majorspawn Posted July 21, 2016 Posted July 21, 2016 Hi Guys, Can I get some assistance please, I am using Hyperspin and HyperlaunchHQ (not RL), I have setup Fade in for mame, nes, TTX etc using the same fade.ini setting file import. The fade-in is working fine except for "PC Games" where it does not kick in at all. Please note PC games is using PCLauncher which is also used by TTX2 where fade is working fine. Here is my fade.ini across all platforms: [Fade]Fade_In=trueFade_In_Duration=3000Fade_In_Transition_Animation=DefaultAnimateFadeInFade_In_Delay=7000Fade_In_Exit_Delay=use_globalFade_Out=use_globalFade_Out_Duration=use_globalFade_Out_Transition_Animation=use_globalFade_Out_Delay=use_globalFade_Out_Exit_Delay=use_globalFade_Layer_Interpolation=6Fade_Layer_1_Color=FF000000Fade_Layer_1_Align_Image=use_globalFade_Layer_2_Alignment=use_globalFade_Layer_2_X=use_globalFade_Layer_2_Y=use_globalFade_Layer_2_Adjust=use_globalFade_Layer_2_Padding=use_globalFade_Layer_3_Alignment=use_globalFade_Layer_3_X=use_globalFade_Layer_3_Y=use_globalFade_Layer_3_Adjust=use_globalFade_Layer_3_Speed=use_globalFade_Layer_3_Animation=NoAnimationFade_Layer_3_7z_Animation=use_globalFade_Layer_3_Image_Follow_7z_Progress=use_globalFade_Layer_3_Type=use_globalFade_Layer_3_Repeat=use_globalFade_Layer_3_Padding=use_globalFade_Layer_4_Pos=use_globalFade_Layer_4_X=use_globalFade_Layer_4_Y=use_globalFade_Layer_4_Adjust=use_globalFade_Layer_4_FPS=use_globalFade_Layer_4_Padding=use_globalFade_Animated_Gif_Transparent_Color=use_globalFade_Bar_Window=falseFade_Bar_Window_X=use_globalFade_Bar_Window_Y=use_globalFade_Bar_Window_Width=use_globalFade_Bar_Window_Height=use_globalFade_Bar_Window_Radius=use_globalFade_Bar_Window_Margin=use_globalFade_Bar_Window_Hatch_Style=use_globalFade_Bar_Back=falseFade_Bar_Back_Color=use_globalFade_Bar_Height=use_globalFade_Bar_Radius=use_globalFade_Bar_Color=use_globalFade_Bar_Hatch_Style=use_globalFade_Bar_Percentage_Text=use_globalFade_Bar_Info_Text=use_globalFade_Bar_X_Offset=use_globalFade_Bar_Y_Offset=use_globalFade_Rom_Info_Description=disabledFade_Rom_Info_System_Name=disabledFade_Rom_Info_Year=disabledFade_Rom_Info_Manufacturer=disabledFade_Rom_Info_Genre=disabledFade_Rom_Info_Rating=disabledFade_Rom_Info_Order=use_globalFade_Rom_Info_Text_Placement=use_globalFade_Rom_Info_Text_Margin=use_globalFade_Rom_Info_Text_1_Options=use_globalFade_Rom_Info_Text_2_Options=use_globalFade_Rom_Info_Text_3_Options=use_globalFade_Rom_Info_Text_4_Options=use_globalFade_Rom_Info_Text_5_Options=use_globalFade_Rom_Info_Text_6_Options=use_globalFade_Stats_Number_of_Times_Played=disabledFade_Stats_Last_Time_Played=disabledFade_Stats_Average_Time_Played=disabledFade_Stats_Total_Time_Played=disabledFade_Stats_System_Total_Played_Time=disabledFade_Stats_Total_Global_Played_Time=disabledFade_Stats_Info_Order=use_globalFade_Stats_Info_Text_Placement=use_globalFade_Stats_Info_Text_Margin=use_globalFade_Stats_Info_Text_1_Options=use_globalFade_Stats_Info_Text_2_Options=use_globalFade_Stats_Info_Text_3_Options=use_globalFade_Stats_Info_Text_4_Options=use_globalFade_Stats_Info_Text_5_Options=use_globalFade_Stats_Info_Text_6_Options=use_globalFade_Text_1_X=use_globalFade_Text_1_Y=use_globalFade_Text_1_Options=use_globalFade_Text_1=use_globalFade_Text_2_X=use_globalFade_Text_2_Y=use_globalFade_Text_2_Options=use_globalFade_Text_2=use_globalFade_Font=use_globalFade_System_And_Rom_Layers_Only=use_global here is my HyperlaunchHQ log: DEBUG 2016-07-22 07:38:51 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is C:\HyperSpin\Settings\HyperLaunchHQ.iniDEBUG 2016-07-22 07:38:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\HyperSpin\Settings\HyperLaunchHQ.iniDEBUG 2016-07-22 07:38:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\HyperLaunch.iniDEBUG 2016-07-22 07:38:51 [1] HyperEmu.Ini.HyperLaunchHQIni HyperEmu.Ini.HyperLaunchHQIni..ctor(:0) – HyperLaunchHQ ini file path is C:\HyperSpin\Settings\HyperLaunchHQ.iniDEBUG 2016-07-22 07:38:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\HyperSpin\Settings\HyperLaunchHQ.iniDEBUG 2016-07-22 07:38:51 [1] HyperEmu.Forms.BaseWindow HyperEmu.Forms.BaseWindow..ctor(:0) – Main Folder is C:\HyperspinDEBUG 2016-07-22 07:38:51 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\HyperLaunch.iniDEBUG 2016-07-22 07:38:54 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Global Emulators.iniDEBUG 2016-07-22 07:38:54 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Global HyperLaunch.iniDEBUG 2016-07-22 07:38:54 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Global HyperPause.iniDEBUG 2016-07-22 07:39:58 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Cave\Emulators.iniDEBUG 2016-07-22 07:39:58 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Cave\Games.iniDEBUG 2016-07-22 07:39:58 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Cave\HyperLaunch.iniDEBUG 2016-07-22 07:39:58 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Cave\HyperPause.iniDEBUG 2016-07-22 07:39:59 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Global Emulators.iniDEBUG 2016-07-22 07:39:59 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Global HyperLaunch.iniDEBUG 2016-07-22 07:39:59 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Global HyperPause.iniDEBUG 2016-07-22 07:40:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Rotary Games\Emulators.iniDEBUG 2016-07-22 07:40:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Rotary Games\Games.iniDEBUG 2016-07-22 07:40:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Rotary Games\HyperLaunch.iniDEBUG 2016-07-22 07:40:02 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\Rotary Games\HyperPause.iniDEBUG 2016-07-22 07:40:03 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\PC Games\Emulators.iniDEBUG 2016-07-22 07:40:03 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\PC Games\Games.iniDEBUG 2016-07-22 07:40:03 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\PC Games\HyperLaunch.iniDEBUG 2016-07-22 07:40:03 [1] HyperEmu.Ini.IniFile HyperEmu.Ini.IniFile..ctor(:0) – Loading INI File C:\Hyperspin\Settings\PC Games\HyperPause.ini any suggestions? also excuse the ignorance what log level do i choose in the log file above in HL, is the log I am submitting the HyperLaunchHQ.log? Thanks in advance MS My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
Metalzoic Posted July 22, 2016 Posted July 22, 2016 Are you sure it isn't as simple as you turned fade off for your PC System under its specific settings menu? I dont remember for HyperLauncher, but for RocketLauncher you set logging to troublshooting and it spits out a log about 100 miles long.
majorspawn Posted July 22, 2016 Author Posted July 22, 2016 Are you sure it isn't as simple as you turned fade off for your PC System under its specific settings menu? I dont remember for HyperLauncher, but for RocketLauncher you set logging to troublshooting and it spits out a log about 100 miles long. no i already checked that, my fade settings were an import form the fade.ini config posted above, its currently set to enabled. I refreshed it by disabling and enabling again. It doesn't even pause after leaving the HS screen to indicate that its trying to fade-in. Funny thing is it works with other systems with exactly the same import config etc. is the error log posted above the correct one? i cant see any fade-in specific diagnostic within. My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
majorspawn Posted July 22, 2016 Author Posted July 22, 2016 The log you want is the HyperLaunch log set to Troubleshooting, not the HyperLaunchHQ log. Open HLHQ and on the General Settings -> HyperLaunch tab set Logging Level to Troubleshooting then run game and post the HyperLaunch.log file from your HyperLaunch folder. log file: 17:20:05:276 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.3 17:20:05:277 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin OS: WIN_8 Architecture: 64-bit (might not be accurate) OS Language: 0409 OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 17:20:05:277 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1200 17:20:05:277 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch.exe exists 17:20:05:278 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\gdip.ahk exists 17:20:05:287 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:20:05:288 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\RIni.ahk exists 17:20:05:293 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 17:20:05:293 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\CLR.ahk exists 17:20:05:294 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:20:05:295 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\COM.ahk exists 17:20:05:296 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:20:05:297 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\JSON.ahk exists 17:20:05:298 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 17:20:05:298 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Init.ahk exists 17:20:05:299 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:299 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause Init.ahk exists 17:20:05:300 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:300 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper Init.ahk exists 17:20:05:301 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:301 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame Init.ahk exists 17:20:05:302 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:302 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics Init.ahk exists 17:20:05:302 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:302 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade.ahk exists 17:20:05:304 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:304 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause.ahk exists 17:20:05:314 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:315 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper.ahk exists 17:20:05:316 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:316 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame.ahk exists 17:20:05:318 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:318 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Bezel.ahk exists 17:20:05:319 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:320 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics.ahk exists 17:20:05:321 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:322 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Rom Mapping Launch Menu.ahk exists 17:20:05:326 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:326 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Shared.ahk exists 17:20:05:329 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:329 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\XHotkey.ahk exists 17:20:05:331 | HL | ERROR | +0 | CRC Check - CRC does not match for this Library. Please re-download this file to continue using HyperLaunch: C:\HyperSpin\Lib\XHotkey.ahk 17:20:05:331 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Animations.ahk exists 17:20:05:333 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 17:20:05:333 | HL | INFO | +0 | Main - HyperLaunch received "PCLauncher" and "Shank 2" 17:20:05:339 | HL | INFO | +16 | Main - Shank 2 is using the default emulator: PCLauncher 17:20:05:339 | HL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\HyperSpin\Settings\PCLauncher\Emulators.ini 17:20:05:339 | HL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\HyperSpin\Settings\Global Emulators.ini 17:20:05:340 | HL | INFO | +0 | Main - Found [PCLauncher] in C:\HyperSpin\Settings\Global Emulators.ini 17:20:05:340 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ahk exists 17:20:05:344 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 17:20:05:345 | HL | INFO | +0 | Main - Shank 2 will use module: C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ahk 17:20:05:362 | HL | INFO | +16 | Main - INI Keys read 17:20:05:363 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.exe exists 17:20:05:363 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.dll exists 17:20:05:363 | HL | INFO | +0 | CheckPaths - Started 17:20:05:363 | HL | INFO | +0 | CheckFile - Checking if \ exists 17:20:05:364 | HL | INFO | +0 | CheckPaths - Ended 17:20:05:364 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 17:20:05:364 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 17:20:05:364 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 17:20:05:365 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 276 17:20:05:367 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 17:20:05:367 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 17:20:05:367 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 17:20:05:367 | HL | INFO | +15 | Main - Module is built 17:20:05:367 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\AutoHotkey.dll exists 17:20:05:370 | HL | INFO | +0 | SystemCursor - Hiding mouse cursor 17:20:05:372 | HL | INFO | +0 | Main - Running module 17:20:05:457 | MD | INFO | +N/A | Module initialized 17:20:05:460 | MD | INFO | +0 | StartModule - Started 17:20:05:460 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: https://sites.google.com/site/hyperlaunch2/additional-features/pclauncher MAuthor: djvj MVersion: 2.0 MCRC: 9689E4E0 iCRC: D22F072A MSystem: Games for Windows 17:20:05:461 | MD | INFO | +0 | StartModule - Ended 17:20:05:461 | MD | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ini exists 17:20:05:461 | MD | INFO | +16 | Module Setting - PathToSteam: G:\Steam 17:20:05:462 | MD | INFO | +0 | Module Setting - Application: C:\Emulators\PC Games\Shank 2\bin\Shank 2.exe 17:20:05:463 | MD | INFO | +0 | Module Setting - PreLaunch: C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe 17:20:05:465 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe exists 17:20:05:465 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\PC Games\Shank 2\bin\Shank 2.exe exists 17:20:05:465 | MD | INFO | +0 | PCLauncher - PreLaunch set by user, running: C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe 17:20:05:465 | MD | INFO | +0 | Module Run - Running: C:\Emulators\PC Games\Shank 2\bin\"Shank2ahk.exe" 17:20:05:500 | MD | INFO | +31 | Module Run - Running: C:\Emulators\PC Games\Shank 2\bin\"Shank 2.exe" 17:20:05:527 | MD | INFO | +32 | PCLauncher - FadeTitle not set by user, waiting for AppPID: 3112 17:20:05:527 | MD | INFO | +0 | Module WinWait - Waiting for ahk_pid 3112 17:20:06:691 | MD | INFO | +1156 | Module WinWaitActive - Waiting for ahk_pid 3112 17:20:06:789 | MD | INFO | +109 | PCLauncher - Waiting for AppPID "3112" to close. 17:20:06:789 | MD | INFO | +0 | Module Process - WaitClose 3112 17:20:14:545 | MD | INFO | +7750 | ExitModule - Started 17:20:14:545 | MD | INFO | +0 | Starting Updating Statistics: 17:20:14:546 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 17:20:14:546 | MD | DEBUG2 | +0 | gameSectionStartTime:159286296 17:20:14:546 | MD | DEBUG2 | +0 | ElapsedTime:9 17:20:14:547 | MD | INFO | +0 | CreateRomTable - Started 17:20:14:547 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 17:20:14:548 | MD | DEBUG2 | +0 | Statistics cleared game name: Shank 2 17:20:14:675 | MD | DEBUG2 | +125 | Loaded game statistics from ini files: Number_of_Times_Played: 17 Last_Time_Played: Friday July 22, 2016 05:17:31 PM Average_Time_Played: 24 Total_Time_Played: 405 System_Total_Played_Time: 12699 Total_Global_Played_Time: 77877 17:20:14:676 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 18 Last_Time_Played: Friday July 22, 2016 05:20:14 PM Average_Time_Played: 23 Total_Time_Played: 414 System_Total_Played_Time: 12708 Total_Global_Played_Time: 77886 17:20:14:719 | MD | INFO | +47 | Game section statistics updated. 17:20:14:719 | MD | INFO | +0 | ExitModule - Ended 17:20:14:719 | MD | INFO | +0 | End of Module Logs 17:20:14:759 | HL | INFO | +9391 | Main - Module ended, exiting HyperLaunch normally 17:20:14:759 | HL | INFO | +0 | ExitScript - Started 17:20:14:763 | HL | DEBUG1 | +0 | ExitScript - Putting HyperSpin.exe back in focus 17:20:14:774 | HL | INFO | +16 | SystemCursor - Restoring mouse cursor 17:20:14:787 | HL | INFO | +0 | ExitScript - Ended My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
gigapig Posted July 22, 2016 Posted July 22, 2016 Did RocketLauncher.0.0.3 only have one level of error checking as there is no mention of fade in that log that I could see? Do your systems with fade working show it in the log?
majorspawn Posted July 22, 2016 Author Posted July 22, 2016 Ill check that next gig... thanks for reply buddy Sent from my SM-G930F using Tapatalk My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
majorspawn Posted July 22, 2016 Author Posted July 22, 2016 Did RocketLauncher.0.0.3 only have one level of error checking as there is no mention of fade in that log that I could see? Do your systems with fade working show it in the log? please see below log for mame which Fadein works fine. 22:26:02:403 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.3 22:26:02:404 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin OS: WIN_8 Architecture: 64-bit (might not be accurate) OS Language: 0409 OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 22:26:02:404 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1200 22:26:02:404 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch.exe exists 22:26:02:405 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\gdip.ahk exists 22:26:02:411 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:02:411 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\RIni.ahk exists 22:26:02:415 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:02:415 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\CLR.ahk exists 22:26:02:416 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:02:416 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\COM.ahk exists 22:26:02:418 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:02:418 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\JSON.ahk exists 22:26:02:419 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:02:419 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Init.ahk exists 22:26:02:419 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:420 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause Init.ahk exists 22:26:02:420 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:421 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper Init.ahk exists 22:26:02:421 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:421 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame Init.ahk exists 22:26:02:422 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:422 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics Init.ahk exists 22:26:02:423 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:423 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade.ahk exists 22:26:02:424 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:424 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause.ahk exists 22:26:02:433 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:434 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper.ahk exists 22:26:02:434 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:434 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame.ahk exists 22:26:02:434 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:434 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Bezel.ahk exists 22:26:02:434 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:434 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics.ahk exists 22:26:02:434 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:434 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Rom Mapping Launch Menu.ahk exists 22:26:02:446 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:447 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Shared.ahk exists 22:26:02:450 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:451 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\XHotkey.ahk exists 22:26:02:453 | HL | ERROR | +0 | CRC Check - CRC does not match for this Library. Please re-download this file to continue using HyperLaunch: C:\HyperSpin\Lib\XHotkey.ahk 22:26:02:453 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Animations.ahk exists 22:26:02:455 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:02:456 | HL | INFO | +0 | Main - HyperLaunch received "MAME" and "sf" 22:26:02:465 | HL | INFO | +0 | Main - sf is using the default emulator: MAME 22:26:02:465 | HL | INFO | +15 | Main - Checking for a [MAME] section in C:\HyperSpin\Settings\MAME\Emulators.ini 22:26:02:466 | HL | INFO | +0 | Main - Found [MAME] in C:\HyperSpin\Settings\MAME\Emulators.ini 22:26:02:466 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\MAME\MAME (MAME .148 djvj 2.0).ahk exists 22:26:02:467 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 22:26:02:467 | HL | INFO | +0 | Main - sf will use module: C:\HyperSpin\Modules\MAME\MAME (MAME .148 djvj 2.0).ahk 22:26:02:489 | HL | INFO | +16 | Main - INI Keys read 22:26:02:489 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.exe exists 22:26:02:490 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.dll exists 22:26:02:490 | HL | INFO | +0 | CheckPaths - Started 22:26:02:490 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\mame0148\roms\sf.zip 22:26:02:492 | HL | INFO | +0 | CheckPaths - Found rom: E:\mame0148\roms\sf.zip 22:26:02:492 | HL | INFO | +0 | CheckFile - Checking if E:\mame0148\mame.exe exists 22:26:02:493 | HL | INFO | +0 | CheckPaths - Ended 22:26:02:493 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 22:26:02:493 | HL | INFO | +0 | BuildScript - Loaded Fade Init.ahk scripts 22:26:02:493 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 22:26:02:493 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 22:26:02:494 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 280 22:26:02:495 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 22:26:02:495 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 22:26:02:495 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 22:26:02:496 | HL | INFO | +0 | Main - Module is built 22:26:02:496 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\AutoHotkey.dll exists 22:26:02:498 | HL | INFO | +16 | SystemCursor - Hiding mouse cursor 22:26:02:500 | HL | INFO | +0 | Main - Running module 22:26:02:628 | MD | INFO | +N/A | Module initialized 22:26:02:631 | MD | DEBUG1 | +0 | fadeInTransitionAnimation: DefaultAnimateFadeIn 22:26:02:632 | MD | DEBUG1 | +0 | fadeOutTransitionAnimation: DefaultAnimateFadeOut 22:26:02:632 | MD | DEBUG1 | +0 | fadeLyr3Animation: NoAnimation 22:26:02:632 | MD | DEBUG1 | +0 | fadeLyr37zAnimation: DefaultFadeAnimation 22:26:02:632 | MD | INFO | +0 | StartModule - Started 22:26:02:633 | MD | INFO | +0 | StartModule - MEmu: MAME MEmuV: v0.148 MURL: http://www.mame.net/ MAuthor: djvj MVersion: 2.0 MCRC: 2C317D7A iCRC: 8E4C99AB MSystem: Cave 22:26:02:633 | MD | INFO | +0 | StartModule - Ended 22:26:02:633 | MD | DEBUG1 | +0 | FadeInStart started 22:26:02:639 | MD | INFO | +15 | GetFadePicFile - Layer 1 will use C:\HyperSpin\Media\Fade\_Default\Layer 1.png 22:26:02:639 | MD | INFO | +0 | GetFadePicFile - Layer 2 will use C:\HyperSpin\Media\Fade\MAME\sf\Layer 2.png 22:26:03:024 | MD | INFO | +375 | Drawing First FadeIn Image. 22:26:06:023 | MD | DEBUG1 | +3000 | FadeInDelay started 22:26:06:023 | MD | DEBUG1 | +0 | FadeInDelay ended 22:26:06:023 | MD | DEBUG1 | +0 | CoverFE started 22:26:06:024 | MD | DEBUG1 | +0 | CoverFE ended 22:26:06:024 | MD | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\MAME\MAME (MAME .148 djvj 2.0).ini exists 22:26:06:024 | MD | INFO | +0 | Module Setting - Fullscreen: true 22:26:06:024 | MD | INFO | +0 | Module Setting - Videomode: d3d 22:26:06:024 | MD | INFO | +0 | Module Setting - PauseMethod: 1 22:26:06:024 | MD | INFO | +0 | Module Setting - BezelMode: layout 22:26:06:024 | MD | INFO | +0 | Module Setting - CheatMode: false 22:26:06:024 | MD | INFO | +0 | Module Run - Running: E:\mame0148\mame.exe sf -nowindow -video d3d -nouse_bezels -nouse_overlays -nouse_backdrops -rompath "E:\mame0148\roms" 22:26:06:070 | MD | INFO | +47 | Module WinWait - Waiting for MAME ahk_class MAME 22:26:06:301 | MD | INFO | +234 | Module WinWaitActive - Waiting for MAME ahk_class MAME 22:26:06:411 | MD | INFO | +110 | Module Process - WaitClose mame.exe 22:26:06:421 | MD | DEBUG1 | +15 | FadeInExit started 22:26:09:454 | MD | DEBUG1 | +3032 | FadeInExit ended, waiting for user to close launched application 22:26:09:454 | MD | INFO | +0 | ExitModule - Started 22:26:09:454 | MD | INFO | +0 | Starting Updating Statistics: 22:26:09:454 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 22:26:09:454 | MD | DEBUG2 | +0 | gameSectionStartTime:320328 22:26:09:454 | MD | DEBUG2 | +0 | ElapsedTime:0 22:26:09:454 | MD | INFO | +0 | CreateRomTable - Started 22:26:09:454 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 22:26:09:454 | MD | DEBUG2 | +0 | Statistics cleared game name: sf 22:26:09:484 | MD | DEBUG2 | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 3 Last_Time_Played: Wednesday July 20, 2016 10:59:31 PM Average_Time_Played: 5 Total_Time_Played: 14 System_Total_Played_Time: 1619 Total_Global_Played_Time: 77894 22:26:09:484 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 4 Last_Time_Played: Friday July 22, 2016 10:26:09 PM Average_Time_Played: 4 Total_Time_Played: 14 System_Total_Played_Time: 1619 Total_Global_Played_Time: 77894 22:26:09:506 | MD | INFO | +16 | Game section statistics updated. 22:26:09:506 | MD | INFO | +0 | ExitModule - Ended 22:26:09:506 | MD | INFO | +0 | End of Module Logs 22:26:09:514 | HL | INFO | +7015 | Main - Module ended, exiting HyperLaunch normally 22:26:09:514 | HL | INFO | +0 | ExitScript - Started 22:26:09:514 | HL | DEBUG1 | +0 | ExitScript - Putting HyperSpin.exe back in focus 22:26:09:539 | HL | INFO | +16 | SystemCursor - Restoring mouse cursor 22:26:09:559 | HL | INFO | +15 | ExitScript - Ended My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
gigapig Posted July 22, 2016 Posted July 22, 2016 Now that one does show fade in. Weird. I'm sorry that this is an incredibly simple question but I forget the simple things. You do have media in the fade folder for "PC Games"?
majorspawn Posted July 22, 2016 Author Posted July 22, 2016 Now that one does show fade in. Weird. I'm sorry that this is an incredibly simple question but I forget the simple things. You do have media in the fade folder for "PC Games"? HI Gig, maaaate ask away please, i had existing media under fade for "Pc Games", the system name is "Pc games" also which is same as my database name. I have the default stuff here: C:\HyperSpin\Media\Fade\_Default I also have C:\HyperSpin\Media\Fade\PC Games\_Default the below: Layer 1.png Layer 2.png Layer 3.png and a Layer 2.png in C:\HyperSpin\Media\Fade\PC Games and Layer 2.png in the game folder " Shank 2" as a test I'm assuming even without game specific media it should show the default Layer x My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
gigapig Posted July 22, 2016 Posted July 22, 2016 I see your HyperLaunch media is in your HyperSpin folder but over chat you said others are working...Odd
gigapig Posted July 22, 2016 Posted July 22, 2016 An update. Just did a Teamviewer session with Major. So we found that fade is working when launching through HLHQ. Thinking HS was not using HyperLaunch as I also noticed the HyperSpin setting.ini was missing the path to HyperLaunch although the games still launch.
majorspawn Posted July 22, 2016 Author Posted July 22, 2016 Hi Angent47, Gig remoted in and had a look, we really couldn't find anything wrong in the settings, as mentioned previously fade works fine with other setup emus ia HLHQ eg mame, NGC and ttx, exactly same settings. What we noticed is that when launching a game e.g. "shank 2" directly via HLHQ settings > games > audit > rocket icon, the fade works and the screen can be seen. The fade entries also appear int he hyperlaunch.log file, when running the same game via HyoerSpin directly fade does not work and the log is missing the fade stuff... very strange here is a youtube vid showing the strange behavior and workflow... https://www.youtube.com/watch?v=C_ornXW-BWg Here are 2 logs to compare when launching "PC Games" direct via HyperLaunch > Games > Audit > rocket icon log: (fade diagnostic present, highlighted in bold) 00:16:31:382 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.3 00:16:31:383 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin OS: WIN_8 Architecture: 64-bit (might not be accurate) OS Language: 0409 OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 00:16:31:383 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 00:16:31:383 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch.exe exists 00:16:31:383 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\gdip.ahk exists 00:16:31:389 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 00:16:31:389 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\RIni.ahk exists 00:16:31:393 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:16:31:393 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\CLR.ahk exists 00:16:31:394 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:16:31:394 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\COM.ahk exists 00:16:31:395 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:16:31:395 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\JSON.ahk exists 00:16:31:396 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:16:31:396 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Init.ahk exists 00:16:31:396 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:396 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause Init.ahk exists 00:16:31:396 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:397 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper Init.ahk exists 00:16:31:397 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:397 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame Init.ahk exists 00:16:31:397 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:397 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics Init.ahk exists 00:16:31:398 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:398 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade.ahk exists 00:16:31:399 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:399 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause.ahk exists 00:16:31:408 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:408 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper.ahk exists 00:16:31:409 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:409 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame.ahk exists 00:16:31:410 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:410 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Bezel.ahk exists 00:16:31:411 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:411 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics.ahk exists 00:16:31:412 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:412 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Rom Mapping Launch Menu.ahk exists 00:16:31:416 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:416 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Shared.ahk exists 00:16:31:418 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:418 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\XHotkey.ahk exists 00:16:31:419 | HL | ERROR | +15 | CRC Check - CRC does not match for this Library. Please re-download this file to continue using HyperLaunch: C:\HyperSpin\Lib\XHotkey.ahk 00:16:31:419 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Animations.ahk exists 00:16:31:421 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:16:31:421 | HL | INFO | +0 | Main - HyperLaunch received "PC Games" and "Shank 2" 00:16:31:426 | HL | INFO | +0 | Main - Shank 2 is using the default emulator: PCLauncher 00:16:31:426 | HL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\HyperSpin\Settings\PC Games\Emulators.ini 00:16:31:426 | HL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\HyperSpin\Settings\Global Emulators.ini 00:16:31:426 | HL | INFO | +0 | Main - Found [PCLauncher] in C:\HyperSpin\Settings\Global Emulators.ini 00:16:31:427 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ahk exists 00:16:31:428 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 00:16:31:428 | HL | INFO | +0 | Main - Shank 2 will use module: C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ahk 00:16:31:437 | HL | INFO | +16 | Main - INI Keys read 00:16:31:437 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.exe exists 00:16:31:437 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.dll exists 00:16:31:437 | HL | INFO | +0 | CheckPaths - Started 00:16:31:437 | HL | INFO | +0 | CheckFile - Checking if \ exists 00:16:31:437 | HL | INFO | +0 | CheckPaths - Ended 00:16:31:437 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 00:16:31:437 | HL | INFO | +0 | BuildScript - Loaded Fade Init.ahk scripts 00:16:31:437 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 00:16:31:438 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 00:16:31:438 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 280 00:16:31:440 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 00:16:31:440 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 00:16:31:440 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 00:16:31:440 | HL | INFO | +0 | Main - Module is built 00:16:31:440 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\AutoHotkey.dll exists 00:16:31:442 | HL | INFO | +0 | SystemCursor - Hiding mouse cursor 00:16:31:444 | HL | INFO | +0 | Main - Running module 00:16:31:561 | MD | INFO | +N/A | Module initialized 00:16:31:566 | MD | DEBUG1 | +0 | fadeInTransitionAnimation: DefaultAnimateFadeIn 00:16:31:566 | MD | DEBUG1 | +0 | fadeOutTransitionAnimation: DefaultAnimateFadeOut 00:16:31:566 | MD | DEBUG1 | +0 | fadeLyr3Animation: NoAnimation 00:16:31:566 | MD | DEBUG1 | +0 | fadeLyr37zAnimation: DefaultFadeAnimation 00:16:31:566 | MD | INFO | +0 | StartModule - Started 00:16:31:566 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: https://sites.google.com/site/hyperlaunch2/additional-features/pclauncher MAuthor: djvj MVersion: 2.0 MCRC: 9689E4E0 iCRC: D22F072A MSystem: Games for Windows 00:16:31:566 | MD | INFO | +0 | StartModule - Ended 00:16:31:566 | MD | DEBUG1 | +0 | FadeInStart started 00:16:31:569 | MD | INFO | +0 | GetFadePicFile - Layer 1 will use C:\HyperSpin\Media\Fade\PC Games\_Default\Layer 1.png 00:16:31:569 | MD | INFO | +0 | GetFadePicFile - Layer 2 will use C:\HyperSpin\Media\Fade\PC Games\Shank 2\Layer 2.png 00:16:31:760 | MD | INFO | +188 | Drawing First FadeIn Image. 00:16:34:751 | MD | DEBUG1 | +3000 | FadeInDelay started 00:16:34:751 | MD | DEBUG1 | +0 | FadeInDelay ended 00:16:34:751 | MD | DEBUG1 | +0 | CoverFE started 00:16:34:759 | MD | DEBUG1 | +0 | CoverFE ended 00:16:34:759 | MD | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ini exists 00:16:34:759 | MD | INFO | +0 | Module Setting - PathToSteam: G:\Steam 00:16:34:759 | MD | INFO | +0 | Module Setting - Application: C:\Emulators\PC Games\Shank 2\bin\Shank 2.exe 00:16:34:760 | MD | INFO | +0 | Module Setting - PreLaunch: C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe 00:16:34:762 | MD | INFO | +15 | Module Setting - HideCursor: true 00:16:34:762 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe exists 00:16:34:763 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\PC Games\Shank 2\bin\Shank 2.exe exists 00:16:34:764 | MD | INFO | +0 | Hiding mouse cursor 00:16:34:776 | MD | INFO | +0 | PCLauncher - PreLaunch set by user, running: C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe 00:16:34:776 | MD | INFO | +0 | Module Run - Running: C:\Emulators\PC Games\Shank 2\bin\"Shank2ahk.exe" 00:16:34:810 | MD | INFO | +47 | Module Run - Running: C:\Emulators\PC Games\Shank 2\bin\"Shank 2.exe" 00:16:34:826 | MD | INFO | +16 | PCLauncher - FadeTitle not set by user, waiting for AppPID: 4496 00:16:34:826 | MD | INFO | +0 | Module WinWait - Waiting for ahk_pid 4496 00:16:36:017 | MD | INFO | +1187 | Module WinWaitActive - Waiting for ahk_pid 4496 00:16:36:124 | MD | INFO | +110 | PCLauncher - Waiting for AppPID "4496" to close. 00:16:36:124 | MD | INFO | +0 | Module Process - WaitClose 4496 00:16:36:144 | MD | DEBUG1 | +15 | FadeInExit started 00:16:39:151 | MD | DEBUG1 | +3000 | FadeInExit ended, waiting for user to close launched application 00:16:42:796 | MD | INFO | +3656 | Restoring mouse cursor 00:16:42:800 | MD | INFO | +0 | ExitModule - Started 00:16:42:800 | MD | INFO | +0 | Starting Updating Statistics: 00:16:42:800 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 00:16:42:800 | MD | DEBUG2 | +0 | gameSectionStartTime:6950015 00:16:42:800 | MD | DEBUG2 | +0 | ElapsedTime:3 00:16:42:801 | MD | INFO | +0 | CreateRomTable - Started 00:16:42:801 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 00:16:42:801 | MD | DEBUG2 | +0 | Statistics cleared game name: Shank 2 00:16:42:868 | MD | DEBUG2 | +63 | Loaded game statistics from ini files: Number_of_Times_Played: 2 Last_Time_Played: Saturday July 23, 2016 12:09:08 AM Average_Time_Played: 5 Total_Time_Played: 9 System_Total_Played_Time: 741 Total_Global_Played_Time: 78186 00:16:42:868 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 3 Last_Time_Played: Saturday July 23, 2016 12:16:42 AM Average_Time_Played: 4 Total_Time_Played: 12 System_Total_Played_Time: 744 Total_Global_Played_Time: 78189 00:16:42:912 | MD | INFO | +47 | Game section statistics updated. 00:16:42:913 | MD | INFO | +0 | ExitModule - Ended 00:16:42:913 | MD | INFO | +0 | End of Module Logs 00:16:42:984 | HL | INFO | +11547 | Main - Module ended, exiting HyperLaunch normally 00:16:42:984 | HL | INFO | +0 | ExitScript - Started 00:16:42:990 | HL | DEBUG1 | +0 | ExitScript - Putting HyperSpin.exe back in focus 00:16:42:005 | HL | INFO | +16 | SystemCursor - Restoring mouse cursor 00:16:43:023 | HL | INFO | +15 | ExitScript - Ended log when launching same game via HS frontend: (no fade in specifics in the log compared to above log extract) 00:21:02:299 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.3 00:21:02:300 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin OS: WIN_8 Architecture: 64-bit (might not be accurate) OS Language: 0409 OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 00:21:02:300 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1200 00:21:02:300 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch.exe exists 00:21:02:300 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\gdip.ahk exists 00:21:02:310 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 00:21:02:310 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\RIni.ahk exists 00:21:02:315 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:21:02:315 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\CLR.ahk exists 00:21:02:316 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:21:02:316 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\COM.ahk exists 00:21:02:318 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:21:02:318 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\JSON.ahk exists 00:21:02:318 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 00:21:02:319 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Init.ahk exists 00:21:02:319 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:319 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause Init.ahk exists 00:21:02:320 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:320 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper Init.ahk exists 00:21:02:320 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:320 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame Init.ahk exists 00:21:02:321 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:321 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics Init.ahk exists 00:21:02:321 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:321 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade.ahk exists 00:21:02:323 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:323 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\HyperPause.ahk exists 00:21:02:338 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:338 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Keymapper.ahk exists 00:21:02:340 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:340 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\MultiGame.ahk exists 00:21:02:346 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:346 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Bezel.ahk exists 00:21:02:348 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:348 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Statistics.ahk exists 00:21:02:350 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:350 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Rom Mapping Launch Menu.ahk exists 00:21:02:355 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:355 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Shared.ahk exists 00:21:02:360 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:360 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\XHotkey.ahk exists 00:21:02:363 | HL | ERROR | +0 | CRC Check - CRC does not match for this Library. Please re-download this file to continue using HyperLaunch: C:\HyperSpin\Lib\XHotkey.ahk 00:21:02:364 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Lib\Fade Animations.ahk exists 00:21:02:368 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 00:21:02:369 | HL | INFO | +0 | Main - HyperLaunch received "PCLauncher" and "Shank 2" 00:21:02:377 | HL | INFO | +16 | Main - Shank 2 is using the default emulator: PCLauncher 00:21:02:377 | HL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\HyperSpin\Settings\PCLauncher\Emulators.ini 00:21:02:377 | HL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\HyperSpin\Settings\Global Emulators.ini 00:21:02:378 | HL | INFO | +0 | Main - Found [PCLauncher] in C:\HyperSpin\Settings\Global Emulators.ini 00:21:02:379 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ahk exists 00:21:02:382 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 00:21:02:382 | HL | INFO | +0 | Main - Shank 2 will use module: C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ahk 00:21:02:401 | HL | INFO | +15 | Main - INI Keys read 00:21:02:401 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.exe exists 00:21:02:401 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.dll exists 00:21:02:401 | HL | INFO | +0 | CheckPaths - Started 00:21:02:401 | HL | INFO | +0 | CheckFile - Checking if \ exists 00:21:02:401 | HL | INFO | +0 | CheckPaths - Ended 00:21:02:401 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 00:21:02:401 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 00:21:02:401 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 00:21:02:402 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 276 00:21:02:406 | HL | INFO | +16 | BuildScript - Loaded Statistics.ahk script 00:21:02:407 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 00:21:02:407 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 00:21:02:407 | HL | INFO | +0 | Main - Module is built 00:21:02:407 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\AutoHotkey.dll exists 00:21:02:410 | HL | INFO | +0 | SystemCursor - Hiding mouse cursor 00:21:02:413 | HL | INFO | +0 | Main - Running module 00:21:02:554 | MD | INFO | +N/A | Module initialized 00:21:02:556 | MD | INFO | +0 | StartModule - Started 00:21:02:556 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: https://sites.google.com/site/hyperlaunch2/additional-features/pclauncher MAuthor: djvj MVersion: 2.0 MCRC: 9689E4E0 iCRC: D22F072A MSystem: Games for Windows 00:21:02:556 | MD | INFO | +0 | StartModule - Ended 00:21:02:556 | MD | INFO | +0 | CheckFile - Checking if C:\HyperSpin\Modules\PCLauncher\PCLauncher (djvj 2.0).ini exists 00:21:02:557 | MD | INFO | +0 | Module Setting - PathToSteam: G:\Steam 00:21:02:557 | MD | INFO | +0 | Module Setting - Application: C:\Emulators\PC Games\Shank 2\bin\Shank 2.exe 00:21:02:558 | MD | INFO | +0 | Module Setting - PreLaunch: C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe 00:21:02:560 | MD | INFO | +16 | Module Setting - HideCursor: true 00:21:02:560 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe exists 00:21:02:560 | MD | INFO | +0 | CheckFile - Checking if C:\Emulators\PC Games\Shank 2\bin\Shank 2.exe exists 00:21:02:561 | MD | INFO | +0 | Hiding mouse cursor 00:21:02:572 | MD | INFO | +0 | PCLauncher - PreLaunch set by user, running: C:\Emulators\PC Games\Shank 2\bin\Shank2ahk.exe 00:21:02:573 | MD | INFO | +0 | Module Run - Running: C:\Emulators\PC Games\Shank 2\bin\"Shank2ahk.exe" 00:21:02:608 | MD | INFO | +47 | Module Run - Running: C:\Emulators\PC Games\Shank 2\bin\"Shank 2.exe" 00:21:02:627 | MD | INFO | +16 | PCLauncher - FadeTitle not set by user, waiting for AppPID: 4796 00:21:02:627 | MD | INFO | +0 | Module WinWait - Waiting for ahk_pid 4796 00:21:03:814 | MD | INFO | +1187 | Module WinWaitActive - Waiting for ahk_pid 4796 00:21:03:924 | MD | INFO | +109 | PCLauncher - Waiting for AppPID "4796" to close. 00:21:03:924 | MD | INFO | +0 | Module Process - WaitClose 4796 00:21:11:645 | MD | INFO | +7719 | Restoring mouse cursor 00:21:11:653 | MD | INFO | +0 | ExitModule - Started 00:21:11:653 | MD | INFO | +0 | Starting Updating Statistics: 00:21:11:653 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 00:21:11:653 | MD | DEBUG2 | +0 | gameSectionStartTime:7213421 00:21:11:653 | MD | DEBUG2 | +0 | ElapsedTime:9 00:21:11:653 | MD | INFO | +0 | CreateRomTable - Started 00:21:11:653 | MD | INFO | +16 | CreateRomTable - Ended, 7 Loops to create table. 00:21:11:653 | MD | DEBUG2 | +0 | Statistics cleared game name: Shank 2 00:21:11:761 | MD | DEBUG2 | +94 | Loaded game statistics from ini files: Number_of_Times_Played: 30 Last_Time_Played: Saturday July 23, 2016 12:08:35 AM Average_Time_Played: 18 Total_Time_Played: 541 System_Total_Played_Time: 12939 Total_Global_Played_Time: 78189 00:21:11:761 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 31 Last_Time_Played: Saturday July 23, 2016 12:21:11 AM Average_Time_Played: 18 Total_Time_Played: 550 System_Total_Played_Time: 12948 Total_Global_Played_Time: 78198 00:21:11:828 | MD | INFO | +78 | Game section statistics updated. 00:21:11:828 | MD | INFO | +0 | ExitModule - Ended 00:21:11:828 | MD | INFO | +0 | End of Module Logs 00:21:11:921 | HL | INFO | +9515 | Main - Module ended, exiting HyperLaunch normally 00:21:11:921 | HL | INFO | +0 | ExitScript - Started 00:21:11:924 | HL | DEBUG1 | +0 | ExitScript - Putting HyperSpin.exe back in focus 00:21:11:934 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 00:21:11:944 | HL | INFO | +16 | ExitScript - Ended very very confused.... My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
Metalzoic Posted July 22, 2016 Posted July 22, 2016 It's obvious. His computer is drunk. EDIT: Also possible he accidentally changed the PCLauncher module? Or somehow has a faulty or wrong module version? Or doesn't have the right one set under the Emulators tab?
gigapig Posted July 22, 2016 Posted July 22, 2016 Ahh, Metalzoic mentions PCLauncher Module. Nothing to do with that really. But why is HyperSpin sending PCLauncher and not the system name PC Games? Have you set that correctly, is the system name PC Games in HyperSpin? That was taken from what I saw in your HS Log in the teamviewer sesh and is in the second log you posted. First log shows PC Games.
majorspawn Posted July 23, 2016 Author Posted July 23, 2016 I might create a new system called computer games to recrete it from scratch. Then copy game config across. Sent from my SM-G930F using Tapatalk My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
majorspawn Posted July 23, 2016 Author Posted July 23, 2016 Ok guys, I fixed the issue by total accident. Here is how not sure why it worked.... navigated to: C:\HyperSpin\Settings\PCLauncher (pclauncher used by PC Games... checked HyperLaunch.ini the [Fade] config was set to use_global as below: [Fade]Fade_In=use_globalFade_In_Duration=use_globalFade_In_Transition_Animation=use_globalFade_In_Delay=use_globalFade_In_Exit_Delay=use_globalFade_Out=use_globalFade_Out_Duration=use_globalFade_Out_Transition_Animation=use_globalFade_Out_Delay=use_globalFade_Out_Exit_Delay=use_globalFade_Layer_Interpolation=use_globalFade_Layer_1_Color=use_globalFade_Layer_1_Align_Image=use_globalFade_Layer_2_Alignment=use_globalFade_Layer_2_X=use_globalFade_Layer_2_Y=use_globalFade_Layer_2_Adjust=use_globalFade_Layer_2_Padding=use_globalFade_Layer_3_Alignment=use_globalFade_Layer_3_X=use_globalFade_Layer_3_Y=use_globalFade_Layer_3_Adjust=use_globalFade_Layer_3_Padding=use_globalFade_Layer_3_Speed=use_globalFade_Layer_3_Animation=use_globalFade_Layer_3_7z_Animation=use_globalFade_Layer_3_Image_Follow_7z_Progress=use_globalFade_Layer_3_Type=use_globalFade_Layer_3_Repeat=use_globalFade_Layer_4_Pos=use_globalFade_Layer_4_X=use_globalFade_Layer_4_Y=use_globalFade_Layer_4_Adjust=use_globalFade_Layer_4_Padding=use_globalFade_Layer_4_FPS=use_globalFade_Animated_Gif_Transparent_Color=use_globalFade_Bar_Window=use_globalFade_Bar_Window_X=use_globalFade_Bar_Window_Y=use_globalFade_Bar_Window_Width=use_globalFade_Bar_Window_Height=use_globalFade_Bar_Window_Radius=use_globalFade_Bar_Window_Margin=use_globalFade_Bar_Window_Hatch_Style=use_globalFade_Bar_Back=use_globalFade_Bar_Back_Color=use_globalFade_Bar_Height=use_globalFade_Bar_Radius=use_globalFade_Bar_Color=use_globalFade_Bar_Hatch_Style=use_globalFade_Bar_Percentage_Text=use_globalFade_Bar_Info_Text=use_globalFade_Bar_X_Offset=use_globalFade_Bar_Y_Offset=use_globalFade_Rom_Info_Description=use_globalFade_Rom_Info_System_Name=use_globalFade_Rom_Info_Year=use_globalFade_Rom_Info_Manufacturer=use_globalFade_Rom_Info_Genre=use_globalFade_Rom_Info_Rating=use_globalFade_Rom_Info_Order=use_globalFade_Rom_Info_Text_Placement=use_globalFade_Rom_Info_Text_Margin=use_globalFade_Rom_Info_Text_1_Options=use_globalFade_Rom_Info_Text_2_Options=use_globalFade_Rom_Info_Text_3_Options=use_globalFade_Rom_Info_Text_4_Options=use_globalFade_Rom_Info_Text_5_Options=use_globalFade_Rom_Info_Text_6_Options=use_globalFade_Stats_Number_of_Times_Played=use_globalFade_Stats_Last_Time_Played=use_globalFade_Stats_Average_Time_Played=use_globalFade_Stats_Total_Time_Played=use_globalFade_Stats_System_Total_Played_Time=use_globalFade_Stats_Total_Global_Played_Time=use_globalFade_Stats_Info_Order=use_globalFade_Stats_Info_Text_Placement=use_globalFade_Stats_Info_Text_Margin=use_globalFade_Stats_Info_Text_1_Options=use_globalFade_Stats_Info_Text_2_Options=use_globalFade_Stats_Info_Text_3_Options=use_globalFade_Stats_Info_Text_4_Options=use_globalFade_Stats_Info_Text_5_Options=use_globalFade_Stats_Info_Text_6_Options=use_globalFade_Text_1_X=use_globalFade_Text_1_Y=use_globalFade_Text_1_Options=use_globalFade_Text_1=use_globalFade_Text_2_X=use_globalFade_Text_2_Y=use_globalFade_Text_2_Options=use_globalFade_Text_2=use_globalFade_Font=use_globalFade_System_And_Rom_Layers_Only=use_globalthen created a PCLauncher folder under media \Fade\PCLauncher, the media within this folder is now showing up as a fadein... bizare. but works My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
