tjay Posted March 30, 2010 Posted March 30, 2010 I saw something - or at least thought I saw something - that said hyperspin now has multiple emu support for one wheel. How do I do this? I know its probably something really simple because I haven't found a thread yet that mentions this
tjay Posted April 1, 2010 Author Posted April 1, 2010 I got this quote from the homepage " We've gathered lots of feedback on the features that our users have been wanting including faster list navigation, favorites support, more controls options, main menu program launching, fuller backend, built in BetaBrite support, multi emu support from one wheel etc..." Maybe I got the wrong impression of what this actually means. Does this mean I can put games that use the zinc emu (or any other emu) and put it on the mame wheel?
shimoda Posted April 1, 2010 Posted April 1, 2010 YEs, you have to install Zinc, although it doesn't have to APPEAR in the main menu. There are some threads about this out there, but a short tutorial will be forthcoming on the docs pages. In the xml for the system (MAME) you would place <exe>Zinc</exe> for the game's executable selection. path=c:\HyperSpin;%path% ; clear the runway, HyperSpin is coming through! for /f "tokens=not_enough delims=gameover" %%A in (HSKicksAss.txt) do echo believe the hype > badassfrontend.txt[sIGPIC][/sIGPIC]
SomeOldDoor Posted April 1, 2010 Posted April 1, 2010 I'm also really interested in getting this working on my system. I've done a little search around and found a few threads that mention it, but I haven't really been able to find concrete instruction on how this fits together and works. I'm interested in only having a small number of games working on my system, so having a single menu would be ideal. The games I am planning on include a mixture of SNES, Genesis, Arcade and PC games. Is it possible to make a menu that uses both emulators and allows launching of PC games? How are themes and images managed on a multi-wheel emulator? Lastly, does the <exe> tag refer to the "System" name for the scripts in the Hyperlaunch ahk, or to an actual exe file somewhere on my system? Thanks to everyone who has worked/is working on Hyperspin. Definitely the most impressive cabinet frontend I've ever seen! J
Zinger19 Posted April 1, 2010 Posted April 1, 2010 This is how I did it. For an example I will use psxfin and espxe. Prob the easiest thing for you to do would be to set up both emulators using the main menu wizard. You don't have to but this is what I did. This will create 2 different Playstation emulators on your main wheel. Set up all your emulator information rom path,ext,hyperlaunch,ect... This will create your system.ini files(which I believe this is whats needed for multiple emulators).One for psxfin and one for and one for epsxe If you want to do it manually without creating all the theme folders and theme information in your ini file then this is how you would do it. For Ex: [exe info] path=D:\Arcade\PSXfin\ rompath=D:\HyperSpin\Emulators\Sony Playstation\EPSXE\roms\ userompath= exe=psxfin.exe romextension=iso,bin,img parameters= searchsubfolders= pcgame=false winstate=HIDDEN hyperlaunch=true This is my secondary emulator system.ini file for psxfin. This is really all you need to have in you ini file in order for it to work work as a secondary emulator. You could also just copy and paste your main playstation emulator ini settings into a new text document, edit your rom path,exts,and turn hyperlaunch on or off. Next you'll want to save the file for example as Epsxe.ini,and place it in the settings folder in Hyperspin. Now that we've gone over creating ini files lets move on to the next step.You are going to want to remove your secondary emulator from the main wheel xml if you used the hyperlaunch main menu wizard to create your ini files. Next we are going to edit your Sony Playstation XML. Lets assume that I'm using Psxfin for my main emulator, but I have a game that doesn't work with it. We will using Blood Omen for the example because it doesn't work for it(At least not correctly). All you are going to need to do now is add add this line to your XML <exe></exe> <game name="Blood Omen - Legacy of Kain (U) [sLUS-00027]" index="" image=""> <description>Blood Omen - Legacy of Kain (U) [sLUS-00027]</description> <cloneof></cloneof> <crc> </crc> <manufacturer> </manufacturer> <year> </year> <exe>Epsxe</exe> This should be the name of your system.ini file your created <genre> </genre> That's pretty much all there is to it. NES Arcade Build StarKade: A Raspberry Pi Arcade 80's Toy Collection
tjay Posted April 1, 2010 Author Posted April 1, 2010 Thanks guys I appreciate the help. I'll try to get this working tonight
SomeOldDoor Posted April 2, 2010 Posted April 2, 2010 Thanks Zinger19 for the detailed help. I'm going to try this out too. I still have one question regarding this setup that I think was not addressed in what people have said so far. I can see how by doing what Zinger19 suggested I can get multiple emulators working, but what if I also wanted to have just normal LNK files to launch PC games in the same wheel. Could I get that to work somehow? If so, how would I go about it? Thanks again!
SophT Posted April 3, 2010 Posted April 3, 2010 but what if I also wanted to have just normal LNK files to launch PC games in the same wheel. Could I get that to work somehow? If so, how would I go about it? Yes- what you do is create a PC games wheel where the extension is LNK, and then set the exe to PC Games. After that you can even remove the PC Games wheel item from main menu if you don't want it to appear, just leave the back end files there. Things I Break ----- System Requirements? How do I remove rom warnings? How do I shut-down my computer? How do I shell HyperSpin?
SomeOldDoor Posted April 5, 2010 Posted April 5, 2010 Finally got a chance to try this out this weekend. Everything works perfectly! Combined with the HD Monitor workaround thread in this forum I've got HS set up almost exactly like I want. Thank you again to those who answered on this thread! Great community + great application = awesome.
marcade Posted May 17, 2010 Posted May 17, 2010 thanks for the write up, took me a while to set it up as your instructions were a bit confusing. Got there in the end, i setup naomi this way to work with vertical and horizontal games. cheers
jclausing Posted September 21, 2010 Posted September 21, 2010 I am completely confused. I am trying to set up where I can launch a few PC Games from the single wheel where all other games appear. I have reviewed the tutorial for setting up un-supported emulators but do not understand how to launch the PC game. Is there anyone that can give a simple to follow version from A to Z?
dark Posted October 15, 2010 Posted October 15, 2010 Yea I just wanted to thank Zinger19 for posting this, it really helped me out too.
TheManuel Posted October 17, 2010 Posted October 17, 2010 Thanks for the informative post. One more question: If I set up some games to use a different emulator than the system they're under, I would have to also set the <exe></exe> line in the genre xml files where the game appears, correct? Otherwise, launching from one of the genre wheels would use the default emulator.
ZedEx48K Posted December 19, 2011 Posted December 19, 2011 Hi, thanks for the little guide, has helped sort me out (doing a driving game only list) however I'm failing to add a PC game to it (Outrun 2), I can add and get it running from the main wheel, but seem to fail when adding it to the xml, any help would be great cheers. Welcome to the fantasy zone, get ready!
Pyramid_Head Posted December 19, 2011 Posted December 19, 2011 Hi, thanks for the little guide, has helped sort me out (doing a driving game only list) however I'm failing to add a PC game to it (Outrun 2), I can add and get it running from the main wheel, but seem to fail when adding it to the xml, any help would be great cheers. I'm actually in the process of doing the same thing and successfully added Outrun 2006 PC to the list if that's what your referring to? I can post my list if you wish. I'm still adding stuff to it ha ha.
ZedEx48K Posted December 19, 2011 Posted December 19, 2011 I'm actually in the process of doing the same thing and successfully added Outrun 2006 PC to the list if that's what your referring to? I can post my list if you wish. I'm still adding stuff to it ha ha. Yes, that would be great thanks, once I know how to do one the rest should be easy. Welcome to the fantasy zone, get ready!
Pyramid_Head Posted December 20, 2011 Posted December 20, 2011 Yes, that would be great thanks, once I know how to do one the rest should be easy.Sure thing! I've been trying to post to Hyperlist but for some odd reason it won't let me. I'd love for others to add to it and post it back Here ya go! hope you're familiar with Pastebin though it's pretty straight forward. Enjoy! http://pastebin.com/5G6AQvcP
ZedEx48K Posted December 21, 2011 Posted December 21, 2011 Cheers for that, I managed to figure out PC launching the other morning, I see you are doing the same as me and creating just a driving game list, can I ask which Dreamcast emu you are using? The Hyperspin launcher gives me an error when using the last release of NullDC and I can't get a working command line to launch the disc image I want, actually I might as well ask you how you got Vivanonno working too Welcome to the fantasy zone, get ready!
ZedEx48K Posted December 21, 2011 Posted December 21, 2011 Actually I notice you have a few 360 degree racing games in there too (Pole position, turbo), they are actually spinner games like Supersprint, and thusly I have given up on those since they don't properly config to a 270 degree wheel as you are probably using like the rest of us. Welcome to the fantasy zone, get ready!
Pyramid_Head Posted December 21, 2011 Posted December 21, 2011 Cheers for that, I managed to figure out PC launching the other morning, I see you are doing the same as me and creating just a driving game list, can I ask which Dreamcast emu you are using? The Hyperspin launcher gives me an error when using the last release of NullDC and I can't get a working command line to launch the disc image I want, actually I might as well ask you how you got Vivanonno working too Sure thing! I'm using the latest Nulldc found here http://www.emucr.com/2011/09/nulldc-optimized-svn-r139.html are you using Hyperlaunch 2.0 and the right module?Sorry about the 360 degree games. I honestly didn't know that until you mentioned it. I always assumed they are analog games like mos tof the other driving/racing games. Though I'll keep them in the list since they are driving games. I also added a lot more games. I'm still adding more so I'll post an updated version. Still sucks I can't upload it to Hyperlaunch
ZedEx48K Posted December 21, 2011 Posted December 21, 2011 Hey, 360 games are fine, I had them in my list till I found out they are a pig to play on a wheel, I think there are a couple more games like that, ooh Roadblasters I think is a dodgy one plus it needs up and down analogue for firing. As for the DC, yes I have that version (needed it for the analogue controls), I have the latest HS but when using it I get either a plugin error from NullDC, or if I use HS it launches to the point where I get the little box with the iso selector, if I select that I can hear NullDC start but not see it, but on exit I have the VMU emulator open Or if I launch it as an exe with the command line -config ImageReaderefaultImage="%romPath%%romName%%romEx tension%", %EmuPath%,Hide UseErrorLevel it does the same, I'm wondering if it is a NullDC setting I've missed. I will end up having spent more time setting this up than playing on it Welcome to the fantasy zone, get ready!
Hypnoziz Posted December 21, 2011 Posted December 21, 2011 Make sure you didn't miss: Emulator.AutoStart=1 and LoadDefaultImage=1 in nullDC.cfg. <em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
ZedEx48K Posted December 21, 2011 Posted December 21, 2011 Make sure you didn't miss: Emulator.AutoStart=1 and LoadDefaultImage=1 in nullDC.cfg. I have both those selected, could it be to do with the surrounding image options? [imageReader] PatchRegion=0 LoadDefaultImage=1 DefaultImage=default.gdi LastImage=D:\emulators\roms\dc\18 Wheeler.cdi I sometimes get this error too "unhandled exeption while initiating image reader plugin by authors etc Welcome to the fantasy zone, get ready!
ZedEx48K Posted December 21, 2011 Posted December 21, 2011 I now get "sega dreamcast is an invalid system name or nulldc.exe isn't supported yet" Welcome to the fantasy zone, get ready!
