aftermath17 Posted February 12, 2017 Posted February 12, 2017 I upgraded to RetroArch 1.4.1. It kept my custom path for my System/BIOS folder for RetroArch when launched by itself. When I launch through Hyperspin, the path has been reset to /data/data/com.retroarch/system. I want to change this to /storage/emulated/0/RetroArch/system (sdcard/RetroArch/system). I can't because there is no way to browse that folder through the interface. When I click to change it, the only path options available are: /data/data/com.retroarch /storage / None of those will allow me to browse to /storage/emulated/0. If I click into storage > emulated, 0 never displays because the Android OS doesn't have access to /storage/emulated. I also can't directly edit the cfg because it's in /data/data which I also don't have access to. How can this be changed? Or, how does RetroArch generate the list of folders as default when I click to change a path?
Pouteur Posted February 13, 2017 Posted February 13, 2017 Just click to "/" then you can browse to the path you want
aftermath17 Posted February 13, 2017 Author Posted February 13, 2017 I tried that and it wouldn't work, said permission denied (because we don't have access to "/" unless we root the device?)
talonx32 Posted February 14, 2017 Posted February 14, 2017 Hi I'm having the exact same issue when trying to play a CD base game. The fix for this was to start a game in Hyperspin that doesn't require a bios and go into RetroArch bios setting (which defaults to /data/data/com.retroarch) but any attempt to change this to my preferred location is not allowed because hitting the "/" results in an empty screen with <use this directory> and nothing else. Im currently trying to set this up on the Nvidia Sheld TV 2017 500G. Thanks,
aftermath17 Posted February 14, 2017 Author Posted February 14, 2017 6 hours ago, Pouteur said: My device isn't rooted and i can go there Yes you can go to "/" but you can't start navigating further up the tree, you're stuck there. I can provide a screenshot, you definitely can't navigate. I can see why, we don't even have read writes to "/".
aftermath17 Posted February 14, 2017 Author Posted February 14, 2017 2 hours ago, talonx32 said: Hi I'm having the exact same issue when trying to play a CD base game. The fix for this was to start a game in Hyperspin that doesn't require a bios and go into RetroArch bios setting (which defaults to /data/data/com.retroarch) but any attempt to change this to my preferred location is not allowed because hitting the "/" results in an empty screen with <use this directory> and nothing else. Im currently trying to set this up on the Nvidia Sheld TV 2017 500G. Thanks, Yes, same issue. I resolved this by moving my RetroArch system folder and config folder to my external HD (where I store all my Hyperspin stuff). I just created a RetroArch folder there and added folders for system and config. Then I pointed my "standalone" RetroArch system and config folders there as well as my "Hyperspin" RetroArch folders there. Now everything works and should always work because I always have access to my external drive by navigating via /storage.
thatman84 Posted February 14, 2017 Posted February 14, 2017 I think I remember testing this the other day. Any game launching retroarch from Hyperspin uses the retroarch.cfg in the data/data root folder and navigating around the directories does not work. you do as above I guess but I didn't try that. The other fix is to use the duel config trick I posted in emulators forum. That will let you change most directories Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
talonx32 Posted February 14, 2017 Posted February 14, 2017 2 hours ago, aftermath17 said: Yes, same issue. I resolved this by moving my RetroArch system folder and config folder to my external HD (where I store all my Hyperspin stuff). I just created a RetroArch folder there and added folders for system and config. Then I pointed my "standalone" RetroArch system and config folders there as well as my "Hyperspin" RetroArch folders there. Now everything works and should always work because I always have access to my external drive by navigating via /storage. Thanks, When I get home ill try this method.
thatman84 Posted February 14, 2017 Posted February 14, 2017 Best to make point your config, remaps and anything you may use to some local folders at the same time. I point almost everything at the RetroArch folder on the internal storage. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
talonx32 Posted February 15, 2017 Posted February 15, 2017 Ok I tried to copy the system and config folder on the device but when I navigated to the /sdcard/Andriod/data/com.retroarch/files I don't see a system folder but I do see the config files, am I in the right area? Anyway I create a system and config folder were I have my "hyperspin" and RetroArch installed. I copies the config file over and started up RetroArch went into the config setting > pointed to the new location were I place the files in including the bios settings then I quit RetroArch. I open up Hyperspin and started a genesis game, I press the button to go into RetroArch to see if it was pointing to my config file but it was showing the original default path. I tried to change it to where I put the bios and the config file but it just show the same option as before. I know I probably miss something or maybe I need to reinstall RetroArch so I'm going to try again tonite.
sonkun Posted February 15, 2017 Posted February 15, 2017 If you're changing your Retroarch core directory within Hyperspin then also remember to hit "Save core overrides" in the Quick Menu before quiting that way your settings actually saves. At least that's how it works for me using retroarch 1.4.1
thatman84 Posted February 15, 2017 Posted February 15, 2017 You need to create a system folder. i created mine and put it in the RetroArch folder that's in the main internal storage you shouldn't need to reinstall RA but if you don't have much setup may aswell. use the config trick Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
talonx32 Posted February 15, 2017 Posted February 15, 2017 I really appreciate the help guys and will be trying the config trick when I get home.
thatman84 Posted February 15, 2017 Posted February 15, 2017 On that side I just recorded a really rough video for it, gonna check it make sure it's not really bad. Lol no voice I'm afraid as I can't stand talking to myself. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted February 15, 2017 Posted February 15, 2017 Heres that video It may be a little fast to follow. Check the steps in the video discription Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
aftermath17 Posted February 17, 2017 Author Posted February 17, 2017 On 2017-02-14 at 5:48 AM, Pouteur said: My device isn't rooted and i can go there Yes you can choose "/" but you can't list the contents in the directory nor can you continue browsing after "/", regular users do not have list, read or write privileges to the root folder. I just tried this on a second Shield, it does not work.
lovebus5 Posted May 29, 2017 Posted May 29, 2017 I just did this, following the video, and it worked! thanks for the effort
thatman84 Posted May 29, 2017 Posted May 29, 2017 Glad it worked Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
