rfancella Posted April 25, 2014 Author Posted April 25, 2014 Some bezels here, all 16:9, just sidebars, no top or bottom, i upload to "/Upload Here/_HyperLaunch Media/Bezels/Submissions Open/Knewlife" for aprobal:Amstrad GX4000 Bally Astrocade ColecoVision Casio PV-1000 Entex Adventure Vision Someone knows where to upload FADE media? Sweeet!! Thank you Knewlife! I put a folder in _HyperLaunch Media/Fade... If you would like, put it there. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted April 25, 2014 Posted April 25, 2014 Ok I'am adding bezels to all my systems, so the ones that i cant find... i will create them will upload the fades when i can thanks FADE SCREENS: Another Bezels: Emerson Arcadia 2001 DICE Fairchild Channel F EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
rfancella Posted April 27, 2014 Author Posted April 27, 2014 Ok I'am adding bezels to all my systems, so the ones that i cant find... i will create them will upload the fades when i can thanks Thanks so muche Knewlife! All the bezels have been moved to Submitted Final. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted May 3, 2014 Posted May 3, 2014 Sega Model 2 EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
knewlife Posted May 9, 2014 Posted May 9, 2014 2 More: Nintendo Famicom Nintendo Famicom Disk System Uploaded to FTP:/Upload Here/_HyperLaunch Media/Bezels/Submissions Open EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
rfancella Posted May 9, 2014 Author Posted May 9, 2014 2 More:Nintendo Famicom [ATTACH=CONFIG]41014[/ATTACH] Nintendo Famicom Disk System [ATTACH=CONFIG]41015[/ATTACH] Uploaded to FTP:/Upload Here/_HyperLaunch Media/Bezels/Submissions Open Very Cool!!! I will get moved today!! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted May 29, 2014 Posted May 29, 2014 I noted that some of my bezels (Those of old systems that i emulate with mess) present some small empty spaces at the sides. I corrected those bezels and can upload then again but want to know if it just happens to me (i use a bezel i found in the FTP as base for the ini and png so i think it should work perfectly) or they are really wrong. Thanks EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
rfancella Posted May 29, 2014 Author Posted May 29, 2014 I noted that some of my bezels (Those of old systems that i emulate with mess) present some small empty spaces at the sides. I corrected those bezels and can upload then again but want to know if it just happens to me (i use a bezel i found in the FTP as base for the ini and png so i think it should work perfectly) or they are really wrong.Thanks I checked the Casio PV-1000 and Colecovision on my 16x10 setup. It does show a small gap on the right side between the emu window and the bezel. If you could upload your changes to the Submissions Open folder, I'll move them ASAP. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted May 29, 2014 Posted May 29, 2014 Ok they are for 16:9 but with the small fix i made it should work ok for you as they did for my. will uplaod when get home EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
relic Posted May 29, 2014 Posted May 29, 2014 Ok they are for 16:9 but with the small fix i made it should work ok for you as they did for my. will uplaod what fix brother 100%
knewlife Posted May 29, 2014 Posted May 29, 2014 I means the corrected bezels Sent from my Nokia Lumia 520 using Tapatalk EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
relic Posted May 29, 2014 Posted May 29, 2014 knewlife I means the corrected bezels and geniously rfan explained it to me clearly thanks for fixing the module bro your all legends 100%
knewlife Posted May 29, 2014 Posted May 29, 2014 There you go: all fixed bezels uploaded to the FTP, i think i didnt forget any. EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
rfancella Posted May 29, 2014 Author Posted May 29, 2014 There you go:all fixed bezels uploaded to the FTP, i think i didnt forget any. Thank you so much! I'll get them checked out and moved. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 4, 2014 Author Posted June 4, 2014 Hi guys, Two new bezels added by Gigapig for your Daphne setup. Check out the mastery! Thanks Gig for the contribution! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted June 4, 2014 Posted June 4, 2014 I add a fase screen for casio pv1000 to the submission folder Also will upload a pretty much better dice bezel... No hurry as I can't make it work with bezels.... Someone can? EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
rfancella Posted June 4, 2014 Author Posted June 4, 2014 I add a fase screen for casio pv1000 to the submission folderAlso will upload a pretty much better dice bezel... No hurry as I can't make it work with bezels.... Someone can? Sweet! Thanks, I will check them and move. Mine works just fine using your bezel. If you open up the module (Dice.ahk) in notepad and remove the ";" from the front of the following lines, it should work fine (not sure why they were commented out). Line 19 "; BezelGUI" Line 25 "; BezelStart()" Line 41 "; BezelDraw()" Line 42 "; Sleep, 1000" Line 47 "; BezelExit()" Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 4, 2014 Author Posted June 4, 2014 I add a fase screen for casio pv1000 to the submission folderAlso will upload a pretty much better dice bezel... No hurry as I can't make it work with bezels.... Someone can? Is your Casio submission a Fade or Bezel? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted June 4, 2014 Posted June 4, 2014 Casio is a fade This is the DICE bezel... i think it looks better not all black, wath you think? EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
rfancella Posted June 4, 2014 Author Posted June 4, 2014 Casio is a fade Sweet! Thanks so much! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 6, 2014 Author Posted June 6, 2014 Casio is a fade This is the DICE bezel... i think it looks better not all black, wath you think? [ATTACH=CONFIG]41691[/ATTACH] I think that looks good my friend! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 6, 2014 Author Posted June 6, 2014 Hello all! Another FTP update. Gigapig has uploaded a couple more 16x9 Daphne bezels. This time for Space Ace: And an ASA (All Screen Aspects) bezel for GCE Vectrex: Thanks Gig for the contributions!! This project could not be possible without people like you!! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
rfancella Posted June 6, 2014 Author Posted June 6, 2014 Another large update today! Only this time in the Fade folder. Moved fade images for the following systems: Bally Astrocade Casio PV-1000 DICE Emerson Arcadia 2001 Thanks to Knewlife for the great contributions!! Moved fade images for Taito Type X! Thanks Gigapig for a total of 144 fade images!! Wow! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
noshgar Posted June 9, 2014 Posted June 9, 2014 I am working on a new bezel pack for 1280x960 4:3. Check out my thread over at HyperLaunch forums for details http://www.hyperlaunch.net/forum/showthread.php?89-New-bezels-on-the-way&p=840#post840
rfancella Posted June 9, 2014 Author Posted June 9, 2014 I am working on a new bezel pack for 1280x960 4:3. Check out my thread over at HyperLaunch forums for details http://www.hyperlaunch.net/forum/showthread.php?89-New-bezels-on-the-way&p=840#post840 Very cool Nosh!!! I am watching that thread as well!!! Great job. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
