TITCHGAMER Posted July 28, 2016 Posted July 28, 2016 Howdy all, I have a bit of a odd problem I cant get my head round. I recently managed to find a Taito Type X game set (Took like a week of searching!) Anyways thanks to Gigas file pack and video I managed to get them all working fine through their assosiated batch files or loaders. But when i loaded them into HS some of them just wont run. I select one HS looses focus as it should, The Batch file window pops up on the screen for a second or 2 as normal and then nothing. HS does not get focus back and the game does not load properly. The actual games that wont run are: Chaos Breakers KOF 98 KOF 13 Power Instinct Spika Adventure Tetris and Trouble Witches. Any pointers appreciated
ninja2bceen Posted July 28, 2016 Posted July 28, 2016 It's a pain in the but. Moving to Windows 10 is great other than this part. Some games run on the bat file and some run on the exe. Disable fade and that is about all you can do Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
gigapig Posted July 28, 2016 Posted July 28, 2016 Titch, first off, apologies for not replying over PM. First one I have tested was Spica Adventure which just says "Loading" to get is working I had to set compatibility to Windows 7. You set that on the file "game.exe", it may work for other and I'll try to test the rest.
TITCHGAMER Posted July 28, 2016 Author Posted July 28, 2016 No prob's Giga I figured you were busy (I know modding is tedius work!) I should add though I am running windows 7 64 bit. All the games run fine when I load them through windows, Just not through HS.
TITCHGAMER Posted July 28, 2016 Author Posted July 28, 2016 It's a pain in the but. Moving to Windows 10 is great other than this part. Some games run on the bat file and some run on the exe. Disable fade and that is about all you can do Which Fade do you mean Ninja? Thanks.
gigapig Posted July 28, 2016 Posted July 28, 2016 The two KOF games are working fine from the bat file and Power Instinct seems to work from an exe Trouble Witches is working and Tetris works when I use GameLoader All RH, so you might want to try that. You can up the res on Tetris with that.
TITCHGAMER Posted July 28, 2016 Author Posted July 28, 2016 I wont get back on it tonight but I know I tried to load the KOF games via the batch files. They load fine and play ok if I double click the batch but If I load the batch through HS it just doesnt work.
ninja2bceen Posted July 28, 2016 Posted July 28, 2016 Fade in Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Metalzoic Posted July 28, 2016 Posted July 28, 2016 You have them all setup correctly using the PCLauncher module in RL? They don't work from HS and RL? or just from HS?
TITCHGAMER Posted July 29, 2016 Author Posted July 29, 2016 Sorry about the late reply people.Ok so I have just had a tinker all of the games launch fine through rocket launcher.Just wont launch through HS. Or rather they do launch but it looses focud and if I try to switch focus back to the game nothing happens.Ile see if I can get a log up in a min.
TITCHGAMER Posted July 29, 2016 Author Posted July 29, 2016 OK here is the RL log though ime not sure it will be any use: 17:06:20:047 | RL | INFO | +N/A | Main - RocketLauncher v1.1.0.7 (www.rlauncher.com) 17:06:20:275 | RL | INFO | +219 | Main - System Specs: RocketLauncher Dir: C:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Ultimate SKU: Ultimate Total Memory: 8191.05 MB Free Memory: 4365.45 MB Used Memory: 3825.609 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: ATI Radeon HD 4800 Series GPU 1 RAM: 512.00 MB GPU 1 Driver Version: 8.970.100.1100 GPU 2 Name: ATI Radeon HD 4800 Series GPU 2 RAM: 512.00 MB GPU 2 Driver Version: 8.970.100.1100 Sound 1 Device: AMD High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: AMD High Definition Audio Device Sound 2 Status: Enabled Sound 3 Device: High Definition Audio Device Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-GB Formats Locale: en-GB Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: Yes RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1600x1200 (1600x1200 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1600 Current AHK Desktop Height: 1200 Monitor #1 DPI: 100 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 17:06:20:275 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\RocketLauncher.exe exists 17:06:20:275 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.1.0.7 LegalCopyright ©2015 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.1.0.7 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2162688 bytes Created: 6/3/2016 - 8:07:21 PM Modified: 5/28/2016 - 12:40:48 AM 17:06:20:275 | RL | TRACE | +0 | File.__New - Creating new file object of: "C:\RocketLauncher\Module Extensions\RocketLauncher.dll" 17:06:20:285 | RL | INFO | +15 | File.CheckFile - Checking if "C:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 17:06:20:285 | RL | TRACE | +0 | File.Exist - This file exists: C:\RocketLauncher\Module Extensions\RocketLauncher.dll 17:06:20:285 | RL | DEBUG | +0 | File.CheckFile - Attributes: FileDescription RocketLauncher Utils FileVersion 1.0.0.8 InternalName RocketLauncher.dll LegalCopyright Copyright © RocketLauncher 2013-2016 OriginalFilename RocketLauncher.dll ProductName RocketLauncher ProductVersion 1.0.0.8 File Size: 67072 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 5/28/2016 - 12:40:06 AM 17:06:20:285 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\Array.ahk 17:06:20:285 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4781 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 5/28/2016 - 12:40:12 AM 17:06:20:285 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2 17:06:20:285 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5077 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 5/28/2016 - 12:40:35 AM 17:06:20:285 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\BlockInput.exe exists 17:06:20:285 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 1/3/2014 - 4:27:34 AM 17:06:20:295 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 17:06:20:296 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5323 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 5/28/2016 - 12:39:47 AM 17:06:20:314 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 17:06:20:314 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 4/29/2013 - 7:56:02 PM 17:06:20:317 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\gdip.ahk 17:06:20:317 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 1/13/2013 - 11:07:30 PM 17:06:20:317 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3 17:06:20:317 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5891 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 12/21/2015 - 5:08:03 AM 17:06:20:317 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\gsdll32.dll exists 17:06:20:347 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 13090816 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 1/7/2015 - 3:20:42 AM 17:06:20:347 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\itextsharp.dll exists 17:06:20:407 | RL | DEBUG | +62 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 6/14/2013 - 8:06:21 PM 17:06:20:407 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Module Extensions\Java.ahk | v1.0.0 17:06:20:407 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 7841 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 12/24/2014 - 5:02:37 AM 17:06:20:407 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\JSON.ahk 17:06:20:407 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9227 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 5/28/2016 - 12:41:23 AM 17:06:20:407 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2 17:06:20:407 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4904 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 3/22/2015 - 8:51:41 PM 17:06:20:407 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\RegRW64.ahk 17:06:20:407 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 5/8/2014 - 9:06:39 AM 17:06:20:417 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\RIni.ahk | v1.7 17:06:20:417 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 6/6/2013 - 12:56:23 AM 17:06:20:417 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 17:06:20:427 | RL | DEBUG | +16 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.5717.6837 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.5717.6837 CompanyName Markovtsev Vadim File Size: 167424 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 9/29/2015 - 3:35:11 AM 17:06:20:427 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3 17:06:20:427 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5504 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 5/28/2016 - 12:40:38 AM 17:06:20:427 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\RocketLauncher\Module Extensions\VA.ahk 17:06:20:427 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 3/2/2013 - 3:05:47 AM 17:06:20:427 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1 17:06:20:427 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3833 bytes Created: 6/3/2016 - 8:07:56 PM Modified: 1/14/2015 - 2:16:56 AM 17:06:20:427 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\7z.ahk | v1.0.8 17:06:20:437 | RL | DEBUG | +15 | CheckFile - Attributes: File Size: 31307 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:03 AM 17:06:20:437 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Bezel.ahk | v1.2.3 17:06:20:437 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 117029 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:31 AM 17:06:20:437 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Fade.ahk | v1.1.8 17:06:20:437 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 39529 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:41:13 AM 17:06:20:437 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Fade Init.ahk | v1.0.3 17:06:20:437 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1130 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:08 AM 17:06:20:447 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Fade Animations.ahk | v1.2.2 17:06:20:447 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 77906 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:41:14 AM 17:06:20:447 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Keymapper.ahk | v1.1.5 17:06:20:447 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 33668 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:50 AM 17:06:20:447 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6 17:06:20:457 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 3956 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:48 AM 17:06:20:457 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\MultiGame.ahk | v1.1.0 17:06:20:457 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 41541 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:28 AM 17:06:20:467 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0 17:06:20:467 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 4/14/2013 - 7:33:19 PM 17:06:20:467 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8 17:06:20:467 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 66776 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 12/7/2015 - 11:37:45 AM 17:06:20:497 | RL | INFO | +31 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Pause.ahk | v1.2.3 17:06:20:497 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 396844 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:24 AM 17:06:20:497 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Pause Init.ahk | v1.0.3 17:06:20:497 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 553 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 8/24/2015 - 1:00:44 AM 17:06:20:497 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Password.ahk | v1.0.4 17:06:20:497 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 10121 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:07 AM 17:06:20:497 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7 17:06:20:497 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 25300 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:51 AM 17:06:20:507 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1 17:06:20:507 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3095 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:39:56 AM 17:06:20:507 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1 17:06:20:507 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5720 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:15 AM 17:06:20:507 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0 17:06:20:507 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1547 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:39:57 AM 17:06:20:507 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5 17:06:20:507 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 7789 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:06 AM 17:06:20:517 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0 17:06:20:517 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 2961 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:37 AM 17:06:20:517 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.5 17:06:20:517 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9145 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:40:44 AM 17:06:20:517 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0 17:06:20:517 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 646 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:40:40 AM 17:06:20:517 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0 17:06:20:517 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4410 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:41:18 AM 17:06:20:517 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.0 17:06:20:517 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3705 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:39:53 AM 17:06:20:517 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5 17:06:20:517 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 9583 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:40:43 AM 17:06:20:517 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1 17:06:20:527 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 1218 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:39:48 AM 17:06:20:527 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0 17:06:20:527 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5386 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:39:58 AM 17:06:20:537 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2 17:06:20:537 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 4559 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:40:09 AM 17:06:20:537 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2 17:06:20:537 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 22844 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:40:02 AM 17:06:20:537 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0 17:06:20:537 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1154 bytes Created: 6/3/2016 - 8:07:25 PM Modified: 5/28/2016 - 12:40:40 AM 17:06:20:547 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7 17:06:20:547 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 72261 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 12/7/2015 - 11:37:59 AM 17:06:20:557 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Shader.ahk | v1.0.1 17:06:20:557 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 3943 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:17 AM 17:06:20:557 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Shader Init.ahk | v1.0.0 17:06:20:557 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 397 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:40:06 AM 17:06:20:557 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Shared.ahk | v1.4.5 17:06:20:557 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 175581 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:41:25 AM 17:06:20:557 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Statistics.ahk | v1.0.4 17:06:20:557 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 26810 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 1/10/2016 - 6:04:41 AM 17:06:20:567 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1 17:06:20:567 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 12/24/2014 - 5:23:48 AM 17:06:20:567 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5 17:06:20:567 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 19148 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 5/28/2016 - 12:41:12 AM 17:06:20:567 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\XHotkey.ahk | v1.0.4 17:06:20:567 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 26540 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 8/14/2015 - 6:14:18 AM 17:06:20:567 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2 17:06:20:567 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 1063 bytes Created: 6/3/2016 - 8:07:24 PM Modified: 8/14/2015 - 6:14:25 AM 17:06:20:567 | RL | INFO | +0 | Main - Raw CLI received: "Taito Type X King of Fighters '98, The Ultimate Match" 17:06:20:567 | RL | DEBUG | +0 | Main - Received this dbName with no path via CLI: "King of Fighters '98, The Ultimate Match" 17:06:20:567 | RL | DEBUG | +0 | Main - dbName: King of Fighters '98, The Ultimate Match 17:06:20:567 | RL | INFO | +0 | Main - Loading Front End Plugin: "RocketLauncherUI" 17:06:20:567 | RL | TRACE | +0 | Process.__New - Creating new process object for: "C:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe" 17:06:20:567 | RL | TRACE | +0 | File.__New - Creating new file object of: "C:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe" 17:06:20:567 | RL | INFO | +0 | Process.Process - "Exist" "RocketLauncherUI.exe" 17:06:20:567 | RL | TRACE | +0 | Process.GetProcessID 17:06:20:567 | RL | INFO | +0 | Main - RocketLauncherUI.exe is not currently running 17:06:20:567 | RL | INFO | +0 | Main - RocketLauncher received "Taito Type X" and "King of Fighters '98, The Ultimate Match" 17:06:20:587 | RL | INFO | +16 | Main - Did not find a "C:\RocketLauncher\Settings\Taito Type X\Game Options.ini" file, skipping any game-specific options. 17:06:20:587 | RL | INFO | +0 | Main - King of Fighters '98, The Ultimate Match is using the default emulator: PCLauncher 17:06:20:587 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\RocketLauncher\Settings\Taito Type X\Emulators.ini 17:06:20:587 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in C:\RocketLauncher\Settings\Global Emulators.ini 17:06:20:587 | RL | INFO | +0 | Main - Found [PCLauncher] in C:\RocketLauncher\Settings\Global Emulators.ini 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "PCLauncher.ahk" 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk" 17:06:20:587 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk exists 17:06:20:587 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 17856 bytes Created: 6/3/2016 - 8:07:57 PM Modified: 5/28/2016 - 12:39:50 AM 17:06:20:587 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 17:06:20:587 | RL | INFO | +0 | Main - King of Fighters '98, The Ultimate Match will use module: C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Profiles" 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\RocketLauncher\Profiles" 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\7z.exe" 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\RocketLauncher\Module Extensions\7z.exe" 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe" 17:06:20:587 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe" 17:06:20:597 | RL | TRACE_DLL | +15 | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\HiToText.exe" 17:06:20:598 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\RocketLauncher\Module Extensions\HiToText.exe" 17:06:20:598 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Utilities\Xpadder\xpadder.exe" 17:06:20:598 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Utilities\Xpadder\xpadder.exe" 17:06:20:599 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Utilities\JoyToKey\JoyToKey.exe" 17:06:20:599 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Utilities\JoyToKey\JoyToKey.exe" 17:06:20:600 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Utilities\VJoy\VJoy.exe" 17:06:20:600 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Utilities\VJoy\VJoy.exe" 17:06:20:614 | RL | TRACE_DLL | +16 | RLDLL.getFullPathFromRelative - Converting "..\temp game files" 17:06:20:614 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\temp game files" 17:06:20:619 | RL | INFO | +0 | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher". 17:06:20:619 | RL | INFO | +0 | Main - INI Keys read 17:06:20:619 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.exe exists 17:06:20:619 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 262144 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 9/29/2015 - 3:35:11 AM 17:06:20:619 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.dll exists 17:06:20:629 | RL | DEBUG | +16 | CheckFile - Attributes: FileDescription 7z Plugin FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.dll ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 1012224 bytes Created: 6/3/2016 - 8:07:55 PM Modified: 9/29/2015 - 3:35:11 AM 17:06:20:629 | RL | INFO | +0 | Main - "King of Fighters '98, The Ultimate Match" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 17:06:20:629 | RL | INFO | +0 | CheckPaths - Started 17:06:20:629 | RL | DEBUG | +0 | CheckPaths - Current romName: 17:06:20:629 | RL | DEBUG | +0 | CheckPaths - Current romPath: 17:06:20:629 | RL | DEBUG | +0 | CheckPaths - Current romExtension: 17:06:20:629 | RL | INFO | +0 | CheckPaths - Ended 17:06:20:629 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event 0 = 2 rlPath = C:\RocketLauncher pluginPath = C:\RocketLauncher\Plugins pluginName = RocketLauncherUI pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.1.0.7 rlAuthor = djvj rlURL = www.rlauncher.com langFile = C:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 0 frontendPath = C:\RocketLauncher\RocketLauncherUI frontendExe = RocketLauncherUI.exe frontendExt = exe frontendName = RocketLauncherUI frontendDrive = C exitEmulatorKey = ~Esc restoreFE = Restore and Click exitScriptKey = ~PGUP & ~PGDN toggleCursorKey = ~e & ~t emuFullPath = emuPath = emuName = PCLauncher emuExt = baseRomPath = romPath = romPathFromIni = romExtension = romExtensionOrig = romExtensions = executable = systemDbName = Taito Type X systemName = Taito Type X dbPath = dbName = King of Fighters '98, The Ultimate Match dbExt = romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = C:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = setResolution = logFile = logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel = 10 logShowDebugConsole = false logShowCommandWindow = false logCommandWindow = false logIncludeModule = true logIncludeFileProperties = true logIncludeDLLLogs = false errorSounds = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = 1 navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1600 originalHeight = 1200 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdDriveLetterScsi = vdAddDrive = true servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = C:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = C:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher winIPACFullPath = ultraMapEnabled = false ultraMapFullPath = emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false suspendFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeSounds = true fade7zProgressMode = extraction fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeProgressDuration = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoDeveloper = text with label fadeRomInfoPublisher = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\RocketLauncher\Media\Fade RLDataPath = C:\RocketLauncher\Data RLMediaPath = C:\RocketLauncher\Media RLErrSoundPath = C:\RocketLauncher\Media\Sounds\Error modulesPath = C:\RocketLauncher\Modules moduleFullName = C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk moduleName = PCLauncher modulePath = C:\RocketLauncher\Modules\PCLauncher moduleExtension = ahk moduleExtensionsPath = C:\RocketLauncher\Module Extensions libPath = C:\RocketLauncher\Lib sevenZEnabled = false sevenZPath = C:\RocketLauncher\Module Extensions\7z.exe sevenZDllPath = C:\RocketLauncher\Module Extensions\7z.dll sevenZExtractPath = C:\temp game files sevenZExtractPathOrig = sevenZAttachSystemName = false sevenZDelTemp = true sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar 7zExtractPath = C:\temp game files mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side mgOnLaunch = false pauseEnabled = false pauseKey = ~NumpadAdd pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = C:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = pauseLoadStateKeyCodes = keyboardEncoder = keyboardEncoderEnabled = false keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Utilities\JoyToKey\JoyToKey.exe profilePath = C:\RocketLauncher\Profiles keymapperProfilePath = C:\RocketLauncher\Profiles\xpadder keymapperFrontEndProfileName = RocketLauncherUI keymapperFrontEndProfile = false keymapperRocketLauncherProfileEnabled = false joyIDsEnabled = false joyIDsPreferredControllersGlobal = joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = C:\RocketLauncher\Profiles\xpadder\RocketLauncherUI defaultProfile = C:\RocketLauncher\Profiles\xpadder\_Default systemProfile = C:\RocketLauncher\Profiles\xpadder\Taito Type X xPadderSystemProfile = C:\RocketLauncher\Profiles\xpadder\Taito Type X\_Default emuProfile = C:\RocketLauncher\Profiles\xpadder\Taito Type X\PCLauncher romProfile = C:\RocketLauncher\Profiles\xpadder\Taito Type X\King of Fighters '98, The Ultimate Match RocketLauncherProfile = C:\RocketLauncher\Profiles\xpadder\RocketLauncher blankProfile = C:\RocketLauncher\Profiles\xpadder\_Default\blank ahkFEProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncherUI ahkDefaultProfile = C:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = C:\RocketLauncher\Profiles\AHK\Taito Type X ahkEmuProfile = C:\RocketLauncher\Profiles\AHK\Taito Type X\PCLauncher ahkRomProfile = C:\RocketLauncher\Profiles\AHK\Taito Type X\King of Fighters '98, The Ultimate Match ahkRocketLauncherProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false shaderName = false shaderColor = shaderTransparency = shaderChangeKey = statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe qResFullPath = C:\RocketLauncher\Module Extensions\QRes.exe mon1O = pacDrivedllFile = C:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = C:\RocketLauncher\Lib\User Fade Animations.ini testFile = testDuration = 17:06:20:639 | RL | INFO | +15 | BuildScript - Loaded XHotkey Init.ahk scripts 17:06:20:639 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 17:06:20:639 | RL | WARNING | +0 | BuildScript - "C:\RocketLauncher\Lib\User Functions Init.ahk" not found 17:06:20:639 | RL | DEBUG | +0 | BuildScript - Module starts on line: 2 17:06:20:639 | RL | INFO | +0 | BuildScript - Validating module 17:06:20:639 | RL | INFO | +0 | BuildScript - Validation complete 17:06:20:639 | RL | INFO | +0 | BuildScript - Module: MEmu = PCLauncher MEmuV = N/A MURL = http://www.rlauncher.com/wiki/index.php?title=PCLauncher MAuthor = djvj MVersion = 2.2.5 MCRC = CCB5E681 iCRC = 495BB6CC mId = 635243126483565041 MSystem = "American Laser Games","Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Singstar","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project","Ultrastar","Ultrastar Deluxe","Windows Games" ;---------------------------------------------------------------------------- ; Notes: ; Use the examples in the ini, in your Modules\PCLauncher\ folder, to add more applications. ; PCLauncher supports per-System inis. Copy your PCLauncher ini in the same folder and rename it to match the System's Name. Use this if you have games with the same name across multiple systems. ; Read the tooltips for each module setting in RocketLauncherUI for the definitions of each key and help using them. ; For information on how to use this module and what all the settings do, please see http://www.rlauncher.com/wiki/index.php?title=PCLauncher ;---------------------------------------------------------------------------- StartModule() moduleIni.CheckFile("Could not find """ . moduleIni.FileFullPath . """`n`nRocketLauncherUI will create this file when you configure your first game to be used with the " . MEmu . " module.") Application := moduleIni.Read(dbName, "Application","","",1) AppWaitExe := moduleIni.Read(dbName, "AppWaitExe","","",1) DiscImage := moduleIni.Read(dbName, "DiscImage","","",1) DXWndGame := moduleIni.Read(dbName, "DXWndGame","","",1) DXWndMaximizeWindow := moduleIni.Read(dbName, "DXWndMaximizeWindow","","",1) ExitMethod := moduleIni.Read(dbName, "ExitMethod","","",1) FadeTitle := moduleIni.Read(dbName, "FadeTitle","","",1) FadeInExitSleep := moduleIni.Read(dbName, "FadeInExitSleep","","",1) HideConsole := moduleIni.Read(dbName, "HideConsole","","",1) OriginGame := moduleIni.Read(dbName, "OriginGame","","",1) Parameters := moduleIni.Read(dbName, "Parameters","","",1) PostLaunch := moduleIni.Read(dbName, "PostLaunch","","",1) PostLaunchParameters := moduleIni.Read(dbName, "PostLaunchParameters","","",1) PostLaunchSleep := moduleIni.Read(dbName, "PostLaunchSleep","","",1) PostExit := moduleIni.Read(dbName, "PostExit","","",1) PostExitParameters := moduleIni.Read(dbName, "PostExitParameters","","",1) PostExitSleep := moduleIni.Read(dbName, "PostExitSleep","","",1) PreLaunch := moduleIni.Read(dbName, "PreLaunch","","",1) PreLaunchParameters := moduleIni.Read(dbName, "PreLaunchParameters","","",1) PreLaunchMode := moduleIni.Read(dbName, "PreLaunchMode","","",1) PreLaunchSleep := moduleIni.Read(dbName, "PreLaunchSleep","","",1) SteamID := moduleIni.Read(dbName, "SteamID","","",1) WorkingFolder := moduleIni.Read(dbName, "WorkingFolder","","",1) If (!Application && !SteamID) { ; Create keys if they do not exist in the ini and this is not a steam game moduleIni.Write(A_Space, dbName, "Application") ScriptError("You have not set up " . dbName . " in RocketLauncherUI yet, so PCLauncher does not know what exe, FadeTitle, and/or SteamID to watch for.") } BezelGUI() FadeInStart() BezelStart() If Application { primaryExe := new Emulator(Application) ; instantiate primary application executable object } If (AppWaitExe != "") { AppWaitExe := new Process(AppWaitExe) } If FadeTitle { FadeTitleObj := StringUtils.ParsePCTitle(FadeTitle) appPrimaryWindow := new Window(new WindowTitle(FadeTitleObj.Title,FadeTitleObj.Class)) ; instantiate primary application window object } ; If Application needs a cd/dvd image in the drive, mount it in DT first If DiscImage { RLLog.Info("PCLauncher - Application is a Disc Image, mounting it in DT") appIsImage := 1 DiscImage := new File(GetFullName(DiscImage)) ; convert a relative path defined in the PCLauncher ini to absolute DiscImage.CheckFile("Cannot find this DiscImage for " . dbName . ":`n" . DiscImage.FileFullPath) ; StringUtils.SplitPath(DiscImage,"",ImagePath,ImageExt,ImageName) If StringUtils.Contains(DiscImage.FileExt,"mds|mdx|b5t|b6t|bwt|ccd|cue|isz|nrg|cdi|iso|ape|flac") { VirtualDrive("get") ; get the vdDriveLetter ; VirtualDrive("mount",ImagePath . "\" . ImageName . "." . ImageExt) VirtualDrive("mount",DiscImage.FileFullPath) } Else ScriptError("You defined a DiscImage, but it is not a supported format for this module and/or DT:`nccd,cdi,cue,iso,isz,nrg") } ; Verify module's settings are set CheckSettings() If PreLaunch { RLLog.Info("PCLauncher - PreLaunch set by user, running: " . PreLaunch) PreLaunchParameters := If (!PreLaunchParameters or PreLaunchParameters="ERROR") ? "" : PreLaunchParameters If (preLaunchMode = "run") { errLevel := PreLaunchExe.Run(If PreLaunchIsURL ? "" : PreLaunchParameters,"","","","",(If PreLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") TimerUtils.Sleep(PreLaunchSleep) } Else { errLevel := PreLaunchExe.RunWait(If PreLaunchIsURL ? "" : PreLaunchParameters,"",(If PreLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") } } If (DXWndGame = "true") ; start dxwnd if needed DxwndRun() If StringUtils.Contains(mode,"steam|steambp") ; steam launch Steam(SteamID, primaryExe.FileFullPath, Parameters) Else If (mode = "origin") ; origin launch Origin(primaryExe.FileName, primaryExe.FilePath, Parameters) Else { If (mode = "url") { RLLog.Info("PCLauncher - Launching URL.") errLevel := primaryExe.Run() } Else { ; standard launch RLLog.Info("PCLauncher - Launching a standard application.") If (HideConsole = "true" and primaryExe.FileExt = "bat") { RLLog.Info("PCLauncher - Hiding DOS console for bat file.") objShell := ComObjCreate("WScript.Shell") objShell.CurrentDirectory := If WorkingFolder ? WorkingFolder : primaryExe.FilePath errLevel := objShell.Run("""" . primaryExe.FileName . """ " . Parameters, 0, false) } Else errLevel := primaryExe.Run(Parameters,"","","","",1,If WorkingFolder ? WorkingFolder : "") } If errLevel ScriptError("There was a problem launching your " . (If appIsImage ? "ImageExe" : "Application") . ". Please check it is a valid executable.") } If PostLaunch { RLLog.Info("PCLauncher - PostLaunch set by user, running: " . PostLaunch) PostLaunchExe := new Process(PostLaunch) PostLaunchParameters := If (!PostLaunchParameters or PostLaunchParameters="ERROR") ? "" : PostLaunchParameters errLevel := PostLaunchExe.Run(If PostLaunchIsURL ? "" : PostLaunchParameters,"","","","",(If PostLaunchIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PostLaunch application. Please check it is a valid executable.") TimerUtils.Sleep(PostLaunchSleep) } If FadeTitle { RLLog.Info("PCLauncher - FadeTitle set by user, waiting for """ . appPrimaryWindow.WinTitle.GetWindowTitle() . """") appPrimaryWindow.Wait() appPrimaryWindow.WaitActive() } Else If AppWaitExe { RLLog.Info("PCLauncher - FadeTitle not set by user, but AppWaitExe is. Waiting for AppWaitExe: " . AppWaitExe.FileName) AppWaitExe.Process("Wait",15) If (AppWaitExe.PID = 0) ScriptError("PCLauncher - There was an error getting the Process ID of your AppWaitExe """ . AppWaitExe.FileName . """. Please try setting a FadeTitle instead.") } Else If SteamIDExe { RLLog.Info("PCLauncher - FadeTitle and AppWaitExe not set by user, but SteamIDExe was found. Waiting for SteamIDExe: " . SteamIDExe.FileFullPath) SteamIDExe.Process("Wait",15) ; wait 15 seconds for this process to launch If (SteamIDExe.PID = 0) ScriptError("PCLauncher - There was an error getting the Process ID from your SteamIDExe for """ . dbName . """. Please try setting a FadeTitle instead.") } Else If primaryExe.PID { RLLog.Info("PCLauncher - FadeTitle and AppWaitExe not set by user, but a PID for the primary application was found. Waiting for PID: " . primaryExe.PID) appPrimaryWindow.PID := primaryExe.PID ; store the PID of the primary exe into the window object appPrimaryWindow.Wait("",primaryExe.PID) ; only wait for the pid, not any other window element appPrimaryWindow.WaitActive("",primaryExe.PID) } Else RLLog.Error("PCLauncher - FadeTitle and AppWaitExe not set by user and no AppPID found from an Application, PCLauncher has nothing to wait for") If (DXWndGame = "true" and (DXWndMaximizeWindow = "aspect" or DXWndMaximizeWindow = "stretch")) appPrimaryWindow.Maximize(If (DXWndMaximizeWindow="aspect") ? "true" : "false") BezelDraw() TimerUtils.Sleep(FadeInExitSleep) ; PCLauncher setting for some stubborn games that keeps the fadeIn screen up a little longer FadeInExit() If AppWaitExe { If !FadeTitle { RLLog.Info("PCLauncher - Creating a window based on the AppWaitExe because FadeTitle was not set") appPrimaryWindow := new Window(new WindowTitle("","","","",AppWaitExe.PID)) ; instantiate AppWaitExe window object appPrimaryWindow.Wait() appPrimaryWindow.Get("ID") appPrimaryWindow.WinTitle.PID := "" ; remove PID from future window matches appPrimaryWindow.WinTitle.ID := appPrimaryWindow.ID ; inject hwnd ID so future matches use it instead } RLLog.Info("PCLauncher - Waiting for AppWaitExe """ . AppWaitExe.FileName . """ to close.") AppWaitExe.Process("WaitClose") } Else If FadeTitle { ; If fadeTitle is set and no appPID was created. RLLog.Info("PCLauncher - Waiting for FadeTitle """ . appPrimaryWindow.WinTitle.GetWindowTitle() . """ to close.") appPrimaryWindow.WaitClose() } Else If SteamIDExe { RLLog.Info("PCLauncher - Waiting for SteamIDExe """ . SteamIDExe.FileName . """ to close.") SteamIDExe.Process("WaitClose") } Else If primaryExe.PID { If !FadeTitle { RLLog.Info("PCLauncher - Creating a window based on the Primary Application """ . primaryExe.FileName . """ because FadeTitle nor AppWaitExe were set") appPrimaryWindow := new Window(new WindowTitle("","","","",primaryExe.PID)) ; instantiate primary application window object appPrimaryWindow.Wait() appPrimaryWindow.Get("ID") appPrimaryWindow.WinTitle.PID := "" ; remove PID from future window matches appPrimaryWindow.WinTitle.ID := appPrimaryWindow.ID ; inject hwnd ID so future matches use it instead } RLLog.Info("PCLauncher - Waiting for the Primary Application PID """ . primaryExe.PID . """ to close.") primaryExe.Process("WaitClose") } Else ScriptError("Could not find a proper AppWaitExe`, FadeTitle`, or AppPID (from the launched Application). Try setting either an AppWaitExe or FadeTitle so the module has something to look for.") If PostExit { RLLog.Info("PCLauncher - PostExit set by user, running: " . PostExit) PostExitExe := new Process(PostExit) PostExitParameters := If (!PostExitParameters or PostExitParameters="ERROR") ? "" : PostExitParameters errLevel := PostExitExe.Run(If PostExitIsURL ? "" : PostExitParameters,"","","","",(If PostExitIsURL ? "" : 1)) ; If this is a url, do not send params If errLevel ScriptError("There was a problem launching your PostExit application. Please check it is a valid executable.") TimerUtils.Sleep(PostExitSleep) } ; If Application is a cd/dvd image, unmount it in DT If appIsImage VirtualDrive("unmount") ; Close steam if it was not open prior to launch, not really needed anymore because module knows how to launch if steam already running now ; If (primaryExe.PID = 0) ; Run, Steam.exe -shutdown, %SteamPath% ; close steam If (DXWndGame = "true") DxwndClose() BezelExit() FadeOutExit() ExitModule() CheckSettings() { Global Application,primaryExe Global PreLaunch,PreLaunchExe,PreLaunchIsURL Global PostLaunch,PostLaunchExe,PostLaunchIsURL Global PostExit,PostExitExe,PostExitIsURL Global moduleName,appIsImage,vdDriveLetter,SteamID,OriginGame,DXWndGame,mode,AppWaitExe,SteamIDExe,FadeTitle Global modulePath,fadeIn RLLog.Info("CheckSettings - Started") ; These checks allow you to run URL and Steam browser protocol commands. Without them ahk would error out that it can't find the file. This is different than setting a SteamID but either work If (SteamID) { mode := "steam" ; setting module to use steam mode RLLog.Info("PCLauncher - SteamID is set, setting mode to: """ . mode . """") } Else If (StringUtils.SubStr(Application,1,3) = "ste") { mode := "steambp" ; setting module to use Steam Browser Protocol mode RLLog.Info("PCLauncher - Application is a Steam Browser Protocol, setting mode to: """ . mode . """") } Else If (StringUtils.SubStr(Application,1,4) = "http") { mode := "url" ; setting module to use url mode RLLog.Info("PCLauncher - Application is a URL, setting mode to: """ . mode . """") } Else If OriginGame { mode := "origin" ; setting module to use Origin mode StringUtils.BackslashCheck(primaryExe.FileFullPath,"Application") RLLog.Info("PCLauncher - Origin mode enabled. Will log in to Origin if required.") } Else If Application { mode := "standard" ; for standard launching StringUtils.BackslashCheck(primaryExe.FileFullPath,"Application") RLLog.Info("PCLauncher - Setting mode to: """ . mode . """") } Else ; error if no modes are used ScriptError("Please set an Application, SteamID, Steam Browser Protocol, or URL in " moduleName . ".ini for """ . dbName . """") If (SteamID && Application) ; do not allow 2 launching methods as module cannot know which should be used ScriptError("You are trying to use Steam and an Application, you must choose one or the other.") If ((mode = "steam" || mode = "steambp") && !AppWaitExe && !FadeTitle) { ; && fadeIn = "true") { ; If AppWaitExe or FadeTitle are defined, that will take precedence over the automatic method using the SteamIDs.ini SteamIDFile := new IniFile(modulePath . "\SteamIDs.ini") SteamIDFile.CheckFile() If !SteamID ; if this game does not have a SteamID defined StringUtils.SplitPath(Application,SteamID) ; try to grab the ID from the Application name SteamIDExe := SteamIDFile.ReadCheck(SteamID, "exe","","",1) If !SteamIDExe ; if it was still not found, error out ScriptError("You are using launching a Steam game but no way for the module to know what window to wait for after launching. Please set a AppWaitExe, FadeTitle, or make sure your SteamID and the correct exe is defined in the SteamIDs.ini",10) Else { RLLog.Info("PCLauncher - Found an exe in the SteamIDs.ini for this game: """ . SteamIDExe . """") SteamIDExe := new Process(SteamIDExe) } } Else If (mode = "url" && !AppWaitExe && !FadeTitle) ScriptError("You are using launching a URL but no way for the module to know what to window to wait for after launching. Please set a AppWaitExe or FadeTitle to your default application that gets launched when opening URLs.",10) If (appIsImage && !primaryExe.FilePath) ; if user only defined an exe for Application with no path, assume it will be found on the root dir of the image when mounted primaryExe.FilePath := vdDriveLetter . ":\" If (!primaryExe.FileName && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing filename on the end of your Application in " . moduleName . ".ini:`n" . primaryExe.FileFullPath) If (!primaryExe.FileExt && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing extension on your Application in " . moduleName . ".ini:`n" . primaryExe.FileFullPath) PreLaunchExe := AltAppCheck(PreLaunch,"PreLaunch",PreLaunchIsURL) PostLaunchExe := AltAppCheck(PostLaunch,"PostLaunch",PostLaunchIsURL) PostExitExe := AltAppCheck(PostExit,"PostExit",PostExitIsURL) If (mode = "standard") primaryExe.CheckFile("Cannot find this Application:`n" . primaryExe.FileFullPath) ; keeping this last so more descriptive errors will trigger first RLLog.Info("CheckSettings - Ended") } AltAppCheck(file,id,ByRef urlID) { If file { obj := new Process(file) urlID := If (StringUtils.SubStr(file,1,4)="http" || StringUtils.SubStr(file,1,3)="ste") ? 1:"" If urlID RLLog.Info("PCLauncher - " . id . " is a URL or Steam Browser Protocol: " . file) Else { StringUtils.BackslashCheck(obj.FileFullPath,id) obj.CheckFile("Cannot find this " . id . " application:`n" . obj.FileFullPath) } Return obj } } CloseProcess: If (ExitMethod != "InGame") { FadeOutStart() If (ExitMethod = "Process Close AppWaitExe" && AppWaitExe) { RLLog.Info("CloseProcess - ExitMethod is ""Process Close AppWaitExe""") AppWaitExe.Process("Close") } Else If (ExitMethod = "WinClose AppWaitExe" && AppWaitExe) { RLLog.Info("CloseProcess - ExitMethod is ""WinClose AppWaitExe""") AppWaitExe.Process("Exist") AppWaitWindow := new Window(new WindowTitle("","","","",AppWaitExe.PID)) AppWaitWindow.Close() } Else If (ExitMethod = "Process Close Application") { RLLog.Info("CloseProcess - ExitMethod is ""Process Close Application""") primaryExe.Process("Close") } Else If (ExitMethod = "WinClose Application" && FadeTitle) { RLLog.Info("CloseProcess - ExitMethod is ""WinClose Close Application""") appPrimaryWindow.Close() } Else If (ExitMethod = "Send Alt+F4") { RLLog.Info("CloseProcess - ExitMethod is ""Send Alt+F4""") KeyUtils.Send("!{F4}") } Else { RLLog.Info("CloseProcess - Default ExitMethod`, using ""WinClose""") appPrimaryWindow.Close() } } Return 17:06:20:649 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 17:06:20:649 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 17:06:20:649 | RL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 17:06:20:649 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 17:06:20:660 | RL | INFO | +16 | Main - Module is built 17:06:20:660 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\AutoHotkey.dll exists 17:06:20:662 | RL | DEBUG | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 6/3/2016 - 8:07:21 PM Modified: 4/20/2013 - 12:16:32 AM 17:06:20:669 | RL | INFO | +15 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 17:06:20:669 | RL | INFO | +0 | Main - Running module 17:06:20:893 | MD | INFO | +N/A | Module initialized 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Started 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 17:06:20:893 | MD | INFO | +0 | StartModule - Started 17:06:20:893 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: http://www.rlauncher.com/wiki/index.php?title=PCLauncher MAuthor: djvj MVersion: 2.2.5 MCRC: CCB5E681 iCRC: 495BB6CC MID: MSystem: "American Laser Games","Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Singstar","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project","Ultrastar","Ultrastar Deluxe","Windows Games" 17:06:20:893 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Taito Type X" 17:06:20:893 | MD | INFO | +0 | PluginInit - Started 17:06:20:893 | MD | DEBUG | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 17:06:20:893 | MD | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\RocketLauncherUI\Databases\Taito Type X\Taito Type X.xml exists 17:06:20:893 | MD | DEBUG | +0 | CheckFile - Attributes: File Size: 6372 bytes Created: 7/26/2016 - 5:46:08 PM Modified: 7/26/2016 - 5:43:57 PM 17:06:20:893 | MD | DEBUG | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 17:06:20:893 | MD | WARNING | +0 | BuildDatabaseTable - Ended - no "Game Name" found. Assigning "King of Fighters '98, The Ultimate Match" to the label "Name" 17:06:20:893 | MD | INFO | +0 | PluginInit - Ended 17:06:20:893 | MD | DEBUG | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: King of Fighters '98, The Ultimate Match 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Started 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc, 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 17:06:20:893 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 17:06:20:893 | MD | TRACE | +0 | Process.__New - Creating new process object for: "C:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe" 17:06:20:893 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe" 17:06:20:923 | MD | TRACE | +31 | File.__New - Creating new file object of: "C:\RocketLauncher\Modules\PCLauncher\Taito Type X\King of Fighters '98, The Ultimate Match.ini" 17:06:20:923 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\RocketLauncher\Modules\PCLauncher\Taito Type X.ini" 17:06:20:923 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini" 17:06:20:923 | MD | TRACE | +0 | File.Exist - This file exists: C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini 17:06:20:923 | MD | DEBUG | +0 | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "C:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini" 17:06:20:923 | MD | INFO | +0 | StartModule - Ended 17:06:20:923 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - Application: ..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat 17:06:20:953 | MD | INFO | +31 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - AppWaitExe: game.exe 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - DiscImage: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - DiscImage: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - DXWndGame: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - DXWndGame: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - DXWndMaximizeWindow: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - DXWndMaximizeWindow: (NO VALUE) 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - ExitMethod: WinClose Application 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - FadeTitle: Kof98 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - FadeInExitSleep: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - FadeInExitSleep: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - HideConsole: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - HideConsole: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - OriginGame: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - OriginGame: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - Parameters: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - Parameters: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PostLaunch: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunch: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PostLaunchParameters: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunchParameters: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PostLaunchSleep: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PostLaunchSleep: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PostExit: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PostExit: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PostExitParameters: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PostExitParameters: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PostExitSleep: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PostExitSleep: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PreLaunch: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunch: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PreLaunchParameters: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchParameters: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PreLaunchMode: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchMode: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - PreLaunchSleep: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - PreLaunchSleep: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - SteamID: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - SteamID: (NO VALUE) 17:06:20:953 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [King of Fighters '98, The Ultimate Match] - WorkingFolder: Key does not exist 17:06:20:953 | MD | INFO | +0 | RIniFile.Read - Module - WorkingFolder: (NO VALUE) 17:06:20:953 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 17:06:20:953 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 17:06:20:953 | MD | TRACE | +0 | Emulator.__New - Creating new emulator object for: "..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:953 | MD | TRACE | +0 | Process.__New - Creating new process object for: "..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:953 | MD | TRACE | +0 | File.__New - Creating new file object of: "..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:953 | MD | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:953 | MD | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:953 | MD | TRACE | +0 | Process.__New - Creating new process object for: "game.exe" 17:06:20:953 | MD | TRACE | +0 | File.__New - Creating new file object of: "game.exe" 17:06:20:963 | MD | TRACE | +0 | StringUtils.Contains - "Kof98" does not contain "ahk_class" 17:06:20:963 | MD | TRACE | +0 | Window.__New - Created: "Kof98" 17:06:20:963 | MD | TRACE | +0 | StringUtils.SubStr - Retrieved "..\" from "..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:963 | MD | TRACE | +0 | StringUtils.SubStr - Retrieved "..\T" from "..\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:20:963 | MD | INFO | +0 | File.CheckFile - Checking if "C:\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" exists 17:06:20:963 | MD | TRACE | +0 | File.Exist - This file exists: C:\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat 17:06:20:963 | MD | DEBUG | +0 | File.CheckFile - Attributes: File Size: 34 bytes Created: 7/25/2016 - 6:45:46 PM Modified: 8/3/2013 - 9:53:41 PM 17:06:20:963 | MD | TRACE | +0 | StringUtils.Contains - "standard" does not contain "steam|steambp" 17:06:20:963 | MD | INFO | +0 | PCLauncher - Launching a standard application. 17:06:20:963 | MD | TRACE | +0 | CustomFunction.PreLaunch - Starting 17:06:20:963 | MD | INFO | +0 | PreLaunch - Starting 17:06:20:963 | MD | INFO | +0 | PreLaunch - Ending 17:06:20:963 | MD | TRACE | +0 | CustomFunction.PreLaunch - Ending 17:06:20:963 | MD | INFO | +0 | Process.Run - Running: "C:\Taito type x\King of Fighters '98, The Ultimate Match\King of Fighters '98, The Ultimate Match.bat" 17:06:21:013 | MD | DEBUG | +63 | Process.Run - "King of Fighters '98, The Ultimate Match.bat" Process ID: 1520 17:06:21:013 | MD | TRACE | +0 | CustomFunction.PostLaunch - Starting 17:06:21:013 | MD | INFO | +0 | PostLaunch - Starting 17:06:21:013 | MD | INFO | +0 | PostLaunch - Ending 17:06:21:013 | MD | TRACE | +0 | CustomFunction.PostLaunch - Ending 17:06:21:013 | MD | INFO | +0 | PCLauncher - FadeTitle set by user, waiting for "Kof98" 17:06:21:013 | MD | TRACE | +0 | Window.__New - Created: "ahk_id 655832" 17:06:21:013 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 17:06:21:013 | MD | TRACE | +0 | Window.GetPos - Retrieved x:0 y:0 w: 1600 h: 1200 from "ahk_id 655832" 17:06:21:013 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 17:06:21:013 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1600 | Height: 1200 | Window HWND: 0xa01d8 | Process ID: 292 | Process Path: C:\hyperspin\HyperSpin.exe 17:06:21:013 | MD | INFO | +0 | Window.Wait - Waiting for window "Kof98" 17:06:21:363 | MD | TRACE | +343 | Window.__New - Created: "ahk_id 1114720" 17:06:21:363 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 17:06:21:363 | MD | TRACE | +0 | Window.GetPos - Retrieved x:0 y:0 w: 640 h: 480 from "ahk_id 1114720" 17:06:21:363 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 17:06:21:363 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: Kof98 | Class: Kof98 | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0x110260 | Process ID: 708 | Process Path: C:\Taito type x\King of Fighters '98, The Ultimate Match\game.exe 17:06:21:363 | MD | TRACE | +0 | Window.__New - Created: "ahk_id 1114720" 17:06:21:363 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 17:06:21:523 | MD | TRACE | +156 | Window.GetPos - Retrieved x:0 y:0 w: 640 h: 480 from "ahk_id 1114720" 17:06:21:523 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 17:06:21:523 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: Kof98 | Class: Kof98 | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0x110260 | Process ID: 708 | Process Path: C:\Taito type x\King of Fighters '98, The Ultimate Match\game.exe 17:06:21:523 | MD | INFO | +0 | Window.WaitActive - Waiting for "Kof98" 17:06:21:853 | MD | TRACE | +343 | Window.__New - Created: "ahk_id 1114720" 17:06:21:853 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 17:06:21:853 | MD | TRACE | +0 | Window.GetPos - Retrieved x:0 y:0 w: 640 h: 480 from "ahk_id 1114720" 17:06:21:853 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 17:06:21:854 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: Kof98 | Class: Kof98 | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0x110260 | Process ID: 708 | Process Path: C:\Taito type x\King of Fighters '98, The Ultimate Match\game.exe 17:06:22:089 | MD | TRACE | +234 | TimerUtils.Sleep - Sleeping for milliseconds 17:06:22:089 | MD | TRACE | +0 | CustomFunction.PostLoad - Starting 17:06:22:090 | MD | INFO | +0 | PostLoad - Starting 17:06:22:090 | MD | INFO | +0 | PostLoad - Ending 17:06:22:090 | MD | TRACE | +0 | CustomFunction.PostLoad - Ending 17:06:22:090 | MD | INFO | +0 | PCLauncher - Waiting for AppWaitExe "game.exe" to close. 17:06:22:090 | MD | INFO | +0 | Process.Process - "WaitClose" "game.exe" 17:06:22:090 | MD | TRACE | +0 | Process.GetProcessID 17:06:32:707 | MD | INFO | +10608 | CloseProcess - Started, user requested to end launched application 17:06:32:708 | MD | INFO | +0 | CloseProcess - ExitMethod is "WinClose Close Application" 17:06:32:708 | MD | TRACE | +0 | Window.Close - Closing: "Kof98" 17:06:33:106 | MD | INFO | +406 | CloseProcess - Ended 17:06:33:106 | MD | DEBUG | +0 | Process.Process - "game.exe" returned 0 and is now closed. Continuing thread. 17:06:33:106 | MD | INFO | +0 | StopGlobalUserFeatures - Starting 17:06:33:106 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 17:06:33:106 | MD | INFO | +0 | ExitModule - Started 17:06:33:106 | MD | INFO | +0 | Starting Updating Statistics: 17:06:33:106 | MD | TRACE | +0 | Total Elapsed Time in Pause in seconds: 0 17:06:33:106 | MD | TRACE | +0 | gameSectionStartTime:953618 17:06:33:106 | MD | TRACE | +0 | ElapsedTime:12 17:06:33:106 | MD | TRACE | +0 | Statistics cleared game name: King of Fighters '98, The Ultimate Match 17:06:33:146 | MD | TRACE | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 7 Last_Time_Played: Friday July 29, 2016 04:57:56 PM Average_Time_Played: 24 Total_Time_Played: 165 System_Total_Played_Time: 1500 Total_Global_Played_Time: 3498 17:06:33:146 | MD | TRACE | +0 | Updated Statistics: Number_of_Times_Played: 8 Last_Time_Played: Friday July 29, 2016 05:06:20 PM Average_Time_Played: 22 Total_Time_Played: 177 System_Total_Played_Time: 1512 Total_Global_Played_Time: 3510 17:06:33:176 | MD | INFO | +31 | Game section statistics updated. 17:06:33:176 | MD | TRACE | +0 | CustomFunction.PostExit - Starting 17:06:33:176 | MD | INFO | +0 | PostExit - Starting 17:06:33:176 | MD | INFO | +0 | PostExit - Ending 17:06:33:176 | MD | TRACE | +0 | CustomFunction.PostExit - Ending 17:06:33:176 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 17:06:33:226 | RL | INFO | +12558 | Main - Module ended, exiting RocketLauncher normally 17:06:33:226 | RL | INFO | +0 | ExitScript - Started 17:06:33:226 | RL | TRACE | +0 | StringUtils.Contains - "false" does not contain "true|kill" 17:06:33:226 | RL | TRACE | +0 | StringUtils.Contains - "false" does not contain "do_not_restore|kill_&_do_not_restore" 17:06:33:246 | RL | INFO | +16 | SystemCursor - Restoring mouse cursor 17:06:33:256 | RL | INFO | +0 | ExitScript - Restored cursor
Metalzoic Posted July 29, 2016 Posted July 29, 2016 I don't have time to look through your log, but do you have either an AppWaitExe set for each game (for most it is just game.exe, but not all) or a FadeTitle?
gigapig Posted July 29, 2016 Posted July 29, 2016 I don't have time to look through your log, but do you have either an AppWaitExe set for each game (for most it is just game.exe, but not all) or a FadeTitle? It looks like he does which could be the problem, I think I only have the one set. Or it could be something stealing focus (xpadder for instance) or the desktop options in RLui may need adjusting.
TITCHGAMER Posted July 29, 2016 Author Posted July 29, 2016 It looks like he does which could be the problem, I think I only have the one set. Or it could be something stealing focus (xpadder for instance) or the desktop options in RLui may need adjusting. Which options do i need to change ile give them a shot. Cheers 47 ile try that.
TITCHGAMER Posted July 29, 2016 Author Posted July 29, 2016 Tried your idea 47 still the same. Also tried deleting the wait.exe and fade title still the same. Also just to add shouldn't be x padder i dont use it.
TITCHGAMER Posted August 1, 2016 Author Posted August 1, 2016 Anymore idea guys n gals? Still got problems with these :s Also for some reason my regain focus fix for the vertical games (Raiden etc) seems to of stopped working :s Worked fine before using the restore and click option coupled with the regain focus ahk script.
