malarrya Posted April 28, 2017 Posted April 28, 2017 View File JoyToKey Profiles for Hyperspin and Rocket Launcher What's New for Version 1.1.0: ADDED 7 New Systems (80 TOTAL) + HS/RL/Default profiles. New systems include Sega Model 1, Sega System 16, Sega System 24, , Sega X Board, Sega Y Board, Pop-Cap, and Microsoft MS-DOS. Changed the ESC key functionality to buttons 7 + 8 (COIN+START). You must now press both to exit the game. Placed the ESC key location on Button 25 (a dummy location good for using combo buttons). Changed Button 5 to TAB. Changed Button 6 to P (PAUSE). Changed Button 9 to C. Changed Button 10 to V. Changed Button 11 to Z. Changed Button 12 to X. I'll see how this configuration works for me for the time being. If it's a pain or something is not quite right, I'll continue tweaking it until I find what's best. ***************** BACK UP YOUR OLD PROFILES IN CASE YOU DON'T LIKE THE CHANGES ***************** ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- I created about 75 profiles for various systems, added them to a RAR archive, and attached to this post. All you have to do is unrar and place the folders within the archive into your ..\RocketLauncher\Profiles\JoyToKey directory. For example, mine is -- C:\Hyperspin\RocketLauncher\Profiles\JoyToKey. You may need to edit the profiles so they are more to your liking or work correctly with your setup. I use the default MAME setup for everything. If you want to change one or all of them, all you have to do is edit only one CFG file, copy the CFG file to every other folder, and rename the CFG file and FOLDER to the name of the emulator you're using for the system. For example -- I use Stella for the Atari 2600. My path is then C:\Hyperspin\RocketLauncher\Profiles\JoyToKey\Atari 2600\Stella\Stella.cfg Maybe you don't use Stella for the Atari 2600 but use RetroArch. Here's how to change it: You would simply rename C:\Hyperspin\RocketLauncher\Profiles\JoyToKey\Atari 2600\Stella\Stella.cfg to C:\Hyperspin\RocketLauncher\Profiles\JoyToKey\Atari 2600\RetroArch\RetroArch.cfg. It's the same path\folder\file but the innermost folder and cfg file have simply been renamed to match the emulator being used. It's tedious to copy, paste, and rename but it doesn't take too long. I've copied these files to another machine that uses Launch Box, set up JoyToKey in Rocket Launcher via the tutorial link below, and found it working beautifully. MAME is a bit of a jerk, however. Sometimes it works straight away and sometimes you still have to map the game within the MAME TAB menu. I ONLY HAVE CONTROLLER 1 MAPPED IN THESE FILES! NOTE: There are NO games or programs within this archive. There are, however, 2 other files -- a BAT file for killing the JoyToKey process and a shortcut that gives that BAT file ADMIN privileges. Place the BAT and LNK files in your root Hyperspin directory and use the JoyToKey.exe as the startup program and JoyToKeyKill.lnk as a shutdown program in the HyperHQ UI. Using the LNK shortcut file allows for Administrator privileges with the CMD prompt window. You may need to create your own shortcut but I've included it for completeness. See the attached images. All files were created manually by me so there's no copyright issue. **** Here is a very good tutorial on how to set up JoyToKey with both Hyperspin and Rocket Launcher - READ IT CAREFULLY!: http://bit.ly/2oA2CJ4 ----------------------------------- ONLY FOR THOSE USING A MOGA PRO CONTROLLER----------------------------------- In case you have a Moga Controller, download and install the Moga Serial program: https://github.com/Zel-os/MogaSerial NOTE: I can only get it to work in Mode A on the PRO Controller but it works great! Your computer will also need BlueTooth enabled and successfully linked to the MOGA. Here is where you can get the latest vJoy USB Controller Driver (you'll need this for the MOGA Controller): http://vjoystick.sourceforge.net/site/ Submitter malarrya Submitted 04/28/2017 Category 3rd Party Apps Credits malarrya 1 1 Dungeons & Dragons - Manuals & Modules PDF Main Menu and System Themes 700 Future Pinball Wheel Images and Database 80+ JoyToKey Ready-Made Profiles Atari Jaguar CD - System Theme Terrordrome - Main Menu Theme MAME Horror Games (Genre) Database (XML) ALL Files
malarrya Posted April 18, 2018 Author Posted April 18, 2018 Updated my JoyToKey repository. Let me know your comments, questions, or concerns; especially if you like/dislike the new configuration. Thanks! What's New for Version 1.1.0: ADDED 7 New Systems (80 TOTAL) + HS/RL/Default profiles. New systems include Sega Model 1, Sega System 16, Sega System 24, , Sega X Board, Sega Y Board, Pop-Cap, and Microsoft MS-DOS. Changed the ESC key functionality to buttons 7 + 8 (COIN+START). You must now press both to exit the game. Placed the ESC key location on Button 25 (a dummy location good for using combo buttons). Changed Button 5 to TAB. Changed Button 6 to P (PAUSE). Changed Button 9 to C. Changed Button 10 to V. Changed Button 11 to Z. Changed Button 12 to X. I'll see how this configuration works for me for the time being. If it's a pain or something is not quite right, I'll continue tweaking it until I find what's best. ***************** BACK UP YOUR OLD PROFILES IN CASE YOU DON'T LIKE THE CHANGES ***************** 1 Dungeons & Dragons - Manuals & Modules PDF Main Menu and System Themes 700 Future Pinball Wheel Images and Database 80+ JoyToKey Ready-Made Profiles Atari Jaguar CD - System Theme Terrordrome - Main Menu Theme MAME Horror Games (Genre) Database (XML) ALL Files
ninja2bceen Posted July 27, 2018 Posted July 27, 2018 Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Create an account
Register a new accountSign in
Sign In Now
