viper360 Posted September 21, 2016 Posted September 21, 2016 Hey guys madnefen not loading rom through retroarch masterv1 Could this be due to a bad cue file or is it a retroarch issue. Id use a different emulator but i cant seem to get a good fit with the bezels and not too kean on widescreen any help is appreciated thanks
kylecp1979 Posted September 21, 2016 Posted September 21, 2016 open the cue file with notepad and see if it matches the bin file name and make sure you have the right bios.
thatman84 Posted September 21, 2016 Posted September 21, 2016 Try putting the cue file as the 1st extension in your settings file. Seen that on other things before Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
viper360 Posted September 21, 2016 Author Posted September 21, 2016 So iv checked the names their ok and placed the correct bios file in my systems folder but still no joy the error im getting from retroarch is ::rarch_log_libretro:: ::(libretro Error):: error opening file no such file in directry. Rocketlauncher error is please make sure you have the correct emulator for this moduel. Check moduel notes but i cant seem to find what im looking for in their. Thanks for any help
viper360 Posted September 21, 2016 Author Posted September 21, 2016 i think it sees the cue file but no boot ill post more info tomorrow when i dinish work if i can cheers guys
viper360 Posted September 21, 2016 Author Posted September 21, 2016 Try putting the cue file as the 1st extension in your settings file. Seen that on other things before
viper360 Posted September 21, 2016 Author Posted September 21, 2016 Its the retroarch emulator mate that is missing something or another another not the hyperspin side i think maybe i should check retroarch forums too tomoz cheers any way
thcdgaf Posted September 21, 2016 Posted September 21, 2016 Its the retroarch emulator mate that is missing something or another another not the hyperspin side i think maybe i should check retroarch forums too tomoz cheers any way do you have latest retroarch 1.3.6?
viper360 Posted September 22, 2016 Author Posted September 22, 2016 Not sure but it wont be the latest one as i got it from simply austins youtube vid should i rip retroarch out and start again
viper360 Posted September 22, 2016 Author Posted September 22, 2016 Still no joy should i start a fresh retroarch
BATTLEDONKEY Posted September 22, 2016 Posted September 22, 2016 If it says that it can't find the correct file it sounds like the .cue is pointing to the wrong .bin file but if u say it's correct then we will move on. Yes it is a very old version of retroarch and it could still be a number of things. Try loading a rom using just retroarch, without hyperspin/rocketlauncher on, does it load, crash, throw an error? Is it all games, are you sure the bios is good and named correct? Do u have the correct core downloaded and configured, have u set the default core in the rocketlauncher module section for ps1? Do u have all the proper .dll installed to run retroarch I.e. visual studio, direct x, etc... I don't remember which ones are needed but a quick search will net u the answers. If all else fails download the latest version of retroarch into an empty folder and start fresh to see if the results are different. You can have multiple versions of retroarch installed in different folders if you need to test things without risk of screwing things up in what u know is working properly, just remember to copy over ur system folder with bios files to the new versions
viper360 Posted September 23, 2016 Author Posted September 23, 2016 Bios is ok as iv tryed all these above and through other emulators got correct direct x installed and so on will try the latest version of retroarch tonight fingers crossed it will work. will copy all systems folder as you say thanks for that as this may have took longer if i forgotten lol
kylecp1979 Posted September 23, 2016 Posted September 23, 2016 May sure your bios are in the system folder and named correctly or retroarch won't find them  Here is a list of the ones I have not sure if you need them all  scph5500.binscph5501.binscph5502.binscph7001.binscph7502.binscph1001.bin
viper360 Posted September 23, 2016 Author Posted September 23, 2016 Yippee it works in the new install of retroarch now
viper360 Posted September 23, 2016 Author Posted September 23, 2016 Its not a retroarch error that i know
kylecp1979 Posted September 24, 2016 Posted September 24, 2016 What error are you getting? Â You might need to tell RL what core you are using. Â click on your playstation system in RL go to the module tab > edit global module settings > sony playstation tab > libretro core > then find the core your usuing . Cores are stored in the core folder of retroarch. Â If your not sure of the name of the core name load up retroarch and your core then go to information > core information it will tell you the name of the core also it will tell you what extension will work with that core.
viper360 Posted September 24, 2016 Author Posted September 24, 2016 Ok so i try'd this still no joy i must not have the correct moduel even tho im using retroarch moduel now im baffeld
viper360 Posted September 24, 2016 Author Posted September 24, 2016 Its a nightly build of retroarch could this be the problem? My core is 1.3.6 - Mednafen PSX v0.9.32 core name mednafen_psx_libretro.dll
viper360 Posted September 25, 2016 Author Posted September 25, 2016 That error from RL just means that the RA is crashing and one of the possible causes is a wrong emu version, but that's not very likely with RA. The more likely cause is a bad setting in RL that's causing RA to crash since you have it working outside RL. One possible cause is not having 7z enabled if you're using compressed roms, which means the 7z is getting sent to RA instead of the cue inside it causing it to crash. Check that first and if that's not it post your RL Troubleshooting log. To generate that log open RLUI and on the General Settings -> RocketLauncher tab set the Logging Level to Troubleshooting. Then run a game through RLUI and post the RocketLauncher.log file that's generated in your RocketLauncher folder here.
viper360 Posted September 25, 2016 Author Posted September 25, 2016 hey mate i try'd roms with 7z with out 7z. 7z roms unziped roms but still no difference, here is my log i did cut some out because it looked very large.   08:58:37:556 | MD |    INFO  | +0   | LoadProperties - Started and loading this cfg into memory: F:\HyperSpin\Emulators\RetroArch\retroarch-core-options.cfg 08:58:37:556 | MD |    INFO  | +0   | LoadProperties - Ended 08:58:37:556 | MD |   TRACE  | +0   | StringUtils.Contains - "mednafen_psx_libretro" does not contain "^(mame|mess|ume)" 08:58:37:556 | MD |   TRACE  | +0   | StringUtils.Contains - "LibRetro_PSX" does not contain "LibRetro_N64" 08:58:37:556 | MD |   TRACE  | +0   | StringUtils.Contains - "LibRetro_PSX" does not contain "LibRetro_NES" 08:58:37:556 | MD |   TRACE  | +0   | StringUtils.Contains - "LibRetro_PSX" does not contain "LibRetro_LYNX" 08:58:37:556 | MD |   TRACE  | +0   | StringUtils.Contains - "LibRetro_PSX" contains "LibRetro_PSX" at position 1 08:58:37:556 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - PSX_CD_Image_Cache: Section does not exist 08:58:37:556 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - PSX_CD_Image_Cache: Key does not exist 08:58:37:556 | MD |    INFO  | +0   | RIniFile.Read - Module - PSX_CD_Image_Cache: "enabled" (DEFAULT) 08:58:37:556 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - PSX_Memcard_Handling: Section does not exist 08:58:37:593 | MD |   TRACE  | +31   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - PSX_Memcard_Handling: Key does not exist 08:58:37:593 | MD |    INFO  | +0   | RIniFile.Read - Module - PSX_Memcard_Handling: "libretro" (DEFAULT) 08:58:37:593 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - PSX_Dualshock_Analog_Toggle: Section does not exist 08:58:37:593 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - PSX_Dualshock_Analog_Toggle: Key does not exist 08:58:37:593 | MD |    INFO  | +0   | RIniFile.Read - Module - PSX_Dualshock_Analog_Toggle: "enabled" (DEFAULT) 08:58:37:593 | MD |   DEBUG  | +0   | WriteProperty - Writing - beetle_psx_cdimagecache: "enabled" 08:58:37:593 | MD |   DEBUG  | +0   | WriteProperty - Writing - beetle_psx_use_mednafen_memcard0_method: "libretro" 08:58:37:593 | MD |   DEBUG  | +0   | WriteProperty - Writing - beetle_psx_analog_toggle: "enabled" 08:58:37:593 | MD |    INFO  | +0   | SaveProperties - Started and saving this cfg to disk: F:\HyperSpin\Emulators\RetroArch\retroarch-core-options.cfg 08:58:37:593 | MD |    INFO  | +0   | SaveProperties - Ended 08:58:37:593 | MD |   TRACE  | +0   | File.__New - Creating new file object of: "F:\Roms\Sony Playstation\007 - The World Is Not Enough (USA)\.m3u" 08:58:37:593 | MD |   TRACE  | +0   | StringUtils.Contains - "LibRetro_PSX" contains "LibRetro_PSX" at position 1 08:58:37:593 | MD |   TRACE  | +0   | StringUtils.Contains - "mednafen_psx_libretro" does not contain "^(mame|mess|ume)" 08:58:37:593 | MD |    INFO  | +0   | Module - Retroarch standard mode enabled 08:58:37:593 | MD |   TRACE  | +0   | StringUtils.Contains - "LibRetro_PSX" does not contain "LibRetro_PCECD|LibRetro_TGCD" 08:58:37:593 | MD |   DEBUG  | +0   | WriteProperty - Writing - video_rotation: 0 08:58:37:625 | MD |   TRACE  | +31   | StringUtils.Contains - "LibRetro_PSX" contains "LibRetro_PSX" at position 1 08:58:37:625 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P1_Controller_Type: Section does not exist 08:58:37:625 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P1_Controller_Type: Key does not exist 08:58:37:625 | MD |    INFO  | +0   | RIniFile.Read - Module - P1_Controller_Type: 517 (DEFAULT) 08:58:37:625 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p1: 517 08:58:37:625 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P2_Controller_Type: Section does not exist 08:58:37:625 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P2_Controller_Type: Key does not exist 08:58:37:625 | MD |    INFO  | +0   | RIniFile.Read - Module - P2_Controller_Type: 517 (DEFAULT) 08:58:37:625 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p2: 517 08:58:37:625 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P3_Controller_Type: Section does not exist 08:58:37:625 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P3_Controller_Type: Key does not exist 08:58:37:625 | MD |    INFO  | +0   | RIniFile.Read - Module - P3_Controller_Type: 517 (DEFAULT) 08:58:37:656 | MD |   DEBUG  | +32   | WriteProperty - Writing - input_libretro_device_p3: 517 08:58:37:725 | MD |   TRACE  | +78   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P4_Controller_Type: Section does not exist 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P4_Controller_Type: Key does not exist 08:58:37:725 | MD |    INFO  | +0   | RIniFile.Read - Module - P4_Controller_Type: 517 (DEFAULT) 08:58:37:725 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p4: 517 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P5_Controller_Type: Section does not exist 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P5_Controller_Type: Key does not exist 08:58:37:725 | MD |    INFO  | +0   | RIniFile.Read - Module - P5_Controller_Type: 517 (DEFAULT) 08:58:37:725 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p5: 517 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P6_Controller_Type: Section does not exist 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P6_Controller_Type: Key does not exist 08:58:37:725 | MD |    INFO  | +0   | RIniFile.Read - Module - P6_Controller_Type: 517 (DEFAULT) 08:58:37:725 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p6: 517 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P7_Controller_Type: Section does not exist 08:58:37:725 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P7_Controller_Type: Key does not exist 08:58:37:725 | MD |    INFO  | +0   | RIniFile.Read - Module - P7_Controller_Type: 517 (DEFAULT) 08:58:37:725 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p7: 517 08:58:37:756 | MD |   TRACE  | +31   | RIniFile.Read - Module {GlobalModuleIni} - [007 - The World Is Not Enough (USA)] - P8_Controller_Type: Section does not exist 08:58:37:756 | MD |   TRACE  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [sony PlayStation] - P8_Controller_Type: Key does not exist 08:58:37:793 | MD |    INFO  | +31   | RIniFile.Read - Module - P8_Controller_Type: 517 (DEFAULT) 08:58:37:793 | MD |   DEBUG  | +0   | WriteProperty - Writing - input_libretro_device_p8: 517 08:58:37:793 | MD |    INFO  | +0   | Module - Saving changed settings to: "F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg" 08:58:37:825 | MD |    INFO  | +31   | SaveProperties - Started and saving this cfg to disk: F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg 08:58:37:872 | MD |    INFO  | +47   | SaveProperties - Ended 08:58:37:872 | MD |   TRACE  | +0   | File.__New - Creating new file object of: "F:\HyperSpin\Emulators\RetroArch\srm\Sony PlayStation" 08:58:37:872 | MD |   TRACE  | +0   | Folder.__New - Created new folder object of: "F:\HyperSpin\Emulators\RetroArch\srm\Sony PlayStation" 08:58:37:909 | MD |   TRACE  | +47   | File.__New - Creating new file object of: "F:\HyperSpin\Emulators\RetroArch\save\Sony PlayStation" 08:58:37:909 | MD |   TRACE  | +0   | Folder.__New - Created new folder object of: "F:\HyperSpin\Emulators\RetroArch\save\Sony PlayStation" 08:58:37:909 | MD |   TRACE  | +0   | File.Exist - This folder exists: F:\HyperSpin\Emulators\RetroArch\srm\Sony PlayStation 08:58:37:909 | MD |   TRACE  | +0   | File.Exist - This folder exists: F:\HyperSpin\Emulators\RetroArch\save\Sony PlayStation 08:58:37:909 | MD |   TRACE  | +0   | StringUtils.Contains - "mednafen_psx_libretro" does not contain "^(mame|mess|ume)" 08:58:37:909 | MD |   TRACE  | +0   | CustomFunction.PreLaunch - Starting 08:58:37:909 | MD |   TRACE  | +0   | CustomFunction.PreLaunch - Ending 08:58:37:909 | MD |    INFO  | +0   | Process.Run - Running: F:\HyperSpin\Emulators\RetroArch\retroarch.exe  "F:\Roms\Sony Playstation\007 - The World Is Not Enough (USA)\007 - The World Is Not Enough (USA).bin" -f -c "F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg" -L "F:\HyperSpin\Emulators\RetroArch\cores\mednafen_psx_libretro.dll" -s "F:\HyperSpin\Emulators\RetroArch\srm\Sony PlayStation\007 - The World Is Not Enough (USA).srm" -S "F:\HyperSpin\Emulators\RetroArch\save\Sony PlayStation\007 - The World Is Not Enough (USA).state" 08:58:37:992 | MD |   DEBUG  | +78   | Process.Run - "retroarch.exe  "F:\Roms\Sony Playstation\007 - The World Is Not Enough (USA)\007 - The World Is Not Enough (USA).bin" -f -c "F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg" -L "F:\HyperSpin\Emulators\RetroArch\cores\mednafen_psx_libretro.dll" -s "F:\HyperSpin\Emulators\RetroArch\srm\Sony PlayStation\007 - The World Is Not Enough (USA).srm" -S "F:\HyperSpin\Emulators\RetroArch\save\Sony PlayStation\007 - The World Is Not Enough (USA).state"" Process ID: 11168 08:58:37:993 | MD |   TRACE  | +0   | CustomFunction.PostLaunch - Starting 08:58:37:994 | MD |   TRACE  | +0   | CustomFunction.PostLaunch - Ending 08:58:37:994 | MD |   TRACE  | +0   | Window.__New - Created: "ahk_id 6292510" 08:58:37:994 | MD |   TRACE  | +0   | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 08:58:37:994 | MD |   TRACE  | +0   | Window.GetPos - Retrieved x:-11 y:-11 w: 1846 h: 988 from "ahk_id 6292510" 08:58:37:994 | MD |   TRACE  | +0   | MiscUtils.DetectHiddenWindows - Mode changed to "On" 08:58:37:994 | MD |   DEBUG  | +0   | MiscUtils.GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.7 [ FE = HyperSpin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;725c7f2b-37ac-49e4-ba17-4a4fa5fb6ed5] | State: 1 | X: -11 | Y: -11 | Width: 1846 | Height: 988 | Window HWND: 0x60041e | Process ID: 408 | Process Path: F:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe 08:58:37:994 | MD |    INFO  | +0   | Window.Wait - Waiting for window "RetroArch ahk_class RetroArch" 08:59:07:988 | MD |   TRACE  | +30000 | Window.__New - Created: "ahk_id 6292510" 08:59:08:305 | MD |   TRACE  | +313  | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 08:59:08:305 | MD |   TRACE  | +0   | Window.GetPos - Retrieved x:-11 y:-11 w: 1846 h: 988 from "ahk_id 6292510" 08:59:08:305 | MD |   TRACE  | +0   | MiscUtils.DetectHiddenWindows - Mode changed to "On" 08:59:08:305 | MD |   DEBUG  | +0   | MiscUtils.GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.7 [ FE = HyperSpin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;725c7f2b-37ac-49e4-ba17-4a4fa5fb6ed5] | State: 1 | X: -11 | Y: -11 | Width: 1846 | Height: 988 | Window HWND: 0x60041e | Process ID: 408 | Process Path: F:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 08:59:08:305 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:08:336 | MD |   TRACE  | +31   | XHotkeyTableCreation - Ended 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7" 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 08:59:08:336 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:08:367 | MD |   TRACE  | +31   | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError" 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:08:367 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:08:752 | MD |   DEBUG  | +391  | ScriptError - Playing error sound: error11.mp3 08:59:20:762 | MD |   TRACE  | +12000 | XHotkeyTableCreation - Started 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc" 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:20:762 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabling extended Hotkey method for key(s): "~1joy7" 08:59:20:815 | MD |   TRACE  | +62   | XHotkeyTableCreation - Post loop 12 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Started 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - KeyGroup ~1joy7 is in TableKeyGroups ~Esc,~1joy7,~NumpadAdd,PrintScreen,~e&~t, 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 10 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 11 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy7" to call a group label 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Post loop 12 check 08:59:20:815 | MD |   TRACE  | +0   | XHotkeyTableCreation - Ended 08:59:20:846 | MD |   ERROR  | +32   | ScriptError - There was an error waiting for the window "RetroArch ahk_class RetroArch". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 08:59:20:846 | MD |    INFO  | +0   | ExitModule - Started 08:59:20:846 | MD |    INFO  | +0   | Starting Updating Statistics: 08:59:20:846 | MD |   TRACE  | +0   | Total Elapsed Time in Pause in seconds: 0 08:59:20:846 | MD |   TRACE  | +0   | gameSectionStartTime:75695953 08:59:20:846 | MD |   TRACE  | +0   | ElapsedTime:43 08:59:20:846 | MD |   TRACE  | +0   | Statistics cleared game name: 007 - The World Is Not Enough 08:59:20:915 | MD |   TRACE  | +62   | Loaded game statistics from ini files: Number_of_Times_Played: 46 Last_Time_Played: Sunday September 25, 2016 08:54:30 AM Average_Time_Played: 48 Total_Time_Played: 2204 System_Total_Played_Time: 7834 Total_Global_Played_Time: 37405 08:59:20:915 | MD |   TRACE  | +0   | Updated Statistics: Number_of_Times_Played: 47 Last_Time_Played: Sunday September 25, 2016 08:58:37 AM Average_Time_Played: 48 Total_Time_Played: 2247 System_Total_Played_Time: 7877 Total_Global_Played_Time: 37448 08:59:21:015 | MD |    INFO  | +94   | Game section statistics updated. 08:59:21:015 | MD |   TRACE  | +0   | CustomFunction.PostExit - Starting 08:59:21:015 | MD |   TRACE  | +0   | CustomFunction.PostExit - Ending 08:59:21:015 | MD |    INFO  | +0   | ExitModule - Ended End of Module Logs 08:59:21:062 | RL |    INFO  | +44578 | Main - Module ended, exiting RocketLauncher normally 08:59:21:062 | RL |    INFO  | +0   | ExitScript - Started 08:59:21:062 | RL |   DEBUG  | +0   | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 08:59:21:062 | RL |   DEBUG  | +0   | Registry.Read - Registry Read finished, returning 0 08:59:21:062 | RL |   TRACE  | +0   | StringUtils.Contains - "false" does not contain "true|kill" 08:59:21:062 | RL |    INFO  | +0   | ExitScript - Restoring taskbar 08:59:21:062 | RL |   TRACE  | +0   | Window.__New - Created: "ahk_class Shell_TrayWnd" 08:59:21:078 | RL |   TRACE  | +15   | Window.__New - Created: "Start ahk_class Button" 08:59:21:078 | RL |   TRACE  | +0   | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 08:59:21:178 | RL |   TRACE  | +110  | Window.Show - Unhiding window "Start ahk_class Button" 08:59:21:199 | RL |    INFO  | +15   | SystemCursor - Restoring mouse cursor 08:59:21:215 | RL |    INFO  | +16   | ExitScript - Restored cursor [/code]
viper360 Posted September 25, 2016 Author Posted September 25, 2016 thanks for ur help up to now guys much appreciated
viper360 Posted September 25, 2016 Author Posted September 25, 2016 Dam this worked and did fix it for 1 boot so i tryed to see if it would work if i changed it to 7z so i enabled bezel,fade and 7z then it did not work so i set everything back to how i had it before and now i dont get a boot from retroarch so deleted retroarch started angain and nothing it just sits on rocketlauncher screen awaiting emulator my head why did i do that grrr
viper360 Posted September 25, 2016 Author Posted September 25, 2016 hey iv got it working again but on cirtain cames im still getting the same error and a runtime error too ill post log if anyone can give me any info thanks
viper360 Posted September 26, 2016 Author Posted September 26, 2016  21:00:59:083 | RL |    INFO  | +N/A  | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 21:00:59:415 | RL |    INFO  | +328  | Main - System Specs: RocketLauncher Dir: F:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 8140.04 MB Free Memory: 5317.81 MB Used Memory: 2822.227 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GTX 970 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 10.18.13.5940 Sound 1 Device: Realtek High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: NVIDIA High Definition Audio Sound 3 Status: Enabled OS Language: English_United_States System Locale: en-GB Formats Locale: en-GB Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: ~ HIGHDPIAWARE Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1824x1026 (1824x966 work) [32bit] [60hz] [Landscape]  (Primary) Current AHK Desktop Width: 1824 Current AHK Desktop Height: 1026 Monitor #1 DPI: 150 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 21:00:59:415 | RL |    INFO  | +0   | CheckFile - Checking if F:\RocketLauncher\RocketLauncher.exe exists 21:00:59:415 | RL |    INFO  | +0   | Main - Raw CLI received: "-s Sony PlayStation -r 2Xtreme (USA) -f F:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1" 21:00:59:416 | RL |    INFO  | +0   | Main - Loading Front End Plugin: "HyperSpin" 21:00:59:416 | RL |    INFO  | +0   | Main - RocketLauncher received "Sony PlayStation" and "2Xtreme (USA)" 21:00:59:421 | RL |    INFO  | +0   | Main - Did not find a "F:\RocketLauncher\Settings\Sony PlayStation\Game Options.ini" file, skipping any game-specific options. 21:00:59:421 | RL |    INFO  | +0   | Main - 2Xtreme (USA) is using the default emulator: RetroArch 21:00:59:421 | RL |    INFO  | +0   | Main - Checking for a [RetroArch] section in F:\RocketLauncher\Settings\Sony PlayStation\Emulators.ini 21:00:59:422 | RL |    INFO  | +0   | Main - Checking for a [RetroArch] section in F:\RocketLauncher\Settings\Global Emulators.ini 21:00:59:422 | RL |    INFO  | +0   | Main - Found [RetroArch] in F:\RocketLauncher\Settings\Global Emulators.ini 21:00:59:423 | RL |    INFO  | +0   | CheckFile - Checking if F:\RocketLauncher\Modules\RetroArch\RetroArch.ahk exists 21:00:59:427 | RL |    INFO  | +16   | Main - CRC Check - CRC matches, this is an official unedited module. 21:00:59:427 | RL |    INFO  | +0   | Main - 2Xtreme (USA) will use module: F:\RocketLauncher\Modules\RetroArch\RetroArch.ahk 21:00:59:431 | RL |  WARNING  | +0   | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "F:\RocketLauncher\Settings\Global RocketLauncher.ini" 21:00:59:431 | RL |  WARNING  | +0   | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "F:\RocketLauncher\Settings\Sony PlayStation\RocketLauncher.ini" 21:00:59:504 | RL |    INFO  | +78   | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 21:00:59:508 | RL |    INFO  | +0   | CheckFile - Checking if F:\HyperSpin\Emulators\RetroArch\retroarch.exe exists 21:00:59:509 | RL |    INFO  | +0   | Main - INI Keys read 21:00:59:510 | RL |    INFO  | +0   | CheckFile - Checking if F:\RocketLauncher\Module Extensions\7z.exe exists 21:00:59:511 | RL |    INFO  | +0   | CheckFile - Checking if F:\RocketLauncher\Module Extensions\7z.dll exists 21:00:59:520 | RL |    INFO  | +16   | Main - "2Xtreme (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 21:00:59:520 | RL |    INFO  | +0   | CheckPaths - Started 21:00:59:520 | RL |    INFO  | +0   | CheckPaths - Looking for rom: F:\Roms\Sony Playstation\2Xtreme (USA).7z 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom by name in subfolder: F:\Roms\Sony Playstation\2Xtreme (USA)\2Xtreme (USA).7z 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom by extension: F:\Roms\Sony Playstation\2Xtreme (USA)\*.7z 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom: F:\Roms\Sony Playstation\2Xtreme (USA).rar 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom by name in subfolder: F:\Roms\Sony Playstation\2Xtreme (USA)\2Xtreme (USA).rar 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom by extension: F:\Roms\Sony Playstation\2Xtreme (USA)\*.rar 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom: F:\Roms\Sony Playstation\2Xtreme (USA).zip 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom by name in subfolder: F:\Roms\Sony Playstation\2Xtreme (USA)\2Xtreme (USA).zip 21:00:59:521 | RL |    INFO  | +0   | CheckPaths - Looking for rom by extension: F:\Roms\Sony Playstation\2Xtreme (USA)\*.zip 21:00:59:522 | RL |    INFO  | +0   | CheckPaths - Looking for rom: F:\Roms\Sony Playstation\2Xtreme (USA).cue 21:00:59:522 | RL |    INFO  | +0   | CheckPaths - Looking for rom by name in subfolder: F:\Roms\Sony Playstation\2Xtreme (USA)\2Xtreme (USA).cue 21:00:59:522 | RL |    INFO  | +0   | CheckPaths - Found rom by matching name in subfolder: F:\Roms\Sony Playstation\2Xtreme (USA)\2Xtreme (USA).cue 21:00:59:522 | RL |    INFO  | +0   | CheckPaths - Ended 21:00:59:523 | RL |    INFO  | +0   | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;----------------------------------------------------------------------------  #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event 0 = 12 rlPath = F:\RocketLauncher pluginPath = F:\RocketLauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = 1 rlMode = rlTitle = RocketLauncher rlVersion = 1.1.1.1 rlAuthor = djvj rlURL = www.rlauncher.com langFile = F:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = frontendPath = F:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = F exitEmulatorKey = ~Esc|H:1joy7 restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = F:\HyperSpin\Emulators\RetroArch\retroarch.exe emuPath = F:\HyperSpin\Emulators\RetroArch emuName = RetroArch emuExt = exe baseRomPath = romPath = F:\Roms\Sony Playstation\2Xtreme (USA) romPathFromIni = F:\Roms\Sony Playstation romExtension = .cue romExtensionOrig = .cue romExtensions = 7z|rar|zip|cue|bin|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|sfc|iso|ccd|chd|gb|gba| executable = retroarch.exe systemDbName = Sony PlayStation systemName = Sony PlayStation dbPath = dbName = 2Xtreme (USA) dbExt = romName = 2Xtreme (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = true blockInputTime = 0 blockInputFile = F:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = setResolution = logFile = logLabel := ["   INFO"," WARNING","  ERROR","  DEBUG","  TRACE"] logLevel = 3 logShowDebugConsole = false logShowCommandWindow = false logCommandWindow = false logIncludeModule = true logIncludeFileProperties = true logIncludeDLLLogs = false errorSounds = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1824 originalHeight = 1026 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdDriveLetterScsi = vdAddDrive = true demulShooterPath = servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = F:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = F:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher winIPACFullPath = ultraMapEnabled = false ultraMapFullPath = emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false suspendFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 5000 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 5000 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeSounds = true fade7zProgressMode = extraction fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeProgressDuration = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoDeveloper = text fadeRomInfoPublisher = image fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = F:\RocketLauncher\Media\Fade RLDataPath = F:\RocketLauncher\Data RLMediaPath = F:\RocketLauncher\Media RLErrSoundPath = F:\RocketLauncher\Media\Sounds\Error modulesPath = F:\RocketLauncher\Modules moduleFullName = F:\RocketLauncher\Modules\RetroArch\RetroArch.ahk moduleName = RetroArch modulePath = F:\RocketLauncher\Modules\RetroArch moduleExtension = ahk moduleExtensionsPath = F:\RocketLauncher\Module Extensions libPath = F:\RocketLauncher\Lib sevenZEnabled = false sevenZPath = F:\RocketLauncher\Module Extensions\7z.exe sevenZDllPath = F:\RocketLauncher\Module Extensions\7z.dll sevenZExtractPath = C:\RocketLauncher temp sevenZExtractPathOrig = sevenZAttachSystemName = true sevenZDelTemp = false sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar 7zExtractPath = C:\RocketLauncher temp mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side mgOnLaunch = false pauseEnabled = true pauseKey = ~NumpadAdd pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = F:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F3 down}{F3 up}|{Shift down}{2 down}{2 up}{Shift up}{F3 down}{F3 up}|{Shift down}{3 down}{3 up}{Shift up}{F3 down}{F3 up}|{Shift down}{4 down}{4 up}{Shift up}{F3 down}{F3 up}|{Shift down}{5 down}{5 up}{Shift up}{F3 down}{F3 up}|{Shift down}{6 down}{6 up}{Shift up}{F3 down}{F3 up}|{Shift down}{7 down}{7 up}{Shift up}{F3 down}{F3 up}|{Shift down}{8 down}{8 up}{Shift up}{F3 down}{F3 up}|{Shift down}{9 down}{9 up}{Shift up}{F3 down}{F3 up}|{Shift down}{10 down}{10 up}{Shift up}{F3 down}{F3 up} pauseLoadStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F4 down}{F4 up}|{Shift down}{2 down}{2 up}{Shift up}{F4 down}{F4 up}|{Shift down}{3 down}{3 up}{Shift up}{F4 down}{F4 up}|{Shift down}{4 down}{4 up}{Shift up}{F4 down}{F4 up}|{Shift down}{5 down}{5 up}{Shift up}{F4 down}{F4 up}|{Shift down}{6 down}{6 up}{Shift up}{F4 down}{F4 up}|{Shift down}{7 down}{7 up}{Shift up}{F4 down}{F4 up}|{Shift down}{8 down}{8 up}{Shift up}{F4 down}{F4 up}|{Shift down}{9 down}{9 up}{Shift up}{F4 down}{F4 up}|{Shift down}{10 down}{10 up}{Shift up}{F4 down}{F4 up} keyboardEncoder = keyboardEncoderEnabled = false keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadderFullPath = F:\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Users\RTist\Desktop\JoyToKey_en\JoyToKey.exe profilePath = F:\RocketLauncher\Profiles keymapperProfilePath = F:\RocketLauncher\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = joytokey keymapperRocketLauncherProfileEnabled = false joyIDsEnabled = false joyIDsPreferredControllersGlobal = joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = F:\RocketLauncher\Profiles\\HyperSpin defaultProfile = F:\RocketLauncher\Profiles\\_Default systemProfile = F:\RocketLauncher\Profiles\\Sony PlayStation xPadderSystemProfile = F:\RocketLauncher\Profiles\\Sony PlayStation\_Default emuProfile = F:\RocketLauncher\Profiles\\Sony PlayStation\RetroArch romProfile = F:\RocketLauncher\Profiles\\Sony PlayStation\2Xtreme (USA) RocketLauncherProfile = F:\RocketLauncher\Profiles\\RocketLauncher blankProfile = F:\RocketLauncher\Profiles\\blank ahkFEProfile = F:\RocketLauncher\Profiles\AHK\HyperSpin ahkDefaultProfile = F:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = F:\RocketLauncher\Profiles\AHK\Sony PlayStation ahkEmuProfile = F:\RocketLauncher\Profiles\AHK\Sony PlayStation\RetroArch ahkRomProfile = F:\RocketLauncher\Profiles\AHK\Sony PlayStation\2Xtreme (USA) ahkRocketLauncherProfile = F:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = true bezelICEnabled = false shaderName = false shaderColor = shaderTransparency = statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = F:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe qResFullPath = F:\RocketLauncher\Module Extensions\QRes.exe mon1O = pacDrivedllFile = F:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = F:\RocketLauncher\Lib\User Fade Animations.ini testFile = testDuration = initialErrorMode = 0  21:00:59:531 | RL |    INFO  | +0   | BuildScript - Loaded XHotkey Init.ahk scripts 21:00:59:531 | RL |    INFO  | +0   | BuildScript - Loaded Pause Init.ahk scripts 21:00:59:531 | RL |    INFO  | +0   | BuildScript - Loaded Statistics Init.ahk scripts 21:00:59:531 | RL |  WARNING  | +0   | BuildScript - "F:\RocketLauncher\Lib\User Functions Init.ahk" not found 21:00:59:531 | RL |    INFO  | +0   | BuildScript - Validating module 21:00:59:538 | RL |    INFO  | +15   | BuildScript - Validation complete 21:00:59:538 | RL |    INFO  | +0   | BuildScript - Module: MEmu = RetroArch MEmuV =  v05-11-2015 Nightly MURL = http://themaister.net/retroarch.html MAuthor = djvj,zerojay MVersion = 2.4.2 MCRC = A8D5F162 iCRC = F7B77133 MID = 635038268922229162 MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics" ;---------------------------------------------------------------------------- ; Notes: ; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working! ; Devs stated they will never add support for mounted images (like via DT) ; Fullscreen is controlled via the module setting in RocketLauncherUI ; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe). ; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect ; Enable 7z support for archived roms ; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1 ; ; LibRetro DLLs: ; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/ ; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system. ; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores ; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270 ; ; SRM files: ; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm ; ; Save states: ; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save ; ; Config files: ; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI. ; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg). ; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg ; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg. ; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config. ; ; MultiGame: ; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch. ; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind. ; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12. ; ; MAME: ; MAME BIOS roms should be placed in the system\mame folder ; ; System Specific Notes: ; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine. ; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg. ; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg. ; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these. ; NEC TurboGrafx-CD (using pce fast core) - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg. ; NEC TurboGrafx-CD (using MAME core) ;  - You'll need to update a couple mame specific options in the Retroarch core options file to get it to boot from the cli. These should probably be updated automagically by the module. Turning softlists off, but might not need to. ;    mame_boot_from_cli = "enabled" ;    mame_softlists_enable = "disabled" ;    mame_softlists_auto_media = "disabled" ; - Requires hash folder from MAME/MESS/UME, either from the source or release package. Save this in the system_directory you've defined for RetroArch. Something like \RetroArch\system\mame\hash\ ; - Requires the CD bios file(s) saved in the mame bios folder you've defined. Usually \RetroArch\system\mame\bios\ ; For PC Engine-CD you'll need the file "[cd] cd-rom system (japan) (v2.1).pce" zipped as cdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\cdsys.zip ; For PC Engine SuperGrafx-CD you'll need the file "[cd] super cd-rom system (japan) (v3.0).pce" zipped as scdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\scdsys.zip ; For TurboGrafx-CD you'll need the file "[cd] turbografx cd system card (usa) (v2.0).pce" zipped as cdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\cdsys.zip ; For TurboDuo you'll need the file "[cd] turbografx cd super system card (usa) (v3.0).pce" zipped as scdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\scdsys.zip ; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode. ; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files. ; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory. ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart()  primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object emuPrimaryWindow := new Window(new WindowTitle("RetroArch","RetroArch")) ; instantiate primary emulator window object emuConsoleWindow := new Window(new WindowTitle("","ConsoleWindowClass")) ; instantiate emulator console window object  ; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt. ; 1 - Official System Name in RocketLauncher ; 2 - Short name used only for easy referencing within module ; 3 - Default core ; 4 - The system ID MAME core recognizes RLLog.Debug("Module - Started building the " . MEmu . " object") mTypeVar:=" ( LTrim AAE|LibRetro_AAE|mame_libretro Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464 Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000 APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic Atari 2600|LibRetro_2600|stella_libretro|a2600 Atari 5200|LibRetro_5200|mess_libretro|a5200 Atari 7800|LibRetro_7800|prosystem_libretro|a7800 Atari 8-Bit|LibRetro_ATARI8|mess_libretro|a800 Atari Classics|LibRetro_ACLS|mame_libretro Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar Atari Lynx|LibRetro_LYNX|handy_libretro|lynx Atari ST|LibRetro_ST|hatari_libretro Atari XEGS|LibRetro_XEGS|mess_libretro|xegs Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78 Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000 Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor Canon X07|LibRetro_CX07|mess_libretro|x07 Capcom Classics|LibRetro_CAPC|mame_libretro Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro Capcom Play System II|LibRetro_CPS2|fba_cores_cps2_libretro Capcom Play System III|LibRetro_CPS3|mame_libretro Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000 Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000 Cave|LibRetro_CAVE|mame_libretro Coleco ADAM|LibRetro_ADAM|mess_libretro|adam ColecoVision|LibRetro_COLEC|mess_libretro|coleco Commodore Amiga|LibRetro_PUAE|puae_libretro Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10 Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck Data East Classics|LibRetro_DATA|mame_libretro Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64 Elektronika BK|LibRetro_EBK|mess_libretro|bk0010 Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64 Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan GamePark 32|LibRetro_GP32|mess_libretro|gp32 GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000 Irem Classics|LibRetro_IREM|mame_libretro JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii Konami Classics|LibRetro_KONC|mame_libretro Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2 MAME|LibRetro_MAME|mame_libretro|mame Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32 Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius Mattel Intellivision|LibRetro_INTV|mess_libretro|intv MGT Sam Coupe|LibRetro_SAMCP|mess_libretro| Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro Microsoft MSX|LibRetro_MSX|bluemsx_libretro Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro Midway Classics|LibRetro_MIDC|mame_libretro Namco Classics|LibRetro_NAMC|mame_libretro Namco System 22|LibRetro_NAM2|mame_libretro NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce,cart NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce,cdrom NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx,cart NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16,cart NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16,cdrom Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64 Nintendo 64DD|LibRetro_N64|mupen64plus_libretro Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro Nintendo Classics|LibRetro_NINC|mame_libretro Nintendo DS|LibRetro_DS|desmume_libretro Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes Nintendo Famicom|LibRetro_NFAM|nestopia_libretro Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy Nintendo Game & Watch|LibRetro_GW|gw_libretro Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro Panasonic 3DO|LibRetro_3DO|4do_libretro Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1 Philips Videopac|LibRetro_PVID|mess_libretro|videopac RCA Studio II|LibRetro_STUD2|mess_libretro|studio2 SCUMMVM|LibRetro_SCUMM|scummvm_libretro Sega 32X|LibRetro_32X|picodrive_libretro|32x Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd Sega Classics|LibRetro_SEGC|mame_libretro Sega Dreamcast|LibRetro_DCAST|reicast_libretro Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro Sega Meganet|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Nomad|LibRetro_GEN|genesis_plus_gx_libretro|genesis Sega Pico|LibRetro_PICO|picodrive_libretro Sega Saturn|LibRetro_SAT|yabause_libretro|saturn Sega Saturn Japan|LibRetro_SAT|yabause_libretro|saturnjp Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000 Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro Sega ST-V|LibRetro_STV|mame_libretro Sega VMU|LibRetro_SVMU|mess_libretro|svmu Sharp X1|LibRetro_SX1|mess_libretro|x1 Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum SNK Classics|LibRetro_SNKC|mame_libretro SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psu Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat Sony PSP|LibRetro_PSP|ppsspp_libretro Sony PSP Minis|LibRetro_PSP|ppsspp_libretro Sord M5|LibRetro_SORD|mess_libretro|m5 Spectravideo|LibRetro_SV328|mess_libretro|svi328n Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes Taito Classics|LibRetro_TAIC|mame_libretro Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3 Technos|LibRetro_TECHN|mame_libretro Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a Thomson MO5|LibRetro_MO5|mess_libretro|mo5 Thomson TO7|LibRetro_TO7|mess_libretro|to7 Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom Tiki-100|LibRetro_TIKI|mess_libretro|kontiki Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision Watara Supervision|LibRetro_SUPRV|mess_libretro|svision Williams Classics|LibRetro_WILLS|mame_libretro )" mType := Object() Loop, Parse, mTypeVar, `n, `r { obj := {} Loop, Parse, A_LoopField, | { If (A_Index = 1) obj.System := A_LoopField Else If (A_Index = 2) obj.ID := A_LoopField Else If (A_Index = 3) obj.Core := A_LoopField Else { ; 4 StringSplit, tmp, A_LoopField, `, obj.MAMEID := tmp1 obj.MAMEMedia := tmp2 } } mType.Insert(obj["System"], obj) } RLLog.Debug("Module - Finished building the " . MEmu . " object") ; For easier use throughout the module retroSystem := mType[systemName].System retroID := mType[systemName].ID retroCore := mType[systemName].Core retroMAMEID := mType[systemName].MAMEID retroMAMEMedia := mType[systemName].MAMEMedia RLLog.Info("Module - Using these system variables:") RLLog.Info("Module - retroSystem: " . retroSystem) RLLog.Info("Module - retroID: " . retroID) RLLog.Info("Module - retroCore: " . retroCore) RLLog.Info("Module - retroMAMEID: " . retroMAMEID) RLLog.Info("Module - retroMAMEMedia: " . retroMAMEMedia) If !retroSystem ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName) If !retroCore ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.")  Fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1) configFolder := moduleIni.Read("Settings", "ConfigFolder",emuPath . "\config","",1) mameRomPath := moduleIni.Read("MAME", "BIOS_Roms_Folder","","",1) mameHideNag := If moduleIni.Read("MAME", "Hide_Nag_Screen","false","",1) = "true" ? "enabled" : "disabled" mameHideInfo := If moduleIni.Read("MAME", "Hide_Info_Screen","false","",1) = "true" ? "enabled" : "disabled" mameHideWarn := If moduleIni.Read("MAME", "Hide_Warning_Screen","false","",1) = "true" ? "enabled" : "disabled" hideConsole := moduleIni.Read("Settings", "HideConsole","true","",1) ejectToggleKey := moduleIni.Read("Settings", "Eject_Toggle_Key","","",1) nextDiskKey := moduleIni.Read("Settings", "Next_Disk_Key","","",1) prevDiskKey := moduleIni.Read("Settings", "Previous_Disk_Key","","",1) core := moduleIni.Read(romName . "|" . systemName, "LibRetro_Core",retroCore,"",1) superGB := moduleIni.Read(romName . "|" . systemName, "SuperGameBoy","false","",1) enableNetworkPlay := moduleIni.Read(romName . "|Network", "Enable_Network_Play","false","",1) overlay := moduleIni.Read(romName . "|" . systemName, "Overlay","","",1) videoShader := moduleIni.Read(romName . "|" . systemName, "VideoShader","","",1) aspectRatioIndex := moduleIni.Read(romName . "|" . systemName, "AspectRatioIndex","","",1) customViewportWidth := moduleIni.Read(romName . "|" . systemName, "CustomViewportWidth","","",1) customViewportHeight := moduleIni.Read(romName . "|" . systemName, "CustomViewportHeight","","",1) customViewportX := moduleIni.Read(romName . "|" . systemName, "CustomViewportX","","",1) customViewportY := moduleIni.Read(romName . "|" . systemName, "CustomViewportY","","",1) stretchToFillBezel := moduleIni.Read(romName . "|" . systemName, "StretchToFillBezel","false","",1) rotation := moduleIni.Read(romName . "|" . systemName, "Rotation",0,"",1) cropOverscan := moduleIni.Read(romName . "|" . systemName, "CropOverscan","","",1) threadedVideo := moduleIni.Read(romName . "|" . systemName, "ThreadedVideo","","",1) vSync := moduleIni.Read(romName . "|" . systemName, "VSync","","",1) integerScale := moduleIni.Read(romName . "|" . systemName, "IntegerScale","","",1) configurationPerCore := moduleIni.Read(romName . "|" . systemName, "ConfigurationPerCore","false","",1)  If (StringUtils.Contains(core, "^(mame|mess|ume)") && !retroMAMEID) { retroMAMEID := "mame" ; set all systems that use a mame core to the default mame ID so any system name is supported RLLog.Warning("Module - Setting MAMEID to default ""mame"" for """ . retroSystem . """") }  configFolder := RLObject.getFullPathFromRelative(rlPath,configFolder) mameRomPath := If mameRomPath ? RLObject.getFullPathFromRelative(rlPath,mameRomPath) : romPath overlay := RLObject.getFullPathFromRelative(rlPath,overlay) videoShader := RLObject.getFullPathFromRelative(rlPath,videoShader) rotateBezel := false  configFolder := new Folder(configFolder)  If (retroID = "LibRetro_SGB" || superGB = "true") ; if system or rom is set to use Super Game Boy { superGB := "true" ; setting this just in case it's false and the system is Nintendo Super Game Boy sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system") CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system") retroID := "LibRetro_SGB" ; switching to Super Game Boy mode retroSystem := "Nintendo Super Game Boy" }  ; Find the dll for this system libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll")  ; Find the cfg file to use If !configFolder.Exist() ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder.FilePath . """") globalRetroCfg := emuPath . "\retroarch.cfg" systemRetroCfg := configFolder.FilePath . "\" . retroSystem . ".cfg" coreRetroCfg := configFolder.FilePath . "\" . core . ".dll.cfg" RLLog.Info("Module - Global cfg should be: " . globalRetroCfg) RLLog.Info("Module - System cfg should be: " . systemRetroCfg) RLLog.Info("Module - Core cfg should be: " . coreRetroCfg) foundCfg := ""  systemRetroCfg := new File(systemRetroCfg) coreRetroCfg := new File(coreRetroCfg) globalRetroCfg := new File(globalRetroCfg)  If systemRetroCfg.Exist() { ; check for system cfg first retroCFGFile := systemRetroCfg foundCfg := 1 RLLog.Info("Module - Found a System cfg!") } Else If coreRetroCfg.Exist() { ; 2nd option is a core config retroCFGFile := coreRetroCfg foundCfg := 1 RLLog.Info("Module - Found a Core cfg!") } Else If globalRetroCfg.Exist() { ; 3rd is global cfg retroCFGFile := globalRetroCfg foundCfg := 1 RLLog.Info("Module - Found a Global cfg!") } If foundCfg { RLLog.Info("Module - " . MEmu . " is using " . retroCFGFile.FileFullPath . " as its config file.") retroCFG := LoadProperties(retroCFGFile.FileFullPath) } Else RLLog.Warning("Module - Could not find a cfg file to update settings. RetroArch will make one for you.")  If StringUtils.Contains(rotation,"1|3") ; use vertical bezel if RA rotation is set to 90 or 270 degrees rotateBezel := true  If StringUtils.Contains(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") { ; these systems require the retroarch settings to be read retroSysDir := ReadProperty(retroCFG,"system_directory") ; read value retroSysDir := ConvertRetroCFGKey(retroSysDir) ; remove dbl quotes retroSysDirLeft := StringUtils.Left(retroSysDir, 2) If (retroSysDirLeft = ":\") { ; if retroarch is set to use a default folder retroSysDir := StringUtils.TrimLeft(retroSysDir, 1) RLLog.Info("Module - RetroArch is using a relative system path: """ . retroSysDir . """") retroSysDir := emuPath . retroSysDir } If !retroSysDir ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.") checkForSlash := StringUtils.Right(retroSysDir, 1) If (checkForSlash = "\") ; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders retroSysDir := StringUtils.TrimRight(retroSysDir, 1) }  If (StringUtils.Contains(core, "^(mame|mess|ume)")) || (StringUtils.Contains(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX")) || (StringUtils.Contains(retroID, "LibRetro_NES") && (StringUtils.Contains(core, "nestopia_libretro"))) { ; these systems will use an ini to store game specific settings RLLog.Info("Module - Reading / creating system ini for specific settings.") If !StringUtils.Contains(core, "^(mame|mess|ume)") { If !SystemModuleIni.Exist() SystemModuleIni.Append ; create a new blank ini file if one does not exist }  If (configurationPerCore = "true") { coreOptionsCFGFile := new File(configFolder.FilePath . "\retroarch-core-options.cfg") coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . configFolder.FilePath . """") } Else { coreOptionsCFGFile := new File(emuPath . "\retroarch-core-options.cfg") coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . emuPath . """") } coreOptionsCFG := LoadProperties(coreOptionsCFGFile.FileFullPath)  If StringUtils.Contains(core, "^(mame|mess|ume)") { ; Set some MAME/MESS/UME core options. tmpCore := If StringUtils.Contains(core, "mame") ? "mame" : "mess" WriteProperty(coreOptionsCFG, tmpCore . "_read_config", """enabled""", 1) WriteProperty(coreOptionsCFG, tmpCore . "_boot_from_cli", """enabled""", 1) ; This needs to be enabled in order to run games with RLauncher WriteProperty(coreOptionsCFG, tmpCore . "_hide_nagscreen", "" . mameHideNag . "", 1) WriteProperty(coreOptionsCFG, tmpCore . "_hide_infoscreen", "" . mameHideInfo . "", 1) WriteProperty(coreOptionsCFG, tmpCore . "_hide_warnings", "" . mameHideWarn . "", 1) } Else If StringUtils.Contains(retroID, "LibRetro_N64") { ; Nintendo 64 mupenGfx := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Plugin", "auto","",1) mupenRsp := moduleIni.Read(romName . "|" . systemName, "Mupen_RSP_Plugin", "auto","",1) mupenCpu := moduleIni.Read(romName . "|" . systemName, "Mupen_CPU_Core", "dynamic_recompiler","",1) mupenPak1 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_1", "memory","",1) mupenPak2 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_2", "memory","",1) mupenPak3 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_3", "memory","",1) mupenPak4 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_4", "memory","",1) mupenGfxAccur := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Accuracy", "high","",1) mupenExpMem := moduleIni.Read(romName . "|" . systemName, "Mupen_Disable_Exp_Memory", "no","",1) mupenTexturFilt := moduleIni.Read(romName . "|" . systemName, "Mupen_Texture_Filtering", "nearest","",1) mupenViRefresh := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Refresh", "2200","",1) mupenFramerate := moduleIni.Read(romName . "|" . systemName, "Mupen_Framerate", "fullspeed","",1) mupenResolution := moduleIni.Read(romName . "|" . systemName, "Mupen_Resolution", "640x480","",1) mupenPolyOffstFctr := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Factor", "-3.0","",1) mupenPolyOffstUnts := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Units", "-3.0","",1) mupenViOverlay := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Overlay", "disabled","",1) mupenAnalogDzone := moduleIni.Read(romName . "|" . systemName, "Mupen_Analog_Deadzone", "15","",1)  WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1) WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1) WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1) WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1) WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1) WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1) WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1) WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1) WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1) WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1) WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1) WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1) WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1) WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1) WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1) WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1) WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1) } Else If StringUtils.Contains(retroID, "LibRetro_NES") { ; these systems will use an ini to store game specific settings If StringUtils.Contains(core, "nestopia_libretro") { ; Nestopia nestopiaBlargg := moduleIni.Read(romName . "|Nestopia", "Nestopia_Blargg_NTSC_Filter", "disabled","",1) nestopiaPalette := moduleIni.Read(romName . "|Nestopia", "Nestopia_Palette", "canonical","",1) nestopiaNoSprteLimit := moduleIni.Read(romName . "|Nestopia", "Nestopia_Remove_Sprites_Limit", "disabled","",1)  WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1) WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1) WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1) } } Else If StringUtils.Contains(retroID, "LibRetro_LYNX") { ; Atari Lynx If StringUtils.Contains(core, "handy_libretro") {  ; Handy handyRotate := moduleIni.Read(romName . "|" . systemName, "Handy_Rotation", "None","",1) If StringUtils.Contains(handyRotate, "240") or StringUtils.Contains(handyRotate, "90") rotateBezel := true WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1) } } Else If StringUtils.Contains(retroID, "LibRetro_PSX") { ; Sony PlayStation psxCdImageCache := moduleIni.Read(romName . "|" . systemName, "PSX_CD_Image_Cache", """enabled""","",1) psxMemcardHandling := moduleIni.Read(romName . "|" . systemName, "PSX_Memcard_Handling", """libretro""","",1) psxDualshockAnalogToggle := moduleIni.Read(romName . "|" . systemName, "PSX_Dualshock_Analog_Toggle", """enabled""","",1)  WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1) WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1) WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1) } SaveProperties(coreOptionsCFGFile.FileFullPath, coreOptionsCFG) }  hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1) 7z(romPath, romName, romExtension, sevenZExtractPath)  mgM3UFile := new File(romPath . "\" . romTable[1,4] . ".m3u")  mgRomExtensions := "cue|iso|ccd" mgValidExtension := false  Loop, Parse, mgRomExtensions, | If (romExtension = "." . A_LoopField) mgValidExtension := true  If (StringUtils.Contains(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated m3uRomIndex := Object() mgType := romTable[1,6] . " " mgMaxIndex := romTable.MaxIndex() mgRomIndex := 0  If mgM3UFile.Exist() mgM3UFile.Delete()  Loop % mgMaxIndex { If (romTable[A_Index, 3] = romName) { tempType := romTable[A_Index, 5] mgRomIndex := StringUtils.TrimLeft(tempType, StringUtils.StringLength(mgType)) RLLog.Info("Found rom index in rom set in romTable: " . mgRomIndex) Break } }  If (mgRomIndex > 0) { tempRomIndex := mgRomIndex Loop % mgMaxIndex { mgTypeIndex := mgType . tempRomIndex m3uRomIndex.Insert(tempRomIndex)  Loop % mgMaxIndex { If (romTable[A_Index, 5] = mgTypeIndex) { tempRomPath := romTable[A_Index, 1] mgM3UFile.Append(tempRomPath . "`n") RLLog.Info("Module - Appending rom path to m3u: " . tempRomPath) Break } }  If (tempRomIndex < mgMaxIndex) tempRomIndex++ Else tempRomIndex := 1 } } }  ; MAME/MESS/UME core options MAMEParam1 := "" MAMEParam2 := "" MAMEParam3 := "" If StringUtils.Contains(core, "^(mame|mess|ume)") { ; if a MAME/MESS/UME core is used If !retroMAMEID ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MAME/MESS/UME LibRetro core") Else RLLog.Info("Module - MAME/MESS/UME mode using a known ident: " . retroMAMEID)  If !mameRomPath ScriptError("Please set the RetroArch module setting ""BIOS_Roms_Folder"" to the folder that contains your MAME/MESS/UME BIOS roms to use with RetroArch.")  If (retroMAMEID = "mame") { ; want this for arcade mame only RLLog.Info("Module - Retroarch MAME/MESS/UME Arcade mode enabled") fullRomPath := " """ . romPath . "\" . romName . romExtension . """" } Else { RLLog.Info("Module - Retroarch MAME/MESS/UME Console/PC mode enabled") MAMEParam1 := "" MAMEParam2 := " -rompath \""" . mameRomPath . "\"""  ; If we already have a media type, then use it. If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cart") { ;MAMEParam3 := " -cart \" . """" . romPath . "\" . romName . romExtension . "\" . """" MAMEParam3 := " -cart \""" . romPath . "\" . romName . romExtension . "\""""" ; TODO: This needs a better way to handle the cdrom bios files, in my opinion. As it is, there's no clean way to pick between the v2.00 or v3.00 bios. ;    Defaulting to the TurboDuo cdrom bios since it will play 2.00 or 3.00 games. } Else If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cdrom") { ;MAMEParam3 := " -cart cdsys -cdrm \" . """" . romPath . "\" . romName . romExtension . "\" . """" MAMEParam3 := " -cart scdsys -cdrm \""" . romPath . "\" . romName . romExtension . "\""""" } Else { ; Build a key/value object containing the different MAMEParam3 choices MAMEP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","saturn","cdrm","saturnjp","cdrm","svi328n","cass","pecom64","cass","psu","cdrm","svmu","quik","gamecom","cart1","mbeeic","quik1") MAMEParam3 := MAMEP3[retroMAMEID] ; search object for the retroMAMEID pair MAMEParam3 := " -" . (If MAMEParam3 ? MAMEParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" }  If (retroMAMEID = "mbeeic") ; Applied Technology MicroBee { microbeeModel := IniReadCheck(MAMESysINI, romName, "MicroBee_Model","mbeeic","",1) If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56 ScriptError("This is not a known MicroBee model value: " . microbeeModel) Else If (microbeeModel != "mbeeic") retroMAMEID := microbeeModel If romExtension in .mwb,.com,.bee mediaDeviceType := "quik1" Else If romExtension in .wav,.tap mediaDeviceType := "cass" Else If romExtension in .rom mediaDeviceType := "cart" Else If romExtension in .dsk mediaDeviceType := "flop1" Else ; .bin format mediaDeviceType := "quik2" MAMEParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """" }  fullRomPath := MAMEParam1 . MAMEParam2 . MAMEParam3 } } Else If (superGB = "true") { RLLog.Info("Module - Retroarch Super Game Boy mode enabled") fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """" } Else { RLLog.Info("Module - Retroarch standard mode enabled") fullRomPath := " """ . romPath . "\" . romName . romExtension . """" }  If (retroID = "LibRetro_NFDS") ; Nintendo Famicom Disk System { disksysRom := new File(retroSysDir . "\disksys.rom") If !disksysRom.Exist() ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If (retroID = "LibRetro_SCD") ; Sega CD { If !StringUtils.Contains(romExtension, "\.bin|\.cue|\.iso") ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension) biosCDEBin := new File(retroSysDir . "\bios_CD_E.bin") biosCDUBin := new File(retroSysDir . "\bios_CD_U.bin") biosCDJBin := new File(retroSysDir . "\bios_CD_J.bin") If !biosCDEBin.Exist() ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") If !biosCDUBin.Exist() ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") If !biosCDJBin.Exist() ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If StringUtils.Contains(retroID,"LibRetro_PCECD|LibRetro_TGCD") ; NEC PC Engine-CD and NEC TurboGrafx-CD { If !StringUtils.Contains(romExtension,"\.ccd|\.cue") ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension) sysCard3Pce := new File(retroSysDir . "\syscard3.pce") If !sysCard3Pce.Exist() ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If (retroID = "LibRetro_PCFX") { If !StringUtils.Contains(romExtension,"\.ccd|\.cue") ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension) pcfxBios := new File(retroSysDir . "\pcfx.bios") If !pcfxBios.Exist() ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """") } Else If (retroID = "LibRetro_SCUMM") { scummFile := new File(romPath . "\" . romName . ".scummvm") If !scummFile.Exist() scummFile.Append("""" . romName . """") }  networkSession := "" If (enableNetworkPlay = "true") { RLLog.Info("Module - Network Multi-Player is an available option for " . dbName)  netplayNickname := moduleIni.Read("Network", "NetPlay_Nickname","Player","",1) getWANIP := moduleIni.Read("Network", "Get_WAN_IP","false","",1)  If (getWANIP = "true") myPublicIP := GetPublicIP()  RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE") defaultServerIP := moduleIni.Read("Network", "Default_Server_IP", myPublicIP,"",1) defaultServerPort := moduleIni.Read("Network", "Default_Server_Port","","",1) lastIP := moduleIni.Read("Network", "Last_IP", defaultServerIP,"",1) ; does not need to be on the ISD lastPort := moduleIni.Read("Network", "Last_Port", defaultServerPort,"",1) ; does not need to be on the ISD  mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,"",0) If (mpMenuStatus = -1) { ; if user exited menu early RLLog.Warning("Module - Cancelled MultiPlayer Menu. Exiting module.") ExitModule() } If networkSession { RLLog.Info("Module - Using a Network for " . dbName) moduleIni.Write(networkPort, "GlobalModuleIni", "Network", "Last_Port") ; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort% If (networkType = "client") { moduleIni.Write(networkIP, "GlobalModuleIni", "Network", "Last_IP") ; Save last used IP and Port for quicker launching next time netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """" ; -C = connect as client } Else { ; server netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """" ; -H = host as server } RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE") RLLog.Info("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """") } Else RLLog.Info("Module - User chose Single Player mode for this session") }  BezelStart(,,(If rotateBezel ? 1:""))  If foundCfg { If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath) { customViewportWidth := bezelScreenWidth customViewportHeight := bezelScreenHeight customViewportX := 0 customViewportY := 0 aspectRatioIndex := 22 RLLog.Info("Stretching viewport to fit bezel") }  raCfgHasChanges := "" WriteRetroProperty("input_overlay", overlay) WriteRetroProperty("video_shader", videoShader) WriteRetroProperty("aspect_ratio_index", aspectRatioIndex) WriteRetroProperty("custom_viewport_width", customViewportWidth) WriteRetroProperty("custom_viewport_height", customViewportHeight) WriteRetroProperty("custom_viewport_x", customViewportX) WriteRetroProperty("custom_viewport_y", customViewportY) WriteRetroProperty("video_rotation", rotation) WriteRetroProperty("video_crop_overscan", cropOverscan) WriteRetroProperty("video_threaded", threadedVideo) WriteRetroProperty("video_vsync", vSync) WriteRetroProperty("video_scale_integer", integerScale) WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey) WriteRetroProperty("input_disk_next", nextDiskKey) WriteRetroProperty("input_disk_prev", prevDiskKey) If StringUtils.Contains(retroID, "LibRetro_PSX") { Loop, 8 ; Loop 8 times for 8 controllers { p%A_Index%ControllerType := moduleIni.Read(romName . "|" . systemName, "P" . A_Index . "_Controller_Type", 517,"",1) WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType) } }  If raCfgHasChanges { RLLog.Info("Module - Saving changed settings to: """ . retroCFGFile.FileFullPath . """") SaveProperties(retroCFGFile.FileFullPath, retroCFG) } }  fullscreen := If fullscreen = "true" ? " -f" : "" srmPath := new Folder(emuPath . "\srm\" . retroSystem) ; path for this system's srm files saveStatePath := new Folder(emuPath . "\save\" . retroSystem) ; path for this system's save state files retroCFGFileCLI := If foundCfg ? " -c """ . retroCFGFile.FileFullPath . """" : ""  If !srmPath.Exist("folder") srmPath.CreateDir() ; creating srm dir if it doesn't exist If !saveStatePath.Exist("folder") saveStatePath.CreateDir() ; creating save dir if it doesn't exist  HideAppStart(hideEmuObj,hideEmu)  If (StringUtils.Contains(core, "^(mame|mess|ume)") && (retroMAMEID != "mame")) {   ; if a MAME/MESS/UME core is used primaryExe.Run(" """ . (retroMAMEID ? retroMAMEID : "") . fullRomPath . """ " . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide") } Else If (retroID = "LibRetro_SCUMM") { primaryExe.Run(" """ . scummFile . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide") } Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case. primaryExe.Run(fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . fullRomPath . netCommand, "Hide") } Else If mgM3UFile.Exist() { primaryExe.Run(" """ . mgM3UFile.FileFullPath . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide") } Else { primaryExe.Run(" " . fullRomPath . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide") }  mpMenuStatus := "" If networkSession { canceledServerWait := false multiplayerMenuExit := false TimerUtils.SetTimer("NetworkConnectedCheck", 500)  If (networkType = "server") { RLLog.Info("Module - Waiting for a client to connect to your server") mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.") } Else { ; client RLLog.Info("Module - Trying to contact the server to establish a connection.") mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...") }  If (mpMenuStatus = -1) { ; if user exited menu early before a client connected RLLog.Warning("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.") If primaryExe.Process("Exist") primaryExe.Process("Close") ; must close process as the exe is waiting for a client to connect and no window was drawn yet ExitModule() } Else { ; blank response from MultiPlayerMenu, exited properly RLLog.Info("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server") emuPrimaryWindow.Wait() emuPrimaryWindow.WaitActive() } TimerUtils.SetTimer("NetworkConnectedCheck", "Off") } Else { ; single player emuPrimaryWindow.Wait() emuPrimaryWindow.WaitActive() }  If (hideConsole = "true") emuConsoleWindow.Set("Transparent", "On") ; makes the console window transparent so you don't see it on exit  BezelDraw() HideAppEnd(hideEmuObj,hideEmu) FadeInExit() primaryExe.Process("WaitClose") 7zCleanUp() BezelExit() FadeOutExit() ExitModule()   ; Writes new properties into the retroCFG if defined by user WriteRetroProperty(key,value="") { If (value != "") { Global retroCFG,raCfgHasChanges WriteProperty(retroCFG, key, value,1,1) raCfgHasChanges := 1 } }  ; Used to convert between RetroArch keys and usable data ConvertRetroCFGKey(txt,direction="read"){ Global emuPath,RLLog If (direction = "read") { newtxt := StringUtils.TrimLeft(txt,1,0) ; removes the " from the left of the txt newtxt := StringUtils.TrimRight(newtxt,1,0) ; removes the " from the right of the txt relativeCheck := StringUtils.SubStr(newtxt,1,1,0) If StringUtils.Contains(relativeCheck,":",0) { ; if the path contains a ":" then it is a relative path RLLog.Debug("ConvertRetroCFGKey - " . newtxt . " is a relative path") newtxt := StringUtils.TrimLeft(newtxt,1,0) ; removes the : from the left of the txt newtxt := AbsoluteFromRelative(emuPath, "." . newtxt) ; convert relative to absolute } If StringUtils.Contains(newtxt,"/",0) newtxt := StringUtils.Replace(newtxt,"/","\",1,"",0) ; replaces all forward slashes with backslashes } Else If (direction = "write") { newtxt := """" . txt . """" ; wraps the txt with "" If StringUtils.Contains(newtxt,"\\",0) newtxt := StringUtils.Replace(newtxt,"\","/",1,"",0) ; replaces all backslashes with forward slashes } Else ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.") RLLog.Debug("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt) Return newtxt }  MultiGame: KeyUtils.SetKeyDelay(100) emuPrimaryWindow.Activate() KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; eject disc in Retroarch If (!mgLastRomIndex) { mgLastRomIndex := mgRomIndex } selectedRomIndex := 0 selectedRomIndex := StringUtils.TrimLeft(selectedRomNum, StringUtils.StringLength(mgType,0))  Loop % mgMaxIndex { If (m3uRomIndex[A_index] = mgLastRomIndex) { tempLastRomIndex := A_index RLLog.Debug("Module - Last index: " . tempLastRomIndex) } If (m3uRomIndex[A_index] = selectedRomIndex) { tempSelectedRomIndex := A_index RLLog.Debug("Module - Selected index: " . tempSelectedRomIndex) } }  mgNewIndex := tempLastRomIndex - tempSelectedRomIndex  If (mgNewIndex < 0) { mgNewIndex := mgNewIndex * -1 Loop % mgNewIndex { RLLog.Debug("Module - Sending the next disk key: " . nextDiskKey) KeyUtils.Send("{" . nextDiskKey . " down}{" . nextDiskKey . " up}") } } Else If (mgNewIndex > 0) { Loop % mgNewIndex { RLLog.Debug("Module - Sending the previous disk key: " . mgNewIndex) KeyUtils.Send("{" . prevDiskKey . " down}{" . prevDiskKey . " up}") } }  KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}") ; close disc in Retroarch mgLastRomIndex := selectedRomIndex Return  NetworkConnectedCheck: If clientConnected multiplayerMenuExit := true Else If emuPrimaryWindow.Exist() { RLLog.Info("Module - RetroArch session started, closing the MultiPlayer menu") multiplayerMenuExit := true } Return  CloseProcess: FadeOutStart() emuPrimaryWindow.Close() Return  21:00:59:553 | RL |    INFO  | +16   | BuildScript - Loaded Pause scripts 21:00:59:554 | RL |    INFO  | +0   | BuildScript - Loaded Multi-Player scripts 21:00:59:558 | RL |    INFO  | +0   | BuildScript - Loaded Statistics.ahk script 21:00:59:558 | RL |  WARNING  | +0   | BuildScript - "F:\RocketLauncher\Lib\User Functions.ahk" not found 21:00:59:558 | RL |    INFO  | +0   | BuildScript - Finished injecting functions into module 21:00:59:560 | RL |    INFO  | +0   | Main - Module is built 21:00:59:560 | RL |    INFO  | +0   | CheckFile - Checking if F:\RocketLauncher\AutoHotkey.dll exists 21:00:59:561 | RL |    INFO  | +0   | Main - Running module 21:00:59:763 | MD |    INFO  | +N/A  | Module initialized 21:00:59:766 | MD |    INFO  | +0   | StartModule - Started 21:00:59:766 | MD |    INFO  | +0   | StartModule - MEmu: RetroArch MEmuV: v05-11-2015 Nightly MURL: http://themaister.net/retroarch.html MAuthor: djvj,zerojay MVersion: 2.4.2 MCRC: A8D5F162 iCRC: F7B77133 MID: MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics" 21:00:59:766 | MD |    INFO  | +0   | StartModule - You have a supported System Name for this module: "Sony PlayStation" 21:00:59:767 | MD |    INFO  | +0   | PluginInit - Started 21:00:59:767 | MD |    INFO  | +0   | CheckFile - Checking if F:\HyperSpin\Databases\Sony PlayStation\Sony PlayStation.xml exists 21:00:59:809 | MD |    INFO  | +47   | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 21:00:59:809 | MD |    INFO  | +0   | BuildAssetsTable - Ended 21:00:59:809 | MD |    INFO  | +0   | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 21:00:59:867 | MD |    INFO  | +62   | BuildAssetsTable - Ended 21:00:59:867 | MD |    INFO  | +0   | BuildAssetsTable - Started - Building Table for: Game Video|System Video 21:00:59:867 | MD |    INFO  | +0   | BuildAssetsTable - Ended 21:00:59:867 | MD |    INFO  | +0   | PluginInit - Ended 21:00:59:871 | MD |    INFO  | +0   | StartModule - Ended 21:00:59:871 | MD |    INFO  | +0   | BezelGUI - Started 21:00:59:901 | MD |    INFO  | +32   | BezelGUI - Ended 21:00:59:902 | MD |    INFO  | +0   | Module - Using these system variables: 21:00:59:902 | MD |    INFO  | +0   | Module - retroSystem: Sony PlayStation 21:00:59:902 | MD |    INFO  | +0   | Module - retroID: LibRetro_PSX 21:00:59:902 | MD |    INFO  | +0   | Module - retroCore: mednafen_psx_libretro 21:00:59:902 | MD |    INFO  | +0   | Module - retroMAMEID: psu 21:00:59:902 | MD |    INFO  | +0   | Module - retroMAMEMedia: cdrom 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Fullscreen: true (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - ConfigFolder: F:\HyperSpin\Emulators\RetroArch\config (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - BIOS_Roms_Folder: (NO VALUE) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Hide_Nag_Screen: false (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Hide_Info_Screen: false (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Hide_Warning_Screen: false (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - HideConsole: true (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Eject_Toggle_Key: (NO VALUE) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Next_Disk_Key: (NO VALUE) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Previous_Disk_Key: (NO VALUE) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module {GlobalModuleIni} - [Sony PlayStation] - LibRetro_Core: mednafen_psx_libretro 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - SuperGameBoy: false (DEFAULT) 21:00:59:902 | MD |    INFO  | +0   | RIniFile.Read - Module - Enable_Network_Play: false (DEFAULT) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - Overlay: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - VideoShader: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - AspectRatioIndex: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - CustomViewportWidth: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - CustomViewportHeight: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - CustomViewportX: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - CustomViewportY: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - StretchToFillBezel: false (DEFAULT) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - Rotation: 0 (DEFAULT) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - CropOverscan: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - ThreadedVideo: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - VSync: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - IntegerScale: (NO VALUE) 21:00:59:903 | MD |    INFO  | +0   | RIniFile.Read - Module - ConfigurationPerCore: false (DEFAULT) 21:00:59:904 | MD |    INFO  | +0   | CheckFile - Checking if F:\HyperSpin\Emulators\RetroArch\cores\mednafen_psx_libretro.dll exists 21:00:59:904 | MD |    INFO  | +0   | Module - Global cfg should be: F:\HyperSpin\Emulators\RetroArch\retroarch.cfg 21:00:59:904 | MD |    INFO  | +0   | Module - System cfg should be: F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg 21:00:59:904 | MD |    INFO  | +0   | Module - Core cfg should be: F:\HyperSpin\Emulators\RetroArch\config\mednafen_psx_libretro.dll.cfg 21:00:59:904 | MD |    INFO  | +0   | Module - Found a System cfg! 21:00:59:904 | MD |    INFO  | +0   | Module - RetroArch is using F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg as its config file. 21:00:59:904 | MD |    INFO  | +0   | LoadProperties - Started and loading this cfg into memory: F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg 21:00:59:906 | MD |    INFO  | +0   | LoadProperties - Ended 21:00:59:906 | MD |    INFO  | +0   | Module - Reading / creating system ini for specific settings. 21:00:59:906 | MD |    INFO  | +0   | File.CheckFile - Checking if "F:\HyperSpin\Emulators\RetroArch\retroarch-core-options.cfg" exists 21:00:59:906 | MD |    INFO  | +0   | LoadProperties - Started and loading this cfg into memory: F:\HyperSpin\Emulators\RetroArch\retroarch-core-options.cfg 21:00:59:907 | MD |    INFO  | +0   | LoadProperties - Ended 21:00:59:907 | MD |    INFO  | +0   | RIniFile.Read - Module - PSX_CD_Image_Cache: "enabled" (DEFAULT) 21:00:59:907 | MD |    INFO  | +0   | RIniFile.Read - Module - PSX_Memcard_Handling: "libretro" (DEFAULT) 21:00:59:907 | MD |    INFO  | +0   | RIniFile.Read - Module - PSX_Dualshock_Analog_Toggle: "enabled" (DEFAULT) 21:00:59:907 | MD |    INFO  | +0   | SaveProperties - Started and saving this cfg to disk: F:\HyperSpin\Emulators\RetroArch\retroarch-core-options.cfg 21:00:59:926 | MD |    INFO  | +31   | SaveProperties - Ended 21:00:59:926 | MD |    INFO  | +0   | Module - Retroarch standard mode enabled 21:00:59:926 | MD |    INFO  | +0   | BezelStart - Started 21:01:00:042 | MD |    INFO  | +109  | Bezel - Game will be moved to monitor 1 if RL finds a valid bezel to be show. 21:01:00:046 | MD |    INFO  | +0   | Bezel - Loading Bezel image: F:\RocketLauncher\Media\Bezels\Sony PlayStation\_Default\Bezel - 16x9 Sony Playstation (Austin585).png 21:01:00:071 | MD |    INFO  | +31   | Bezel - Loading Background image: F:\RocketLauncher\Media\Bezels\_Default\Background4 Nosh.png 21:01:00:075 | MD |    INFO  | +0   | BezelStart - Ended 21:01:00:076 | MD |    INFO  | +0   | RIniFile.Read - Module - P1_Controller_Type: 517 (DEFAULT) 21:01:00:076 | MD |    INFO  | +0   | RIniFile.Read - Module - P2_Controller_Type: 517 (DEFAULT) 21:01:00:077 | MD |    INFO  | +0   | RIniFile.Read - Module - P3_Controller_Type: 517 (DEFAULT) 21:01:00:077 | MD |    INFO  | +0   | RIniFile.Read - Module - P4_Controller_Type: 517 (DEFAULT) 21:01:00:078 | MD |    INFO  | +0   | RIniFile.Read - Module - P5_Controller_Type: 517 (DEFAULT) 21:01:00:078 | MD |    INFO  | +0   | RIniFile.Read - Module - P6_Controller_Type: 517 (DEFAULT) 21:01:00:079 | MD |    INFO  | +0   | RIniFile.Read - Module - P7_Controller_Type: 517 (DEFAULT) 21:01:00:080 | MD |    INFO  | +0   | RIniFile.Read - Module - P8_Controller_Type: 517 (DEFAULT) 21:01:00:080 | MD |    INFO  | +0   | Module - Saving changed settings to: "F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg" 21:01:00:080 | MD |    INFO  | +0   | SaveProperties - Started and saving this cfg to disk: F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg 21:01:00:105 | MD |    INFO  | +32   | SaveProperties - Ended 21:01:00:105 | MD |    INFO  | +0   | Process.Run - Running: F:\HyperSpin\Emulators\RetroArch\retroarch.exe  "F:\Roms\Sony Playstation\2Xtreme (USA)\2Xtreme (USA).cue" -c "F:\HyperSpin\Emulators\RetroArch\config\Sony PlayStation.cfg" -L "F:\HyperSpin\Emulators\RetroArch\cores\mednafen_psx_libretro.dll" -s "F:\HyperSpin\Emulators\RetroArch\srm\Sony PlayStation\2Xtreme (USA).srm" -S "F:\HyperSpin\Emulators\RetroArch\save\Sony PlayStation\2Xtreme (USA).state" 21:01:00:145 | MD |    INFO  | +47   | Window.Wait - Waiting for window "RetroArch ahk_class RetroArch" 21:01:39:339 | MD |   ERROR  | +39187 | ScriptError - There was an error waiting for the window "RetroArch ahk_class RetroArch". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 21:01:39:339 | MD |    INFO  | +0   | ExitModule - Started 21:01:39:339 | MD |    INFO  | +0   | Starting Updating Statistics: 21:01:39:782 | MD |    INFO  | +438  | Game section statistics updated. 21:01:39:782 | MD |    INFO  | +0   | ExitModule - Ended End of Module Logs 21:01:39:862 | RL |    INFO  | +40312 | Main - Module ended, exiting RocketLauncher normally 21:01:39:862 | RL |    INFO  | +0   | ExitScript - Started 21:01:39:884 | RL |    INFO  | +16   | ExitScript - Restoring taskbar 21:01:40:009 | RL |    INFO  | +125  | SystemCursor - Restoring mouse cursor 21:01:40:021 | RL |    INFO  | +16   | ExitScript - Restored cursor
