Creezz67 Posted January 2, 2017 Posted January 2, 2017 Hi, does anyone have the settings for sega saturn & sega cd to use on nvidia shied tv ? thanks for any info
reznnate Posted January 2, 2017 Posted January 2, 2017 These work for me... Uoyabause exe=org.uoyabause.android/org.uoyabause.android.Yabause parameters=org.uoyabause.android.FileNameEx Retroarch - SegaCD exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture parameters=cores/picodrive_libretro_android.so
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 thanks, got it all setup but game wont load they are in bin,cue format do your settings have cue,bin,iso ? thanks
thatman84 Posted January 2, 2017 Posted January 2, 2017 Sega CD or Saturn? i just finished Sega CD today been testing on Genesis Gx core though. Sega CD extensions bin,cue,iso,BIN,CUE,ISO Not Tried Saturn yet it's on the list after 3DO rom sorting Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 hi, yes sega cd any chance you can list your settings for this system ? got sega saturn working now problem, tried pico and genesis gx core and genesis gx goes to play it but black screen thanks
thatman84 Posted January 2, 2017 Posted January 2, 2017 Sega CD.ini FYI dont use this settings file as my special art and game text is custom You also need the Sega CD BIOS files Open RA load the core and go and look in Information Core Info That will show you the BIOS files needed Place them in you Retroarch System folder (Wherever your RA System/BIOS Directory is pointing to) Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
philcabs66 Posted January 2, 2017 Posted January 2, 2017 Happy new year 2017 For Sega CD i use MdEmu it's working flawlessly. And for Saturn Uoyabause I attach my config files ??Sega CD + Saturn USA/Jap Sega Settings.zip
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 ahh, it's the sega cd bios I must be missing. I will try that Thanks
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 thanks, i will try mdemu if retroarch does not work. i have added bios files and all are present now, but when i load game its just a black screen i have 65 other systems running fine, this one just does not want to know it tries to load it but just sits there any ideas ?
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 question, can you play roms from external drive for sega cd ? just tried and i get error opening file thanks
thatman84 Posted January 2, 2017 Posted January 2, 2017 i run them from a network drive without bios I just got screen flick no black screen Your roms are bin/cue? (SINGLE bin/cue) bin named as HS xml? Cue named as HS aml & inside the cue file you have renamed the line pointing to the .bin file to match the new .bin file name? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
reznnate Posted January 2, 2017 Posted January 2, 2017 If bios isn't issue, for some reason, some emulators prefer .cue first (or vice versa) Sent from my Nexus 6P using Tapatalk
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 CRACKED IT, thanks to thatman84, you learn something new every day. sega cd roms work fine on hyperspin for pc as they are, but yes i had to change the cue name to match the .bin now it's working. Thanks again
thatman84 Posted January 2, 2017 Posted January 2, 2017 Good news i just spent many hours over the last few days converting a whole set from Ccd/img to bin/cue and renaming them. Less frustrating than trying to find the right set online Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 yeah it's a slog, I spent forever converting a whole set of Sega Dreamcast roms in a similar way. Now it looks like Sega CD cue files will all need editing and changed to match .bin name Thanks again
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 Just noticed I have .img files in my set too what did you use to convert ? THANKS
Creezz67 Posted January 2, 2017 Author Posted January 2, 2017 Also, FYI some games are freezing at the start of loading the games - using MDEmu Adventures Of Batman & Robin, The (USA) - freezes about 10 seconds into game Cobra Command (USA).zip - freezes when on loading screen
thatman84 Posted January 2, 2017 Posted January 2, 2017 I have VirtualClone Drive & imgBurn Mount the ccd file to a virtual drive Open imgBurn and hit "Create image from disk" Set an Output directory and start. only takes a min or 2 to convert. Then rename the output files Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
