extracampine Posted April 4, 2017 Posted April 4, 2017 Pulling my hair out over this one! Things were working fine around a week ago - but over the last few days I've been trying to play Nintendo Entertainment System games, and there is no sound! I am using Rocketlauncher to launch and Retroarch with the Nestopia.ahk module. There is sound when browsing in Hyperspin itself, and I get the "loading complete" speech, but as soon as the game is running then there is no sound! I tried loading a game via HS/RL/RA with a different emulator (Sega Master System) and the game loaded but there was no sound there either. Any help or pointers would be much appreciated. Running on 2016 Macbook Pro.
Metalzoic Posted April 4, 2017 Posted April 4, 2017 Do you have sound within Retroarch or Nestopia turned off or muted? Either in the emulator or in your Windows sound mixer?
extracampine Posted April 4, 2017 Author Posted April 4, 2017 Wow...such a simple thing. Yes, the sound for Retroarch was muted in the Windows mixer. No idea why, as I don't recall ever muting it! While you're here, may I ask something else? If you don't know I can open another thread. Basically, when I change the screen size in Retroarch for the emulator (under video settings then custom viewport size) this works, but when I close down and restart RA/the emulator, the setting is not remembered. I tried selecting save current config in RA but still no beans. I also selected allow per core configuration in RA but same issue. Edit: I figured out one way to do it, but not sure if it is the right way: I edited the retroarch.ini file and changed the CustomViewportWidth settings under the NES heading.
extracampine Posted April 4, 2017 Author Posted April 4, 2017 Now I've noticed that whenver I run a game in Retroarch, Retroarch goes muted in the Windows mixer. I can unmute it and it then works fine, but why is this happening and how can I stop it?
dougan78 Posted April 4, 2017 Posted April 4, 2017 Now I've noticed that whenver I run a game in Retroarch, Retroarch goes muted in the Windows mixer. I can unmute it and it then works fine, but why is this happening and how can I stop it?I know there is a setting in rocket launcher if you are using that, that can mute the emulator. Test not setting that to true. Good luck.Sent from my SM-G920V using Tapatalk
extracampine Posted April 4, 2017 Author Posted April 4, 2017 I couldn't find that setting in RocketLauncherUI - do you know where it is? Thanks.
Metalzoic Posted April 4, 2017 Posted April 4, 2017 2 hours ago, extracampine said: Wow...such a simple thing. Yes, the sound for Retroarch was muted in the Windows mixer. No idea why, as I don't recall ever muting it! Maybe you hit a hotkey? I can't answer the rest. I don't use Retroarch at all, I don't think it's any good. Sorry. 52 minutes ago, extracampine said: I couldn't find that setting in RocketLauncherUI - do you know where it is? Thanks. I think it's under a systems Fade settings. Mute during fade in = true/false. Even when set to true it's supposed to unmute when the game loads, but maybe it isn't for some reason.
dougan78 Posted April 4, 2017 Posted April 4, 2017 I think it's under a systems Fade settings. Mute during fade in = true/false. Even when set to true it's supposed to unmute when the game loads, but maybe it isn't for some reason. It doesnt work with some emulators. As in it wont unmute. I know kega fusion is one for sure. Worth a shot. Good luckSent from my SM-G920V using Tapatalk
