nuklhed86
Hello,
Hopefully someone here can help. I can only play one game at a time in Hyperspin. It seems Hyperlaunch is stuck processing in Task Manager. I have to exit Hyperspin after every game play & manually kill the Hyperlaunch process in Task Manager then re-open Hyperspin. This is a pain & hopefully there's an easy solution. Thanks!
Are you using rocketlauncher or the old hyper LaunchHQ?
Have you setup your exit emulator hot key in the main settings (RL/HQ)?
I am using the latest versions of both RL & HL.
I am not aware of how to change those settings. My last laptop build i didn't have this problem. Please explain. Thanks again!
If your on the global tab, main settings there is a "exit emulator" command.
Set it to what you want via hotkey, I believe default it is escape....is that what it says?
Any thoughts? Still can't figure this one out! One & done...
Still need to figure out how to kill the process in task manager automatically instead of manually.
