Can't enter any sub-wheel
David7065
I've been having this issue for a while now and decided to re-download Hyperspin and start from scratch. I've looked around the forums and most of the threads state that the issue is not having a sound driver installed. I can hear everything Hyperspin is doing and upon clicking "Games", which is the only sub-wheel I have added, it returns to the Main Menu. Now all I did aside from what the default installation did was create a new database folder called 'Games' with the original 'Main Menu' xml renamed to Games inside of the folder. I used HyperHQ to make the only thing on the Main Menu the 'Games' sub-wheel. And there are no current filters set, such as only wheels with themes. Here's the log:
11:48:17 AM | HyperSpin Started
11:48:17 AM | Going FullScreen
11:48:17 AM | Checking for updates
11:48:17 AM | Update Check Complete
11:48:17 AM | Startup program unavailable
11:48:17 AM | Error intializing joysticks
11:48:17 AM | Menu Mode is multi
11:48:17 AM | Loading Main Menu.xml
11:48:17 AM | Main Menu.xml successfully loaded
11:48:18 AM | Main Menu wheel loaded successfully
11:48:21 AM | Loading Games.xml
11:48:21 AM | Loading Main Menu.xml
11:48:21 AM | No Games found in current filter
11:48:21 AM | Main Menu.xml successfully loaded
11:48:21 AM | Main Menu wheel loaded successfully
11:48:23 AM | Loading Games.xml
11:48:24 AM | Loading Main Menu.xml
11:48:24 AM | No Games found in current filter
11:48:24 AM | Main Menu.xml successfully loaded
11:48:24 AM | Main Menu wheel loaded successfully
11:48:27 AM | Exit program unavailable
11:48:27 AM | Quiting Hyperspin
11:48:27 AM | Bye!
Any help would be greatly appreciated!! :o
Why in the world would you want to put everything from the main menu inside one wheel and name it games? The problem with this setup is how is hyperspin to know the file ext? Hyperspin was not designed to be setup like this.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
A boy stuck in a mans body
That setup is the worst idea I have ever heard.
Also your comment about sound drivers is incorrect. There is an issue with HyperSpin that is caused by not having something plugged into the speakers. That is all.
In my signature you will find the How to Install HyperSpin Tutorial.
If you don't want to use HyperSpin and HLHQ in the way it was intended you won't get support as setting up something that way is nuts.
Start from scratch again cause your current config won't do squat. :P
11:48:27 AM | Bye!
The main menu XML only has system names, it does not have any games by default. You can't just take the Main Menu XML and use it as a sub wheel XML.
To make things worse the XML formatting from the Main Menu and the formatting used for sub menu wheels is completely different.
Hyperspin quit on you because it was not able to find any games in your "Games" XML.
Actually this is incorrect, the bug can occur if you have either no speakers, or no sound driver.
I was setting it up like this because, (correct me if I'm wrong), I believe Hyperspin can be used for more than just emulators. You could practically run anything from it using batch files correctly. Which I was planning to use the other sub-wheels on the main menu for Movies or various things like that. 32assassin, I deleted all of the system names and replaced it with Games as those are all just sub-wheels too aren't they? And there isn't any way to make other sub-wheels with systems in it or other sub-wheels within the main menu sub-wheels? Sorry if I wrote it out as confusing.
  • 3 months later...
Well I'm having the same issue except I have speakers connected and windows sound works fine.
I don't have a headphone jack, just line in, speaker out and mic in.
