No systems are opening from Main Menu. Just reloads Main Menu
Hyperion
***SOLVED***
Speakers need to be plugged in for Hyperspin to work.
________________________________________________
Hi Sports Fans,
First post in many years. Thanks in advance for any replies.
My problem is I'm trying to migrate my Hyperspin install to a new PC. Back in the day I had the foresight to make all my paths relative so it could be as portable as possible. Even so, I've copied my Hyperspin folder to a drive with the same drive letter as my old PC just to be sure.
Anyway, my problem is the exact same as this guy's: https://www.reddit.com/r/MAME/comments/1lej55/hyperspin_not_going_to_rom_list/
When I load Hyperspin the main menu works fine, all the animations and wheels are as they should be but if I select any of the systems, instead of it taking me to the rom list of the selected system it just reloads Hyperspin back to the menu. Another odd symptom is that when I press "back" in order to exit hyperspin the exit menu overlay is invisible. I can still choose "yes" from memory but I actually can't see the overlay, text or cursor.
I've test hyperlaunch outside in Hyperlaunch HQ and there's no problem loading roms there. The problem is with Hyperspin not showing me my rom list.
There's probably an obvious solution but I'm pretty rusty at good ol' complex as hell Hyperspin. ;)
Thanks.
My first cocktail cab: The Hyper Arcade Entertainment System
Win 7 64bit | i5 3570K Overclocked to 4.2GHz | 16GB 1600MHz DDR3 | GTX 970 Strix | Samsung 250GB 840 Evo SSD + 8x4TB green drives in RAID 5 for XBMC/KODI
All those look good to me. They're identical to the good system I'm copying them from which doesn't have this main menu problem. I did a HyperLaunch audit to check the databases. All good there. No filters in use as far as I can tell.
Here's my Hyperspin log:
07:59:42 PM |  HyperSpin Started
07:59:42 PM |  Going windowed mode
07:59:42 PM |  Checking for updates
07:59:42 PM |  Update Check Complete
07:59:42 PM |  Startup program unavailable
07:59:42 PM |  Error intializing joysticks
07:59:42 PM |  Menu Mode is multi
07:59:42 PM |  Loading Main Menu.xml
07:59:42 PM |  Main Menu.xml successfully loaded
07:59:42 PM |  Main Menu wheel loaded successfully
07:59:44 PM |  Loading Main Menu.xml
07:59:44 PM |  Main Menu.xml successfully loaded
07:59:45 PM |  Main Menu wheel loaded successfully
07:59:49 PM |  Loading Main Menu.xml
07:59:49 PM |  Main Menu.xml successfully loaded
07:59:49 PM |  Main Menu wheel loaded successfully
07:59:56 PM |  Exit program unavailable
07:59:56 PM |  Quiting Hyperspin
07:59:56 PM |  Bye!
Speakers! That old trick!
Thanks everyone! It was the speakers. All fixed. I've update the first post with the solution.
