KennethRyan Posted March 10, 2017 Posted March 10, 2017 This button I have my finger on is not customizable in the MAME tab menu. It exits the game which makes it nearly impossible to finish a game because player 2 eventually hits it. I'm fairly new to joytokey and hyperspin. It registers as "button 3" on joytokey. Any suggestions?
MydknyteStyrm Posted March 10, 2017 Posted March 10, 2017 If it exits Mame then your Mame exit is probably set to that key. Why are you using JoyToKey for buttons? What encoder are you using for your buttons?Sent from my iPhone using Tapatalk
KennethRyan Posted March 10, 2017 Author Posted March 10, 2017 I'm guessing somewhere here is my problem?
KennethRyan Posted March 10, 2017 Author Posted March 10, 2017 When I edit those mame settings it brings up joytokey
Spawk Posted March 10, 2017 Posted March 10, 2017 He's right, I don't think you need JTK at all. Your buttons should already be registering as keystrokes. No? If your control panel is for some reason recognized as a "joystick" windows then check out my JTK tutorial for how to integrate it properly with RL.
mafiafan123 Posted April 29, 2017 Posted April 29, 2017 Remove JoytoKey Mame profile backup just incase needed. Then launch mame and hit tab on your keyboard config keys press delete to remove any old data for that key when done test. Then hit tab exit game. If mame won't exit then you need to add a script to startup and end JoytoKey with mame Sent from my iPhone using Tapatalk
joseph2626 Posted May 22, 2017 Posted May 22, 2017 your configration is wrong from my view . in Mame it reads like that : player 1 buttton 0 in your case is button 1 player 1 button 1 in your case is button 2 player 1 button 2 in your case is button 3 and so on so as i can see in your case you configered 2 as escape button so mame reads it as button 3 and it should be Esc button on your keyboard. thats why it escapes delet player 1 and player 2 joystick configration from HQ in mame just hit TAB button on keybord to simply configer any machine in other systems use joy to key generally Esc button is to exit in all programs so leave it as exit button. hop i helpd.
