Has anyone added NESiCAxLive to their HS?
rastan
Just set some games up outside of HS to get them running and I have some themes for HS. My guess is the same process for setting up TTX games will apply... and they seem to be cranking these bad boys out fast and furious... definitely looks like a nice add for those into Arcades. I'll admit that I haven't played any of the games yet or even configured the controls... but the games I tested ran and that's all I really cared about for the moment.
Well, I've redrawn the logo:
It's a start, at least you have a wheel/logo for a theme to use :)
Only problem I'm having and also noticing others are having the same issue... is with the controls. so far whenever i map the controls they just don't work.. the only key that works is whatever I map to exit/quit. I'm using xpadder but I even tried to just use keyboard to map controls and still no go. I'm sure sooner or later that issue will get worked out... as long as the games actually run is all I care about.. the controls can always be figured out down the road but hopefully I'll get it going sooner than later lol.
Find a idmac package. It supplies a config to set keys. Use keys in xpadder to use gamepad.
I have the ImacX which had all the required extras to set everything up.... but for some reason it's not working for me. it comes with the Jconfig but people say TTX.congfig.exe works better.. I've tried both but will be messing with it again... it has to be something
went back and played with it... it was a weird one... I basically used the typex.config.exe to create the typex bindings then I renamed that .bin file to the monitor_input.bin and opened jconfig and set the buttons... and it worked.. I did also notice that whatever I put for service... was triggering player 1 coin. whatever the case it works.
5 hours ago, cataclysm67 said:
I mapped the controls using xpadder for XBOX 360 Controller and they all seem to work fine (the 10 I have running that is :) )
I was able to setup the controls fine for most of the games but a few just won't work for whatever reason.. I've tried over and over to get the controls to work but a few of the game I have already setup with taito type x so it's no big deal but I have a HD patch for the Nestica games and they seem to look better but it could be all in my head lol.
Hi friends
I am having exactly same problem as you mentioned, and I did followed your trick but still cant get it work. Renamed the file and opened jconfig and set buttons again and save, closed. But nothing is working
7 hours ago, shitoken said:
Hi friends
Some of the Nesica games work fine with the jconfig but some don't. I can't get trouble witches to work and other games but some of the games I have on Taito Type X so it's no big deal but for sure I can tell you some of the nesica game just won't work with the jconfig. Like I said I originally used the type x config and just renamed the file and for whatever reason it worked but I will also say that I noticed whatever I set for the service button was acting as the coin button. I don't know which games you tried to get working but I have the entire nesica collection that was released recently and I managed to get most of them working and some just wouldn't work.
I also have the latest complete set.
Tried your way with the game cosplay mahjong Blaze and few others runs fine but can't get the sticks to work , I am on ultimarc ipac and can play typex games without any problem. Dont know why.
Chaos I can't run the game at all getting error of sav not exists.
Tapatalk を使用して私の A0001 から送信
what's also weird is someone on one of the sources/outlets that has been leaking the games.. posted some default keyboard controls.. which don't seem to work..  I've pressed every key on the keyboard and nothing happens so I'm not even sure there are default keyboard controls. Most arcade pc dumps are expected to have their issues but hopefully Nesica will get like taito type x games.. at least with the controls actually working.. but again some people seem to have them working so I really don't have a clue why certain games work with no problems and others refuse to work with controls even after setting them up. coud also be a direct input issue or something.. who knows?
They released new jconfig , I think you should try that and dont use the one come in package , that might be working with arcade sticks now and other pads. but not yet have time to try. Most confirmed 95% of the problem been solved and working with 360.
