Haloman800 Posted October 15, 2016 Posted October 15, 2016 Is it possible to have multiple systems, but boot into a single wheel (e.g. MAME), example: hyperspin boots directly into MAME wheel, if a player hits the back button, then it shows all the wheels Sent from my SM-N920V using Tapatalk
Haloman800 Posted October 16, 2016 Author Posted October 16, 2016 Okay new question. Would it be possible to create a wheel with something like 60 MAME games? E.g. "All Time Favorites" with Pac-Man, Galaga, etc. And be displayed among the other wheels? Sent from my SM-N920V using Tapatalk
Metalzoic Posted October 16, 2016 Posted October 16, 2016 Okay new question. Would it be possible to create a wheel with something like 60 MAME games? E.g. "All Time Favorites" with Pac-Man, Galaga, etc. And be displayed among the other wheels? Sent from my SM-N920V using Tapatalk Sure. Just make another system wheel with what you want on/in it.
32assassin Posted October 16, 2016 Posted October 16, 2016 yes to both you can boot directly into a wheel, but you have to use a AHK script. go to YouTube and look for Hyperspin Nested it will show you how to create custom Main Menu wheels and how to jump from multiple main menu options to sub wheels. if you want to create a favorites system take the MAME XML, remove all the games you don't want or Make a new XML and add all the games you want from MAME. open HyperHQ add a new system --> MAME1 Open RLUI add all the settings you added to your MAME system to your custom system (MAME1) the global MAME emulator will be missing form the drop down menu in RLUI go to the RocketlauherUI Tab (farthest to the right) and in the General options section remove Valid emulators/module Only check this will display ALL the emulators in the drop down menu (when you assign an emulator in RLUI to a system)
Haloman800 Posted October 17, 2016 Author Posted October 17, 2016 yes to both you can boot directly into a wheel, but you have to use a AHK script. go to YouTube and look for Hyperspin Nested it will show you how to create custom Main Menu wheels and how to jump from multiple main menu options to sub wheels. if you want to create a favorites system take the MAME XML, remove all the games you don't want or Make a new XML and add all the games you want from MAME. open HyperHQ add a new system --> MAME1 Open RLUI add all the settings you added to your MAME system to your custom system (MAME1) the global MAME emulator will be missing form the drop down menu in RLUI go to the RocketlauherUI Tab (farthest to the right) and in the General options section remove Valid emulators/module Only check this will display ALL the emulators in the drop down menu (when you assign an emulator in RLUI to a system) Will this work even though I don't use rocketlauncher for anything? I have a hyperspin setup from 2012 that mainly launches everything directly (no hyperlaunch).Sent from my SM-N920V using Tapatalk
Haloman800 Posted October 17, 2016 Author Posted October 17, 2016 This is what I've decided on. I have a list of "favorites" from MAME. I want them in their own wheel under "Arcade Classics", but still have "MAME" which includes the entire list. Is there an easier way than manually creating a new wheel & adding all of the artwork? I can also post the favorites list if it helps. Sent from my SM-N920V using Tapatalk
Metalzoic Posted October 17, 2016 Posted October 17, 2016 This is what I've decided on. I have a list of "favorites" from MAME. I want them in their own wheel under "Arcade Classics", but still have "MAME" which includes the entire list. Is there an easier way than manually creating a new wheel & adding all of the artwork? I can also post the favorites list if it helps. Well you want to have a new wheel, so you need to create a new wheel with its own database etc... The media you can just copy paste (which would be dead simple if you have less than 100 games in the new wheel) or you could use symbolic links to share the MAME media folder between both systems.
heykool69 Posted October 19, 2016 Posted October 19, 2016 yes to both you can boot directly into a wheel, but you have to use a AHK script. go to YouTube and look for Hyperspin Nested it will show you how to create custom Main Menu wheels and how to jump from multiple main menu options to sub wheels. if you want to create a favorites system take the MAME XML, remove all the games you don't want or Make a new XML and add all the games you want from MAME. open HyperHQ add a new system --> MAME1 Open RLUI add all the settings you added to your MAME system to your custom system (MAME1) the global MAME emulator will be missing form the drop down menu in RLUI go to the RocketlauherUI Tab (farthest to the right) and in the General options section remove Valid emulators/module Only check this will display ALL the emulators in the drop down menu (when you assign an emulator in RLUI to a system) Thanks. Will be very helpful when i get a chance to get back on Hyperspin track again.
