tpedge Posted January 28, 2017 Posted January 28, 2017 Hi all, This is my first post (please be gentle ). I've been lurking for a while, reading a lot and I've managed to get HyperSpin setup on my PC with a whole bunch of systems. I've also got HyperSpin installed on my NVIDIA Shield Portable. So far on the shield I've got MegaDrive/Genesis, GBA, PSX and N64 working through RetroArch but I'm getting no where with MAME. I'm using a 0.182 romset, I know this is the most recent so I wondered if that might be the problem? However launching the games manually in MAME4Droid works fine. I've tried editing the settings file with the instructions in this thread to work with MAME4Droid. That didn't work so I tried setting it up through RetroArch which also isn't working for me. If I open HyperSpin and select MAME from the Main Menu the Main Menu just refreshes, I never get to the list of games. I think I have the settings file set up correctly and I've copied over the database that works fine on the PC over to the shield. Here are my settings: [exe info] path=H:\hyperspin\emulators\MAME\ rompath=Emulators/MAME/roms/ userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=zip parameters=mame_libretro_android.so I'd usually consider myself fairly tech savvy but this is my first Android device so I could really do with some help. Any suggestions? Thanks in advance!
thatman84 Posted January 29, 2017 Posted January 29, 2017 We are all gentle round here don't stress!! Well normally If your not getting a games list then it's likely Hyperspin can't see your roms or database. double check you have the xml and all files/folder named the same then check your rompath= Line to make sure it's right also set all the filters to false for testing including rom only. It should get you the games list at least Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tpedge Posted January 29, 2017 Author Posted January 29, 2017 Thanks @thatman84. I hadn't noticed I had themes_only set to TRUE in the MAME settings file, it's always the little things... So now I can get into the list of Games within the HyperSpin launcher but if I select one the screen moves backwards as if it's trying to load and then moves forward again. I assumed this was because RetroArch couldn't find the core. So I tried launching the game directly in RetroArch from the Load Content option. This crashes RetroArch. I've tried using the Online Updater to install the cores and it seems to be installing them. Is there a way to check which cores are installed? As I said I'm new to Android but going to /storage/emulated/Android/data/com.retroarch/files/system/ gives me an empty folder and I thought I'd find the installed cores there?
thatman84 Posted January 29, 2017 Posted January 29, 2017 The in stalled cores are in a root folder. Without a rooted device you can't see them. data/data/com.retroarch or data/user/0/.... im not rooted so never remember the exact path look under retroarch settings-> Directory in the gui another way is to choose load content &I detect core. Choose a zip file and it will list all cores you have that are compatible with .zip files. be aware hyperspin uses a different retroarch.cfg file than retroarch itself. search on here for retroarch dual config trick. I put something out about it as others have. or boot a working game from another system in HS and go into retroarch gui. Close the core and you can edit settings for the HS launched retroarch.cfg to match that of the settings in the one retroarch uses (retroarch uses the retroarch.cfg found in "android/com.retroarch/files") the system folder should only have bios files and any mame folders you create and copy yourself into it Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tpedge Posted January 29, 2017 Author Posted January 29, 2017 We seem to be getting closer. When I choose load and detect core. It gives me the choice of a whole bunch of emulators. Arcade (MAME) launches the game fine - the controls don't work but it's progress. Launching from HS with the settings as above still doesn't work though.Sent from my iPhone using Tapatalk Pro
thatman84 Posted January 29, 2017 Posted January 29, 2017 may be the rompath where do you have them? also the mame core was updated recently and inputs have changed. read the mame 181 is horrible thread it has the details near the bottom Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tpedge Posted January 29, 2017 Author Posted January 29, 2017 The roms are on the SD card: /storage/sdcard1/Hyperspin/Emulators/MAME/roms/mshvsfu.zip I'm using the same format of rompath for the other systems that I've managed to get working so I'm a bit stumped.
thatman84 Posted January 29, 2017 Posted January 29, 2017 This is from memory as I'm not at Shield and I don't use retroarch for normal MAME! unless you tell retroarch your roms are in that location it will be looking for them in its own system folder. com.retroarch/files/system/mame/roms is where it wants them BUT you have options try putting one or two roms in that location above and launch them from HS. i will set it up and drop you the a MAME.ini file for retroarch and HS later. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tpedge Posted January 29, 2017 Author Posted January 29, 2017 I'm not wedded to RetroArch. To be honest I used it as it had been so simple to setup for the other systems. If you'd suggest a different emulator I'd be happy to try that instead. I'll try copying some roms there and see if it helps though.
thatman84 Posted January 29, 2017 Posted January 29, 2017 Retroarch MAME is the most current version and will keep current ish. Mame4droid (red one) is the other option but that uses a .139 set of roms so you would really need that. mame is a pain to setup anyway because it's such an expansive emulator to be inside such another expansive emulator. It's like the emulator Matrix i will drop you some stuff soon Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted January 29, 2017 Posted January 29, 2017 @tpedge i think I got some stuff wrong. i changed my setup point at a MAME set on a network drive for using retroarch and to worked straight away without any need to tell retroarch where the roms are. notbsure why it's not loading for you but I don't want to mess with my setup anymore for testing sorry. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tpedge Posted January 29, 2017 Author Posted January 29, 2017 No worries dude. Thanks for your help so far. I'll keep fiddling and see what I can do. I'll post the fix when/if I find it. Sent from my iPhone using Tapatalk Pro
thatman84 Posted January 29, 2017 Posted January 29, 2017 Please do. just confirm the fault again if you can. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
tpedge Posted January 30, 2017 Author Posted January 30, 2017 The issue I'm having is that when I launch a game from the MAME wheel in Hyperspin the window drops back like it's going to launch another application and then moves back to fill the screen again. I'm sure I've missed something really simple but I have no idea what it is and it's driving me crazy. Potentially helpful information... This is on an NVIDIA Shield Portable running Android 5.1 with a 128Gb Micro SD card My Hyperspin folder is at the root of the SD card which android sees as: /storage/sdcard1/Hyperspin/ The Hyperspin install works fine running Megadrive, Nintendo 64, Gameboy Advance and Playstation games My MAME roms are inside: /storage/sdcard1/Hyperspin/Emulators/MAME/roms The roms are from a non-merged 0.182 romset stored as zip files The roms play fine when loaded manually from inside RetroArch My full MAME.ini file looks like this: [exe info] path=H:\hyperspin\emulators\MAME\ rompath=Emulators/MAME/roms/ userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=zip parameters=mame_libretro_android.so searchsubfolders=false pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false roms_only=true [themes] use_parent_vids=true use_parent_themes=true animate_out_default=false reload_backgrounds=true [wheel] alpha=.15 small_alpha = 1 style = normal speed = high pin_center_width = 500 horz_wheel_y = 512 vert_wheel_position=right y_rotation = right norm_large = 360 norm_small = 230 vert_large = 400 vert_small = 240 pin_large = 500 pin_small = 200 horz_large = 240 horz_small = 150 letter_wheel_x = 800 letter_wheel_y = 384 text_width = 700 text_font = Style2 small_text_width = 260 large_text_width = 400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance = 0 shadow_angle = 45 shadow_color=0x000000 shadow_alpha = 1 shadow_blur = 0 [pointer] animated=true x = 975 y = 384 [video defaults] path=H:\hyperspin\Media\MAME\Video\ [sounds] game_sounds=false wheel_click= true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=false remove_info_text=true use_last_game=true last_game=thunderl random_game=false start_on_favorites=false [Special Art A] default=true active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [Special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [Special Art C] active=false x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active = true show_year = true show_manf = true show_description = true text_color1 = 0xFFFFFF text_color2 = 0xFFFFFF stroke_color = 0x000000 text_font = Style3 text1_textsize = 26 text1_strokesize = 7 text1_x = 32 text1_y = 610 text2_textsize = 36 text2_strokesize = 8 text2_x = 30 text2_y = 640
tpedge Posted January 30, 2017 Author Posted January 30, 2017 I'm such a muppet. parameters=mame_libretro_android.so Missed out the beginning of the parameters. It should have been: parameters=cores/mame_libretro_android.so Thanks @thatman84 sorry for being such a n00b.
thatman84 Posted January 30, 2017 Posted January 30, 2017 Doh I should have spotted that the 1st time you posted it!!! Its always a simple thing. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
