright (c) 1999-2015 Igor PavlovOriginalFilename         7z.dllProductName             7-ZipProductVersion           15.06 betaCompanyName             Igor PavlovFile Size: 1012224 bytesCreated: 10/2/2015 - 1:27:11Modified: 10/2/2015 - 1:51:5110:59:00:824 | RL |     INFO  | +0     | Main - "AddamsFamily_v1.3_0419" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side10:59:00:824 | RL |     INFO  | +0     | CheckPaths - Started10:59:00:824 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: F:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419.7z10:59:00:824 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: F:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419\AddamsFamily_v1.3_0419.7z10:59:00:824 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found10:59:00:824 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: F:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419.zip10:59:00:825 | RL |     INFO  | +0     | CheckPaths - Found rom: F:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419.zip10:59:00:825 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: AddamsFamily_v1.3_041910:59:00:825 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: F:\Roms\Commodore Amiga10:59:00:825 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip10:59:00:825 | RL |     INFO  | +0     | CheckPaths - Ended10:59:00:826 | RL |     INFO  | +0     | BuildScript - User Variables:;----------------------------------------------------------------------------; INJECTED VARIABLES;---------------------------------------------------------------------------- #NoTrayIcon#InstallKeybdHookDetectHiddenWindows, ONSetTitleMatchMode, 2SendMode, Event0 = 10pluginPath = D:\RocketLauncher\PluginspluginName = HyperSpinpluginExt = .plugincontextOnExit = 1rlMode =rlTitle = RocketLauncherrlVersion = 1.0.1.3rlAuthor = djvjrlURL = www.rlauncher.comlangFile = D:\RocketLauncher\Data\Language\Localization.iniprimMonitor = 1frontendPID =frontendPath = D:\HyperspinfrontendExe = HyperSpin.exefrontendExt = exefrontendName = HyperSpinfrontendDrive = D:exitEmulatorKey = ~Esc|H1100:1joy7restoreFE = falseexitScriptKey = ~q & ~stoggleCursorKey = ~e & ~temuFullPath = D:\Hyperspin\Emulators\WinUAE\winuae.exeemuPath = D:\Hyperspin\Emulators\WinUAEemuName = WinUAEemuExt = exeromPath = F:\Roms\Commodore AmigaromPathFromIni = F:\Roms\Commodore AmigaromExtension = .zipromExtensionOrig = .zipromExtensions = 7z|zip|adf|infoexecutable = winuae.exesystemDbName = Commodore AmigasystemName = Commodore AmigadbPath =dbName = AddamsFamily_v1.3_0419dbExt =romName = AddamsFamily_v1.3_0419romMapPath =romMappingEnabled = falseromMappingLaunchMenuEnabled = falseromMappingFirstMatchingExt = falseromMappingShowAllRomsInArchive = trueromMappingNumberOfGamesByScreen = 7romMappingMenuWidth = 400romMappingMenuMargin = 65romMappingTextFont = Bebas NeueromMappingTextOptions = cFFFFFFFF r4 s60 BoldromMappingDisabledTextColor = ff888888romMappingTextSizeDifference = 7romMappingTextMargin = 15romMappingTitleTextFont = Bebas NeueromMappingTitleTextOptions = cFFFFFFFF r4 s90 BoldromMappingTitle2TextFont = Bebas NeueromMappingTitle2TextOptions = cFFFFFFFF r4 s22 BoldromMappingGameInfoTextFont = Bebas NeueromMappingGameInfoTextOptions = cFFFFFFFF r4 s22 RegularromMappingBackgroundBrush = aa000000romMappingColumnBrush = 33000000romMappingButtonBrush1 = 6f000000romMappingButtonBrush2 = 33000000romMappingBackgroundAlign = Stretch and Lose AspectromMappingMenuFlagWidth = 55romMappingMenuFlagSeparation = 7romMappingDefaultMenuList = FullListromMappingSingleFilteredRomAutomaticLaunch = falsealtArchiveNameOnly =altRomNameOnly =altArchiveAndRomName =altArchiveAndManyRomNames =altRomNamesOnly =romMapScenario =skipchecks = falseromMatchExt = falseblockInputTime = 0blockInputFile = D:\RocketLauncher\Module Extensions\BlockInput.exeerrorLevelReporting = falselockLaunch = falselockLaunchGame =screenRotationAngle = 0screenRotationAngleGame =logFile = D:\RocketLauncher\RocketLauncher.loglogLabel := ["    INFO"," WARNING","   ERROR","  DEBUG1","  DEBUG2"]logLevel = 10logShowDebugConsole = falselogIncludeModule = truelogIncludeFileProperties = truelogShowCommandWindow = falselogCommandWindow = falserlDebugConsoleStdout =sysLang = English_United_StatessysType = 64-bitbroadcastWindowTitle =navUpKey = UpnavDownKey = DownnavLeftKey = LeftnavRightKey = RightnavSelectKey = EnternavP2UpKey = Numpad8navP2DownKey = Numpad2navP2LeftKey = Numpad4navP2RightKey = Numpad6navP2SelectKey = NumpadEnteroriginalWidth = 1920originalHeight = 1080vdEnabled = falsevdFullPath = C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exevdUseSCSI = truevdDriveLetter = IvdAddDrive = falseservoStikEnabled = falseservoStikExitMode = falseledblinkyEnabled = falseledblinkyFullPath =ledblinkyProfilePath = D:\RocketLauncher\Profiles\LEDBlinkyledblinkyRLProfile = D:\RocketLauncher\Profiles\LEDBlinky\RocketLauncheremuIdleShutdown = 0launchPasswordHash = UpUpDownDownLeftRightLeftRighthideCursor = falsehideEmu = falsehideFE = falsefadeIn = falsefadeInDuration = 500fadeInTransitionAnimation = DefaultAnimateFadeInfadeInDelay = 4000fadeInExitDelay = 0fadeOutExitDelay = 0fadeOut = falsefadeOutExtraScreen = falsefadeOutDuration = 500fadeOutTransitionAnimation = DefaultAnimateFadeOutfadeOutDelay = 4000fadeLyrInterpolation = 7fadeMuteEmulator = falsefadeUseBackgrounds = falsefadeWidthBaseRes = 1920fadeHeightBaseRes = 1080fadeLyr1Color = FF000000fadeLyr1AlignImage = Stretch and Lose AspectfadeLyr2Pos = Stretch and Lose AspectfadeLyr2X = 0fadeLyr2Y = 0fadeLyr2W =fadeLyr2H =fadeLyr2Adjust = 1fadeLyr2PicPad = 0fadeLyr2Prefix = Extra Layer 1 - ConsolefadeLyr3Pos = CenterfadeLyr3X = 450fadeLyr3Y = 450fadeLyr3W =fadeLyr3H =fadeLyr3Adjust = 1fadeLyr3PicPad = 0fadeLyr3Speed = 750fadeLyr3Animation = DefaultFadeAnimationfadeLyr37zAnimation = DefaultFadeAnimationfadeLyr3Type = imageandbarfadeLyr3ImgFollow7zProgress = truefadeLyr3Repeat = 1fadeLyr3BackImageTransparency = 30fadeLyr3StaticPos = No AlignmentfadeLyr3StaticX = 0fadeLyr3StaticY = 870|1575fadeLyr3StaticW =fadeLyr3StaticH =fadeLyr3StaticAdjust = 1fadeLyr3StaticPicPad = 0fadeLyr3StaticPrefix = Info BarfadeLyr4Adjust = 1fadeLyr4X = 1792|952fadeLyr4Y = 891|1596fadeLyr4W = 128fadeLyr4H =fadeLyr4Pos = No AlignmentfadeLyr4FPS = 50fadeLyr4PicPad = 0fadeTranspGifColor = FFFFFFfadeBarWindow = ImagefadeBarWindowX =fadeBarWindowY =fadeBarWindowW = 900fadeBarWindowH =fadeBarWindowR = 30fadeBarWindowM = 30fadeBarWindowHatchStyle = 8fadeBar = 7zOnlyfadeBarNon7zProgressTime = 0fadeBarBack = truefadeBarBackColor = FF555555fadeBarH = 30fadeBarR = 10fadeBarColor = DD00BFFFfadeBarHatchStyle = 8fadeBarPercentageText = truefadeBarInfoText = truefadeBarXOffset = 0fadeBarYOffset = 150fadeRomInfoDescription = filtered textfadeRomInfoSystemName = imagefadeRomInfoYear = text with labelfadeRomInfoManufacturer = text with labelfadeRomInfoGenre = disabledfadeRomInfoRating = imagefadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|RatingfadeRomInfoTextPlacement = User DefinedfadeRomInfoTextMargin = 7fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left RegularfadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 BoldfadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left RegularfadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left RegularfadeRomInfoText5Options = cFF555555 r4 s42 BoldfadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 RegularfadeStats_Number_of_Times_Played = text with labelfadeStats_Last_Time_Played = text with labelfadeStats_Average_Time_Played = text with labelfadeStats_Total_Time_Played = text with labelfadeStats_System_Total_Played_Time = text with labelfadeStats_Total_Global_Played_Time = text with labelfadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_TimefadeStatsInfoTextPlacement = topRightfadeStatsInfoTextMargin = 7fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 BoldfadeStatsInfoText2Options = cFFB4B4B4 r4 s22 BoldfadeStatsInfoText3Options = cFFB4B4B4 r4 s22 BoldfadeStatsInfoText4Options = cFFB4B4B4 r4 s22 BoldfadeStatsInfoText5Options = cFFB4B4B4 r4 s22 BoldfadeStatsInfoText6Options = cFFB4B4B4 r4 s22 BoldfadeText1X = 0fadeText1Y = 0fadeText1Options = cFFB4B4B4 r4 s30 Right BoldfadeText1 = Loading GamefadeText2X = 0fadeText2Y = 0fadeText2Options = cFFB4B4B4 r4 s30 Right BoldfadeText2 = Extraction Complete, ReadyfadeText3 = Loading GamefadeText4 = Loading CompletefadeFont = Bebas NeuefadeSystemAndRomLayersOnly = falsefadeExtractionTime = disabledfadeExtractionTimeTextX = 0fadeExtractionTimeTextY = 0fadeExtractionTimeTextOptions = cFF555555 r4 s20 BoldfadeInterruptKey =detectFadeErrorEnabled = truefadeImgPath = D:\RocketLauncher\Media\FadeRLDataPath = D:\RocketLauncher\DataRLMediaPath = D:\RocketLauncher\MediaRLErrSoundPath = D:\RocketLauncher\Media\Sounds\ErrormodulesPath = D:\RocketLauncher\ModulesmoduleFullName = D:\RocketLauncher\Modules\WinUAE\WinUAE.ahkmoduleName = WinUAEmodulePath = D:\RocketLauncher\Modules\WinUAEmoduleExtension = ahkmoduleExtensionsPath = D:\RocketLauncher\Module ExtensionslibPath = D:\RocketLauncher\Lib7zEnabled = false7zPath = D:\RocketLauncher\Module Extensions\7z.exe7zDllPath = D:\RocketLauncher\Module Extensions\7z.dll7zExtractPath = D:\TEMP GAME HS7zExtractPathOrig =7zAttachSystemName = false7zDelTemp = true7zSounds = true7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar7zFormatsNoP = zip,rar,7z,lzh,gzip,tarmgEnabled = falsemgKey = ~NumpadSubmgBackgroundColor = FF000000mgSidePadding = 0.2mgWidthBaseRes = 1920mgHeightBaseRes = 1080mgYOffset = 500|800mgFont = ArialmgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalicmgText1Text = Please select a gamemgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalicmgText2Offset = 100mgUseSound = truemgSoundfreq = 300mgExitEffect = nonemgSelectedEffect = rotatemgUseGameArt = falsemgCandidate =mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(SidemgOnLaunch = falsepauseEnabled = truepauseKey = H1100:1joy8pauseBackToMenuBarKey = XpauseZoomInKey = CpauseZoomOutKey = VpauseScreenshotKey = ~PrintScreenpauseHiToTextPath = D:\RocketLauncher\Module Extensions\HiToText.exepauseSaveStateKeyCodes =pauseLoadStateKeyCodes =keymapperEnabled = falsekeymapperAHKMethod = falsekeymapper = xpadderxpadderFullPath = D:\Hyperspin\Utilities\Xpadder\Xpadder.exejoyToKeyFullPath = D:\RocketLauncher\Profiles\JoyToKey\JoyToKey.exekeymapperProfilePath = D:\RocketLauncher\Profiles\xpadderkeymapperFrontEndProfileName = HyperSpinkeymapperFrontEndProfile = xpadderkeymapperRocketLauncherProfileEnabled = truejoyIDsEnabled = falsejoyIDsPreferredControllersGlobal =joyIDsPreferredControllersSystem = use_globaljoyIDsPreferredControllersOnExit =CustomJoyNamesEnabled = falseCustomJoyNames =rotateMethod = falseFEProfile = D:\RocketLauncher\Profiles\xpadder\HyperSpindefaultProfile = D:\RocketLauncher\Profiles\xpadder\_DefaultsystemProfile = D:\RocketLauncher\Profiles\xpadder\Commodore AmigaxPadderSystemProfile = D:\RocketLauncher\Profiles\xpadder\Commodore Amiga\_DefaultemuProfile = D:\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAEromProfile = D:\RocketLauncher\Profiles\xpadder\Commodore Amiga\AddamsFamily_v1.3_0419RocketLauncherProfile = D:\RocketLauncher\Profiles\xpadder\RocketLauncherblankProfile = D:\RocketLauncher\Profiles\xpadder\_Default\blankahkFEProfile = D:\RocketLauncher\Profiles\AHK\HyperSpinahkDefaultProfile = D:\RocketLauncher\Profiles\AHK\_DefaultahkSystemProfile = D:\RocketLauncher\Profiles\AHK\Commodore AmigaahkEmuProfile = D:\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAEahkRomProfile = D:\RocketLauncher\Profiles\AHK\Commodore Amiga\AddamsFamily_v1.3_0419ahkRocketLauncherProfile = D:\RocketLauncher\Profiles\AHK\RocketLauncherbezelEnabled = falsebezelICEnabled = falsestatisticsEnabled = truepressDuration = -1emuVolume = 1dxwndIni = D:\RocketLauncher\Module Extensions\dxwnd\dxwnd.inidxwndFullPath = D:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exemon1O =pacDrivedllFile = D:\RocketLauncher\Module Extensions\PacDrive32.dlluserFadeAnimIniFile = D:\RocketLauncher\Lib\User Fade Animations.ini 10:59:00:835 | RL |     INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts10:59:00:836 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts10:59:00:836 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts10:59:00:836 | RL |  WARNING  | +0     | BuildScript - "D:\RocketLauncher\Lib\User Functions Init.ahk" not found10:59:00:836 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 210:59:00:836 | RL |     INFO  | +0     | BuildScript - Validating module10:59:00:841 | RL |     INFO  | +0     | BuildScript - Validation complete10:59:00:841 | RL |     INFO  | +0     | BuildScript - Module:MEmu = WinUAEMEmuV =  v3.0.0MURL = http://www.winuae.net/MAuthor = brolly,TurraniusMVersion = 2.1.9MCRC = 4C755A18iCRC = AFD49B34mId = 635138307631183750MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos";----------------------------------------------------------------------------; Notes:; You can have specific configuration files inside a Configurations folder on WinUAE main dir.; Just name them the same as the game name on the XML file.; Make sure you create a host config files with these names:; CD32 : cd32host.uae and cd32mousehost.uae;; CDTV : cdtvhost.uae and cdtvmousehost.uae;; Amiga : amigahost.uae;; Amiga CD : amigacdhost.uae;; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both; a joystick and a mouse on Port1 and only a joystick on Port2.; Set all your other preferences like video display settings. And make sure you are saving a HOST; configuration file and not a general configuration file.;; If you want to configure an exit key through WinUAE:; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.; If you want to configure a key to toggle fullscreen/windowed mode:; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.;; CD32 and CDTV:; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:;; [Lemmings (Europe)]; UseMouse=true;; [Project-X & F17 Challenge (Europe)]; DelayHack=true;; Amiga:; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10; END+SHIFT+1-0 = insert image from swapper slot 11-20; END+CTRL+1-4 = select drive;; To do that follow the same procedure as above for the exit; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.;; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.;; Amiga CD:; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set; RequiresWB to false.;; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:; http://www.winuae.net/; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory;----------------------------------------------------------------------------StartModule()BezelGUI()FadeInStart() settingsFile := modulePath . "\" . systemName . ".ini" ; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")ident := mType[systemName] ; search object for the systemName identifier MESS usesIf !identScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName) specialcfg = %emuPath%\Configurations\%romName%.uae If romExtension in .hdf,.vhdDefaultRequireWB := "true"ElseDefaultRequireWB := "false" If romExtension in .zip,.lha,.rar,.7z{SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")If (SlaveFile) {If romName contains (AGA){defaultCycleExact := "false"defaultCpuSpeed := "max"} Else {defaultCycleExact := "true"defaultCpuSpeed := "real"}defaultImmediateBlittler = "false"defaultCpuCompatible := "false"defaultCacheSize := "0" ;8192}} If (ident = "amigacd") {DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to truedefaultz3Ram := "128"isAmigaCd := "true"} ; SettingsFS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)If (pathtoextradrive)pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive) usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1) ; Displayvideomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1) ; CPUcpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1) ; Chipsetcycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1) ; RAMchipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1) ; Expansionsrtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1) ; WHDLoadPathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1) BezelStart() ; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modesIf bezelPath {FS := "fullwindow"gfx_filter_autoscale := "scale"} windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreenIf (FS = "true" or FS = "fullwindow")windowClass = AmigaPowah If (cpucycleexact and blittercycleexact)cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states if (cpu != "68060" and cpu_no_unimplemented)cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.} ; Make sure 24bitaddressing is false if using Z3 memory.If z3fastmemory24bitaddressing := "false" ;Fill both z3 slots when amount of RAM requires itIf (z3fastmemory = "384") {z3fastmemory = "256"z3fastmemoryb = "128"} Else If (z3fastmemory = "768") {z3fastmemory = "512"z3fastmemoryb = "256"} Else If (z3fastmemory = "1536") {z3fastmemory = "1024"z3fastmemoryb = "512"} videomode := If videomode = "NTSC" ? "-s ntsc=true" : "" If (requireswb = "true") {ident := "a1200"CheckFile(PathToWorkBenchBase)wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"} If romExtension in .hdf,.vhd{ident := "a1200"gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"} If (pathtoextradrive){CheckFile(pathtoextradrive,,,,,,1) ;allow foldersIf InStr(FileExist(pathtoextradrive), "D") ;it's a folderextraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"Else ;it's a file{SplitPath, pathtoextradrive,,,extradriveExtensionIf extradriveExtension in .hdf,.vhdextraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"ElseextraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"}} options := options . " " . videomode If (ident = "a500" or ident = "a1200") {If romName contains (AGA),(LW)ident := "a1200" If (SlaveFile) {CheckFolder(PathToWHDFolder) ident := "a1200" ;Create the user-startup file to launch the gameWHDUserStartupFile := PathToWHDFolder . "\S\user-startup"SplitPath, SlaveFile, SlaveName, SlaveFolder FileDelete, %WHDUserStartupFile%FileAppend, echo "";`n, %WHDUserStartupFile%FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%FileAppend, echo "";`n, %WHDUserStartupFile%FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%}} hideEmuObj := Object("ahk_class " . windowClass,1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later7z(romPath, romName, romExtension, 7zExtractPath) ;--- Detecting what Configuration File to use (Or Quick Start Mode) --- If FileExist(specialcfg) {;Game specific configuration file existsconfigFile = %romName%.uae} Else {;Game specific configuration file doesn't existIf (ident = "cd32" or ident = "cdtv") {configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")} Else {;Amiga or Amiga CD game configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"If quickstartmodequickcfg := "-s quickstart=" . quickstartmodeElsequickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")}} ;--- Setting up command line arguments to use --- ; Global command line arguments.If use_guioptions := options . " -s use_gui=" . use_gui If (FS = "true") {options := options . " -s gfx_width_fullscreen=" . gfx_widthoptions := options . " -s gfx_height_fullscreen=" . gfx_height} Else If (FS = "false") {If (gfx_width != "native" and gfx_height != "native") {options := options . " -s gfx_width_windowed=" . gfx_widthoptions := options . " -s gfx_height_windowed=" . gfx_height}} If gfx_linemodeoptions := options . " -s gfx_linemode=" . gfx_linemodeIf gfx_filter_autoscaleoptions := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscaleIf gfx_blacker_than_blackoptions := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_blackIf gfx_flickerfixeroptions := options . " -s gfx_flickerfixer=" . gfx_flickerfixerIf gfx_filter_modeoptions := options . " -s gfx_filter_mode=" . gfx_filter_mode If (gfx_lores_mode = "true")options := options . " -s gfx_lores_mode=filtered"Else If (gfx_lores_mode = "false")options := options . " -s gfx_lores_mode=normal" If gfx_resolution {options := options . " -s gfx_resolution=" . gfx_resolutionIf (gfx_resolution = "lores") {options := options . " -s gfx_autoresolution_vga=false"options := options . " -s gfx_lores=true"}Else {options := options . " -s gfx_lores=false"}} If gfx_filter_mask {gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_maskLOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)If FileExist(gfx_filter_mask_path)options := options . " -s gfx_filter_mask=" . gfx_filter_mask} If gfx_filter {If (SubStr(gfx_filter, 1, 4) = "D3D:") {StringTrimLeft, FilterFileName, gfx_filter, 4FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileNameIf FileExist(FilterFile)options := options . " -s gfx_filter=" . gfx_filter} Else {options := options . " -s gfx_filter=" . gfx_filter}} If (ident = "cd32" or ident = "cdtv") {If (delayhack = "true")options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"Elseoptions := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"} Else {If floppyspeedoptions := options . " -s floppy_speed=" . floppyspeedIf kickstart_rom_fileoptions := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"If (cachesize || cachesize = "0")options := options . " -s cachesize=" . cachesizeIf immediateblitteroptions := options . " -s immediate_blits=" . immediateblitterIf cycleexactoptions := options . " -s cycle_exact=" . cycleexactIf cpucycleexactoptions := options . " -s cpu_cycle_exact=" . cpucycleexactIf blittercycleexactoptions := options . " -s blitter_cycle_exact=" . blittercycleexactIf cpucompatibleoptions := options . " -s cpu_compatible=" . cpucompatibleIf cpuspeedoptions := options . " -s cpu_speed=" . cpuspeedIf cpuoptions := options . " -s cpu_model=" . cpuIf cpu_no_unimplementedoptions := options . " -s cpu_no_unimplemented=" . cpu_no_unimplementedIf (mmu_model = "true")options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.If 24bitaddressingoptions := options . " -s cpu_24bit_addressing=" . 24bitaddressingIf fpuoptions := options . " -s fpu_model=" . fpuIf fpu_strictoptions := options . " -s fpu_strict=" . fpu_strictIf fpu_no_unimplementedoptions := options . " -s fpu_no_unimplemented=" . fpu_no_unimplementedIf collisionleveloptions := options . " -s collision_level=" . collisionlevelIf chipmemoryoptions := options . " -s chipmem_size=" . chipmemoryIf fastmemoryoptions := options . " -s fastmem_size=" . fastmemoryIf autoconfigfastmemoryoptions := options . " -s fastmem_autoconfig=" . autoconfigfastmemoryIf slowmemoryoptions := options . " -s bogomem_size=" . slowmemoryIf z3fastmemoryoptions := options . " -s z3mem_size=" . z3fastmemoryIf z3fastmemoryboptions := options . " -s z3mem2_size=" . z3fastmemorybIf megachipmemoryoptions := options . " -s megachipmem_size=" . megachipmemoryIf processorslotfastmemoryoptions := options . " -s mbresmem_size=" . processorslotfastmemoryIf rtgcardtypeoptions := options . " -s gfxcard_type=" . rtgcardtypeIf rtgvramsizeoptions := options . " -s gfxcard_size=" . rtgvramsizeIf rtghardwarespriteoptions := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite If (SlaveFile) {;WHDLoad Gameoptions := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"}Else If (gameDrive) {;HDD Gameoptions := options . " " . wbDrive . " " . gameDrive ;Check if there's also a CD to loadIfExist, %romPath%\%romName%.cuecdDrive := romPath . "\" . romName . ".cue"IfExist, %romPath%\%romName%.isocdDrive := romPath . "\" . romName . ".iso"IfExist, %romPath%\%romName%.mdscdDrive := romPath . "\" . romName . ".mds" If extraDriveoptions := options . " " . extraDriveIf cdDriveoptions := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"} Else If romExtension in .cue,.iso,.mds{;Amiga CD game ;Check if game has a HDD installationIfExist, %romPath%\%romName%.hdfinstalledHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"IfExist, %romPath%\%romName%.vhdinstalledHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """" options := options . " " . wbDrive . installedHdd If extraDriveoptions := options . " " . extraDrive options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"} Else {;Floppy Game ;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots. romCount = % romTable.MaxIndex()If romName contains (Disk 1){;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menuIf romCount > 1{options := options . " -s nr_floppies=2"mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"}}options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions If romCount > 1{;DiskSwapper;diskswapper := " -diskswapper "Loop % romTable.MaxIndex() ; loop each item in our array{;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"}options := options . diskswapper}}} configFileFullPath := EmuPath . "\Configurations\" . configFile ;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfgIf FileExist(configFileFullPath)param1 := "-f " . """" . configFileFullPath . """"param1 := param1 . " " . quickcfg param2 := "-s gfx_fullscreen_amiga=" . FSparam3 := options HideEmuStart()Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath) If (use_gui = "true") {WinWait("WinUAE Properties",,60)FadeInExit()WinWaitClose("WinUAE Properties")Sleep, 100Process("Exist",executable)If (ErrorLevel=0) {7zCleanUp()ExitModule()}} WinWait("ahk_class " . windowClass)WinWaitActive("ahk_class " . windowClass) BezelDraw()HideEmuEnd()FadeInExit()Process("WaitClose",executable)7zCleanUp()BezelExit()FadeOutExit()ExitModule()  MultiGame:If currentButton = 10diskslot = 0Else If currentButton > 10diskslot := currentButton - 10Elsediskslot := currentButton If currentButton > 10Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}ElseSend, {End Down}%diskslot%{End Up}Return CloseProcess:If (ident = "a500" or ident = "a1200") {If (SlaveFile) {CheckFolder(PathToWHDFolder);Copy default-user-startup to user-startup if file existsIfExist, %PathToWHDFolder%\S\default-user-startupFileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1}}FadeOutStart()WinClose, ahk_class %windowClass%Return 10:59:00:856 | RL |     INFO  | +15    | BuildScript - Loaded Pause scripts10:59:00:857 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts10:59:00:859 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script10:59:00:859 | RL |  WARNING  | +0     | BuildScript - "D:\RocketLauncher\Lib\User Functions.ahk" not found10:59:00:859 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module10:59:00:862 | RL |     INFO  | +16    | Main - Module is built10:59:00:862 | RL |     INFO  | +0     | CheckFile - Checking if D:\RocketLauncher\AutoHotkey.dll exists10:59:00:878 | RL |   DEBUG1  | +16    | CheckFile - Attributes:FileDescription         AutoHotkey_H ANSI 32-bitFileVersion             1.1.09.04InternalName             AutoHotkey_HLegalCopyright           Copyright (C) 2012OriginalFilename         AutoHotkey.exeProductName             AutoHotkey_HProductVersion           1.1.09.04File Size: 785408 bytesCreated: 10/2/2015 - 1:27:09Modified: 4/19/2013 - 7:16:3210:59:00:879 | RL |     INFO  | +0     | Main - Running module10:59:00:879 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.10:59:01:055 | MD |     INFO  | +N/A   | Module initialized10:59:01:055 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started10:59:01:055 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups10:59:01:056 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check10:59:01:056 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check10:59:01:056 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"10:59:01:057 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended10:59:01:057 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started10:59:01:057 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy7 not in TableKeyGroups ~Esc,10:59:01:058 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check10:59:01:058 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check10:59:01:058 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label10:59:01:058 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended10:59:01:165 | MD |   DEBUG2  | +109   | XHotkeyTableCreation - Started10:59:01:165 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy8 not in TableKeyGroups ~Esc,~1joy7,10:59:01:165 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check10:59:01:165 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check10:59:01:165 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy8" to call a group label10:59:01:166 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended10:59:01:166 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started10:59:01:166 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1joy7,~1joy8,10:59:01:166 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check10:59:01:166 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check10:59:01:166 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"10:59:01:167 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended10:59:01:167 | MD |     INFO  | +0     | StartModule - Started10:59:01:167 | MD |     INFO  | +0     | StartModule - MEmu: WinUAEMEmuV: v3.0.0MURL: http://www.winuae.net/MAuthor: brolly,TurraniusMVersion: 2.1.9MCRC: 4C755A18iCRC: AFD49B34MID:MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"10:59:01:167 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"10:59:01:169 | MD |     INFO  | +0     | PluginInit - Started10:59:01:170 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating10:59:01:170 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Databases\Commodore Amiga\Commodore Amiga.xml exists10:59:01:171 | MD |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 568042 bytesCreated: 10/13/2015 - 1:04:56Modified: 10/31/2015 - 9:37:3110:59:01:172 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database10:59:01:172 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!10:59:01:172 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name10:59:01:172 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Addams Family, The"10:59:01:172 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof10:59:01:195 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Cloneof10:59:01:195 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer10:59:01:195 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer10:59:01:195 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year10:59:01:195 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year10:59:01:196 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre10:59:01:196 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre10:59:01:196 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating10:59:01:196 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"10:59:01:196 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:GameInfo Label: Name | GameInfo Value:GameInfo Label: Rating | GameInfo Value:10:59:01:196 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended10:59:01:197 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo10:59:01:197 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\AddamsFamily_v1.3_0419.png10:59:01:198 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png10:59:01:198 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:Asset Label: Game Logo | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\AddamsFamily_v1.3_0419.png | Asset Extension1:  png | Asset Type1:  gameAsset Label: System Logo | Asset Path1:  D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system10:59:01:198 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended10:59:01:198 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other10:59:01:198 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork1\AddamsFamily_v1.3_0419.png10:59:01:199 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork2\AddamsFamily_v1.3_0419.png10:59:01:199 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork3\AddamsFamily_v1.3_0419.png10:59:01:225 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Flyers: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork4\AddamsFamily_v1.3_0419.png10:59:01:225 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Hyperspin\Media\Commodore Amiga\Images\Letters10:59:01:294 | MD |   DEBUG1  | +63    | BuildAssetsTable - Searching for a Other: D:\Hyperspin\Media\Commodore Amiga\Images\Other10:59:01:297 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:Asset Label: Cartridge | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Artwork3\AddamsFamily_v1.3_0419.png | Asset Extension1:  png | Asset Type1:  gameAsset Label: Flyers | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Artwork4\AddamsFamily_v1.3_0419.png | Asset Extension1:  png | Asset Type1:  gameAsset Label: Letters | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  systemAsset Label: Letters | Asset Path2:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  systemAsset Label: Letters | Asset Path3:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  systemAsset Label: Letters | Asset Path4:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  systemAsset Label: Letters | Asset Path5:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  systemAsset Label: Letters | Asset Path6:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  systemAsset Label: Letters | Asset Path7:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  systemAsset Label: Letters | Asset Path8:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  systemAsset Label: Letters | Asset Path9:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  systemAsset Label: Letters | Asset Path10:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  systemAsset Label: Letters | Asset Path11:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  systemAsset Label: Letters | Asset Path12:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  systemAsset Label: Letters | Asset Path13:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  systemAsset Label: Letters | Asset Path14:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  systemAsset Label: Letters | Asset Path15:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  systemAsset Label: Letters | Asset Path16:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  systemAsset Label: Letters | Asset Path17:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  systemAsset Label: Letters | Asset Path18:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  systemAsset Label: Letters | Asset Path19:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  systemAsset Label: Letters | Asset Path20:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  systemAsset Label: Letters | Asset Path21:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  systemAsset Label: Letters | Asset Path22:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  systemAsset Label: Letters | Asset Path23:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  systemAsset Label: Letters | Asset Path24:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  systemAsset Label: Letters | Asset Path25:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  systemAsset Label: Letters | Asset Path26:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  systemAsset Label: Letters | Asset Path27:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  systemAsset Label: Letters | Asset Path28:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  systemAsset Label: Letters | Asset Path29:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  systemAsset Label: Letters | Asset Path30:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  systemAsset Label: Letters | Asset Path31:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  systemAsset Label: Letters | Asset Path32:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  systemAsset Label: Letters | Asset Path33:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  systemAsset Label: Letters | Asset Path34:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  systemAsset Label: Letters | Asset Path35:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  systemAsset Label: Letters | Asset Path36:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  systemAsset Label: Letters | Asset Path37:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  systemAsset Label: Letters | Asset Path38:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  systemAsset Label: Letters | Asset Path39:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  systemAsset Label: Other | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system10:59:01:297 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended10:59:01:318 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Game Video|System Video10:59:01:318 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: D:\Hyperspin\Media\Commodore Amiga\Video\AddamsFamily_v1.3_0419.*10:59:01:352 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Video: D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.*10:59:01:352 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:Asset Label: Game Video | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Video\AddamsFamily_v1.3_0419.flv | Asset Extension1:  flv | Asset Type1:  gameAsset Label: System Video | Asset Path1:  D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.flv | Asset Extension1:  flv | Asset Type1:  system10:59:01:353 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended10:59:01:353 | MD |     INFO  | +0     | PluginInit - Ended10:59:01:353 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: AddamsFamily_v1.3_041910:59:01:354 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started10:59:01:354 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy7,~1joy8,PrintScreen,10:59:01:354 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check10:59:01:354 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check10:59:01:355 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"10:59:01:355 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended10:59:01:358 | MD |     INFO  | +0     | StartModule - Ended10:59:01:503 | MD |     INFO  | +157   | Module Setting - [Settings] - ScreenMode: true10:59:01:503 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - ScreenMode: true10:59:01:504 | MD |     INFO  | +0     | Module Setting - [Settings] - QuickStartMode:10:59:01:504 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - QuickStartMode:10:59:01:504 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:10:59:01:504 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - KickstartFile:10:59:01:505 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:10:59:01:505 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - Options:10:59:01:505 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Top_Offset: 010:59:01:506 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - Bezel_Top_Offset: 010:59:01:506 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 010:59:01:506 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - Bezel_Bottom_Offset: 010:59:01:507 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 010:59:01:507 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - Bezel_Right_Offset: 010:59:01:507 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 010:59:01:507 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - Bezel_Left_Offset: 010:59:01:508 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false10:59:01:508 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - UseGui: false10:59:01:508 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo10:59:01:509 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - FloppySpeed: turbo10:59:01:509 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd10:59:01:509 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd10:59:01:510 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:10:59:01:510 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - PathToExtraDrive:10:59:01:510 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - UseMouse: false10:59:01:510 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - DelayHack: false10:59:01:511 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - RequiresWB: false10:59:01:511 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: PAL10:59:01:511 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - VideoMode: PAL10:59:01:512 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: native10:59:01:512 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - XResolution: native10:59:01:512 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: native10:59:01:513 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - YResolution: native10:59:01:513 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false10:59:01:513 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - BlackerThanBlack: false10:59:01:513 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false10:59:01:514 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - RemoveInterlaceArtifacts: false10:59:01:514 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:10:59:01:514 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - LineMode:10:59:01:515 | MD |     INFO  | +0     | Module Setting - [Display] - AutoScale:10:59:01:515 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - AutoScale:10:59:01:515 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:10:59:01:515 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - ShaderMask:10:59:01:516 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:10:59:01:516 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - FilterShader:10:59:01:516 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:10:59:01:539 | MD |     INFO  | +31    | Module Setting - [AddamsFamily_v1.3_0419] - FilterShaderScale:10:59:01:539 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:10:59:01:539 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - FilteredLowResolution:10:59:01:540 | MD |     INFO  | +0     | Module Setting - [Display] - ResolutionMode: hires10:59:01:540 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - ResolutionMode: hires10:59:01:540 | MD |     INFO  | +0     | Module Setting - [CPU] - CPU:10:59:01:540 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CPU:10:59:01:541 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuSpeed: real10:59:01:541 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CpuSpeed: real10:59:01:541 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:10:59:01:542 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CpuCycleExact:10:59:01:542 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible: false10:59:01:542 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CpuCompatible: false10:59:01:543 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false10:59:01:543 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - MMU: false10:59:01:543 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedCPU: true10:59:01:543 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - DisableUnimplementedCPU: true10:59:01:544 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:10:59:01:544 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - FPU:10:59:01:544 | MD |     INFO  | +0     | Module Setting - [CPU] - MoreCompatibleFPU: false10:59:01:545 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - MoreCompatibleFPU: false10:59:01:545 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedFPU: true10:59:01:545 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - DisableUnimplementedFPU: true10:59:01:545 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize: 010:59:01:546 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CacheSize: 010:59:01:546 | MD |     INFO  | +0     | Module Setting - [CPU] - 24-BitAddressing: true10:59:01:546 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - 24-BitAddressing: true10:59:01:547 | MD |     INFO  | +0     | Module Setting - [Chipset] - CycleExact: true10:59:01:547 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CycleExact: true10:59:01:547 | MD |     INFO  | +0     | Module Setting - [Chipset] - ImmediateBlitter: "false"10:59:01:569 | MD |     INFO  | +31    | Module Setting - [AddamsFamily_v1.3_0419] - ImmediateBlitter: "false"10:59:01:569 | MD |     INFO  | +0     | Module Setting - [Chipset] - BlitterCycleExact:10:59:01:569 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - BlitterCycleExact:10:59:01:569 | MD |     INFO  | +0     | Module Setting - [Chipset] - CollisionLevel:10:59:01:570 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - CollisionLevel:10:59:01:570 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:10:59:01:570 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - ChipMemory:10:59:01:571 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:10:59:01:571 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - FastMemory:10:59:01:571 | MD |     INFO  | +0     | Module Setting - [RAM] - AutoConfigFastMemory:10:59:01:571 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - AutoConfigFastMemory:10:59:01:572 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:10:59:01:572 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - SlowMemory:10:59:01:572 | MD |     INFO  | +0     | Module Setting - [RAM] - Z3FastMemory:10:59:01:573 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - Z3FastMemory:10:59:01:573 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:10:59:01:573 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - MegaChipMemory:10:59:01:574 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:10:59:01:574 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - ProcessorSlotFast:10:59:01:574 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:10:59:01:574 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - RTGCardType:10:59:01:575 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:10:59:01:575 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - RTGVRAMSize:10:59:01:575 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGHardwareSprite:10:59:01:576 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - RTGHardwareSprite:10:59:01:576 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - PathToWHDFolder: .\WHD10:59:01:576 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - PathToWHDFolder: .\WHD10:59:01:577 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD10:59:01:577 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - WHDLoadOptions: PRELOAD10:59:01:577 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - NeverExtract: false10:59:01:577 | MD |     INFO  | +0     | Module Setting - [AddamsFamily_v1.3_0419] - NeverExtract: false10:59:01:578 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\WHD exists10:59:01:578 | MD |   DEBUG1  | +0     | CheckFile - Attributes:File Size: 0 bytesCreated: 10/20/2015 - 3:51:38Modified: 10/20/2015 - 3:51:3810:59:01:606 | MD |     INFO  | +31    | Run - Running: D:\Hyperspin\Emulators\WinUAE\winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Hyperspin\Emulators\WinUAE\WHD" -s filesystem=ro,Games:"F:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419.zip"  -portable10:59:02:361 | MD |   DEBUG1  | +766   | Run - "winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Hyperspin\Emulators\WinUAE\WHD" -s filesystem=ro,Games:"F:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419.zip"  -portable" Process ID: 684810:59:02:362 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.0.7 [ FE = HyperSpin 1.4 | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;fe6706dc-fd1a-45d4-89b9-4a0850b01147] | State: 0 | X: 584 | Y: 32 | Width: 1310 | Height: 1047 | Window HWND: 0x106091a | Process ID: 216 | Process Path: D:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe10:59:02:362 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"10:59:05:299 | MD |   DEBUG1  | +2938  | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x1204c6 | Process ID: 6848 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe10:59:05:299 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x1204c6 | Process ID: 6848 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
10:59:05:299 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
10:59:05:441 | MD |   DEBUG1  | +140   | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.0.7 [ FE = HyperSpin 1.4 | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;fe6706dc-fd1a-45d4-89b9-4a0850b01147] | State: 0 | X: 584 | Y: 32 | Width: 1310 | Height: 1047 | Window HWND: 0x106091a | Process ID: 216 | Process Path: D:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe
10:59:05:474 | MD |     INFO  | +31    | Process - WaitClose winuae.exe
Hi diskmach,
Wow, I cannot read that log.  ;)
Try it a different way please.  zip your RocketLauncher log file and attach it to a post.
Thanks,
Ron
Thanks for your answer, Ron.
If I just open WinUAE, CPU defaults to 68000. When I then load amigahost it´s set to 68030 (that the error asked for).
Amigahost.uae is in the "Host" folder.
Also I`m on Windows 10. Found this webpage: "http://www.tweakguides.com/Amiga_3.html", under "Paths: Important" it mentions possible problems
with the paths. My hyperspin setup is on my D drive, difficult to change this. I tried to give WinUAE admin privileges and moved the UAC bar all the way down, but still the same.
​Here is the log:
...snip...
That is perfect.
Here is your run line:
And here is mine:
Run - Running: G:\Emulators\WinUAE3.1.0\winuae64-3.2b15.exe -f "G:\Emulators\WinUAE3.1.0\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s gfx_fullscreen_amiga=fullwindow   -s use_gui=false -s gfx_filter_autoscale=scale -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"G:\Emulators\WinUAE3.1.0\WHD" -s filesystem=ro,Games:"G:\Roms\Commodore Amiga\AddamsFamily_v1.3_0419.zip"  -portable
The differences i see are not important.  Should work just fine.
Maybe send me your amigahost.uae file??
Thanks,
Ron
 I really messed that one up, didn´t I?   :ermm:
Try attached file instead...
  • 3 weeks later...
Hey guys, I am at my wits end! I am following Austins guides and the Amiga is giving me trouble. The games all run but they run slow and the sounds is crackling mostly its fine just performance is below standard and my system is well capable. the problem is my harware config in win uae is not saving so i cannot set the ROM to ver3.1 as per Rons guide. Everything else saves ok the Host settings save but the hardware will not! Any help appreciated.I have the settings as Rons guide descibes except the ROM ver which is currently 3.0 instead of 3.1. I'm not sure if this is causing the performance issues but obviously if the config is not saving then something is wrong. Any help appreciated
Yep i go to configurations and click save over the Default profile. I close winUAE and reopen and no changes in the hardware section seem to save.
No I am trying to change the settings for which ever config is auto loaded on startup. Maybe i am saving to the wrong file? I can make changes to the HOST section of the config and they save but the Hardware section will not save any changes. I am not Loading any configs manually.
Hi,
Be sure and use the .../Configurations/Host/amigahost.uae file.  That is the one that is used when launching Commodore Amiga files.
Thanks,
Ron
Ok that makes sense and yes if i manually load the config settings are as i have set them. How can i setup winUAE to auto load this config I see the autoload checkbox is greyed out and unclickable
For some reason my default config folder is \Configurations\ not \Configurations\Host\ should i move amigahost.uae to the host folder and point the path there instead or would it not matter?
Hi Carlo,
Yes, you should put it in the Host directory.  That is where the module looks for it.  :D
Thanks,
Ron
Just a heads up that all the links in the original first post are broken and you just get bounced to the forum index. Looks like these forums have changed the URL format at some stage, I tried to fix them so could post fixed links but couldn't work it out.
Thanks, I did a bit of editing.
  • 3 weeks later...
Hi Ron,
Christmas time is right to update Hyperspin stuff. Hyperlaunch to Rocket and also new WinUAE emulator.
But I've some issues I would like to ask your help.
As matchaman I face 3 different situations: good, not enough memory and amiga floppy.
Here below screenshot and logs. Do you think you can help me? Thanks Ron.
OK LOADING:
[code]
14:58:54:306 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com)
14:58:54:415 | RL |     INFO  | +109   | Main - System Specs:
					RocketLauncher Dir: D:\Hyperspin\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Ultimate
					SKU: Ultimate
					Total Memory: 7644.39 MB
					Free Memory: 6084.93 MB
					Used Memory: 1559.457 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: AMD Radeon HD 5700 Series
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 13.251.0.0
					GPU 2 Name: AMD Radeon HD 7560D
					GPU 2 RAM: 512.00 MB
					GPU 2 Driver Version: 13.251.0.0
					Sound 1 Device: AMD High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: AMD High Definition Audio Device
					Sound 2 Status: Enabled
					Sound 3 Device: Dispositivo High Definition Audio
					Sound 3 Status: Enabled
					OS Language: Italian_Standard
					OS Admin Status: No
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x984 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1280
					Current AHK Desktop Height: 1024
					AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
14:58:54:415 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\RocketLauncher.exe exists
14:58:54:415 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.4
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2063360 bytes
					Created:			12/9/2015 - 10:44:38
					Modified:			12/9/2015 - 10:52:27
14:58:54:415 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Array.ahk exists
14:58:54:431 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
14:58:54:431 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4924 bytes
					Created:			12/9/2015 - 10:50:09
					Modified:			12/9/2015 - 10:50:09
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BinHexRW.ahk exists
14:58:54:431 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5077 bytes
					Created:			12/9/2015 - 10:52:17
					Modified:			12/9/2015 - 10:52:17
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			12/9/2015 - 10:48:01
					Modified:			12/9/2015 - 10:48:03
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\CLR_L.ahk exists
14:58:54:431 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			5474 bytes
					Created:			12/9/2015 - 10:48:53
					Modified:			12/9/2015 - 10:48:53
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
					File Size:			5716 bytes
					Created:			12/9/2015 - 10:55:59
					Modified:			12/9/2015 - 10:56:00
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip.ahk exists
					File Size:			88789 bytes
					Created:			12/9/2015 - 10:45:19
					Modified:			12/9/2015 - 10:45:19
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip_alt.ahk exists
					File Size:			5895 bytes
					Created:			12/9/2015 - 10:54:51
					Modified:			12/9/2015 - 10:54:51
14:58:54:431 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gsdll32.dll exists
					File Size:			13090816 bytes
					Created:			12/9/2015 - 10:48:54
					Modified:			12/9/2015 - 10:49:14
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			12/9/2015 - 10:50:23
					Modified:			12/9/2015 - 10:50:30
14:58:54:431 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Java.ahk exists
14:58:54:446 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
14:58:54:446 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
					Created:			12/9/2015 - 10:52:47
					Modified:			12/9/2015 - 10:52:47
14:58:54:446 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\JSON.ahk exists
14:58:54:446 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			9203 bytes
					Created:			12/9/2015 - 10:54:34
					Modified:			12/9/2015 - 10:54:34
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Origin.ahk exists
14:58:54:446 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			4904 bytes
					Created:			12/9/2015 - 10:55:54
					Modified:			12/9/2015 - 10:55:54
14:58:54:446 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RegRW64.ahk exists
					File Size:			6915 bytes
					Created:			12/9/2015 - 10:49:29
					Modified:			12/9/2015 - 10:49:29
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RIni.ahk exists
					File Size:			67561 bytes
					Created:			12/9/2015 - 10:55:11
					Modified:			12/9/2015 - 10:55:12
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Created:			12/9/2015 - 10:52:48
					Modified:			12/9/2015 - 10:52:49
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Steam.ahk exists
					File Size:			5347 bytes
					Created:			12/9/2015 - 10:55:51
					Modified:			12/9/2015 - 10:55:51
14:58:54:446 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\VA.ahk exists
					File Size:			34688 bytes
					Created:			12/9/2015 - 10:48:27
					Modified:			12/9/2015 - 10:48:27
14:58:54:446 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\VA_Extension.ahk exists
					File Size:			3833 bytes
					Created:			12/9/2015 - 10:51:59
					Modified:			12/9/2015 - 10:51:59
14:58:54:462 | RL |   DEBUG1  | +16    | VA_Extension.ahk Version: 1.0.1
14:58:54:462 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\7z.ahk exists
14:58:54:462 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
14:58:54:462 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29149 bytes
					Created:			12/9/2015 - 10:52:18
					Modified:			12/9/2015 - 10:52:19
14:58:54:462 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.2
14:58:54:462 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Bezel.ahk exists
					File Size:			104277 bytes
					Created:			12/9/2015 - 10:47:59
					Modified:			12/9/2015 - 10:47:59
14:58:54:462 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.7
14:58:54:462 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade.ahk exists
					File Size:			38251 bytes
					Created:			12/9/2015 - 10:49:19
					Modified:			12/9/2015 - 10:49:20
14:58:54:462 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.4
14:58:54:462 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Init.ahk exists
					File Size:			1065 bytes
					Created:			12/9/2015 - 10:52:32
					Modified:			12/9/2015 - 10:52:32
14:58:54:462 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.2
14:58:54:462 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Animations.ahk exists
					File Size:			81174 bytes
					Created:			12/9/2015 - 10:53:29
					Modified:			12/9/2015 - 10:53:30
14:58:54:462 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.10
14:58:54:462 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper.ahk exists
14:58:54:478 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
14:58:54:478 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			12/9/2015 - 10:55:59
14:58:54:478 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
14:58:54:478 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper Init.ahk exists
14:58:54:478 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			3461 bytes
					Created:			12/9/2015 - 10:49:51
					Modified:			12/9/2015 - 10:49:51
14:58:54:478 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
14:58:54:478 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame.ahk exists
					File Size:			40753 bytes
					Created:			12/9/2015 - 10:53:56
					Modified:			12/9/2015 - 10:53:56
14:58:54:478 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
14:58:54:478 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame Init.ahk exists
					File Size:			161 bytes
					Created:			12/9/2015 - 10:54:32
					Modified:			12/9/2015 - 10:54:33
14:58:54:478 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
14:58:54:478 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiPlayer.ahk exists
					File Size:			66452 bytes
					Created:			12/9/2015 - 10:55:03
					Modified:			12/9/2015 - 10:55:03
14:58:54:478 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.7
14:58:54:478 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Pause.ahk exists
14:58:54:493 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
14:58:54:493 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
					Created:			12/9/2015 - 10:52:23
					Modified:			12/9/2015 - 10:52:24
14:58:54:493 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.5
14:58:54:493 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Pause Init.ahk exists
14:58:54:493 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			553 bytes
					Created:			12/9/2015 - 10:52:56
					Modified:			12/9/2015 - 10:52:56
14:58:54:493 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
14:58:54:493 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Password.ahk exists
					File Size:			10025 bytes
					Created:			12/9/2015 - 10:53:13
					Modified:			12/9/2015 - 10:53:13
14:58:54:493 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
14:58:54:493 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
					File Size:			74101 bytes
					Created:			12/9/2015 - 10:49:55
					Modified:			12/9/2015 - 10:49:56
14:58:54:493 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.6
14:58:54:493 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Shared.ahk exists
14:58:54:509 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
14:58:54:509 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			139893 bytes
					Created:			12/9/2015 - 10:54:43
					Modified:			12/9/2015 - 10:54:44
14:58:54:509 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.5
14:58:54:509 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics.ahk exists
14:58:54:509 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			26143 bytes
					Created:			12/9/2015 - 10:47:04
					Modified:			12/9/2015 - 10:47:04
14:58:54:509 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
14:58:54:509 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics Init.ahk exists
					File Size:			33 bytes
					Created:			12/9/2015 - 10:55:53
					Modified:			12/9/2015 - 10:55:53
14:58:54:509 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
14:58:54:509 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Virtual Drive.ahk exists
					File Size:			18329 bytes
					Created:			12/9/2015 - 10:47:53
					Modified:			12/9/2015 - 10:47:53
14:58:54:509 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.3
14:58:54:509 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey.ahk exists
					File Size:			26540 bytes
					Created:			12/9/2015 - 10:51:35
					Modified:			12/9/2015 - 10:51:35
14:58:54:509 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
14:58:54:509 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey Init.ahk exists
					File Size:			1063 bytes
					Created:			12/9/2015 - 10:53:20
					Modified:			12/9/2015 - 10:53:20
14:58:54:509 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
14:58:54:509 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r 1000Miglia_v1.1b -f D:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"
14:58:54:509 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "1000Miglia_v1.1b"
14:58:54:509 | RL |   DEBUG1  | +0     | Main - dbName: 1000Miglia_v1.1b
14:58:54:509 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
14:58:54:509 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "1000Miglia_v1.1b"
14:58:54:524 | RL |     INFO  | +15    | Main - Did not find a "D:\Hyperspin\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
14:58:54:524 | RL |     INFO  | +0     | Main - 1000Miglia_v1.1b is using the default emulator: WinUAE
14:58:54:524 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Hyperspin\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
14:58:54:524 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Hyperspin\RocketLauncher\Settings\Global Emulators.ini
14:58:54:524 | RL |     INFO  | +0     | Main - Found [WinUAE] in D:\Hyperspin\RocketLauncher\Settings\Global Emulators.ini
14:58:54:524 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
14:58:54:524 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23650 bytes
					Created:			12/9/2015 - 10:48:42
					Modified:			12/9/2015 - 10:48:42
14:58:54:524 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
14:58:54:524 | RL |     INFO  | +0     | Main - 1000Miglia_v1.1b will use module: D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk
14:58:54:540 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
14:58:54:540 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\winuae.exe exists
14:58:54:540 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.2.1.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.2.1.0
					File Size:			14642248 bytes
					Created:			4/30/2014 - 6:18:49
					Modified:			11/19/2015 - 6:10:08
14:58:54:540 | RL |     INFO  | +0     | Main - INI Keys read
14:58:54:540 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe exists
					FileVersion             	15.06 beta
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.06 beta
					File Size:			262144 bytes
					Created:			12/9/2015 - 10:54:36
					Modified:			12/9/2015 - 10:54:36
14:58:54:540 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll exists
					FileDescription         	7z Plugin
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1012224 bytes
					Created:			12/9/2015 - 10:47:37
					Modified:			12/9/2015 - 10:47:40
14:58:54:556 | RL |     INFO  | +15    | Main - "1000Miglia_v1.1b" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
14:58:54:556 | RL |     INFO  | +0     | CheckPaths - Started
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Commodore Amiga\Official\1000Miglia_v1.1b.7z
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Hyperspin\Games\Commodore Amiga\Official\1000Miglia_v1.1b\1000Miglia_v1.1b.7z
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Commodore Amiga\Official\1000Miglia_v1.1b.zip
14:58:54:556 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Hyperspin\Games\Commodore Amiga\Official\1000Miglia_v1.1b.zip
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: 1000Miglia_v1.1b
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Hyperspin\Games\Commodore Amiga\Official
14:58:54:556 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
14:58:54:556 | RL |     INFO  | +0     | CheckPaths - Ended
14:58:54:556 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Hyperspin\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.4
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Hyperspin\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc
					restoreFE = Restore and Click
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Hyperspin\Emulators\WinUAE\winuae.exe
					emuPath = D:\Hyperspin\Emulators\WinUAE
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Hyperspin\Games\Commodore Amiga\Official
					romPathFromIni = D:\Hyperspin\Games\Commodore Amiga\Official|D:\Hyperspin\Games\Commodore Amiga\WHD+|D:\Hyperspin\Games\Commodore Amiga\ADF|D:\Hyperspin\Games\Commodore Amiga\IPF
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = 7z|zip|adf|info|cue
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = 1000Miglia_v1.1b
					dbExt =
					romName = 1000Miglia_v1.1b
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Hyperspin\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysLang = Italian_Standard
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1280
					originalHeight = 1024
					vdEnabled = true
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Hyperspin\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Hyperspin\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==
					hideCursor = false
					hideEmu = false
					hideFE = true
					fadeIn = true
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = true
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr2Prefix = Info Bar
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Extraction In Progress, Please Wait
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Hyperspin\RocketLauncher\Media\Fade
					RLDataPath = D:\Hyperspin\RocketLauncher\Data
					RLMediaPath = D:\Hyperspin\RocketLauncher\Media
					RLErrSoundPath = D:\Hyperspin\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Hyperspin\RocketLauncher\Modules
					moduleFullName = D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Hyperspin\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Hyperspin\RocketLauncher\Module Extensions
					libPath = D:\Hyperspin\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\yashijoe\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Hyperspin\RocketLauncher\Module Extensions\HiToText\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = true
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe
					joyToKeyFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\JoyToKey\JoyToKey.exe
					keymapperProfilePath = D:\Hyperspin\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = xpadder
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\1000Miglia_v1.1b
					RocketLauncherProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga\1000Miglia_v1.1b
					ahkRocketLauncherProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Hyperspin\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Hyperspin\RocketLauncher\Lib\User Fade Animations.ini
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
14:58:54:556 | RL |  WARNING  | +0     | BuildScript - "D:\Hyperspin\RocketLauncher\Lib\User Functions Init.ahk" not found
14:58:54:556 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Validating module
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Validation complete
14:58:54:556 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.2.0
					MCRC = 4C755A18
					iCRC = 5974D94
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
14:58:54:571 | RL |     INFO  | +16    | BuildScript - Loaded Pause scripts
14:58:54:571 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
14:58:54:587 | RL |     INFO  | +16    | BuildScript - Loaded Statistics.ahk script
14:58:54:587 | RL |  WARNING  | +0     | BuildScript - "D:\Hyperspin\RocketLauncher\Lib\User Functions.ahk" not found
14:58:54:587 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
14:58:54:587 | RL |     INFO  | +0     | Main - Module is built
14:58:54:587 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\AutoHotkey.dll exists
14:58:54:587 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Created:			12/9/2015 - 10:55:48
					Modified:			12/9/2015 - 10:55:49
14:58:54:587 | RL |     INFO  | +0     | Main - Running module
14:58:54:587 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
14:58:54:790 | MD |     INFO  | +N/A   | Module initialized
14:58:54:790 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:58:54:790 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
14:58:54:790 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:54:821 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Post loop 2 check
14:58:54:821 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:58:54:821 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:54:821 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe exists
14:58:54:821 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			12/9/2015 - 11:16:28
					Modified:			1/1/2015 - 5:05:33
14:58:54:821 | MD |     INFO  | +0     | Keymapper - Loading xpadder
14:58:54:821 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
14:58:54:821 | MD |     INFO  | +0     | GetJoystickArray - Started
14:58:54:883 | MD |   DEBUG2  | +62    | GetJoystickArray - Joysticks Detected: 1000000000000000
14:58:54:883 | MD |     INFO  | +0     | GetJoystickGUID - Started
14:58:54:883 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 000970E22C40E5118001444553540000
14:58:54:883 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: I-PAC 2 | MID: d209 | PID: 0420 | GUID: 000970E22C40E5118001444553540000
14:58:54:883 | MD |     INFO  | +0     | GetJoystickArray - Ended
14:58:54:883 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe"
14:58:54:883 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
14:58:54:883 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "I-PAC 2"
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\1000Miglia_v1.1b|D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE|D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default|D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default|D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\1000Miglia_v1.1b\I-PAC 2\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\1000Miglia_v1.1b\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE\I-PAC 2\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default\I-PAC 2\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\I-PAC 2\p1.xpadderprofile
14:58:54:883 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile
14:58:54:883 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile
14:58:54:883 | MD |     INFO  | +0     | RunXpadder - Started
14:58:54:883 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
14:58:54:883 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
14:58:54:883 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe /C
14:58:54:961 | MD |   DEBUG1  | +78    | Run - "Xpadder.exe /C" Process ID: 3812
14:58:54:961 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini
14:58:54:961 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
14:58:55:191 | MD |   DEBUG2  | +234   | RunXpadder - Reading the order in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini and arranging profiles found to match that order
14:58:55:192 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
14:58:55:192 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
14:58:55:269 | MD |   DEBUG1  | +78    | Run - "Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 3152
14:58:55:269 | MD |     INFO  | +0     | RunXpadder - Ended
14:58:55:269 | MD |     INFO  | +0     | RunKeymapper - Ended
14:58:55:269 | MD |   DEBUG1  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
14:58:55:269 | MD |   DEBUG1  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
14:58:55:269 | MD |   DEBUG1  | +0     | fadeLyr3Animation: DefaultFadeAnimation
14:58:55:269 | MD |   DEBUG1  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd not in TableKeyGroups ~Esc,
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~NumpadAdd,
14:58:55:269 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
14:58:55:269 | MD |     INFO  | +0     | StartModule - Started
14:58:55:269 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.2.0
					MCRC: 4C755A18
					iCRC: 5974D94
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
14:58:55:269 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
14:58:55:269 | MD |     INFO  | +0     | PluginInit - Started
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
14:58:55:269 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Databases\Commodore Amiga\Commodore Amiga.xml exists
14:58:55:269 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/30/2014 - 6:16:35
					Modified:			4/22/2014 - 9:45:29
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "1000 Miglia"
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
14:58:55:269 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value: 1000 Miglia
					GameInfo Label: Rating | GameInfo Value: Other - NR (Not Rated)
14:58:55:269 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\1000Miglia_v1.1b.png
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png
14:58:55:269 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\1000Miglia_v1.1b.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork1\1000Miglia_v1.1b.png
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork2\1000Miglia_v1.1b.png
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork3\1000Miglia_v1.1b.png
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork4\1000Miglia_v1.1b.png
14:58:55:269 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Hyperspin\Media\Commodore Amiga\Images\Letters
14:58:55:395 | MD |   DEBUG1  | +125   | BuildAssetsTable - Searching for a Other: D:\Hyperspin\Media\Commodore Amiga\Images\Other
14:58:55:398 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
14:58:55:398 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:58:55:399 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
14:58:55:399 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: D:\Hyperspin\Media\Commodore Amiga\Video\1000Miglia_v1.1b.*
14:58:55:399 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a FLV Game Video: D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.*
14:58:55:399 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Video\1000Miglia_v1.1b.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
14:58:55:400 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:58:55:400 | MD |     INFO  | +0     | PluginInit - Ended
14:58:55:400 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: 1000Miglia_v1.1b
14:58:55:400 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:58:55:400 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,
14:58:55:401 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:55:401 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:58:55:401 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
14:58:55:401 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:55:402 | MD |     INFO  | +0     | StartModule - Ended
14:58:55:402 | MD |   DEBUG1  | +0     | FadeInStart - Started
14:58:55:403 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:58:55:403 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:58:55:403 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:58:55:403 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:58:55:420 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 11 check
14:58:55:420 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:58:55:420 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:58:55:420 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:55:420 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:58:55:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:58:55:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:58:55:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:58:55:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:58:55:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:58:55:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:58:55:422 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:55:422 | MD |   DEBUG1  | +0     | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:58:55:422 | MD |   DEBUG2  | +0     | FadeInStart - Fade screen scale factor: X=0.666667, Y= 0.948148
14:58:55:422 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\1000Miglia_v1.1b\Layer 1*.*
14:58:55:422 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer 1*.*
14:58:55:423 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.*
14:58:55:423 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.png
14:58:55:423 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 01 (Gigapig).png
14:58:55:423 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 02 (Gigapig).png
14:58:55:423 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 03 (Gigapig).png
14:58:55:424 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 04 (Gigapig).png
14:58:55:424 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 05 (Gigapig).png
14:58:55:424 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 06 (Gigapig).png
14:58:55:424 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 07 (Gigapig).png
14:58:55:424 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.gif
14:58:55:425 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.tif
14:58:55:425 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.bmp
14:58:55:425 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.jpg
14:58:55:425 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 01 (Gigapig).png
14:58:55:425 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\1000Miglia_v1.1b\Info Bar*.*
14:58:55:426 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Info Bar*.*
14:58:55:426 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Info Bar*.*
14:58:55:426 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:58:55:426 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:58:55:426 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:58:55:427 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:58:55:427 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:58:55:427 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:58:55:427 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:58:55:428 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:58:55:428 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:58:55:596 | MD |     INFO  | +172   | DefaultAnimateFadeIn - Started, direction is: in
14:58:55:596 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
14:58:56:125 | MD |     INFO  | +530   | DefaultAnimateFadeIn - Ended
14:58:56:125 | MD |     INFO  | +0     | DefaultFadeAnimation - Started
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\1000Miglia_v1.1b\Info Bar*.*
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Info Bar*.*
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Info Bar*.*
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:58:56:125 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:58:56:125 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:58:56:156 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\1000Miglia_v1.1b\Layer 3*.*
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer 3*.*
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.*
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.png
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3.png
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.gif
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.tif
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.bmp
14:58:56:156 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.jpg
14:58:56:156 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3.png
14:58:56:188 | MD |   DEBUG1  | +31    | FadeInDelay - Started
14:58:56:188 | MD |   DEBUG1  | +0     | FadeInDelay - Ended
14:58:56:188 | MD |     INFO  | +0     | DefaultFadeAnimation - Ended
14:58:56:188 | MD |   DEBUG1  | +0     | FadeInStart - Ended
14:58:56:188 | MD |     INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
14:58:56:188 | MD |   DEBUG1  | +0     | CoverFE - Started
14:58:56:188 | MD |     INFO  | +0     | HideFE - Hiding Frontend by making it transparent
14:58:56:188 | MD |   DEBUG1  | +0     | CoverFE - Ended
14:58:56:266 | MD |     INFO  | +78    | Module Setting - [Settings] - ScreenMode: true
14:58:56:266 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - ScreenMode: true
14:58:56:297 | MD |     INFO  | +32    | Module Setting - [Settings] - QuickStartMode:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - QuickStartMode:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - KickstartFile:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - Options:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Top_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - Bezel_Top_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - Bezel_Bottom_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - Bezel_Right_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - Bezel_Left_Offset: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - UseGui: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - FloppySpeed: turbo
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - PathToExtraDrive:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - UseMouse: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - DelayHack: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - RequiresWB: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: PAL
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - VideoMode: PAL
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: native
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - XResolution: native
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: native
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - YResolution: native
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - BlackerThanBlack: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - RemoveInterlaceArtifacts: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - LineMode:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - AutoScale:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - AutoScale:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - ShaderMask:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - FilterShader:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - FilterShaderScale:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - FilteredLowResolution:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [Display] - ResolutionMode: hires
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - ResolutionMode: hires
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - CPU:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CPU:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuSpeed: real
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CpuSpeed: real
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CpuCycleExact:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CpuCompatible: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - MMU: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedCPU: true
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - DisableUnimplementedCPU: true
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - FPU:
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - MoreCompatibleFPU: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - MoreCompatibleFPU: false
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedFPU: true
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - DisableUnimplementedFPU: true
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize: 0
14:58:56:297 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CacheSize: 0
14:58:56:328 | MD |     INFO  | +31    | DefaultFadeAnimationLoop - Playing 7z fade complete sound: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\7z complete.mp3
14:58:56:565 | MD |     INFO  | +234   | Module Setting - [CPU] - 24-BitAddressing: true
14:58:56:566 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - 24-BitAddressing: true
14:58:56:566 | MD |     INFO  | +0     | Module Setting - [Chipset] - CycleExact: true
14:58:56:566 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CycleExact: true
14:58:56:566 | MD |     INFO  | +0     | Module Setting - [Chipset] - ImmediateBlitter: "false"
14:58:56:567 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - ImmediateBlitter: "false"
14:58:56:567 | MD |     INFO  | +0     | Module Setting - [Chipset] - BlitterCycleExact:
14:58:56:567 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - BlitterCycleExact:
14:58:56:568 | MD |     INFO  | +0     | Module Setting - [Chipset] - CollisionLevel:
14:58:56:568 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - CollisionLevel:
14:58:56:568 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
14:58:56:568 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - ChipMemory:
14:58:56:569 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:
14:58:56:569 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - FastMemory:
14:58:56:569 | MD |     INFO  | +0     | Module Setting - [RAM] - AutoConfigFastMemory:
14:58:56:569 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - AutoConfigFastMemory:
14:58:56:569 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
14:58:56:570 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - SlowMemory:
14:58:56:570 | MD |     INFO  | +0     | Module Setting - [RAM] - Z3FastMemory:
14:58:56:570 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - Z3FastMemory:
14:58:56:570 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:
14:58:56:571 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - MegaChipMemory:
14:58:56:571 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:
14:58:56:571 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - ProcessorSlotFast:
14:58:56:571 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:
14:58:56:572 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - RTGCardType:
14:58:56:572 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:
14:58:56:572 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - RTGVRAMSize:
14:58:56:572 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGHardwareSprite:
14:58:56:573 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - RTGHardwareSprite:
14:58:56:573 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - PathToWHDFolder: .\WHD
14:58:56:573 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - PathToWHDFolder: .\WHD
14:58:56:573 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
14:58:56:573 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - WHDLoadOptions: PRELOAD
14:58:56:624 | MD |     INFO  | +62    | Module Setting - [WHDLoad] - NeverExtract: false
14:58:56:624 | MD |     INFO  | +0     | Module Setting - [1000Miglia_v1.1b] - NeverExtract: false
14:58:56:624 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\WHD exists
14:58:56:625 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
					Created:			4/30/2014 - 6:18:48
					Modified:			12/26/2015 - 1:36:07
14:58:56:626 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\Emulators\WinUAE\winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Hyperspin\Emulators\WinUAE\WHD" -s filesystem=ro,Games:"D:\Hyperspin\Games\Commodore Amiga\Official\1000Miglia_v1.1b.zip"  -portable
14:58:56:742 | MD |   DEBUG1  | +109   | Run - "winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a1200,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cachesize=0 -s immediate_blits="false" -s cycle_exact=true -s cpu_compatible=false -s cpu_speed=real -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true -s filesystem=rw,WHD:"D:\Hyperspin\Emulators\WinUAE\WHD" -s filesystem=ro,Games:"D:\Hyperspin\Games\Commodore Amiga\Official\1000Miglia_v1.1b.zip"  -portable" Process ID: 1208
14:58:56:742 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x230364 | Process ID: 3764 | Process Path: D:\Hyperspin\RocketLauncher\RocketLauncher.exe
14:58:56:743 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
14:58:57:025 | MD |   DEBUG1  | +281   | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:58:57:074 | MD |   DEBUG1  | +63    | DefaultFadeAnimationLoop - AnimationLoop has finished
14:58:57:074 | MD |   DEBUG1  | +0     | DefaultFadeAnimationLoop - Ended
14:58:57:086 | MD |   DEBUG1  | +0     | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:58:57:469 | MD |   DEBUG1  | +390   | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0xac0034 | Process ID: 1208 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:58:57:469 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0xac0034 | Process ID: 1208 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:58:57:469 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
14:58:57:576 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0xac0034 | Process ID: 1208 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:58:57:628 | MD |   DEBUG1  | +47    | FadeInExit - Started
14:58:57:629 | MD |   DEBUG1  | +0     | FadeInExit - fadeInExitDelay started
14:58:58:385 | MD |   DEBUG1  | +764   | FadeInExit - fadeInExitDelay ended
14:58:58:385 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Started, direction is: out
14:58:58:921 | MD |     INFO  | +530   | DefaultAnimateFadeIn - Ended
14:58:58:988 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - Started
14:58:58:988 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:58:58:988 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:58:58:989 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:58:58:990 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:58:58:990 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:58:58:990 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:58:58:990 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:58:58:990 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:58:58:990 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:58:58:990 | MD |   DEBUG1  | +0     | FadeInExit - Ended, waiting for user to close launched application
14:58:58:991 | MD |     INFO  | +0     | Process - WaitClose winuae.exe
14:59:03:932 | MD |   DEBUG1  | +4945  | CloseProcess - Started, user requested to end launched application
14:59:03:932 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\WHD exists
14:59:03:933 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			0 bytes
14:59:03:933 | MD |   DEBUG1  | +0     | FadeOutStart - Started
14:59:03:933 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:59:03:933 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:59:03:934 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:59:03:934 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:59:03:934 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:59:03:934 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:59:03:934 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:59:03:934 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:59:03:935 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:59:03:935 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:59:03:935 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:59:03:935 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:59:03:935 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:59:03:935 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:59:03:936 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:59:03:936 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:59:03:936 | MD |   DEBUG1  | +0     | FadeOutStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:59:03:936 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\1000Miglia_v1.1b\Layer -1*.*
14:59:03:936 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer -1*.*
14:59:03:936 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer -1*.*
14:59:03:936 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Layer -1*.*
14:59:03:958 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.*
14:59:03:958 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.png
14:59:03:958 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 1 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 2 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 3 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 4 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 5 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 6 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 7 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 8 (Gigapig).png
14:59:03:959 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 01 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 02 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 03 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 04 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 05 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 06 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 07 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 08 (Gigapig).png
14:59:03:960 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 09 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 01 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 02 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 03 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 04 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 05 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 06 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 07 (Gigapig).png
14:59:03:961 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 08 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 09 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 10 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 11 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 12 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 13 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 14 (Gigapig).png
14:59:03:962 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.gif
14:59:03:963 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.tif
14:59:03:963 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.bmp
14:59:03:963 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.jpg
14:59:03:963 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 3 (Gigapig).png
14:59:04:195 | MD |     INFO  | +234   | DefaultAnimateFadeOut - Started, direction is: in
14:59:04:688 | MD |     INFO  | +500   | DefaultAnimateFadeOut - Ended
14:59:04:688 | MD |   DEBUG1  | +0     | FadeOutStart - Ended
14:59:04:688 | MD |   DEBUG1  | +0     | ShowFE - Started
14:59:04:689 | MD |     INFO  | +0     | HideFE - Showing Frontend and removing transparency
14:59:04:689 | MD |   DEBUG1  | +0     | ShowFE - Ended
14:59:04:689 | MD |   DEBUG1  | +0     | CloseProcess - Ended
14:59:04:691 | MD |   DEBUG1  | +0     | FadeOutExit - Started
14:59:04:691 | MD |     INFO  | +0     | DefaultAnimateFadeOut - Started, direction is: out
14:59:05:218 | MD |     INFO  | +530   | DefaultAnimateFadeOut - Ended
14:59:05:220 | MD |   DEBUG1  | +0     | FadeOutExit - Ended
14:59:05:220 | MD |     INFO  | +0     | ExitModule - Started
14:59:05:220 | MD |     INFO  | +0     | Starting Updating Statistics:
14:59:05:220 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
14:59:05:221 | MD |   DEBUG2  | +0     | gameSectionStartTime:10108490
14:59:05:221 | MD |   DEBUG2  | +0     | ElapsedTime:6
14:59:05:221 | MD |   DEBUG2  | +0     | Statistics cleared game name: 1000Miglia_v1.1b
14:59:05:285 | MD |   DEBUG2  | +62    | Loaded game statistics from ini files:
					Number_of_Times_Played: 7
					Last_Time_Played: sabato dicembre 26, 2015 02:57:12
					Average_Time_Played: 9
					Total_Time_Played: 64
					System_Total_Played_Time: 691
					Total_Global_Played_Time: 797
14:59:05:285 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 8
					Last_Time_Played: sabato dicembre 26, 2015 02:58:58
					Total_Time_Played: 70
					System_Total_Played_Time: 697
					Total_Global_Played_Time: 803
14:59:05:349 | MD |     INFO  | +63    | Game section statistics updated.
14:59:05:349 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
14:59:05:350 | MD |     INFO  | +0     | GetJoystickArray - Started
14:59:05:355 | MD |   DEBUG2  | +0     | GetJoystickArray - Joysticks Detected: 1000000000000000
14:59:05:377 | MD |     INFO  | +31    | GetJoystickGUID - Started
14:59:05:377 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 000970E22C40E5118001444553540000
14:59:05:377 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: I-PAC 2 | MID: d209 | PID: 0420 | GUID: 000970E22C40E5118001444553540000
14:59:05:378 | MD |     INFO  | +0     | GetJoystickArray - Ended
14:59:05:378 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
14:59:05:378 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "I-PAC 2"
14:59:05:378 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
14:59:05:378 | MD |   DEBUG2  | +0     | GetProfile - Searching -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
14:59:05:378 | MD |     INFO  | +0     | GetProfile - Loading Profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
14:59:05:379 | MD |     INFO  | +0     | RunXpadder - Started
14:59:05:379 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
14:59:05:380 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
14:59:05:381 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe /C
14:59:05:406 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe /C" Process ID: 3288
14:59:05:406 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini
14:59:05:406 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
14:59:05:630 | MD |   DEBUG2  | +219   | RunXpadder - Reading the order in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini and arranging profiles found to match that order
14:59:05:631 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
14:59:05:631 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M
14:59:05:693 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 3472
14:59:05:693 | MD |     INFO  | +0     | RunXpadder - Ended
14:59:05:693 | MD |     INFO  | +0     | RunKeymapper - Ended
14:59:05:693 | MD |     INFO  | +0     | ExitModule - Ended
14:59:05:693 | MD |     INFO  | +0     | End of Module Logs
14:59:05:776 | RL |     INFO  | +11185 | Main - Module ended, exiting RocketLauncher normally
14:59:05:776 | RL |     INFO  | +0     | ExitScript - Started
14:59:05:808 | RL |     INFO  | +31    | SystemCursor - Restoring mouse cursor
14:59:05:839 | RL |     INFO  | +31    | ExitScript - Ended
[/code]
MEMORY LOADING FAULT:
[code]
14:49:56:850 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com)
14:49:56:960 | RL |     INFO  | +109   | Main - System Specs:
					RocketLauncher Dir: D:\Hyperspin\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Ultimate
					SKU: Ultimate
					Total Memory: 7644.39 MB
					Free Memory: 6108.25 MB
					Used Memory: 1536.137 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: AMD Radeon HD 5700 Series
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 13.251.0.0
					GPU 2 Name: AMD Radeon HD 7560D
					GPU 2 RAM: 512.00 MB
					GPU 2 Driver Version: 13.251.0.0
					Sound 1 Device: AMD High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: AMD High Definition Audio Device
					Sound 2 Status: Enabled
					Sound 3 Device: Dispositivo High Definition Audio
					Sound 3 Status: Enabled
					OS Language: Italian_Standard
					OS Admin Status: No
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x984 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1280
					Current AHK Desktop Height: 1024
					AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
14:49:56:960 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\RocketLauncher.exe exists
14:49:56:960 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.4
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2063360 bytes
					Created:			12/9/2015 - 10:44:38
					Modified:			12/9/2015 - 10:52:27
14:49:56:960 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Array.ahk exists
14:49:56:960 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			4924 bytes
					Created:			12/9/2015 - 10:50:09
					Modified:			12/9/2015 - 10:50:09
14:49:56:960 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BinHexRW.ahk exists
14:49:56:960 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5077 bytes
					Created:			12/9/2015 - 10:52:17
					Modified:			12/9/2015 - 10:52:17
14:49:56:960 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			12/9/2015 - 10:48:01
					Modified:			12/9/2015 - 10:48:03
14:49:56:960 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\CLR_L.ahk exists
					File Size:			5474 bytes
					Created:			12/9/2015 - 10:48:53
					Modified:			12/9/2015 - 10:48:53
14:49:56:960 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
					File Size:			5716 bytes
					Created:			12/9/2015 - 10:55:59
					Modified:			12/9/2015 - 10:56:00
14:49:56:975 | RL |     INFO  | +16    | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip.ahk exists
14:49:56:975 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
14:49:56:975 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			12/9/2015 - 10:45:19
					Modified:			12/9/2015 - 10:45:19
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip_alt.ahk exists
14:49:56:975 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5895 bytes
					Created:			12/9/2015 - 10:54:51
					Modified:			12/9/2015 - 10:54:51
14:49:56:975 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gsdll32.dll exists
					File Size:			13090816 bytes
					Created:			12/9/2015 - 10:48:54
					Modified:			12/9/2015 - 10:49:14
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			12/9/2015 - 10:50:23
					Modified:			12/9/2015 - 10:50:30
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Java.ahk exists
					File Size:			7841 bytes
					Created:			12/9/2015 - 10:52:47
					Modified:			12/9/2015 - 10:52:47
14:49:56:975 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\JSON.ahk exists
					File Size:			9203 bytes
					Created:			12/9/2015 - 10:54:34
					Modified:			12/9/2015 - 10:54:34
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Origin.ahk exists
					File Size:			4904 bytes
					Created:			12/9/2015 - 10:55:54
					Modified:			12/9/2015 - 10:55:54
14:49:56:975 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RegRW64.ahk exists
					File Size:			6915 bytes
					Created:			12/9/2015 - 10:49:29
					Modified:			12/9/2015 - 10:49:29
14:49:56:975 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RIni.ahk exists
14:49:56:991 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			67561 bytes
					Created:			12/9/2015 - 10:55:11
					Modified:			12/9/2015 - 10:55:12
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
14:49:56:991 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Created:			12/9/2015 - 10:52:48
					Modified:			12/9/2015 - 10:52:49
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Steam.ahk exists
14:49:56:991 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5347 bytes
					Created:			12/9/2015 - 10:55:51
					Modified:			12/9/2015 - 10:55:51
14:49:56:991 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\VA.ahk exists
14:49:56:991 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			34688 bytes
					Created:			12/9/2015 - 10:48:27
					Modified:			12/9/2015 - 10:48:27
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\VA_Extension.ahk exists
					File Size:			3833 bytes
					Created:			12/9/2015 - 10:51:59
					Modified:			12/9/2015 - 10:51:59
14:49:56:991 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\7z.ahk exists
					File Size:			29149 bytes
					Created:			12/9/2015 - 10:52:18
					Modified:			12/9/2015 - 10:52:19
14:49:56:991 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.2
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Bezel.ahk exists
					File Size:			104277 bytes
					Created:			12/9/2015 - 10:47:59
					Modified:			12/9/2015 - 10:47:59
14:49:56:991 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.7
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade.ahk exists
					File Size:			38251 bytes
					Created:			12/9/2015 - 10:49:19
					Modified:			12/9/2015 - 10:49:20
14:49:56:991 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.4
14:49:56:991 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Init.ahk exists
14:49:56:006 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
14:49:57:006 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1065 bytes
					Created:			12/9/2015 - 10:52:32
					Modified:			12/9/2015 - 10:52:32
14:49:57:006 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.2
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Animations.ahk exists
14:49:57:006 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			81174 bytes
					Created:			12/9/2015 - 10:53:29
					Modified:			12/9/2015 - 10:53:30
14:49:57:006 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.10
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper.ahk exists
					File Size:			33453 bytes
					Modified:			12/9/2015 - 10:55:59
14:49:57:006 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper Init.ahk exists
					File Size:			3461 bytes
					Created:			12/9/2015 - 10:49:51
					Modified:			12/9/2015 - 10:49:51
14:49:57:006 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame.ahk exists
					File Size:			40753 bytes
					Created:			12/9/2015 - 10:53:56
					Modified:			12/9/2015 - 10:53:56
14:49:57:006 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame Init.ahk exists
					File Size:			161 bytes
					Created:			12/9/2015 - 10:54:32
					Modified:			12/9/2015 - 10:54:33
14:49:57:006 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiPlayer.ahk exists
					File Size:			66452 bytes
					Created:			12/9/2015 - 10:55:03
					Modified:			12/9/2015 - 10:55:03
14:49:57:006 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.7
14:49:57:006 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Pause.ahk exists
14:49:57:022 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
14:49:57:022 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
					Created:			12/9/2015 - 10:52:23
					Modified:			12/9/2015 - 10:52:24
14:49:57:022 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.5
14:49:57:022 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Pause Init.ahk exists
14:49:57:022 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			553 bytes
					Created:			12/9/2015 - 10:52:56
					Modified:			12/9/2015 - 10:52:56
14:49:57:022 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
14:49:57:022 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Password.ahk exists
					File Size:			10025 bytes
					Created:			12/9/2015 - 10:53:13
					Modified:			12/9/2015 - 10:53:13
14:49:57:022 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
14:49:57:022 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
					File Size:			74101 bytes
					Created:			12/9/2015 - 10:49:55
					Modified:			12/9/2015 - 10:49:56
14:49:57:022 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.6
14:49:57:022 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Shared.ahk exists
14:49:57:038 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
14:49:57:038 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			139893 bytes
					Created:			12/9/2015 - 10:54:43
					Modified:			12/9/2015 - 10:54:44
14:49:57:038 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.5
14:49:57:038 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics.ahk exists
14:49:57:038 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			26143 bytes
					Created:			12/9/2015 - 10:47:04
					Modified:			12/9/2015 - 10:47:04
14:49:57:038 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
14:49:57:038 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics Init.ahk exists
					File Size:			33 bytes
					Created:			12/9/2015 - 10:55:53
					Modified:			12/9/2015 - 10:55:53
14:49:57:038 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
14:49:57:038 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Virtual Drive.ahk exists
					File Size:			18329 bytes
					Created:			12/9/2015 - 10:47:53
					Modified:			12/9/2015 - 10:47:53
14:49:57:038 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.3
14:49:57:038 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey.ahk exists
					File Size:			26540 bytes
					Created:			12/9/2015 - 10:51:35
					Modified:			12/9/2015 - 10:51:35
14:49:57:038 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
14:49:57:038 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey Init.ahk exists
					File Size:			1063 bytes
					Created:			12/9/2015 - 10:53:20
					Modified:			12/9/2015 - 10:53:20
14:49:57:038 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
14:49:57:038 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r A10TankKiller_v2.0_3Disk -f D:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"
14:49:57:038 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "A10TankKiller_v2.0_3Disk"
14:49:57:038 | RL |   DEBUG1  | +0     | Main - dbName: A10TankKiller_v2.0_3Disk
14:49:57:038 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
14:49:57:038 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "A10TankKiller_v2.0_3Disk"
14:49:57:053 | RL |     INFO  | +16    | Main - Did not find a "D:\Hyperspin\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
14:49:57:053 | RL |     INFO  | +0     | Main - A10TankKiller_v2.0_3Disk is using the default emulator: WinUAE
14:49:57:053 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Hyperspin\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
14:49:57:053 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Hyperspin\RocketLauncher\Settings\Global Emulators.ini
14:49:57:053 | RL |     INFO  | +0     | Main - Found [WinUAE] in D:\Hyperspin\RocketLauncher\Settings\Global Emulators.ini
14:49:57:053 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
14:49:57:053 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23650 bytes
					Created:			12/9/2015 - 10:48:42
					Modified:			12/9/2015 - 10:48:42
14:49:57:053 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
14:49:57:053 | RL |     INFO  | +0     | Main - A10TankKiller_v2.0_3Disk will use module: D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk
14:49:57:069 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
14:49:57:069 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\winuae.exe exists
14:49:57:069 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.2.1.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.2.1.0
					File Size:			14642248 bytes
					Created:			4/30/2014 - 6:18:49
					Modified:			11/19/2015 - 6:10:08
14:49:57:069 | RL |     INFO  | +0     | Main - INI Keys read
14:49:57:069 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe exists
					FileVersion             	15.06 beta
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.06 beta
					File Size:			262144 bytes
					Created:			12/9/2015 - 10:54:36
					Modified:			12/9/2015 - 10:54:36
14:49:57:069 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll exists
					FileDescription         	7z Plugin
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1012224 bytes
					Created:			12/9/2015 - 10:47:37
					Modified:			12/9/2015 - 10:47:40
14:49:57:084 | RL |     INFO  | +15    | Main - "A10TankKiller_v2.0_3Disk" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
14:49:57:084 | RL |     INFO  | +0     | CheckPaths - Started
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Commodore Amiga\Official\A10TankKiller_v2.0_3Disk.7z
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Hyperspin\Games\Commodore Amiga\Official\A10TankKiller_v2.0_3Disk\A10TankKiller_v2.0_3Disk.7z
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Commodore Amiga\Official\A10TankKiller_v2.0_3Disk.zip
14:49:57:084 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Hyperspin\Games\Commodore Amiga\Official\A10TankKiller_v2.0_3Disk.zip
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: A10TankKiller_v2.0_3Disk
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Hyperspin\Games\Commodore Amiga\Official
14:49:57:084 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
14:49:57:084 | RL |     INFO  | +0     | CheckPaths - Ended
14:49:57:084 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Hyperspin\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.4
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Hyperspin\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc
					restoreFE = Restore and Click
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Hyperspin\Emulators\WinUAE\winuae.exe
					emuPath = D:\Hyperspin\Emulators\WinUAE
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Hyperspin\Games\Commodore Amiga\Official
					romPathFromIni = D:\Hyperspin\Games\Commodore Amiga\Official|D:\Hyperspin\Games\Commodore Amiga\WHD+|D:\Hyperspin\Games\Commodore Amiga\ADF|D:\Hyperspin\Games\Commodore Amiga\IPF
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = 7z|zip|adf|info|cue
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = A10TankKiller_v2.0_3Disk
					dbExt =
					romName = A10TankKiller_v2.0_3Disk
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Hyperspin\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysLang = Italian_Standard
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1280
					originalHeight = 1024
					vdEnabled = true
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Hyperspin\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Hyperspin\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==
					hideCursor = false
					hideEmu = false
					hideFE = true
					fadeIn = true
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = true
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr2Prefix = Info Bar
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Extraction In Progress, Please Wait
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Hyperspin\RocketLauncher\Media\Fade
					RLDataPath = D:\Hyperspin\RocketLauncher\Data
					RLMediaPath = D:\Hyperspin\RocketLauncher\Media
					RLErrSoundPath = D:\Hyperspin\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Hyperspin\RocketLauncher\Modules
					moduleFullName = D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Hyperspin\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Hyperspin\RocketLauncher\Module Extensions
					libPath = D:\Hyperspin\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\yashijoe\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Hyperspin\RocketLauncher\Module Extensions\HiToText\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = true
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe
					joyToKeyFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\JoyToKey\JoyToKey.exe
					keymapperProfilePath = D:\Hyperspin\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = xpadder
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\A10TankKiller_v2.0_3Disk
					RocketLauncherProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga\A10TankKiller_v2.0_3Disk
					ahkRocketLauncherProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Hyperspin\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Hyperspin\RocketLauncher\Lib\User Fade Animations.ini
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
14:49:57:084 | RL |  WARNING  | +0     | BuildScript - "D:\Hyperspin\RocketLauncher\Lib\User Functions Init.ahk" not found
14:49:57:084 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Validating module
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Validation complete
14:49:57:084 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.2.0
					MCRC = 4C755A18
					iCRC = 5974D94
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
14:49:57:100 | RL |     INFO  | +16    | BuildScript - Loaded Pause scripts
14:49:57:100 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
14:49:57:100 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
14:49:57:100 | RL |  WARNING  | +0     | BuildScript - "D:\Hyperspin\RocketLauncher\Lib\User Functions.ahk" not found
14:49:57:100 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
14:49:57:116 | RL |     INFO  | +15    | Main - Module is built
14:49:57:116 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\AutoHotkey.dll exists
14:49:57:116 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Created:			12/9/2015 - 10:55:48
					Modified:			12/9/2015 - 10:55:49
14:49:57:116 | RL |     INFO  | +0     | Main - Running module
14:49:57:116 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
14:49:57:318 | MD |     INFO  | +N/A   | Module initialized
14:49:57:318 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:49:57:318 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
14:49:57:350 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
14:49:57:350 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:49:57:350 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:49:57:350 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:49:57:350 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe exists
14:49:57:350 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			12/9/2015 - 11:16:28
					Modified:			1/1/2015 - 5:05:33
14:49:57:350 | MD |     INFO  | +0     | Keymapper - Loading xpadder
14:49:57:350 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
14:49:57:350 | MD |     INFO  | +0     | GetJoystickArray - Started
14:49:57:412 | MD |   DEBUG2  | +63    | GetJoystickArray - Joysticks Detected: 1000000000000000
14:49:57:412 | MD |     INFO  | +0     | GetJoystickGUID - Started
14:49:57:412 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 000970E22C40E5118001444553540000
14:49:57:412 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: I-PAC 2 | MID: d209 | PID: 0420 | GUID: 000970E22C40E5118001444553540000
14:49:57:412 | MD |     INFO  | +0     | GetJoystickArray - Ended
14:49:57:412 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe"
14:49:57:412 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
14:49:57:412 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "I-PAC 2"
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\A10TankKiller_v2.0_3Disk|D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE|D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default|D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default|D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\A10TankKiller_v2.0_3Disk\I-PAC 2\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\A10TankKiller_v2.0_3Disk\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE\I-PAC 2\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default\I-PAC 2\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\I-PAC 2\p1.xpadderprofile
14:49:57:412 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile
14:49:57:412 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile
14:49:57:412 | MD |     INFO  | +0     | RunXpadder - Started
14:49:57:412 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
14:49:57:412 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
14:49:57:412 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe /C
14:49:57:506 | MD |   DEBUG1  | +93    | Run - "Xpadder.exe /C" Process ID: 4176
14:49:57:506 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini
14:49:57:506 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
14:49:57:718 | MD |   DEBUG2  | +219   | RunXpadder - Reading the order in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini and arranging profiles found to match that order
14:49:57:719 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
14:49:57:719 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
14:49:57:782 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 4528
14:49:57:782 | MD |     INFO  | +0     | RunXpadder - Ended
14:49:57:783 | MD |     INFO  | +0     | RunKeymapper - Ended
14:49:57:783 | MD |   DEBUG1  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
14:49:57:783 | MD |   DEBUG1  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
14:49:57:784 | MD |   DEBUG1  | +0     | fadeLyr3Animation: DefaultFadeAnimation
14:49:57:784 | MD |   DEBUG1  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
14:49:57:785 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:49:57:785 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd not in TableKeyGroups ~Esc,
14:49:57:785 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:49:57:785 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:49:57:785 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:49:57:786 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:49:57:786 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:49:57:786 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~NumpadAdd,
14:49:57:786 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:49:57:786 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:49:57:787 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
14:49:57:787 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:49:57:787 | MD |     INFO  | +0     | StartModule - Started
14:49:57:787 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.2.0
					MCRC: 4C755A18
					iCRC: 5974D94
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
14:49:57:787 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
14:49:57:789 | MD |     INFO  | +0     | PluginInit - Started
14:49:57:789 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
14:49:57:789 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Databases\Commodore Amiga\Commodore Amiga.xml exists
14:49:57:790 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/30/2014 - 6:16:35
					Modified:			4/22/2014 - 9:45:29
14:49:57:791 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
14:49:57:791 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
14:49:57:792 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
14:49:57:792 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "A-10 Tank Killer v1.5"
14:49:57:792 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
14:49:57:792 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
14:49:57:792 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
14:49:57:792 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer
14:49:57:812 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Year
14:49:57:813 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
14:49:57:813 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
14:49:57:813 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
14:49:57:813 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
14:49:57:813 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
14:49:57:814 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value: A-10 Tank Killer v1.5
					GameInfo Label: Rating | GameInfo Value: Other - NR (Not Rated)
14:49:57:814 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
14:49:57:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
14:49:57:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\A10TankKiller_v2.0_3Disk.png
14:49:57:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png
14:49:57:815 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\A10TankKiller_v2.0_3Disk.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
14:49:57:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:49:57:816 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
14:49:57:816 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork1\A10TankKiller_v2.0_3Disk.png
14:49:57:816 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork2\A10TankKiller_v2.0_3Disk.png
14:49:57:816 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork3\A10TankKiller_v2.0_3Disk.png
14:49:57:816 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork4\A10TankKiller_v2.0_3Disk.png
14:49:57:816 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Hyperspin\Media\Commodore Amiga\Images\Letters
14:49:57:947 | MD |   DEBUG1  | +125   | BuildAssetsTable - Searching for a Other: D:\Hyperspin\Media\Commodore Amiga\Images\Other
14:49:57:966 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Box Art | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Artwork2\A10TankKiller_v2.0_3Disk.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
14:49:57:966 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:49:57:966 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
14:49:57:966 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: D:\Hyperspin\Media\Commodore Amiga\Video\A10TankKiller_v2.0_3Disk.*
14:49:57:967 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a FLV Game Video: D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.*
14:49:57:967 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Video\A10TankKiller_v2.0_3Disk.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
14:49:57:967 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:49:57:967 | MD |     INFO  | +0     | PluginInit - Ended
14:49:57:968 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: A10TankKiller_v2.0_3Disk
14:49:57:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:49:57:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,
14:49:57:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:49:57:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:49:57:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
14:49:57:969 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:49:57:970 | MD |     INFO  | +0     | StartModule - Ended
14:49:57:970 | MD |   DEBUG1  | +0     | FadeInStart - Started
14:49:57:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:49:57:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:49:57:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:49:57:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:49:57:972 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:49:57:972 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:49:57:972 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:49:57:972 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:49:57:972 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:49:57:972 | MD |   DEBUG1  | +0     | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:49:57:972 | MD |   DEBUG2  | +0     | FadeInStart - Fade screen scale factor: X=0.666667, Y= 0.948148
14:49:57:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\A10TankKiller_v2.0_3Disk\Layer 1*.*
14:49:57:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer 1*.*
14:49:57:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.*
14:49:57:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.png
14:49:57:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 01 (Gigapig).png
14:49:57:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 02 (Gigapig).png
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 03 (Gigapig).png
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 04 (Gigapig).png
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 05 (Gigapig).png
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 06 (Gigapig).png
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 07 (Gigapig).png
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.gif
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.tif
14:49:57:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.bmp
14:49:57:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.jpg
14:49:57:975 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 06 (Gigapig).png
14:49:57:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\A10TankKiller_v2.0_3Disk\Info Bar*.*
14:49:57:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Info Bar*.*
14:49:57:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Info Bar*.*
14:49:57:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:49:57:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:49:57:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:49:57:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:49:57:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:49:57:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:49:57:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:49:57:977 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:49:57:977 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:49:58:119 | MD |     INFO  | +141   | DefaultAnimateFadeIn - Started, direction is: in
14:49:58:119 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
14:49:58:640 | MD |     INFO  | +530   | DefaultAnimateFadeIn - Ended
14:49:58:671 | MD |     INFO  | +31    | DefaultFadeAnimation - Started
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\A10TankKiller_v2.0_3Disk\Info Bar*.*
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Info Bar*.*
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Info Bar*.*
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:49:58:671 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:49:58:671 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:49:58:702 | MD |   DEBUG1  | +32    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\A10TankKiller_v2.0_3Disk\Layer 3*.*
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer 3*.*
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.*
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.png
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3.png
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.gif
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.tif
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.bmp
14:49:58:702 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.jpg
14:49:58:702 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3.png
14:49:58:733 | MD |   DEBUG1  | +31    | FadeInDelay - Started
14:49:58:733 | MD |   DEBUG1  | +0     | FadeInDelay - Ended
14:49:58:733 | MD |     INFO  | +0     | DefaultFadeAnimation - Ended
14:49:58:733 | MD |   DEBUG1  | +0     | FadeInStart - Ended
14:49:58:733 | MD |     INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
14:49:58:733 | MD |   DEBUG1  | +0     | CoverFE - Started
14:49:58:733 | MD |     INFO  | +0     | HideFE - Hiding Frontend by making it transparent
14:49:58:733 | MD |   DEBUG1  | +0     | CoverFE - Ended
14:49:58:811 | MD |     INFO  | +78    | Module Setting - [Settings] - ScreenMode: true
14:49:58:811 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - ScreenMode: true
14:49:58:811 | MD |     INFO  | +0     | Module Setting - [Settings] - QuickStartMode:
14:49:58:843 | MD |     INFO  | +31    | Module Setting - [A10TankKiller_v2.0_3Disk] - QuickStartMode:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - KickstartFile:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - Options:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Top_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - Bezel_Top_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - Bezel_Bottom_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - Bezel_Right_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - Bezel_Left_Offset: 0
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - UseGui: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - FloppySpeed: turbo
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - PathToExtraDrive:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - UseMouse: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - DelayHack: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - RequiresWB: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: PAL
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - VideoMode: PAL
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: native
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - XResolution: native
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: native
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - YResolution: native
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - BlackerThanBlack: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - RemoveInterlaceArtifacts: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - LineMode:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - AutoScale:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - AutoScale:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - ShaderMask:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - FilterShader:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - FilterShaderScale:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - FilteredLowResolution:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [Display] - ResolutionMode: hires
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - ResolutionMode: hires
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - CPU:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CPU:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuSpeed:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CpuSpeed:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CpuCycleExact:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CpuCompatible:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - MMU: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedCPU: true
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - DisableUnimplementedCPU: true
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - FPU:
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - MoreCompatibleFPU: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - MoreCompatibleFPU: false
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedFPU: true
14:49:58:843 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - DisableUnimplementedFPU: true
14:49:58:874 | MD |     INFO  | +31    | DefaultFadeAnimationLoop - Playing 7z fade complete sound: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\7z complete.mp3
14:49:59:179 | MD |     INFO  | +297   | Module Setting - [CPU] - CacheSize:
14:49:59:180 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CacheSize:
14:49:59:180 | MD |     INFO  | +0     | Module Setting - [CPU] - 24-BitAddressing: true
14:49:59:181 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - 24-BitAddressing: true
14:49:59:320 | MD |     INFO  | +140   | Module Setting - [Chipset] - CycleExact:
14:49:59:321 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CycleExact:
14:49:59:321 | MD |     INFO  | +0     | Module Setting - [Chipset] - ImmediateBlitter:
14:49:59:384 | MD |     INFO  | +62    | Module Setting - [A10TankKiller_v2.0_3Disk] - ImmediateBlitter:
14:49:59:460 | MD |     INFO  | +78    | Module Setting - [Chipset] - BlitterCycleExact:
14:49:59:460 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - BlitterCycleExact:
14:49:59:461 | MD |     INFO  | +0     | Module Setting - [Chipset] - CollisionLevel:
14:49:59:461 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - CollisionLevel:
14:49:59:461 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
14:49:59:462 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - ChipMemory:
14:49:59:640 | MD |   DEBUG1  | +188   | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:49:59:641 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:
14:49:59:642 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - FastMemory:
14:49:59:643 | MD |     INFO  | +0     | Module Setting - [RAM] - AutoConfigFastMemory:
14:49:59:643 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - AutoConfigFastMemory:
14:49:59:644 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
14:49:59:645 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - SlowMemory:
14:49:59:645 | MD |     INFO  | +0     | Module Setting - [RAM] - Z3FastMemory:
14:49:59:646 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - Z3FastMemory:
14:49:59:647 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:
14:49:59:647 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - MegaChipMemory:
14:49:59:648 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:
14:49:59:649 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - ProcessorSlotFast:
14:49:59:649 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:
14:49:59:666 | MD |   DEBUG1  | +31    | DefaultFadeAnimationLoop - AnimationLoop has finished
14:49:59:666 | MD |   DEBUG1  | +0     | DefaultFadeAnimationLoop - Ended
14:49:59:732 | MD |   DEBUG1  | +62    | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:49:59:744 | MD |     INFO  | +16    | Module Setting - [A10TankKiller_v2.0_3Disk] - RTGCardType:
14:49:59:744 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:
14:49:59:745 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - RTGVRAMSize:
14:49:59:746 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGHardwareSprite:
14:49:59:747 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - RTGHardwareSprite:
14:49:59:748 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - PathToWHDFolder: .\WHD
14:49:59:748 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - PathToWHDFolder: .\WHD
14:49:59:749 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
14:49:59:749 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - WHDLoadOptions: PRELOAD
14:49:59:750 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - NeverExtract: false
14:49:59:751 | MD |     INFO  | +0     | Module Setting - [A10TankKiller_v2.0_3Disk] - NeverExtract: false
14:49:59:751 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\Emulators\WinUAE\winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a500,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true turbo -s floppy0="D:\Hyperspin\Games\Commodore Amiga\Official\A10TankKiller_v2.0_3Disk.zip"  -portable
14:49:59:846 | MD |   DEBUG1  | +93    | Run - "winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a500,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true turbo -s floppy0="D:\Hyperspin\Games\Commodore Amiga\Official\A10TankKiller_v2.0_3Disk.zip"  -portable" Process ID: 1032
14:49:59:846 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x360336 | Process ID: 3352 | Process Path: D:\Hyperspin\RocketLauncher\RocketLauncher.exe
14:49:59:847 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
14:50:00:732 | MD |   DEBUG1  | +890   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x4b0260 | Process ID: 1032 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:50:00:732 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x4b0260 | Process ID: 1032 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:50:00:732 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
14:50:00:845 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x4b0260 | Process ID: 1032 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:50:00:931 | MD |   DEBUG1  | +93    | FadeInExit - Started
14:50:00:931 | MD |   DEBUG1  | +0     | FadeInExit - fadeInExitDelay started
14:50:01:694 | MD |   DEBUG1  | +765   | FadeInExit - fadeInExitDelay ended
14:50:01:694 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Started, direction is: out
14:50:02:218 | MD |     INFO  | +515   | DefaultAnimateFadeIn - Ended
14:50:02:280 | MD |   DEBUG2  | +62    | XHotkeyTableCreation - Started
14:50:02:280 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:50:02:281 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:50:02:282 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:50:02:283 | MD |   DEBUG1  | +0     | FadeInExit - Ended, waiting for user to close launched application
14:50:02:283 | MD |     INFO  | +0     | Process - WaitClose winuae.exe
14:50:18:796 | MD |   DEBUG1  | +16521 | CloseProcess - Started, user requested to end launched application
14:50:18:797 | MD |   DEBUG1  | +0     | FadeOutStart - Started
14:50:18:797 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:50:18:797 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:50:18:797 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:50:18:798 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:50:18:799 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:50:18:799 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:50:18:799 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:50:18:799 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:50:18:799 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:50:18:799 | MD |   DEBUG1  | +0     | FadeOutStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:50:18:799 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\A10TankKiller_v2.0_3Disk\Layer -1*.*
14:50:18:800 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer -1*.*
14:50:18:800 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer -1*.*
14:50:18:800 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Layer -1*.*
14:50:18:800 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.*
14:50:18:800 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 1 (Gigapig).png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 2 (Gigapig).png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 3 (Gigapig).png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 4 (Gigapig).png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 5 (Gigapig).png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 6 (Gigapig).png
14:50:18:801 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 7 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 8 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 01 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 02 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 03 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 04 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 05 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 06 (Gigapig).png
14:50:18:802 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 07 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 08 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 09 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 01 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 02 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 03 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 04 (Gigapig).png
14:50:18:803 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 05 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 06 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 07 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 08 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 09 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 10 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 11 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 12 (Gigapig).png
14:50:18:804 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 13 (Gigapig).png
14:50:18:805 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 14 (Gigapig).png
14:50:18:805 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.gif
14:50:18:805 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.tif
14:50:18:805 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.bmp
14:50:18:806 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.jpg
14:50:18:806 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 2 (Gigapig).png
14:50:19:919 | MD |     INFO  | +1123  | DefaultAnimateFadeOut - Started, direction is: in
14:50:20:450 | MD |     INFO  | +530   | DefaultAnimateFadeOut - Ended
14:50:20:450 | MD |   DEBUG1  | +0     | FadeOutStart - Ended
14:50:20:450 | MD |   DEBUG1  | +0     | ShowFE - Started
14:50:20:451 | MD |     INFO  | +0     | HideFE - Showing Frontend and removing transparency
14:50:20:451 | MD |   DEBUG1  | +0     | ShowFE - Ended
14:50:20:579 | MD |   DEBUG1  | +125   | CloseProcess - Ended
14:50:20:580 | MD |   DEBUG1  | +0     | FadeOutExit - Started
14:50:20:581 | MD |     INFO  | +0     | DefaultAnimateFadeOut - Started, direction is: out
14:50:21:106 | MD |     INFO  | +530   | DefaultAnimateFadeOut - Ended
14:50:21:108 | MD |   DEBUG1  | +0     | FadeOutExit - Ended
14:50:21:109 | MD |     INFO  | +0     | ExitModule - Started
14:50:21:109 | MD |     INFO  | +0     | Starting Updating Statistics:
14:50:21:109 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
14:50:21:109 | MD |   DEBUG2  | +0     | gameSectionStartTime:9571784
14:50:21:110 | MD |   DEBUG2  | +0     | ElapsedTime:18
14:50:21:110 | MD |   DEBUG2  | +0     | Statistics cleared game name: A10TankKiller_v2.0_3Disk
14:50:21:177 | MD |   DEBUG2  | +63    | Loaded game statistics from ini files:
					Number_of_Times_Played: 1
					Last_Time_Played: sabato dicembre 26, 2015 02:49:32
					Average_Time_Played: 14
					Total_Time_Played: 14
					System_Total_Played_Time: 627
					Total_Global_Played_Time: 733
14:50:21:177 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 2
					Last_Time_Played: sabato dicembre 26, 2015 02:50:02
					Average_Time_Played: 16
					Total_Time_Played: 32
					System_Total_Played_Time: 645
					Total_Global_Played_Time: 751
14:50:21:258 | MD |     INFO  | +93    | Game section statistics updated.
14:50:21:258 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
14:50:21:258 | MD |     INFO  | +0     | GetJoystickArray - Started
14:50:21:287 | MD |   DEBUG2  | +32    | GetJoystickArray - Joysticks Detected: 1000000000000000
14:50:21:289 | MD |     INFO  | +0     | GetJoystickGUID - Started
14:50:21:289 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 000970E22C40E5118001444553540000
14:50:21:290 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: I-PAC 2 | MID: d209 | PID: 0420 | GUID: 000970E22C40E5118001444553540000
14:50:21:290 | MD |     INFO  | +0     | GetJoystickArray - Ended
14:50:21:290 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
14:50:21:290 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "I-PAC 2"
14:50:21:290 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
14:50:21:290 | MD |   DEBUG2  | +0     | GetProfile - Searching -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
14:50:21:290 | MD |     INFO  | +0     | GetProfile - Loading Profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
14:50:21:291 | MD |     INFO  | +0     | RunXpadder - Started
14:50:21:291 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
14:50:21:292 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
14:50:21:293 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe /C
14:50:21:335 | MD |   DEBUG1  | +46    | Run - "Xpadder.exe /C" Process ID: 1272
14:50:21:335 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini
14:50:21:335 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
14:50:21:560 | MD |   DEBUG2  | +219   | RunXpadder - Reading the order in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini and arranging profiles found to match that order
14:50:21:561 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
14:50:21:561 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M
14:50:21:616 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 2136
14:50:21:616 | MD |     INFO  | +0     | RunXpadder - Ended
14:50:21:617 | MD |     INFO  | +0     | RunKeymapper - Ended
14:50:21:617 | MD |     INFO  | +0     | ExitModule - Ended
14:50:21:617 | MD |     INFO  | +0     | End of Module Logs
14:50:21:652 | RL |     INFO  | +24539 | Main - Module ended, exiting RocketLauncher normally
14:50:21:652 | RL |     INFO  | +0     | ExitScript - Started
14:50:21:699 | RL |     INFO  | +47    | SystemCursor - Restoring mouse cursor
14:50:21:730 | RL |     INFO  | +31    | ExitScript - Ended
[/code]
DISC LOADING FAULT:
[code]
14:52:41:871 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com)
14:52:41:969 | RL |     INFO  | +109   | Main - System Specs:
					RocketLauncher Dir: D:\Hyperspin\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Ultimate
					SKU: Ultimate
					Total Memory: 7644.39 MB
					Free Memory: 6083.00 MB
					Used Memory: 1561.383 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: AMD Radeon HD 5700 Series
					GPU 1 RAM: 1024.00 MB
					GPU 1 Driver Version: 13.251.0.0
					GPU 2 Name: AMD Radeon HD 7560D
					GPU 2 RAM: 512.00 MB
					GPU 2 Driver Version: 13.251.0.0
					Sound 1 Device: AMD High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: AMD High Definition Audio Device
					Sound 2 Status: Enabled
					Sound 3 Device: Dispositivo High Definition Audio
					Sound 3 Status: Enabled
					OS Language: Italian_Standard
					OS Admin Status: No
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x984 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1280
					Current AHK Desktop Height: 1024
					AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
14:52:41:969 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\RocketLauncher.exe exists
14:52:41:969 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.4
					LegalCopyright          	�2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2063360 bytes
					Created:			12/9/2015 - 10:44:38
					Modified:			12/9/2015 - 10:52:27
14:52:41:969 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Array.ahk exists
14:52:41:969 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			4924 bytes
					Created:			12/9/2015 - 10:50:09
					Modified:			12/9/2015 - 10:50:09
14:52:41:969 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BinHexRW.ahk exists
14:52:41:969 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5077 bytes
					Created:			12/9/2015 - 10:52:17
					Modified:			12/9/2015 - 10:52:17
14:52:41:969 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			12/9/2015 - 10:48:01
					Modified:			12/9/2015 - 10:48:03
14:52:41:969 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\CLR_L.ahk exists
					File Size:			5474 bytes
					Created:			12/9/2015 - 10:48:53
					Modified:			12/9/2015 - 10:48:53
14:52:41:969 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
14:52:41:985 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			5716 bytes
					Created:			12/9/2015 - 10:55:59
					Modified:			12/9/2015 - 10:56:00
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip.ahk exists
14:52:41:985 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
14:52:41:985 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			12/9/2015 - 10:45:19
					Modified:			12/9/2015 - 10:45:19
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip_alt.ahk exists
14:52:41:985 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5895 bytes
					Created:			12/9/2015 - 10:54:51
					Modified:			12/9/2015 - 10:54:51
14:52:41:985 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gsdll32.dll exists
					File Size:			13090816 bytes
					Created:			12/9/2015 - 10:48:54
					Modified:			12/9/2015 - 10:49:14
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\itextsharp.dll exists
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			12/9/2015 - 10:50:23
					Modified:			12/9/2015 - 10:50:30
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Java.ahk exists
					File Size:			7841 bytes
					Created:			12/9/2015 - 10:52:47
					Modified:			12/9/2015 - 10:52:47
14:52:41:985 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\JSON.ahk exists
					File Size:			9203 bytes
					Created:			12/9/2015 - 10:54:34
					Modified:			12/9/2015 - 10:54:34
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Origin.ahk exists
					File Size:			4904 bytes
					Created:			12/9/2015 - 10:55:54
					Modified:			12/9/2015 - 10:55:54
14:52:41:985 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RegRW64.ahk exists
					File Size:			6915 bytes
					Created:			12/9/2015 - 10:49:29
					Modified:			12/9/2015 - 10:49:29
14:52:41:985 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RIni.ahk exists
14:52:41:001 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			67561 bytes
					Created:			12/9/2015 - 10:55:11
					Modified:			12/9/2015 - 10:55:12
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
14:52:42:001 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Created:			12/9/2015 - 10:52:48
					Modified:			12/9/2015 - 10:52:49
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\Steam.ahk exists
14:52:42:001 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			5347 bytes
					Created:			12/9/2015 - 10:55:51
					Modified:			12/9/2015 - 10:55:51
14:52:42:001 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\VA.ahk exists
14:52:42:001 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
					File Size:			34688 bytes
					Created:			12/9/2015 - 10:48:27
					Modified:			12/9/2015 - 10:48:27
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\VA_Extension.ahk exists
					File Size:			3833 bytes
					Created:			12/9/2015 - 10:51:59
					Modified:			12/9/2015 - 10:51:59
14:52:42:001 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\7z.ahk exists
					File Size:			29149 bytes
					Created:			12/9/2015 - 10:52:18
					Modified:			12/9/2015 - 10:52:19
14:52:42:001 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.2
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Bezel.ahk exists
					File Size:			104277 bytes
					Created:			12/9/2015 - 10:47:59
					Modified:			12/9/2015 - 10:47:59
14:52:42:001 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.7
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade.ahk exists
					File Size:			38251 bytes
					Created:			12/9/2015 - 10:49:19
					Modified:			12/9/2015 - 10:49:20
14:52:42:001 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.4
14:52:42:001 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Init.ahk exists
14:52:42:016 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
14:52:42:016 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1065 bytes
					Created:			12/9/2015 - 10:52:32
					Modified:			12/9/2015 - 10:52:32
14:52:42:016 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.2
14:52:42:016 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Animations.ahk exists
14:52:42:016 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			81174 bytes
					Created:			12/9/2015 - 10:53:29
					Modified:			12/9/2015 - 10:53:30
14:52:42:016 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.10
14:52:42:016 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper.ahk exists
					File Size:			33453 bytes
					Modified:			12/9/2015 - 10:55:59
14:52:42:016 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
14:52:42:016 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper Init.ahk exists
					File Size:			3461 bytes
					Created:			12/9/2015 - 10:49:51
					Modified:			12/9/2015 - 10:49:51
14:52:42:016 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
14:52:42:016 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame.ahk exists
					File Size:			40753 bytes
					Created:			12/9/2015 - 10:53:56
					Modified:			12/9/2015 - 10:53:56
14:52:42:016 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
14:52:42:016 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame Init.ahk exists
					File Size:			161 bytes
					Created:			12/9/2015 - 10:54:32
					Modified:			12/9/2015 - 10:54:33
14:52:42:016 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
14:52:42:016 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiPlayer.ahk exists
					File Size:			66452 bytes
					Created:			12/9/2015 - 10:55:03
					Modified:			12/9/2015 - 10:55:03
14:52:42:016 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.7
14:52:42:032 | RL |     INFO  | +16    | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Pause.ahk exists
14:52:42:032 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
14:52:42:032 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
					Created:			12/9/2015 - 10:52:23
					Modified:			12/9/2015 - 10:52:24
14:52:42:032 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.5
14:52:42:032 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Pause Init.ahk exists
					File Size:			553 bytes
					Created:			12/9/2015 - 10:52:56
					Modified:			12/9/2015 - 10:52:56
14:52:42:032 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
14:52:42:032 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Password.ahk exists
					File Size:			10025 bytes
					Created:			12/9/2015 - 10:53:13
					Modified:			12/9/2015 - 10:53:13
14:52:42:032 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
14:52:42:032 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
					File Size:			74101 bytes
					Created:			12/9/2015 - 10:49:55
					Modified:			12/9/2015 - 10:49:56
14:52:42:032 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.6
14:52:42:032 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Shared.ahk exists
14:52:42:047 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
14:52:42:047 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			139893 bytes
					Created:			12/9/2015 - 10:54:43
					Modified:			12/9/2015 - 10:54:44
14:52:42:047 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.5
14:52:42:047 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics.ahk exists
14:52:42:047 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			26143 bytes
					Created:			12/9/2015 - 10:47:04
					Modified:			12/9/2015 - 10:47:04
14:52:42:047 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
14:52:42:047 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics Init.ahk exists
					File Size:			33 bytes
					Created:			12/9/2015 - 10:55:53
					Modified:			12/9/2015 - 10:55:53
14:52:42:047 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
14:52:42:047 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Virtual Drive.ahk exists
					File Size:			18329 bytes
					Created:			12/9/2015 - 10:47:53
					Modified:			12/9/2015 - 10:47:53
14:52:42:047 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.3
14:52:42:047 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey.ahk exists
					File Size:			26540 bytes
					Created:			12/9/2015 - 10:51:35
					Modified:			12/9/2015 - 10:51:35
14:52:42:047 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
14:52:42:047 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey Init.ahk exists
					File Size:			1063 bytes
					Created:			12/9/2015 - 10:53:20
					Modified:			12/9/2015 - 10:53:20
14:52:42:047 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
14:52:42:047 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Commodore Amiga -r ChaseHQ_v1.0_0212 -f D:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"
14:52:42:047 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "ChaseHQ_v1.0_0212"
14:52:42:047 | RL |   DEBUG1  | +0     | Main - dbName: ChaseHQ_v1.0_0212
14:52:42:047 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
14:52:42:047 | RL |     INFO  | +0     | Main - RocketLauncher received "Commodore Amiga" and "ChaseHQ_v1.0_0212"
14:52:42:063 | RL |     INFO  | +16    | Main - Did not find a "D:\Hyperspin\RocketLauncher\Settings\Commodore Amiga\Game Options.ini" file, skipping any game-specific options.
14:52:42:063 | RL |     INFO  | +0     | Main - ChaseHQ_v1.0_0212 is using the default emulator: WinUAE
14:52:42:063 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Hyperspin\RocketLauncher\Settings\Commodore Amiga\Emulators.ini
14:52:42:063 | RL |     INFO  | +0     | Main - Checking for a [WinUAE] section in D:\Hyperspin\RocketLauncher\Settings\Global Emulators.ini
14:52:42:063 | RL |     INFO  | +0     | Main - Found [WinUAE] in D:\Hyperspin\RocketLauncher\Settings\Global Emulators.ini
14:52:42:063 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk exists
14:52:42:063 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			23650 bytes
					Created:			12/9/2015 - 10:48:42
					Modified:			12/9/2015 - 10:48:42
14:52:42:063 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
14:52:42:063 | RL |     INFO  | +0     | Main - ChaseHQ_v1.0_0212 will use module: D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk
14:52:42:079 | RL |     INFO  | +15    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
14:52:42:079 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\WinUAE\winuae.exe exists
14:52:42:079 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	WinUAE
					FileVersion             	3.2.1.0
					InternalName            	WinUAE
					LegalCopyright          	� 1996-2015 under the GNU Public License (GPL)
					OriginalFilename        	WinUAE.exe
					ProductName             	WinUAE
					ProductVersion          	3.2.1.0
					File Size:			14642248 bytes
					Created:			4/30/2014 - 6:18:49
					Modified:			11/19/2015 - 6:10:08
14:52:42:079 | RL |     INFO  | +0     | Main - INI Keys read
14:52:42:079 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe exists
					FileVersion             	15.06 beta
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.06 beta
					File Size:			262144 bytes
					Created:			12/9/2015 - 10:54:36
					Modified:			12/9/2015 - 10:54:36
14:52:42:079 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll exists
					FileDescription         	7z Plugin
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1012224 bytes
					Created:			12/9/2015 - 10:47:37
					Modified:			12/9/2015 - 10:47:40
14:52:42:094 | RL |     INFO  | +16    | Main - "ChaseHQ_v1.0_0212" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
14:52:42:094 | RL |     INFO  | +0     | CheckPaths - Started
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Commodore Amiga\Official\ChaseHQ_v1.0_0212.7z
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: D:\Hyperspin\Games\Commodore Amiga\Official\ChaseHQ_v1.0_0212\ChaseHQ_v1.0_0212.7z
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Commodore Amiga\Official\ChaseHQ_v1.0_0212.zip
14:52:42:094 | RL |     INFO  | +0     | CheckPaths - Found rom: D:\Hyperspin\Games\Commodore Amiga\Official\ChaseHQ_v1.0_0212.zip
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: ChaseHQ_v1.0_0212
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Hyperspin\Games\Commodore Amiga\Official
14:52:42:094 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
14:52:42:094 | RL |     INFO  | +0     | CheckPaths - Ended
14:52:42:094 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = D:\Hyperspin\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.4
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = D:\Hyperspin\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = D:\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = D:
					exitEmulatorKey = ~Esc
					restoreFE = Restore and Click
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = D:\Hyperspin\Emulators\WinUAE\winuae.exe
					emuPath = D:\Hyperspin\Emulators\WinUAE
					emuName = WinUAE
					emuExt = exe
					romPath = D:\Hyperspin\Games\Commodore Amiga\Official
					romPathFromIni = D:\Hyperspin\Games\Commodore Amiga\Official|D:\Hyperspin\Games\Commodore Amiga\WHD+|D:\Hyperspin\Games\Commodore Amiga\ADF|D:\Hyperspin\Games\Commodore Amiga\IPF
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = 7z|zip|adf|info|cue
					executable = winuae.exe
					systemDbName = Commodore Amiga
					systemName = Commodore Amiga
					dbPath =
					dbName = ChaseHQ_v1.0_0212
					dbExt =
					romName = ChaseHQ_v1.0_0212
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 300
					romMappingMenuMargin = 50
					romMappingTextMargin = 10
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 40
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = D:\Hyperspin\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout =
					sysLang = Italian_Standard
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1280
					originalHeight = 1024
					vdEnabled = true
					vdFullPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = D:\Hyperspin\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = D:\Hyperspin\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==
					hideCursor = false
					hideEmu = false
					hideFE = true
					fadeIn = true
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = true
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2Pos = No Alignment
					fadeLyr2X = 0
					fadeLyr2Y = 870|1575
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr2Prefix = Info Bar
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 0.8
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH = 180
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Extraction In Progress, Please Wait
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = D:\Hyperspin\RocketLauncher\Media\Fade
					RLDataPath = D:\Hyperspin\RocketLauncher\Data
					RLMediaPath = D:\Hyperspin\RocketLauncher\Media
					RLErrSoundPath = D:\Hyperspin\RocketLauncher\Media\Sounds\Error
					modulesPath = D:\Hyperspin\RocketLauncher\Modules
					moduleFullName = D:\Hyperspin\RocketLauncher\Modules\WinUAE\WinUAE.ahk
					moduleName = WinUAE
					modulePath = D:\Hyperspin\RocketLauncher\Modules\WinUAE
					moduleExtension = ahk
					moduleExtensionsPath = D:\Hyperspin\RocketLauncher\Module Extensions
					libPath = D:\Hyperspin\RocketLauncher\Lib
					7zEnabled = false
					7zPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\yashijoe\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500
					mgFont = Arial
					mgText2Offset = 70
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = D:\Hyperspin\RocketLauncher\Module Extensions\HiToText\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = true
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe
					joyToKeyFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\JoyToKey\JoyToKey.exe
					keymapperProfilePath = D:\Hyperspin\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = xpadder
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga
					xPadderSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default
					emuProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE
					romProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\ChaseHQ_v1.0_0212
					RocketLauncherProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga
					ahkEmuProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga\WinUAE
					ahkRomProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Commodore Amiga\ChaseHQ_v1.0_0212
					ahkRocketLauncherProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = D:\Hyperspin\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = D:\Hyperspin\RocketLauncher\Lib\User Fade Animations.ini
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
14:52:42:094 | RL |  WARNING  | +0     | BuildScript - "D:\Hyperspin\RocketLauncher\Lib\User Functions Init.ahk" not found
14:52:42:094 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Validating module
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Validation complete
14:52:42:094 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = WinUAE
					MEmuV =  v3.0.0
					MURL = http://www.winuae.net/
					MAuthor = brolly,Turranius
					MVersion = 2.2.0
					MCRC = 4C755A18
					iCRC = 5974D94
					mId = 635138307631183750
					MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
					; Notes:
					; You can have specific configuration files inside a Configurations folder on WinUAE main dir.
					; Just name them the same as the game name on the XML file.
					; Make sure you create a host config files with these names:
					; CD32 : cd32host.uae and cd32mousehost.uae;
					; CDTV : cdtvhost.uae and cdtvmousehost.uae;
					; Amiga : amigahost.uae;
					; Amiga CD : amigacdhost.uae;
					; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure
					; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both
					; a joystick and a mouse on Port1 and only a joystick on Port2.
					; Set all your other preferences like video display settings. And make sure you are saving a HOST
					; configuration file and not a general configuration file.
					; If you want to configure an exit key through WinUAE:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator.
					; If you want to configure a key to toggle fullscreen/windowed mode:
					; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen.
					; CD32 and CDTV:
					; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a
					; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file:
					; [Lemmings (Europe)]
					; UseMouse=true
					; [Project-X & F17 Challenge (Europe)]
					; DelayHack=true
					; Amiga:
					; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are:
					; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10
					; END+SHIFT+1-0 = insert image from swapper slot 11-20
					; END+CTRL+1-4 = select drive
					; To do that follow the same procedure as above for the exit
					; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards.
					; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you
					; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical
					; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above.
					; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the
					; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit.
					; Amiga CD:
					; Several Amiga CD games require Hard drive installation, but will also require the game CD to be inserted in the CD drive.
					; The module will take care of this automatically as long as you have the CD image alongside with HDD installed files (.hdf or .vhd).
					; Amiga CD games will require a Workbench disk by default, for games that auto boot, make sure you go to the module settings and set
					; RequiresWB to false.
					; To use the shader options you must first download and put in place the shader pack from the WinUAE website found here:
					; http://www.winuae.net/
					; Download the Direct3D Pixel Shader Filters and extract the zip file into your emulator directory
					StartModule()
					BezelGUI()
					FadeInStart()
					settingsFile := modulePath . "\" . systemName . ".ini"
					; This object controls how the module reacts to different systems. WinUAE can play several systems, but needs to know what system you want to run, so this module has to adapt.
					mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd","Commodore Amiga Demos","a500")
					ident := mType[systemName]	; search object for the systemName identifier MESS uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName)
					specialcfg = %emuPath%\Configurations\%romName%.uae
					If romExtension in .hdf,.vhd
						DefaultRequireWB := "true"
					Else
						DefaultRequireWB := "false"
					If romExtension in .zip,.lha,.rar,.7z
						SlaveFile := RLObject.findByExtension(romPath . "\" . romName . romExtension, "slave")
						If (SlaveFile) {
							If romName contains (AGA)
								defaultCycleExact := "false"
								defaultCpuSpeed := "max"
							} Else {
								defaultCycleExact := "true"
								defaultCpuSpeed := "real"
							defaultImmediateBlittler = "false"
							defaultCpuCompatible := "false"
							defaultCacheSize := "0" ;8192
					If (ident = "amigacd") {
						DefaultRequireWB := "true" ;Most Amiga CD games require installation so better to default this to true
						defaultz3Ram := "128"
						isAmigaCd := "true"
					; Settings
					FS := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ScreenMode","true",,1)
					quickstartmode := IniReadCheck(settingsFile, "Settings" . "|" . romName, "QuickStartMode",A_Space,,1)
					kickstart_rom_file := IniReadCheck(settingsFile, "Settings" . "|" . romName, "KickstartFile","",,1)
					options := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Options","",,1)
					bezelTopOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Top_Offset","0",,1)
					bezelBottomOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Bottom_Offset","0",,1)
					bezelRightOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Right_Offset","0",,1)
					bezelLeftOffset := IniReadCheck(settingsFile, "Settings" . "|" . romName, "Bezel_Left_Offset","0",,1)
					use_gui := IniReadCheck(settingsFile, "Settings" . "|" . romName, "UseGui","false",,1)
					floppyspeed := IniReadCheck(settingsFile, "Settings" . "|" . romName, "FloppySpeed","turbo",,1)
					PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1)
					PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase)
					pathtoextradrive := IniReadCheck(settingsFile, "Settings" . "|" . romName, "PathToExtraDrive", "",,1)
					If (pathtoextradrive)
						pathtoextradrive := AbsoluteFromRelative(EmuPath, pathtoextradrive)
					usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) ;Only needed for CDTV and CD32
					delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) ;Only needed for CDTV and CD32
					requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1)
					; Display
					videomode := IniReadCheck(settingsFile, "Display" . "|" . romName, "VideoMode","PAL",,1)
					gfx_width := IniReadCheck(settingsFile, "Display" . "|" . romName, "XResolution","native",,1)
					gfx_height := IniReadCheck(settingsFile, "Display" . "|" . romName, "YResolution","native",,1)
					gfx_blacker_than_black := IniReadCheck(settingsFile, "Display" . "|" . romName, "BlackerThanBlack","false",,1)
					gfx_flickerfixer := IniReadCheck(settingsFile, "Display" . "|" . romName, "RemoveInterlaceArtifacts","false",,1)
					gfx_linemode := IniReadCheck(settingsFile, "Display" . "|" . romName, "LineMode",,,1)
					gfx_filter_autoscale := IniReadCheck(settingsFile, "Display" . "|" . romName, "AutoScale",,,1)
					gfx_filter_mask := IniReadCheck(settingsFile, "Display" . "|" . romName, "ShaderMask",,,1)
					gfx_filter := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShader",,,1)
					gfx_filter_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilterShaderScale",,,1)
					gfx_lores_mode := IniReadCheck(settingsFile, "Display" . "|" . romName, "FilteredLowResolution",,,1)
					gfx_resolution := IniReadCheck(settingsFile, "Display" . "|" . romName, "ResolutionMode","hires",,1)
					; CPU
					cpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CPU","",,1)
					cpuspeed := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuSpeed",defaultCpuSpeed,,1)
					cpucycleexact := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCycleExact","",,1)
					cpucompatible := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CpuCompatible",defaultCpuCompatible,,1)
					mmu_model := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MMU","false",,1)
					cpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedCPU","true",,1)
					fpu := IniReadCheck(settingsFile, "CPU" . "|" . romName, "FPU","",,1)
					fpu_strict := IniReadCheck(settingsFile, "CPU" . "|" . romName, "MoreCompatibleFPU","false",,1)
					fpu_no_unimplemented := IniReadCheck(settingsFile, "CPU" . "|" . romName, "DisableUnimplementedFPU","true",,1)
					cachesize := IniReadCheck(settingsFile, "CPU" . "|" . romName, "CacheSize",defaultCacheSize,,1)
					24bitaddressing := IniReadCheck(settingsFile, "CPU" . "|" . romName, "24-BitAddressing","true",,1)
					; Chipset
					cycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CycleExact",defaultCycleExact,,1)
					immediateblitter := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "ImmediateBlitter",defaultImmediateBlittler,,1)
					blittercycleexact := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "BlitterCycleExact","",,1)
					collisionlevel := IniReadCheck(settingsFile, "Chipset" . "|" . romName, "CollisionLevel","",,1)
					; RAM
					chipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ChipMemory","",,1)
					fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "FastMemory","",,1)
					autoconfigfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "AutoConfigFastMemory","",,1)
					slowmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "SlowMemory","",,1)
					z3fastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "Z3FastMemory",defaultz3Ram,,1)
					megachipmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "MegaChipMemory","",,1)
					processorslotfastmemory := IniReadCheck(settingsFile, "RAM" . "|" . romName, "ProcessorSlotFast","",,1)
					; Expansions
					rtgcardtype := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGCardType","",,1)
					rtgvramsize := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGVRAMSize","",,1)
					rtghardwaresprite := IniReadCheck(settingsFile, "Expansions" . "|" . romName, "RTGHardwareSprite","",,1)
					; WHDLoad
					PathToWHDFolder := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "PathToWHDFolder", EmuPath . "\HDD\WHD",,1)
					PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder)
					whdloadoptions := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "WHDLoadOptions","PRELOAD",,1)
					neverextract := IniReadCheck(settingsFile, "WHDLoad" . "|" . romName, "NeverExtract","false",,1)
					BezelStart()
					; Force Full Screen Windowed and Autoscale if Bezels are enabled. This must be done here since window class name changes from windowed to fullscreen modes
					If bezelPath {
						FS := "fullwindow"
						gfx_filter_autoscale := "scale"
					windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen
					If (FS = "true" or FS = "fullwindow")
						windowClass = AmigaPowah
					If (cpucycleexact and blittercycleexact)
						cycleexact := "" ;No need to set cycle exact if both cpu and blitter are set as it could lead to inconsistent states
					if (cpu != "68060" and cpu_no_unimplemented)
						cpu_no_unimplemented := "" ; cpu_no_unimplemented requires a 68060 CPU. Disable it if its true without a 68060 CPU.}
					; Make sure 24bitaddressing is false if using Z3 memory.
					If z3fastmemory
						24bitaddressing := "false"
					;Fill both z3 slots when amount of RAM requires it
					If (z3fastmemory = "384") {
						z3fastmemory = "256"
						z3fastmemoryb = "128"
					} Else If (z3fastmemory = "768") {
						z3fastmemory = "512"
						z3fastmemoryb = "256"
					} Else If (z3fastmemory = "1536") {
						z3fastmemory = "1024"
						z3fastmemoryb = "512"
					videomode := If videomode = "NTSC" ? "-s ntsc=true" : ""
					If (requireswb = "true") {
						ident := "a1200"
						CheckFile(PathToWorkBenchBase)
						wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """"
						ident := "a1200"
						gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """"
						CheckFile(pathtoextradrive,,,,,,1) ;allow folders
						If InStr(FileExist(pathtoextradrive), "D") ;it's a folder
							extraDrive := "-s filesystem=rw,Extra:" . """" . pathtoextradrive . """"
						Else ;it's a file
							SplitPath, pathtoextradrive,,,extradriveExtension
							If extradriveExtension in .hdf,.vhd
								extraDrive := "-s hardfile=rw,32,1,2,512," . """" . pathtoextradrive . """"
							Else
								extraDrive := "-s filesystem=ro,Extra:" . """" . pathtoextradrive . """"
					options := options . " " . videomode
					If (ident = "a500" or ident = "a1200") {
						If romName contains (AGA),(LW)
							ident := "a1200"
						If (SlaveFile) {
							CheckFolder(PathToWHDFolder)
							ident := "a1200"
							;Create the user-startup file to launch the game
							WHDUserStartupFile := PathToWHDFolder . "\S\user-startup"
							SplitPath, SlaveFile, SlaveName, SlaveFolder
							FileDelete, %WHDUserStartupFile%
							FileAppend, echo "";`n, %WHDUserStartupFile%
							FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile%
							FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile%
							FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile%
					hideEmuObj := Object("ahk_class " . windowClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					;--- Detecting what Configuration File to use (Or Quick Start Mode) ---
					If FileExist(specialcfg) {
						;Game specific configuration file exists
						configFile = %romName%.uae
					} Else {
						;Game specific configuration file doesn't exist
						If (ident = "cd32" or ident = "cdtv") {
							configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae")
							quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0")
						} Else {
							;Amiga or Amiga CD game
							configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae"
							If quickstartmode
								quickcfg := "-s quickstart=" . quickstartmode
							Else
								quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : (If (isAmigaCd = "true") ? "-s quickstart=a4000`,1" : "-s quickstart=a1200`,1")
					;--- Setting up command line arguments to use ---
					; Global command line arguments.
					If use_gui
						options := options . " -s use_gui=" . use_gui
					If (FS = "true") {
						options := options . " -s gfx_width_fullscreen=" . gfx_width
						options := options . " -s gfx_height_fullscreen=" . gfx_height
					} Else If (FS = "false") {
						If (gfx_width != "native" and gfx_height != "native") {
							options := options . " -s gfx_width_windowed=" . gfx_width
							options := options . " -s gfx_height_windowed=" . gfx_height
					If gfx_linemode
						options := options . " -s gfx_linemode=" . gfx_linemode
					If gfx_filter_autoscale
						options := options . " -s gfx_filter_autoscale=" . gfx_filter_autoscale
					If gfx_blacker_than_black
						options := options . " -s gfx_blacker_than_black=" . gfx_blacker_than_black
					If gfx_flickerfixer
						options := options . " -s gfx_flickerfixer=" . gfx_flickerfixer
					If gfx_filter_mode
						options := options . " -s gfx_filter_mode=" . gfx_filter_mode
					If (gfx_lores_mode = "true")
						options := options . " -s gfx_lores_mode=filtered"
					Else If (gfx_lores_mode = "false")
						options := options . " -s gfx_lores_mode=normal"
					If gfx_resolution {
						options := options . " -s gfx_resolution=" . gfx_resolution
						If (gfx_resolution = "lores") {
							options := options . " -s gfx_autoresolution_vga=false"
							options := options . " -s gfx_lores=true"
						Else {
							options := options . " -s gfx_lores=false"
					If gfx_filter_mask {
						gfx_filter_mask_path := emuPath . "\Plugins\masks\" . gfx_filter_mask
						LOG("Filter - gfx_filter_mask_path = " . gfx_filter_mask_path       ,5)
						If FileExist(gfx_filter_mask_path)
							options := options . " -s gfx_filter_mask=" . gfx_filter_mask
					If gfx_filter {
						If (SubStr(gfx_filter, 1, 4) = "D3D:") {
							StringTrimLeft, FilterFileName, gfx_filter, 4
							FilterFile := EmuPath . "\Plugins\filtershaders\direct3d\" . FilterFileName
							If FileExist(FilterFile)
								options := options . " -s gfx_filter=" . gfx_filter
						} Else {
						If (delayhack = "true")
							options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay"
						Else
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """"
					} Else {
						If floppyspeed
							options := options . " -s floppy_speed=" . floppyspeed
						If kickstart_rom_file
							options := options . " -s kickstart_rom_file=" . """" . kickstart_rom_file . """"
						If (cachesize || cachesize = "0")
							options := options . " -s cachesize=" . cachesize
						If immediateblitter
							options := options . " -s immediate_blits=" . immediateblitter
						If cycleexact
							options := options . " -s cycle_exact=" . cycleexact
						If cpucycleexact
							options := options . " -s cpu_cycle_exact=" . cpucycleexact
						If blittercycleexact
							options := options . " -s blitter_cycle_exact=" . blittercycleexact
						If cpucompatible
							options := options . " -s cpu_compatible=" . cpucompatible
						If cpuspeed
							options := options . " -s cpu_speed=" . cpuspeed
						If cpu
							options := options . " -s cpu_model=" . cpu
						If cpu_no_unimplemented
							options := options . " -s cpu_no_unimplemented=" . cpu_no_unimplemented
						If (mmu_model = "true")
							options := options . " -s mmu_model=" . cpu ; not a typo. Actually needs the same value as CPU.
						If 24bitaddressing
							options := options . " -s cpu_24bit_addressing=" . 24bitaddressing
						If fpu
							options := options . " -s fpu_model=" . fpu
						If fpu_strict
							options := options . " -s fpu_strict=" . fpu_strict
						If fpu_no_unimplemented
							options := options . " -s fpu_no_unimplemented=" . fpu_no_unimplemented
						If collisionlevel
							options := options . " -s collision_level=" . collisionlevel
						If chipmemory
							options := options . " -s chipmem_size=" . chipmemory
						If fastmemory
							options := options . " -s fastmem_size=" . fastmemory
						If autoconfigfastmemory
							options := options . " -s fastmem_autoconfig=" . autoconfigfastmemory
						If slowmemory
							options := options . " -s bogomem_size=" . slowmemory
						If z3fastmemory
							options := options . " -s z3mem_size=" . z3fastmemory
						If z3fastmemoryb
							options := options . " -s z3mem2_size=" . z3fastmemoryb
						If megachipmemory
							options := options . " -s megachipmem_size=" . megachipmemory
						If processorslotfastmemory
							options := options . " -s mbresmem_size=" . processorslotfastmemory
						If rtgcardtype
							options := options . " -s gfxcard_type=" . rtgcardtype
						If rtgvramsize
							options := options . " -s gfxcard_size=" . rtgvramsize
						If rtghardwaresprite
							options := options . " -s gfxcard_hardware_sprite=" . rtghardwaresprite
						If (SlaveFile) {
							;WHDLoad Game
							options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """"
						Else If (gameDrive) {
							;HDD Game
							options := options . " " . wbDrive . " " . gameDrive
							;Check if there's also a CD to load
							IfExist, %romPath%\%romName%.cue
								cdDrive := romPath . "\" . romName . ".cue"
							IfExist, %romPath%\%romName%.iso
								cdDrive := romPath . "\" . romName . ".iso"
							IfExist, %romPath%\%romName%.mds
								cdDrive := romPath . "\" . romName . ".mds"
							If extraDrive
								options := options . " " . extraDrive
							If cdDrive
								options := options . " -cdimage=" . """" . cdDrive . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else If romExtension in .cue,.iso,.mds
							;Amiga CD game
							;Check if game has a HDD installation
							IfExist, %romPath%\%romName%.hdf
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".hdf" . """"
							IfExist, %romPath%\%romName%.vhd
								installedHdd := " -s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . ".vhd" . """"
							options := options . " " . wbDrive . installedHdd
							If extraDrive
							options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true"
						} Else {
							;Floppy Game
							;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore
							;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives
							;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots.
							romCount = % romTable.MaxIndex()
							If romName contains (Disk 1)
								;If the user boots any disk rather than the first one, multi disk support must be done through RocketLauncher MG menu
								If romCount > 1
									options := options . " -s nr_floppies=2"
									mgoptions := " -s floppy1=" . """" . romTable[2,1] . """"
							options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions
							If romCount > 1
								;DiskSwapper
								;diskswapper := " -diskswapper "
								Loop % romTable.MaxIndex() ; loop each item in our array
									;diskswapper := diskswapper . """" . romTable[A_Index,1] . ""","
									diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """"
								options := options . diskswapper
					configFileFullPath := EmuPath . "\Configurations\" . configFile
					;param1 := "-f " . """" . configFileFullPath . """" . " " . quickcfg
					If FileExist(configFileFullPath)
					param1 := param1 . " " . quickcfg
					param2 := "-s gfx_fullscreen_amiga=" . FS
					param3 := options
					HideEmuStart()
					Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . " -portable", emuPath)
					If (use_gui = "true") {
						WinWait("WinUAE Properties",,60)
						FadeInExit()
						WinWaitClose("WinUAE Properties")
						Sleep, 100
						Process("Exist",executable)
						If (ErrorLevel=0) {
							7zCleanUp()
							ExitModule()
					WinWait("ahk_class " . windowClass)
					WinWaitActive("ahk_class " . windowClass)
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					Process("WaitClose",executable)
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					MultiGame:
						If currentButton = 10
							diskslot = 0
						Else If currentButton > 10
							diskslot := currentButton - 10
						Else
							Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up}
						Else
							Send, {End Down}%diskslot%{End Up}
					Return
					CloseProcess:
							If (SlaveFile) {
								;Copy default-user-startup to user-startup if file exists
								IfExist, %PathToWHDFolder%\S\default-user-startup
									FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1
						FadeOutStart()
						WinClose, ahk_class %windowClass%
					Return
14:52:42:110 | RL |     INFO  | +16    | BuildScript - Loaded Pause scripts
14:52:42:110 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
14:52:42:110 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
14:52:42:110 | RL |  WARNING  | +0     | BuildScript - "D:\Hyperspin\RocketLauncher\Lib\User Functions.ahk" not found
14:52:42:110 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
14:52:42:125 | RL |     INFO  | +15    | Main - Module is built
14:52:42:125 | RL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\AutoHotkey.dll exists
14:52:42:125 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Created:			12/9/2015 - 10:55:48
					Modified:			12/9/2015 - 10:55:49
14:52:42:125 | RL |     INFO  | +0     | Main - Running module
14:52:42:125 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
14:52:42:328 | MD |     INFO  | +N/A   | Module initialized
14:52:42:328 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:42:328 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
14:52:42:328 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:52:42:359 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
14:52:42:359 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:52:42:359 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:42:359 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe exists
14:52:42:359 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			12/9/2015 - 11:16:28
					Modified:			1/1/2015 - 5:05:33
14:52:42:359 | MD |     INFO  | +0     | Keymapper - Loading xpadder
14:52:42:359 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
14:52:42:359 | MD |     INFO  | +0     | GetJoystickArray - Started
14:52:42:437 | MD |   DEBUG2  | +78    | GetJoystickArray - Joysticks Detected: 1000000000000000
14:52:42:437 | MD |     INFO  | +0     | GetJoystickGUID - Started
14:52:42:437 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 000970E22C40E5118001444553540000
14:52:42:437 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: I-PAC 2 | MID: d209 | PID: 0420 | GUID: 000970E22C40E5118001444553540000
14:52:42:437 | MD |     INFO  | +0     | GetJoystickArray - Ended
14:52:42:437 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe"
14:52:42:437 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
14:52:42:437 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "I-PAC 2"
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\ChaseHQ_v1.0_0212|D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE|D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default|D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default|D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\ChaseHQ_v1.0_0212\I-PAC 2\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\ChaseHQ_v1.0_0212\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE\I-PAC 2\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\WinUAE\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default\I-PAC 2\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\Commodore Amiga\_Default\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\I-PAC 2\p1.xpadderprofile
14:52:42:437 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile
14:52:42:437 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile
14:52:42:437 | MD |     INFO  | +0     | RunXpadder - Started
14:52:42:437 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
14:52:42:469 | MD |   DEBUG2  | +31    | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
14:52:42:469 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe /C
14:52:42:562 | MD |   DEBUG1  | +94    | Run - "Xpadder.exe /C" Process ID: 4008
14:52:42:562 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini
14:52:42:562 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
14:52:42:781 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini and arranging profiles found to match that order
14:52:42:782 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
14:52:42:782 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
14:52:42:845 | MD |   DEBUG1  | +63    | Run - "Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 3984
14:52:42:845 | MD |     INFO  | +0     | RunXpadder - Ended
14:52:42:845 | MD |     INFO  | +0     | RunKeymapper - Ended
14:52:42:845 | MD |   DEBUG1  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
14:52:42:845 | MD |   DEBUG1  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
14:52:42:846 | MD |   DEBUG1  | +0     | fadeLyr3Animation: DefaultFadeAnimation
14:52:42:846 | MD |   DEBUG1  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
14:52:42:846 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:42:846 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd not in TableKeyGroups ~Esc,
14:52:42:847 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:52:42:847 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:52:42:847 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:52:42:847 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:42:847 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:42:847 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~NumpadAdd,
14:52:42:848 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:52:42:848 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:52:42:848 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
14:52:42:848 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:42:848 | MD |     INFO  | +0     | StartModule - Started
14:52:42:848 | MD |     INFO  | +0     | StartModule - MEmu: WinUAE
					MEmuV: v3.0.0
					MURL: http://www.winuae.net/
					MAuthor: brolly,Turranius
					MVersion: 2.2.0
					MCRC: 4C755A18
					iCRC: 5974D94
					MID:
					MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD","Commodore Amiga Demos"
14:52:42:848 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore Amiga"
14:52:42:849 | MD |     INFO  | +0     | PluginInit - Started
14:52:42:850 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
14:52:42:850 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Databases\Commodore Amiga\Commodore Amiga.xml exists
14:52:42:850 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			568042 bytes
					Created:			4/30/2014 - 6:16:35
					Modified:			4/22/2014 - 9:45:29
14:52:42:852 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
14:52:42:852 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
14:52:42:853 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
14:52:42:853 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Chase H.Q."
14:52:42:854 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
14:52:42:854 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
14:52:42:854 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
14:52:42:854 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Manufacturer
14:52:42:854 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
14:52:42:855 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
14:52:42:855 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
14:52:42:855 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
14:52:42:855 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
14:52:42:855 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
14:52:42:855 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value: Chase H.Q.
					GameInfo Label: Rating | GameInfo Value: Other - NR (Not Rated)
14:52:42:856 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
14:52:42:856 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
14:52:42:856 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\ChaseHQ_v1.0_0212.png
14:52:42:857 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png
14:52:42:857 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Wheel\ChaseHQ_v1.0_0212.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  D:\Hyperspin\Media\Main Menu\Images\Wheel\Commodore Amiga.png | Asset Extension1:  png | Asset Type1:  system
14:52:42:857 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:52:42:857 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
14:52:42:857 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork1\ChaseHQ_v1.0_0212.png
14:52:42:857 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork2\ChaseHQ_v1.0_0212.png
14:52:42:878 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Cartridge: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork3\ChaseHQ_v1.0_0212.png
14:52:42:878 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: D:\Hyperspin\Media\Commodore Amiga\Images\Artwork4\ChaseHQ_v1.0_0212.png
14:52:42:878 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: D:\Hyperspin\Media\Commodore Amiga\Images\Letters
14:52:42:920 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Other: D:\Hyperspin\Media\Commodore Amiga\Images\Other
14:52:42:920 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  D:\Hyperspin\Media\Commodore Amiga\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
14:52:42:920 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
14:52:42:920 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video|MP4 System Video|FLV System Video
14:52:42:920 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: D:\Hyperspin\Media\Commodore Amiga\Video\ChaseHQ_v1.0_0212.*
14:52:42:920 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a FLV Game Video: D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.*
					Asset Label: FLV Game Video | Asset Path1:  D:\Hyperspin\Media\Main Menu\Video\Commodore Amiga.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  D:\Hyperspin\Media\Commodore Amiga\Video\ChaseHQ_v1.0_0212.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
14:52:42:920 | MD |     INFO  | +0     | PluginInit - Ended
14:52:42:920 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: ChaseHQ_v1.0_0212
14:52:42:920 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:42:920 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,
14:52:42:920 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
14:52:42:920 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
14:52:42:920 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
14:52:42:920 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:42:968 | MD |     INFO  | +63    | StartModule - Ended
14:52:42:968 | MD |   DEBUG1  | +0     | FadeInStart - Started
14:52:42:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:42:968 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:52:42:969 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:52:42:969 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:52:42:969 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:52:42:969 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:52:42:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:52:42:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:42:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:42:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:52:42:970 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:52:42:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:52:42:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:52:42:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:52:42:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:52:42:971 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:42:971 | MD |   DEBUG1  | +0     | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:52:42:972 | MD |   DEBUG2  | +0     | FadeInStart - Fade screen scale factor: X=0.666667, Y= 0.948148
14:52:42:972 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\ChaseHQ_v1.0_0212\Layer 1*.*
14:52:42:972 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer 1*.*
14:52:42:972 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.*
14:52:42:972 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.png
14:52:42:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 01 (Gigapig).png
14:52:42:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 02 (Gigapig).png
14:52:42:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 03 (Gigapig).png
14:52:42:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 04 (Gigapig).png
14:52:42:973 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 05 (Gigapig).png
14:52:42:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 06 (Gigapig).png
14:52:42:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 07 (Gigapig).png
14:52:42:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.gif
14:52:42:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.tif
14:52:42:974 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.bmp
14:52:42:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1*.jpg
14:52:42:975 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 1 - 16x9 amiga 02 (Gigapig).png
14:52:42:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\ChaseHQ_v1.0_0212\Info Bar*.*
14:52:42:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Info Bar*.*
14:52:42:975 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Info Bar*.*
14:52:42:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:52:42:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:52:42:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:52:42:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:52:42:976 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:52:42:977 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:52:42:977 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:52:42:977 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:52:42:977 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:52:43:144 | MD |     INFO  | +171   | DefaultAnimateFadeIn - Started, direction is: in
14:52:43:144 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
14:52:43:676 | MD |     INFO  | +531   | DefaultAnimateFadeIn - Ended
14:52:43:707 | MD |     INFO  | +31    | DefaultFadeAnimation - Started
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\ChaseHQ_v1.0_0212\Info Bar*.*
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Info Bar*.*
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Info Bar*.*
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Info Bar images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:52:43:707 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Info Bar pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:52:43:707 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:52:43:739 | MD |   DEBUG1  | +31    | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\ChaseHQ_v1.0_0212\Layer 3*.*
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer 3*.*
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.*
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.png
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3.png
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.gif
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.tif
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.bmp
14:52:43:739 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3*.jpg
14:52:43:739 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer 3.png
14:52:43:770 | MD |   DEBUG1  | +31    | FadeInDelay - Started
14:52:43:770 | MD |   DEBUG1  | +0     | FadeInDelay - Ended
14:52:43:770 | MD |     INFO  | +0     | DefaultFadeAnimation - Ended
14:52:43:770 | MD |   DEBUG1  | +0     | FadeInStart - Ended
14:52:43:770 | MD |     INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to D:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
14:52:43:770 | MD |   DEBUG1  | +0     | CoverFE - Started
14:52:43:770 | MD |     INFO  | +0     | HideFE - Hiding Frontend by making it transparent
14:52:43:770 | MD |   DEBUG1  | +0     | CoverFE - Ended
14:52:43:848 | MD |     INFO  | +78    | Module Setting - [Settings] - ScreenMode: true
14:52:43:848 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - ScreenMode: true
14:52:43:879 | MD |     INFO  | +31    | Module Setting - [Settings] - QuickStartMode:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - QuickStartMode:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - KickstartFile:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - KickstartFile:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - Options:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - Options:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Top_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - Bezel_Top_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Bottom_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - Bezel_Bottom_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Right_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - Bezel_Right_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - Bezel_Left_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - Bezel_Left_Offset: 0
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - UseGui: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - UseGui: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - FloppySpeed: turbo
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - FloppySpeed: turbo
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - PathToWorkBenchBase: D:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Settings] - PathToExtraDrive:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - PathToExtraDrive:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - UseMouse: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - DelayHack: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - RequiresWB: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - VideoMode: PAL
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - VideoMode: PAL
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - XResolution: native
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - XResolution: native
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - YResolution: native
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - YResolution: native
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - BlackerThanBlack: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - BlackerThanBlack: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - RemoveInterlaceArtifacts: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - RemoveInterlaceArtifacts: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - LineMode:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - LineMode:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - AutoScale:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - AutoScale:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - ShaderMask:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - ShaderMask:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShader:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - FilterShader:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - FilterShaderScale:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - FilterShaderScale:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - FilteredLowResolution:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - FilteredLowResolution:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [Display] - ResolutionMode: hires
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - ResolutionMode: hires
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - CPU:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - CPU:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuSpeed:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - CpuSpeed:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCycleExact:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - CpuCycleExact:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - CpuCompatible:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - CpuCompatible:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - MMU: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - MMU: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedCPU: true
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - DisableUnimplementedCPU: true
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - FPU:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - FPU:
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - MoreCompatibleFPU: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - MoreCompatibleFPU: false
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - DisableUnimplementedFPU: true
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - DisableUnimplementedFPU: true
14:52:43:879 | MD |     INFO  | +0     | Module Setting - [CPU] - CacheSize:
14:52:43:910 | MD |     INFO  | +32    | DefaultFadeAnimationLoop - Playing 7z fade complete sound: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\7z complete.mp3
14:52:44:248 | MD |     INFO  | +343   | Module Setting - [ChaseHQ_v1.0_0212] - CacheSize:
14:52:44:248 | MD |     INFO  | +0     | Module Setting - [CPU] - 24-BitAddressing: true
14:52:44:248 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - 24-BitAddressing: true
14:52:44:249 | MD |     INFO  | +0     | Module Setting - [Chipset] - CycleExact:
14:52:44:249 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - CycleExact:
14:52:44:249 | MD |     INFO  | +0     | Module Setting - [Chipset] - ImmediateBlitter:
14:52:44:249 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - ImmediateBlitter:
14:52:44:250 | MD |     INFO  | +0     | Module Setting - [Chipset] - BlitterCycleExact:
14:52:44:250 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - BlitterCycleExact:
14:52:44:250 | MD |     INFO  | +0     | Module Setting - [Chipset] - CollisionLevel:
14:52:44:250 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - CollisionLevel:
14:52:44:250 | MD |     INFO  | +0     | Module Setting - [RAM] - ChipMemory:
14:52:44:251 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - ChipMemory:
14:52:44:251 | MD |     INFO  | +0     | Module Setting - [RAM] - FastMemory:
14:52:44:251 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - FastMemory:
14:52:44:251 | MD |     INFO  | +0     | Module Setting - [RAM] - AutoConfigFastMemory:
14:52:44:252 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - AutoConfigFastMemory:
14:52:44:252 | MD |     INFO  | +0     | Module Setting - [RAM] - SlowMemory:
14:52:44:252 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - SlowMemory:
14:52:44:252 | MD |     INFO  | +0     | Module Setting - [RAM] - Z3FastMemory:
14:52:44:253 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - Z3FastMemory:
14:52:44:253 | MD |     INFO  | +0     | Module Setting - [RAM] - MegaChipMemory:
14:52:44:253 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - MegaChipMemory:
14:52:44:253 | MD |     INFO  | +0     | Module Setting - [RAM] - ProcessorSlotFast:
14:52:44:254 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - ProcessorSlotFast:
14:52:44:254 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGCardType:
14:52:44:254 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - RTGCardType:
14:52:44:254 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGVRAMSize:
14:52:44:254 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - RTGVRAMSize:
14:52:44:255 | MD |     INFO  | +0     | Module Setting - [Expansions] - RTGHardwareSprite:
14:52:44:255 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - RTGHardwareSprite:
14:52:44:255 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - PathToWHDFolder: .\WHD
14:52:44:255 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - PathToWHDFolder: .\WHD
14:52:44:256 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - WHDLoadOptions: PRELOAD
14:52:44:256 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - WHDLoadOptions: PRELOAD
14:52:44:256 | MD |     INFO  | +0     | Module Setting - [WHDLoad] - NeverExtract: false
14:52:44:256 | MD |     INFO  | +0     | Module Setting - [ChaseHQ_v1.0_0212] - NeverExtract: false
14:52:44:256 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\Emulators\WinUAE\winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a500,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true turbo -s floppy0="D:\Hyperspin\Games\Commodore Amiga\Official\ChaseHQ_v1.0_0212.zip"  -portable
14:52:44:367 | MD |   DEBUG1  | +109   | Run - "winuae.exe -f "D:\Hyperspin\Emulators\WinUAE\Configurations\host\amigahost.uae" -s quickstart=a500,1 -s gfx_fullscreen_amiga=true   -s use_gui=false -s gfx_width_fullscreen=native -s gfx_height_fullscreen=native -s gfx_blacker_than_black=false -s gfx_flickerfixer=false -s gfx_resolution=hires -s gfx_lores=false -s floppy_speed=turbo -s cpu_24bit_addressing=true -s fpu_strict=false -s fpu_no_unimplemented=true turbo -s floppy0="D:\Hyperspin\Games\Commodore Amiga\Official\ChaseHQ_v1.0_0212.zip"  -portable" Process ID: 3832
14:52:44:368 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x3f012a | Process ID: 4900 | Process Path: D:\Hyperspin\RocketLauncher\RocketLauncher.exe
14:52:44:368 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class AmigaPowah"
14:52:44:631 | MD |   DEBUG1  | +265   | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:52:44:691 | MD |   DEBUG1  | +63    | DefaultFadeAnimationLoop - AnimationLoop has finished
14:52:44:691 | MD |   DEBUG1  | +0     | DefaultFadeAnimationLoop - Ended
14:52:44:724 | MD |   DEBUG1  | +31    | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:52:44:984 | MD |   DEBUG1  | +265   | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x710278 | Process ID: 3832 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:52:45:129 | MD |   DEBUG1  | +140   | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x710278 | Process ID: 3832 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:52:45:129 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class AmigaPowah"
14:52:45:231 | MD |   DEBUG1  | +110   | GetActiveWindowStatus - Title: WinUAE - [ALT+TAB or middle mouse button untraps mouse - F12 opens settings] | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x710278 | Process ID: 3832 | Process Path: D:\Hyperspin\Emulators\WinUAE\winuae.exe
14:52:45:266 | MD |   DEBUG1  | +31    | FadeInExit - Started
14:52:45:267 | MD |   DEBUG1  | +0     | FadeInExit - fadeInExitDelay started
14:52:46:024 | MD |   DEBUG1  | +764   | FadeInExit - fadeInExitDelay ended
14:52:46:024 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Started, direction is: out
14:52:46:563 | MD |     INFO  | +531   | DefaultAnimateFadeIn - Ended
14:52:46:627 | MD |   DEBUG2  | +62    | XHotkeyTableCreation - Started
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:52:46:628 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:52:46:629 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:46:630 | MD |   DEBUG1  | +0     | FadeInExit - Ended, waiting for user to close launched application
14:52:46:630 | MD |     INFO  | +0     | Process - WaitClose winuae.exe
14:52:53:245 | MD |   DEBUG1  | +6615  | CloseProcess - Started, user requested to end launched application
14:52:53:245 | MD |   DEBUG1  | +0     | FadeOutStart - Started
14:52:53:245 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:53:245 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:52:53:246 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:52:53:246 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:52:53:246 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:52:53:246 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:52:53:246 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:52:53:247 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:53:247 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
14:52:53:247 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:52:53:247 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 10 check
14:52:53:266 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:52:53:266 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 11 check
14:52:53:266 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:52:53:266 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 12 check
14:52:53:267 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
14:52:53:267 | MD |   DEBUG1  | +0     | FadeOutStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:52:53:267 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\ChaseHQ_v1.0_0212\Layer -1*.*
14:52:53:267 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Horizontal\Layer -1*.*
14:52:53:268 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\Commodore Amiga\_Default\Layer -1*.*
14:52:53:268 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Layer -1*.*
14:52:53:268 | MD |   DEBUG1  | +0     | GetFadePicFile - Checking if any Fade Layer -1 images exist in: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.*
14:52:53:269 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.png
14:52:53:269 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 1 (Gigapig).png
14:52:53:269 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 2 (Gigapig).png
14:52:53:270 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 3 (Gigapig).png
14:52:53:270 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 4 (Gigapig).png
14:52:53:270 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 5 (Gigapig).png
14:52:53:270 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 6 (Gigapig).png
14:52:53:270 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 7 (Gigapig).png
14:52:53:271 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x10 GameOver 8 (Gigapig).png
14:52:53:271 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 01 (Gigapig).png
14:52:53:271 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 02 (Gigapig).png
14:52:53:271 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 03 (Gigapig).png
14:52:53:272 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 04 (Gigapig).png
14:52:53:272 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 05 (Gigapig).png
14:52:53:272 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 06 (Gigapig).png
14:52:53:272 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 07 (Gigapig).png
14:52:53:272 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 08 (Gigapig).png
14:52:53:273 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 09 (Gigapig).png
14:52:53:273 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 01 (Gigapig).png
14:52:53:273 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 02 (Gigapig).png
14:52:53:273 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 03 (Gigapig).png
14:52:53:273 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 04 (Gigapig).png
14:52:53:273 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 05 (Gigapig).png
14:52:53:274 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 06 (Gigapig).png
14:52:53:274 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 07 (Gigapig).png
14:52:53:274 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 08 (Gigapig).png
14:52:53:274 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 09 (Gigapig).png
14:52:53:274 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 10 (Gigapig).png
14:52:53:275 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 11 (Gigapig).png
14:52:53:275 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 12 (Gigapig).png
14:52:53:275 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 13 (Gigapig).png
14:52:53:275 | MD |   DEBUG1  | +0     | GetFadePicFile - Found Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 14 (Gigapig).png
14:52:53:275 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.gif
14:52:53:276 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.tif
14:52:53:276 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.bmp
14:52:53:276 | MD |   DEBUG1  | +0     | GetFadePicFile - Looking for Fade Layer -1 pic: D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.jpg
14:52:53:277 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 4x3 GameOver 02 (Gigapig).png
14:52:53:566 | MD |     INFO  | +296   | DefaultAnimateFadeOut - Started, direction is: in
14:52:54:101 | MD |     INFO  | +531   | DefaultAnimateFadeOut - Ended
14:52:54:101 | MD |   DEBUG1  | +0     | FadeOutStart - Ended
14:52:54:101 | MD |   DEBUG1  | +0     | ShowFE - Started
14:52:54:102 | MD |     INFO  | +0     | HideFE - Showing Frontend and removing transparency
14:52:54:102 | MD |   DEBUG1  | +0     | ShowFE - Ended
14:52:54:219 | MD |   DEBUG1  | +124   | CloseProcess - Ended
14:52:54:220 | MD |   DEBUG1  | +0     | FadeOutExit - Started
14:52:54:221 | MD |     INFO  | +0     | DefaultAnimateFadeOut - Started, direction is: out
14:52:54:721 | MD |     INFO  | +500   | DefaultAnimateFadeOut - Ended
14:52:54:724 | MD |   DEBUG1  | +0     | FadeOutExit - Ended
14:52:54:724 | MD |     INFO  | +0     | ExitModule - Started
14:52:54:724 | MD |     INFO  | +0     | Starting Updating Statistics:
14:52:54:724 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
14:52:54:725 | MD |   DEBUG2  | +0     | gameSectionStartTime:9736131
14:52:54:725 | MD |   DEBUG2  | +0     | ElapsedTime:8
14:52:54:725 | MD |   DEBUG2  | +0     | Statistics cleared game name: ChaseHQ_v1.0_0212
14:52:54:791 | MD |   DEBUG2  | +62    | Loaded game statistics from ini files:
					Number_of_Times_Played: 8
					Last_Time_Played: sabato dicembre 26, 2015 02:52:17
					Average_Time_Played: 14
					Total_Time_Played: 113
					System_Total_Played_Time: 663
					Total_Global_Played_Time: 769
14:52:54:791 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 9
					Last_Time_Played: sabato dicembre 26, 2015 02:52:46
					Average_Time_Played: 13
					Total_Time_Played: 121
					System_Total_Played_Time: 671
					Total_Global_Played_Time: 777
14:52:54:851 | MD |     INFO  | +62    | Game section statistics updated.
14:52:54:852 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
14:52:54:852 | MD |     INFO  | +0     | GetJoystickArray - Started
14:52:54:876 | MD |   DEBUG2  | +32    | GetJoystickArray - Joysticks Detected: 1000000000000000
14:52:54:878 | MD |     INFO  | +0     | GetJoystickGUID - Started
14:52:54:878 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 000970E22C40E5118001444553540000
14:52:54:878 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: I-PAC 2 | MID: d209 | PID: 0420 | GUID: 000970E22C40E5118001444553540000
14:52:54:879 | MD |     INFO  | +0     | GetJoystickArray - Ended
14:52:54:879 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
14:52:54:879 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "I-PAC 2"
14:52:54:879 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank
14:52:54:879 | MD |   DEBUG2  | +0     | GetProfile - Searching -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
14:52:54:879 | MD |     INFO  | +0     | GetProfile - Loading Profile -> D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
14:52:54:879 | MD |     INFO  | +0     | RunXpadder - Started
14:52:54:880 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
14:52:54:881 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
14:52:54:881 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe /C
14:52:54:906 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe /C" Process ID: 3468
14:52:54:906 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini
14:52:54:906 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
14:52:55:126 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\xpadder.ini and arranging profiles found to match that order
14:52:55:127 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
14:52:55:127 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\RocketLauncher\Module Extensions\xpadder\Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M
14:52:55:202 | MD |   DEBUG1  | +78    | Run - "Xpadder.exe "D:\Hyperspin\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 3504
14:52:55:202 | MD |     INFO  | +0     | RunXpadder - Ended
14:52:55:202 | MD |     INFO  | +0     | RunKeymapper - Ended
14:52:55:202 | MD |     INFO  | +0     | ExitModule - Ended
14:52:55:202 | MD |     INFO  | +0     | End of Module Logs
14:52:55:316 | RL |     INFO  | +13182 | Main - Module ended, exiting RocketLauncher normally
14:52:55:332 | RL |     INFO  | +16    | ExitScript - Started
14:52:55:363 | RL |     INFO  | +31    | SystemCursor - Restoring mouse cursor
14:52:55:394 | RL |     INFO  | +31    | ExitScript - Ended
[/code]
  • 1 month later...
Thanks for the great write up rfancella. It worked first time.
However, I'm having performance issues. I really shouldn't as I have a Lenovo T530 i7.
The strange thing is if I load the disk directly in winuae (rather than rocket launcher and whdload) the performance is fine.
e.g. AddamsFamily_v1.3_0419.zip from the killergorrilla pack - The sound stutters and the player moves slowly.
